path: root/arch/arm/common
2008-10-30[ARM] sharpsl_pm: fix compilation w/o CONFIG_PMDmitry Baryshkov
Fix compilation of sharpsl_pm when CONFIG_PM in unselected. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-21[ARM] 5315/1: Fix section mismatch warning (sa1111)Kristoffer Ericson
This patch fixes the section mismatch warning from sa1111.o at buildtime. CC arch/arm/common/sa1111.o LD arch/arm/common/built-in.o LD vmlinux.o MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x87f4): Section mismatch in reference from the function sa1111_probe() to the function .devinit.text:sa1110_mb_enable() The function sa1111_probe() references the function __devinit sa1110_mb_enable(). This is often because sa1111_probe lacks a __devinit annotation or the annotation of sa1110_mb_enable is wrong. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-17[ARM] dmabounce requires ZONE_DMARussell King
Rather than having everything that needs DMABOUNCE also select ZONE_DMA, arrange for DMABOUNCE to select it instead. This is far more sensible. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-17[ARM] pxa: fix 3bca103a1e658d23737d20e1989139d9ca8973bfRussell King
arch/arm/common/sa1111.c:593: error: implicit declaration of function 'dmabounce_register_dev' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09[ARM] 5295/1: make ZONE_DMA optionalNicolas Pitre
Most ARM machines don't need a special "DMA" memory zone, and when configured out, the kernel becomes a bit smaller: | text data bss dec hex filename |3826182 102384 111700 4040266 3da64a vmlinux |3823593 101616 111700 4036909 3d992d vmlinux.nodmazone This is because the system now has only one zone total which effect is to optimize away many conditionals in page allocation paths. So let's configure this zone only on machines that need split zones. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-03[ARM] 4733/1: export sharpsl_paramDmitry Baryshkov
EXPORT sharpsl_param which is necessary to support modular build of some depending drivers. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-29[ARM] dma: add validation of DMA paramsRussell King
Validate the direction argument like x86 does. In addition, validate the dma_unmap_* parameters against those passed to dma_map_* when using the DMA bounce code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-29[ARM] dma: coding style cleanupsRussell King
2008-09-29[ARM] dma: fix dmabounce dma_sync_xxx() implementationsRussell King
The dmabounce dma_sync_xxx() implementation have been broken for quite some time; they all copy data between the DMA buffer and the CPU visible buffer no irrespective of the change of ownership. (IOW, a DMA_FROM_DEVICE mapping copies data from the DMA buffer to the CPU buffer during a call to dma_sync_single_for_device().) Fix it by getting rid of sync_single(), moving the contents into the recently created dmabounce_sync_for_xxx() functions and adjusting appropriately. This also makes it possible to properly support the DMA range sync functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-29[ARM] dma: use new dmabounce_sync_for_xxx() for dma_sync_single_xxx()Russell King
2008-09-29[ARM] dma: Reduce to one dma_sync_sg_* implementationRussell King
2008-09-25[ARM] dma: Reduce to one dma_map_sg()/dma_unmap_sg() implementationRussell King
No point having two of these; dma_map_page() can do all the work for us. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-25[ARM] dma: provide a better dma_map_page() implementationRussell King
We can translate a struct page directly to a DMA address using page_to_dma(). No need to use page_address() followed by virt_to_dma(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-25[ARM] Update dma_map_sg()/dma_unmap_sg() APIRussell King
Update the ARM DMA scatter gather APIs for the scatterlist changes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-10[ARM] dma-mapping: provide sync_range APIsRussell King
Convert the existing dma_sync_single_for_* APIs to the new range based APIs, and make the dma_sync_single_for_* API a superset of it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-10[ARM] dma-mapping: improve type-safeness of DMA translationsRussell King
OMAP at least gets the return type(s) for the DMA translation functions wrong, which can lead to subtle errors. Avoid this by moving the DMA translation functions to asm/dma-mapping.h, and converting them to inline functions. Fix the OMAP DMA translation macros to use the correct argument and result types. Also, remove the unnecessary casts in dmabounce.c. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-23Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (85 commits) [ARM] pxa: add base support for PXA930 Handheld Platform (aka SAAR) [ARM] pxa: add base support for PXA930 Evaluation Board (aka TavorEVB) [ARM] pxa: add base support for PXA930 (aka Tavor-P) [ARM] Update mach-types [ARM] pxa: make littleton to use the new smc91x platform data [ARM] pxa: make zylonite to use the new smc91x platform data [ARM] pxa: make mainstone to use the new smc91x platform data [ARM] pxa: make lubbock to use new smc91x platform data [NET] smc91x: prepare SMC_USE_PXA_DMA to be specified in platform data [NET] smc91x: prepare for SMC_IO_SHIFT to be a platform configurable variable [NET] smc91x: add SMC91X_NOWAIT flag to platform data [NET] smc91x: favor the use of SMC91X_USE_* instead of SMC_CAN_USE_* [NET] smc91x: remove "irq_flags" from "struct smc91x_platdata" [ARM] 5146/1: pxa2xx: convert all boards to call pxa2xx_transceiver_mode helper Support for LCD on e740 e750 e400 and e800 e-series PDAs E-series UDC support PXA UDC - allow use of inverted GPIO for pullup Add e350 support Fix broken e-series build E-series GPIO / IRQ definitions. ...
2008-07-21arm: bus_id -> dev_name() and dev_set_name() conversionsKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21driver core: fix a lot of printk usages of bus_idGreg Kroah-Hartman
We have the dev_printk() variants for this kind of thing, use them instead of directly trying to access the bus_id field of struct device. This is done in order to remove bus_id entirely. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-14[ARM] Merge most of the PXA work for initial mergeRussell King
This includes PXA work up to the SPI changes for the initial merge, since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI tree being merged. Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-13Merge branch 'pxa' into develRussell King
2008-07-10Merge branches 'at91', 'dyntick', 'ep93xx', 'iop', 'ixp', 'misc', 'orion', ↵Russell King
'omap-reviewed', 'rpc', 'rtc' and 's3c' into devel
2008-07-10Clocklib: Fix SA1111 clock name mess.Ian Molton
This patch uses the ability of PXA's clocklib to alias clock to resolve the problem caused by sharing the SA1111 IO controller between PXA and SA1100 architectures, which have differing GPIO numbering. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-06-22[ARM] Export dma_sync_sg_for_device()Russell King
Noticed by Martin Michlmayr, this missing export prevents IEEE1394 from building with: ERROR: "dma_sync_sg_for_device" [drivers/ieee1394/ieee1394.ko] undefined! Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: separate out power manager and clock registersRussell King
The power manager and core clock registers aren't present in PXA3 CPUs. Move them out of pxa-regs.h into pxa2xx-regs.h, and include pxa2xx-regs.h where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[RTC] remove old ARM rtc library codeRussell King
Now that all drivers using it are gone, remove the old ARM RTC library. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-19[ARM] pxa: corgibl_limit_intensity build errorsRussell King
If CONFIG_BACKLIGHT_CORGI is not selected, then corgibl_limit_intensity() is not present. However, both corgi_pm.c and sharp_pm.c reference this symbol, resulting in a link error. Wrap the references with the relevant ifdefs, and avoid the resulting NULL pointer dereference by making the code in sharpsl_pm.c also conditional on the config symbol. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-17[ARM] 5026/1: locomo: add .settype for gpio and several small fixesThomas Kunze
irqs.h: * rename IRQ_LOCOMO_SPI_OVRN to IRQ_LOCOMO_SPI_REND locomo.h: * add some definition for locomo spi controller * correct some errors locomo.c: * correct some errors * add set_type for locomo gpio irq chip Signed-off-by: Thomas Kunze <thommycheck@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-19Merge branch 'omap2-upstream' into develRussell King
2008-04-18arch: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-10[ARM] 4962/1: Introduce standard gpio interface for Scoop2.Dmitry Baryshkov
This deprecates old set/reset_scoop_gpio interfacein favour of support for generic gpio interface. It requires gpiolib, so it depends on the previous patch (gpiolib for SA-1100). Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-10[ARM] 4957/1: Drop special macro SCOOP_REG in favour if ioread16/iowrite16.Dmitry Baryshkov
Make scoop driver use generic purpose io routines: ioread16 and iowrite16 instead of direct writing to memory. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-10[ARM] 4956/1: Scoop: sparse cleanupDmitry Baryshkov
Cleanup most errors errors reported by sparse: declare IO space as __iomem, use %p for address printing make functions static Use __devinit instead of __init for scoop_init Make scoop_remove __devexit and use __devexit_p for referencing it. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-28[ARM] 4873/1: Fix ITE 8152 interrupt demuxMike Rapoport
This patch fixes misprints in ITE 8152 interrupt demuxing Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] xtime_seqlock: fix more ARM machines for xtime deadlockingPeter Zijlstra
move update_process_times() out from under xtime_lock. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] remove duplicate includesLucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-12-08Merge branch 'pxa-fixes'Russell King
2007-12-08[ARM] 4667/1: CM-X270 fixesMike Rapoport
Change printk to dev_dbg in ITE 8152 driver and remove printk in ITE 8152 ISR. Move PCI intialization from ->scan to ->preinit method Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-26[ARM] uengine: fix memset size errorLi Zefan
The size passing to memset is wrong. And here we can replace kmalloc with kzalloc. Signed-off-by Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-23arm: build fixFUJITA Tomonori
arch/arm/common/dmabounce.c: In function 'dma_map_sg': arch/arm/common/dmabounce.c:445: error: implicit declaration of function 'sg_page' Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
