path: root/arch/arm/boot
2016-11-29arm: dts: imx7: specify keypad port clocktoradex_imx_4.1.15_1.0.0_ga-nextStefan Agner
To access the keypad port registers the IPG clocks need to be on, specify the clock accordingly. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-10arm: dts: imx7: decrease DMA CMA to 128MBStefan Agner
Currently DMA CMA is set to 320MB which is rather large and cannot be allocated on Colibri iMX7S. Lower the reserved amount to 128MB which should be enouth for most use cases and works with systems which have only 256MiB memory available. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-09ARM: dts: imx7-colibri: Fix use of pull-up by SODIMM 45Sanchayan Maity
The iMX7 wakeup pin currently has a 47k pullup configured. Thus one has to pull the pin to 0V to generate the wakeup event. All other Colibri modules use pull downs and require 3.3V to generate an event. Also on the Colibri Evaluation Board an external 100kOhm pulldown is connected, thus the pin is neither at 0V nor 3.3V but at 2.2V potentially increasing power consumption. Change logic to use pulldown and require 3.3V to generate wakeup event. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-24arm: dts: imx7: fix CAN interrupt sourceMax Krummenacher
The SPI CAN controller MCP2515 was set up to use the wrong interrupt source. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29arm: dts: imx7: mux pad of SODIMM 169 as GPIOStefan Agner
The pad SAI1_RX_DATA can be used as second chip select for dual-die NAND. However, with an assembly option the pad is available as GPIO on SODIMM 169. All current version of Colibri iMX7 modules have the pad available as GPIO hence mux it as GPIO by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29arm: dts: imx7: assign CAN interrupt pin explicitlyStefan Agner
The SPI CAN controller MCP2515 uses a dedicated interrupt line. Assign the interrupt line to the CAN controller node explicitly. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29arm: dts: imx7: revisit some pinmux configurationsStefan Agner
Revisit default pinmux configuration, use pull-ups instead of pull-downs where there is already an external pull-up by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29arm: dts: imx7: move standard pinctrl to module level dtStefan Agner
We traditionally have all standard pinctrl in the module level device tree. Move pinctrl accordingly. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29arm: dts: imx7: disable pull-up on multiplexed pinsStefan Agner
The PWM<A> and PWM<D> have multiplexed pins which by default have a pull-up enabled. Take them into the same pinmux group as the PWM pin and disable pull-ups. This also makes sure that there is no conflicting usage of the same pin... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7d/imx7s-colibri: Enable usb device/host switch using extconSanchayan Maity
Use USBC_DET feature of standard Colibri SODIMM pin 137 for USB device/host switching using the generic extcon USB gpio implementation. Signed-off-by: Sanchayan Maity <sanchayan.maity@toradex.com> [remove pin from FEC and fixed pinmux assignment] Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29ARM: dts: imx7-colibri: use VGA resolution by defaultStefan Agner
Use VGA (640x480) timings by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: disable internal RTC on i.MX 7SoloStefan Agner
Disable internal RTC on i.MX 7Solo since writing to it is currently not possible. This leads to freezes/lockups especially on carrier boards which do not come with an external RTC (where the system tries to use the internal RTC automatically). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29arm: dts: imx7: Add support for PWM polarity controlBhuvanchandra DV
Update #pwm-cells to 3 in order to support PWM signal polarity control. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29arm: dts: imx7-colibri: Use enable-gpios for BL_ONBhuvanchandra DV
Use pwm-backlight driver 'enable-gpios' property for backlight on/off control. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29ARM: dts: imx7-colibri: add ENET sleep stateStefan Agner
Add sleep state for FEC pins to avoid pull-ups feeding the Ethernet PMIC while the Ethernet rail is turned off. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: add GPIO wakeup keyStefan Agner
Add wakeup GPIO key which is able to wake the system from sleep modes (e.g. Suspend-to-Memory). Also rename the intermediate node to imx7d-colibri. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: explicitly disable write-protectStefan Agner
Use the disable-wp property since we don't have a concept of write protect. This also gets rid of the following warning: mmc0: host does not support reading read-only switch, assuming write-enable Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: rename display nodeStefan Agner
Rename display node to avoid node name duplication: device-tree: Duplicate name in lcdif@30730000, renamed to "display#1" Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: make use of the native-mode propertyStefan Agner
We can store multiple modes now and select the mode used by the driver by default using the native-mode property. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: add VBUS regulator also to OTG portStefan Agner
On some carrier boards (namely Aster, Viola and Orchid) the second USB port (USBC) is used in host only mode. In this case, the USBH_PEN signal is also used to enable USB power. This change makes sure that USBH_PEN is also set in case only one USB port is available (as it is the case on Colibri iMX7 Solo). Strictly speaking we should not add the regulator in the Evaluation Board device tree. However, we use the Evaluation Board device tree as our "Colibri Standard" device tree and it does not really hurt on the Evaluation Board... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: select MCLK in SGTL5000 nodeStefan Agner
The SGTL5000 requires a MCLK frequency in the range of 8 to 27MHz to work properly. Make sure the clocking requirements are met by setting the clock within the codecs node. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29ARM: dts: imx7-colibri: add MCLK pinmux to codecStefan Agner
The SAI1 MCLK pad is connected to the Codecs MCLK and essential for the codec to function. This allows to probe the Codec before the DAI which happens to happen by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-07-18Merge remote-tracking branch 'nxp/imx_4.1.15_1.0.0_ga' into ↵Stefan Agner
2016-06-30MLK-12948 ARM: dts: imx7d-sdb: change the hardware reset gpio for mipi dsirel_imx_4.1.15_1.2.0_gaFancy Fang
Change the hardware reset gpio to 'GPIO6_IO15' for mipi dsi to allow fec2 and mipi dsi can run at the same time. This needs some hardware rework as follows: " 1. Replace R631 with 100K resistor; 2. Remove D14, D24; 3. Solder the Cathode of the diode to R471, you can use BAT54HT1(ONSEMI) or NSR0320MW2T1G(ONSEMI); 4. Solder the wire to the Anode end of the diode; 5. Scrape the solder mask(Green oil) of the MIPI Reset via, then solder the end of the wire to the via. " Signed-off-by: Fancy Fang <chen.fang@nxp.com> (cherry picked from commit 0af28564e73f006f742a9af0db4bc5b8588e3490)
2016-06-28ARM: dts: imx7-colibri: add TouchRevolution multitouch controllerStefan Agner
Add TouchRevolution multitouch controller driver which is connectable over I2C bus. The driver supports the 7" and 10" multitouch variant available from TouchRev. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-28ARM: dts: imx7-colibri: Add MCP2515 SPI CAN controller to DTMax Krummenacher
MCP2515 is available on colibri evaluation board, include it in the device tree for Colibri iMX7. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-28ARM: dts: imx7-colibri: reduce SPI clock to datasheet maximumMax Krummenacher
According to the datasheet the SPI clock (for read) must not exceed 1 / 43ns for i.MX7. Reflect that correctly in the device tree. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-24ARM: dts: imx7-colibri: use Toradex evalspiStefan Agner
Use the newly invented device evalspi. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-24ARM: dts: imx7-colibri: cleanup indent and use GPIO flag defineStefan Agner
2016-06-24ARM: dts: imx7-colibri: fix SD-cardStefan Agner
The SDHC stack uses the GPIO flags to determine whether the card detect gpio is active-low or high. Zero means GPIO_ACTIVE_HIGH, which is actually wrong. Specify the card detect to be active-low. Also remove the tunning step property, this is a board specific parameter which seems to come from Sabre, where NXP actually deleted it too. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24MLK-12685 ARM: dts: imx6sx-sabreauto.dts: improve usdhc4 pad drive strengthHaibo Chen
For imx6sx-sabreauto board, the usdhc4 is used for the sd slot locate on the base board, so need to improve the pad drive strength, otherwise we will meet many CRC error or timeout error when insert a sd card. Signed-off-by: Haibo Chen <haibo.chen@nxp.com> (cherry picked from commit 1cbfce01e4e076d7f7e3b879c2c41d217d8afa48)
2016-06-24MLK-12675 ARM: dts: imx: keep RTC enabled for software poweroffAnson Huang
SRTC needs to be kept enabled during system poweroff, SNVS_LP control register bit 0 SRTC_ENV must be set to enable RTC, for software poweroff, kernel just read the register offset and value from dtb and write to SNVS_LP control register to poweroff system, need to make sure bit 0 SRTC_ENV is set to enable RTC during system poweroff. Previous setting did NOT enable it which will cause RTC stop running if using software poweroff. Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
2016-06-24MLK-12623-02 ARM: dts: imx: Add 700MHz setpoint define in dtsBai Ping
According to the latest datasheet(Rev. 0, 12/2015), When the chip is run at LDO enabled mode, the highest setpoint can be set to 700MHz in overdrive mode. Signed-off-by: Bai Ping <ping.bai@nxp.com> (cherry picked from commit 9838ff4b9dfaaacdea01b2bf5f54020ccf991f23)
2016-06-24ARM: dts: imx7-colibri: introduce carrier board level dtsStefan Agner
Split up the colibri device tree into two device tree files for COM and Carrier Board. Use the usual SoC/COM/Board tripplet and follow including scheme used for Vybrid. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24ARM: dts: imx7-colibri: make use of per SoC base device treeStefan Agner
Now that we have a base device tree per SoC we can make use of them by including only imx7s.dtsi for the Colibri iMX7S modules. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24dts: imx7d: create imx7s.dtsi which is the base device treeStefan Agner
The i.MX 7Solo supports a subset of the features which i.MX 7Dual does, hence make imx7s.dtsi to be the base device tree. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24ARM: dts: imx7s-colibri: disable second CPUStefan Agner
The i.MX 7Solo device tree currently builds on the i.MX 7Dual device tree, which specifies two CPU's. This leads to a delay during boot and the following error message: CPU1: failed to come online Unfortunately the CPU driver code seems not to honor the status property, but we can "disable" the second CPU node by clearing the device_type property. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24ARM: dts: imx7d-colibri: Work around poweroff issueStefan Agner
The AD7879 interrupt GPIO is a wakeup pin. On poweroff, the external pull-up is not holding the GPIO high, hence causing a falling edge on the pad. Since the GPIO is a wakeup pin, this causes the SNVS Dumb PMIC to switch to on again (hence causing a reboot instead of a power- off). Make sure the interrupt line stays high during poweroff by configuring a pull-up on the IOMUXC LPSR GPR. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24pinctrl: pinctrl-imx: add support for LPSR GPR padctrlStefan Agner
The LPSR IOMUXC also has a general purpose (GPR) part which is able to define pad settings for GPIO8-15. Implement it as yet another pinctrl driver. Note: 4 GPIO's share one register, the values are currently over- written, hence the current code only allows one GPIO per register to be configured... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24ARM: dts: imx7d-colibri: disable power keyStefan Agner
Disable SNVS power key functionality by default for Colibri i.MX 7 modules. The SNVS power key uses the ONOFF signal, which is directly controlled by reset and therefor not really a power key available to the user. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24imx7d-colibri.dts: fix double declared UART1 DSR/RI pinmuxingMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-24imx7d-colibri.dts: add PMIC / TOUCH interrupt gpioMax Krummenacher
2016-06-24imx7d-colibri.dts: implement mmc card detectMax Krummenacher
2016-06-24ARM: dts: imx7s-colibri: add working dts for soloMax Krummenacher
2016-06-24ARM: dts: imx7d-colibri: use external Ethernet PHY clockMax Krummenacher
Add workaround for M4 NMI issue. Set the Ethernet PHY reference clock to be generated externaly from the i.MX 7 by default (Colibri i.MX 7 V1.1 sample batch) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-24ARM: dts: imx7d-colibri: add AD7879 device tree nodeStefan Agner
Add device tree node for resistive touch screen controller AD7879. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24ARM: dts: imx7d-colibri: add Cortex-M4 related nodesStefan Agner
Add TCM and OCRAM specifications required by the PM code, otherwise booting Linux will fail in imx7d_pm_init. Also add mcctest, mcctty and rpmsg nodes required to enable rpmsg based communciation examples between the two cores. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-24ARM: dts: imx7d-colibri: add initial device treeMax Krummenacher
2016-06-24arm: imx7d-pinfunc: add daisychain setting for UART2_DTE_RXMax Krummenacher
MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX was missing the daisychain register address and value resulting in a non working RX path. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-22MLK-12944 fix makefile miss imx7d-12x12-lpddr3-arm2-pcie.dtbFrank Li
Added imx7d-12x12-lpddr3-arm2-pcie.dtb to makefile Signed-off-by: Frank Li <Frank.Li@nxp.com>
