path: root/arch/arm/boot
2008-04-19[ARM] 4854/1: fix the load address of uImage for CONFIG_ZBOOT_ROM=yUwe Kleine-König
U-Boot puts an image at the load address specified in the uImage header before jumping to the entry point. In the CONFIG_ZBOOT_ROM case ZBOOT_ROM_TEXT is the right load address. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Merge branch 'orion' into develRussell King
* orion: (26 commits) [ARM] Orion: implement power-off method for QNAP TS-109/209 [ARM] Orion: add support for QNAP TS-109/TS-209 [ARM] Orion: I2C support [I2C] i2c-mv64xxx: Don't set i2c_adapter.retries [I2C] Split mv643xx I2C platform support [ARM] Orion: enable CONFIG_RTC_DRV_M41T80 for D-Link DNS-323 [ARM] Orion defconfig [ARM] Orion: add support for Orion/MV88F5181 based D-Link DNS-323 [ARM] Orion: MV88F5181 support bits [ARM] Orion: Buffalo/Revogear Kurobox Pro support [ARM] OrionNAS RD board support [ARM] Orion: support for Marvell Orion-2 (88F5281) Development Board [ARM] Orion: common platform setup for Gigabit Ethernet port [ARM] Orion: platform device registration for UART, USB and NAND [ARM] Orion: system timer support [ARM] Orion edge GPIO IRQ support [ARM] Orion: IRQ support [ARM] Orion: provide GPIO method for enabling hardware assisted blinking [ARM] Orion: GPIO support [ARM] Orion: programable address map support ... Conflicts: arch/arm/Kconfig arch/arm/Makefile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] add Feroceon support to compressed/head.SNicolas Pitre
The cache replacement policy on the Feroceon core doesn't guarantee that reading through a linear chunk of memory flushes the entire cache. This is however what the default method for ARMv5TE cores does. Although the Feroceon is an ARMv5TE core, it implements the same cache handling instructions as the ARMv5TEJ cores, and must use it for proper cache flush. Signed-off-by: Nicolas Pitre <nico@marvell.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] add ARMv5TEJ aware cache flush method to compressed/head.SNicolas Pitre
The default ARMv4 method consisting of reading through some memory area isn't compatible with the cache replacement policy of some ARMv5TEJ compatible cache implementations. It is also a bit wasteful when a dedicated instruction can do the needed work optimally. It is hard to tell if all ARMv5TEJ cores will support the used CP15 instruction, but at least all those implementations Linux currently knows about (ARM926 and ARM1026) do support it. Tested on an OMAP1610 H2 target. Signed-off-by: Nicolas Pitre <nico@marvell.com> Tested-by: George G. Davis <gdavis@mvista.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4647/1: at91rm9200: Remove redundant machine-type verification and ↵Guennadi Liakhovetski
manipulation AT91RM9200 needlessly verifies machine-type numbers of supported / known platforms and overwrites it for unknown ones. Remove it. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-12-17[ARM] 4710/1: Fix coprocessor 14 usage for debug messages via ICEDCCUwe Kleine-König
According to ARM7TDMI Technical Reference Manual (ARM DDI 0210C) writing to the DCC data write register coproc dest registers are 1 and 0, not 0 and 1. ARM920T TRM (ARM DDI 0151C) agrees on that. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12[ARM] 4558/1: pxa: remove MACH_TYPE_LUBBOCK assignment and leave it to boot ↵eric miao
loader since both u-boot and blob support passing MACH_TYPE_LUBBOCK to the kernel, it should be quite safe to remove this Signed-off-by: eric miao <eric.y.miao@gmail.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22Merge branches 'at91', 'imx', 'iop', 'ixp', 'ks8695', 'misc', 'ns9xxx', ↵Russell King
'pxa' and 's3c' into devel
2007-07-22[ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORTBen Dooks
Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT to be CONFIG_S3C_LOWLEVEL_UART_PORT as we move to using plat-s3c for base of S3C operations. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] Make 'i' and 'zi' targets workRussell King
The 'i' and 'zi' targets short-circuit the dependencies for 'install' and 'zinstall' targets; these are useful for installing the kernel on platforms which have make but no compiler installed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4471/1: Compile the uncompressing code with -fno-builtinCatalin Marinas
This is to avoid a compiler warning for overriding the built-in "putc" function. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12Merge branches 'at91', 'davinci', 'imx', 'iop', 'ixp', 'ks8695', 'misc', ↵Russell King
2007-07-12[ARM] 4393/2: ARMv7: Add uncompressing code for the new CPU Id formatCatalin Marinas
The current arch/arm/boot/compressed/head.S code only supports cores to ARMv6 with the old CPU Id format. This patch adds support for the new ARMv6 with the new CPU Id and ARMv7 cores that no longer have the ARMv4 cache operations. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] riscpc: fix decompressor font file handlingRussell King
font_acorn_8x8.o was being built in drivers/video/console/ twice during a build _in the same location_ - once for the kernel proper, and once for the decompressor. The result is when you came to run an install target, the kernel was always rebuilt due to this file apparantly having been built with different compiler arguments. Solve this by making a local copy at build time in the decompressor's directory. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4407/1: Remove in-kernel mach id setting for gtwx5715 ixp4xx boardMichael-Luke Jones
If MACH_GTWX5715 is set in Kconfig, this code sets the mach id automatically. Howeber, this means that any IXP4xx kernel which is setup to support the gtwx5715 board will not successfully boot on any other board. If the bootloader sets the wrong mach id, it should be set correctly by a kernel shim. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-06-25[ARM] 4449/1: more entries in arch/arm/boot/.gitignoreNicolas Pitre
Signed-off-by: Nicolas Pitre <npitre@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-06-25[ARM] 4452/1: Force the literal pool dump before reloc_endCatalin Marinas
In the arch/arm/boot/compressed/head.S file, the contents of the literal pool accumulated during the relocatable code must be dumped before reloc_end. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-06-02[ARM] 4392/2: Do not corrupt the SP register in compressed/head.SCatalin Marinas
ARMv7 support code requires a valid stack for saving/restoring registers as the whole D-cache flushing function is more complex. This patch ensures that the SP register is not corrupted. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-06Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (82 commits) [ARM] Add comments marking in-use ptrace numbers [ARM] Move syscall saving out of the way of utrace [ARM] 4360/1: S3C24XX: regs-udc.h remove unused macro [ARM] 4358/1: S3C24XX: mach-qt2410.c: remove linux/mmc/protocol.h header [ARM] mm 10: allow memory type to be specified with ioremap [ARM] mm 9: add additional device memory types [ARM] mm 8: define mem_types table L1 bit 4 to be for ARMv6 [ARM] iop: add missing parens in macro [ARM] mm 7: remove duplicated __ioremap() prototypes ARM: OMAP: fix OMAP1 mpuio suspend/resume oops ARM: OMAP: MPUIO wake updates ARM: OMAP: speed up gpio irq handling ARM: OMAP: plat-omap changes for 2430 SDP ARM: OMAP: gpio object shrinkage, cleanup ARM: OMAP: /sys/kernel/debug/omap_gpio ARM: OMAP: Implement workaround for GPIO wakeup bug in OMAP2420 silicon ARM: OMAP: Enable 24xx GPIO autoidling [ARM] 4318/2: DSM-G600 Board Support [ARM] 4227/1: minor head.S fixups [ARM] 4328/1: Move i.MX UART regs to driver ...
2007-05-02[PATCH] x86: deflate stack usage in lib/inflate.cJeremy Fitzhardinge
inflate_fixed and huft_build together use around 2.7k of stack. When using 4k stacks, I saw stack overflows from interrupts arriving while unpacking the root initrd: do_IRQ: stack overflow: 384 [<c0106b64>] show_trace_log_lvl+0x1a/0x30 [<c01075e6>] show_trace+0x12/0x14 [<c010763f>] dump_stack+0x16/0x18 [<c0107ca4>] do_IRQ+0x6d/0xd9 [<c010202b>] xen_evtchn_do_upcall+0x6e/0xa2 [<c0106781>] xen_hypervisor_callback+0x25/0x2c [<c010116c>] xen_restore_fl+0x27/0x29 [<c0330f63>] _spin_unlock_irqrestore+0x4a/0x50 [<c0117aab>] change_page_attr+0x577/0x584 [<c0117b45>] kernel_map_pages+0x8d/0xb4 [<c016a314>] cache_alloc_refill+0x53f/0x632 [<c016a6c2>] __kmalloc+0xc1/0x10d [<c0463d34>] malloc+0x10/0x12 [<c04641c1>] huft_build+0x2a7/0x5fa [<c04645a5>] inflate_fixed+0x91/0x136 [<c04657e2>] unpack_to_rootfs+0x5f2/0x8c1 [<c0465acf>] populate_rootfs+0x1e/0xe4 (This was under Xen, but there's no reason it couldn't happen on bare hardware.) This patch mallocs the local variables, thereby reducing the stack usage to sane levels. Also, up the heap size for the kernel decompressor to deal with the extra allocation. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Tim Yamin <plasmaroo@gentoo.org> Cc: Andi Kleen <ak@suse.de> Cc: Matt Mackall <mpm@selenic.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com>
2007-04-21[ARM] 4300/1: Add picotux 200 ARM boardSimon Richter
Add the picotux 200 ARM board: - Enable its machine type in the filter in head.S - Add configuration option - Add board initialisation - Add default configuration Signed-off-by: Simon Richter <Simon.Richter@kleinhenz.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4216/1: add .gitignore entries for ARM specific filesNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-30[ARM] 3809/3: get rid of 4 megabyte kernel image size limitLennert Buytenhek
We currently have a hardcoded 4 megabyte uncompressed kernel image size limit, which is easily exceeded by, for example, enabling some of the various kernel debugging options. When setting up the initial page tables (which is where this 4M limit is hardcoded), it's actually relatively easy to find out the true size of the uncompressed kernel image and create enough page table entries for things to fit, so this patch makes it so. In the decompressor, we also need to know the size of the uncompressed kernel image, to figure out whether there is any chance that uncompressing the kernel might overwrite the compressed kernel image stored elsewhere in memory. We don't have that info at this boot stage, though, so we approximate the size of the uncompressed kernel by taking the compressed kernel image size and allowing for a maximum 4x expansion. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: manage the CP15 thingsHyok S. Choi
All the current CP15 access codes in ARM arch can be categorized and conditioned by the defines as follows: Related operation Safe condition a. any CP15 access !CPU_CP15 b. alignment trap CPU_CP15_MMU c. D-cache(C-bit) CPU_CP15 d. I-cache CPU_CP15 && !( CPU_ARM610 || CPU_ARM710 || CPU_ARM720 || CPU_ARM740 || CPU_XSCALE || CPU_XSC3 ) e. alternate vector CPU_CP15 && !CPU_ARM740 f. TTB CPU_CP15_MMU g. Domain CPU_CP15_MMU h. FSR/FAR CPU_CP15_MMU For example, alternate vector is supported if and only if "CPU_CP15 && !CPU_ARM740" is satisfied. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3838/1: ARM: DCC debug console support for ARM11Tony Lindgren
Adds support for CONFIG_DEBUG_ICEDCC for ARM11. Tested on ARM1136 (OMAP2420). Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3828/1: iop3xx: remove useless loadsp macroLennert Buytenhek
The iop33x loadsp hunk in arch/arm/boot/compressed/head.S serves no purpose -- remove it. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3816/1: iop3xx: rename config symbolsLennert Buytenhek
Rename CONFIG_ARCH_IOP321 to CONFIG_ARCH_IOP32X and CONFIG_ARCH_IOP331 to CONFIG_ARCH_IOP33X. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
2006-07-01[ARM] 3541/2: workaround for PXA27x erratum E7Nicolas Pitre
Patch from Nicolas Pitre According to the Intel PXA27x Processor Family Specification Update document (doc.nr. 280071-009) erratum E7, some care must be taken to locate the disabling and re-enabling of the MMU to the beginning of a cache line to avoid problems in some circumstances. Credits to Simon Vogl <simon.vogl@researchstudios.at> for bringing this up. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26[ARM] 3654/1: add ajeco 1arm sbc supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Ajeco 1ARM Single Board Computer, a VME form factor SBC based on the Atmel AT91 SoC, with 64M RAM, seven serial ports, three ethernet ports, IDE, CF, USB host and device, and S-Video/VGA out.-- Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove LOADREGS macroRussell King
As for RETINSTR, LOADREGS is a left-over from the 26-bit days. Remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-20[ARM] 3604/1: AT91RM9200 New boardsAndrew Victor
Patch from Andrew Victor This patch adds support for an additional 4 AT91RM9200-based boards: 1. Conitec ARM&EVA [MACH_CARMEVA] (http://www.conitec.net/english/linuxboard.htm) 2. KwikByte KB920x [MACH_KB9200] (http://kwikbyte.com/KB9202_description_new.htm) 3. Embest ATEB9200 [MACH_ATEB9200] (http://www.embedinfo.com/english/product/ATEB9200.asp) 4. Sperry-Sun KAFA board [MACH_KAFA] (unknown) Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3548/1: Fix the ARMv6 CPU id in compressed/head.SCatalin Marinas
Patch from Catalin Marinas This code was still using the old format for the ARMv6 CPU id and it wasn't flushing the caches on the MPCore CPU (and other ARM1176 cores). The patch changes the mask bits to cope with the new id format. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-02[ARM] 3488/1: make icedcc_putc do the right thingUwe Zeisberger
Patch from Uwe Zeisberger a) use coprocessor 14 b) make reading the dcc status volatile Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-09[ARM] Allow decompressor to be built with -ffunction-sectionsRussell King
Arrange for all the text ends up in the right place when -ffunction-sections is used. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-28Merge nommu treeRussell King
2006-03-28[ARM] Move ice-dcc code into misc.cRussell King
2006-03-28[ARM] Fix decompressor serial IO to give CRLF not LFCRRussell King
As per the corresponding change to the serial drivers, arrange for ARM decompressors to give CRLF. Move the common putstr code into misc.c such that machines only need to supply "putc" and "flush" functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-27[ARM] nommu: MPU support in boot/compressed/head.SHyok S. Choi
This patch adds MPU support in boot/compressed/head.S. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-25Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3030/2: fix permission check in the obscur cmpxchg syscall [ARM] nommu: rename compressed/head.S symbols to a new style [ARM] select TLS_REG_EMUL and NEEDS_SYSCALL_FOR_CMPXCHG [ARM] nommu: Move hardware page table definitions to pgtable-hwdef.h [ARM] Move read of processor ID out of lookup_processor_type() [ARM] Fix typo in tlbflush.h [ARM] noMMU: removes TLB codes in nommu mode [ARM] noMMU: block sys_fork in nommu mode [ARM] 3399/1: Fix link problem when CONFIG_PRINTK is disabled [ARM] 3398/1: Fix the VFP registers loading/storing base address [ARM] 3397/1: AT91RM9200 Header update [ARM] 3385/1: Battery support for sharp zaurus sl-5500 (collie) [ARM] SMP: don't set cpu_*_map in smp_prepare_boot_cpu include/linux/clk.h is betraying its ARM origins [ARM] Move enable_irq and disable_irq to assembler.h [ARM] 3391/1: use PLAT8250_DEV_PLATFORM{,1} for platform device id instead of 0/1
2006-03-24[ARM] nommu: rename compressed/head.S symbols to a new styleHyok S. Choi
This patch renames symbols to a new style to prepare mpu support code merging. e.g. __armv4_cache_on --> __armv4_mmu_cache_on Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-06kbuild: change kbuild to not rely on incorrect GNU make behaviorPaul Smith
The kbuild system takes advantage of an incorrect behavior in GNU make. Once this behavior is fixed, all files in the kernel rebuild every time, even if nothing has changed. This patch ensures kbuild works with both the incorrect and correct behaviors of GNU make. For more details on the incorrect behavior, see: http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html Changes in this patch: - Keep all targets that are to be marked .PHONY in a variable, PHONY. - Add .PHONY: $(PHONY) to mark them properly. - Remove any $(PHONY) files from the $? list when determining whether targets are up-to-date or not. Signed-off-by: Paul Smith <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-18[ARM] 3272/1: fix kernel decompressor crashNicolas Pitre
Patch from Nicolas Pitre Commit f4619025a51747a3788fd1bb6bdc46e368a889a7 broke the kernel decompressor (at least on PXA). Here's the fix. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-12[ARM] Allow r2 to be passed through the decompressor to the kernelRussell King
This is part of a patch from Marc Singer to allow r2 to be passed to the kernel. Marc's original comments follow: This revised R2 (atags pointer) patch incorporates comments from Nico Pitre and Ben Dooks. It modifies the head.S files such that the R2 value set by the bootloader is conveyed to the kernel startup code. The kernel head.S heuristically validates the pointer. It will set R2 to zero if it believes the pointer is invalid. Presently, it requires that the ATAGS list reside in the first 16KiB of physical RAM. Relaxing this contraint may be both desirable as well as tricky. Signed-off-by: Marc Singer <elf@buici.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-09[ARM] 3240/2: AT91RM9200 support for 2.6 (Core)SAN People
Patch from SAN People Following changes were made to clock.c: 1) Replaced <asm/hardware/clock.h> with <linux/clk.h> 2) Removed old unused clk_enable & clk_disable. 3) Replaced clk_use/clk_unuse with clk_enable/clk_disable. Otherwise it's the same as the previous patch. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[ARM] Remove EPXA10DB machine supportRussell King
EPXA10DB seems to be uncared for: - the "PLD" code has never been merged - no one has reported that this platform has been broken since at least 2.6.10 - interest seems to have dried up around March 2003. Therefore, remove EPXA10DB support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
