[ Upstream commit ca70ea43f80c98582f5ffbbd1e6f4da2742da0c4 ]
MCPM does a soft reset of the CPUs and uses common cpu_resume() routine to
perform low-level platform initialization. This results in a try to install
HYP stubs for the second time for each CPU and results in false HYP/SVC
mode mismatch detection. The HYP stubs are already installed at the
beginning of the kernel initialization on the boot CPU (head.S) or in the
secondary_startup() for other CPUs. To fix this issue MCPM code should use
a cpu_resume() routine without HYP stubs installation.
This change fixes HYP/SVC mode mismatch on Samsung Exynos5422-based Odroid
XU3/XU4/HC1 boards.
Fixes: 3721924c8154 ("ARM: 8081/1: MCPM: provide infrastructure to allow for MCPM loopback")
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Anand Moon <linux.amoon@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 06dfe5cc0cc684e735cb0232fdb756d30780b05d upstream.
SA1111 PCMCIA was broken when PCMCIA switched to using dev_pm_ops for
the PCMCIA socket class. PCMCIA used to handle suspend/resume via the
socket hosting device, which happened at normal device suspend/resume
time.
However, the referenced commit changed this: much of the resume now
happens much earlier, in the noirq resume handler of dev_pm_ops.
However, on SA1111, the PCMCIA device is not accessible as the SA1111
has not been resumed at _noirq time. It's slightly worse than that,
because the SA1111 has already been put to sleep at _noirq time, so
suspend doesn't work properly.
Fix this by converting the core SA1111 code to use dev_pm_ops as well,
and performing its own suspend/resume at noirq time.
This fixes these errors in the kernel log:
pcmcia_socket pcmcia_socket0: time out after reset
pcmcia_socket pcmcia_socket1: time out after reset
and the resulting lack of PCMCIA cards after a S2RAM cycle.
Fixes: d7646f7632549 ("pcmcia: use dev_pm_ops for class pcmcia_socket_class")
commit 5070fb14a0154f075c8b418e5bc58a620ae85a45 upstream.
When trying to set the ICST 307 clock to 25174000 Hz I ran into
this arithmetic error: the icst_hz_to_vco() correctly figure out
DIVIDE=2, RDW=100 and VDW=99 yielding a frequency of
25174000 Hz out of the VCO. (I replicated the icst_hz() function
in a spreadsheet to verify this.)
However, when I called icst_hz() on these VCO settings it would
instead return 4122709 Hz. This causes an error in the common
clock driver for ICST as the common clock framework will call
.round_rate() on the clock which will utilize icst_hz_to_vco()
followed by icst_hz() suggesting the erroneous frequency, and
then the clock gets set to this.
The error did not manifest in the old clock framework since
this high frequency was only used by the CLCD, which calls
clk_set_rate() without first calling clk_round_rate() and since
the old clock framework would not call clk_round_rate() before
setting the frequency, the correct values propagated into
the VCO.
After some experimenting I figured out that it was due to a simple
arithmetic overflow: the divisor for 24Mhz reference frequency
as reference becomes 24000000*2*(99+8)=0x132212400 and the "1"
in bit 32 overflows and is lost.
But introducing an explicit 64-by-32 bit do_div() and casting
the divisor into (u64) we get the right frequency back, and the
right frequency gets set.
Tested on the ARM Versatile.
Cc: linux-clk@vger.kernel.org
Cc: Pawel Moll <pawel.moll@arm.com>
commit e972c37459c813190461dabfeaac228e00aae259 upstream.
Since the dawn of time the ICST code has only supported divide
by one or hang in an eternal loop. Luckily we were always dividing
by one because the reference frequency for the systems using
the ICSTs is 24MHz and the [min,max] values for the PLL input
if [10,320] MHz for ICST307 and [6,200] for ICST525, so the loop
will always terminate immediately without assigning any divisor
for the reference frequency.
But for the code to make sense, let's insert the missing i++
Reported-by: David Binderman <dcb314@hotmail.com>
Pull dmaengine updates from Vinod Koul:
"This time we have a very typical update which is mostly fixes and
updates to drivers and no new drivers.
- the biggest change is coming from Peter for edma cleanup which even
caused some last minute regression, things seem settled now
- idma64 and dw updates
- iotdma updates
- module autoload fixes for various drivers
- scatter gather support for hdmac"
* tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits)
dmaengine: edma: Add dummy driver skeleton for edma3-tptc
Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3"
Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3"
dmaengine: dw: some Intel devices has no memcpy support
dmaengine: dw: platform: provide platform data for Intel
dmaengine: dw: don't override platform data with autocfg
dmaengine: hdmac: Add scatter-gathered memset support
dmaengine: hdmac: factorise memset descriptor allocation
dmaengine: virt-dma: Fix kernel-doc annotations
dmaengine: edma: New device tree binding
dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP
dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx
dmaengine: edma: Merge the of parsing functions
dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot
dmaengine: edma: Refactor the dma device and channel struct initialization
dmaengine: edma: Get qDMA channel information from HW also
dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq
dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_)
Move the code out from arch/arm/common and merge it inside of the dmaengine
driver.
This change is done with as minimal (if eny) functional change to the code
as possible to avoid introducing regression.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Since the driver stack no longer depends on lookup with id number in a
global array of pointers, the limitation for the number of eDMAs are no
longer needed. We can handle as many eDMAs in legacy and DT boot as we have
memory for them to allocate the needed structures.
Instead of relying on indexes pointing to edma private date in the global
pointer array, pass the private data pointer via the public API.
Merge the iomem into the 'struct edma' and change the internal (static)
functions to use pointer to the edma_cc instead of the ctlr number.
If the of_dma_controller is registered in the non dmaengine driver we could
have race condition:
the of_dma_controller has been registered, but the dmaengine driver is not
yet probed. Drivers requesting DMA channels during this window will fail
since we do not yet have dmaengine drivers registered.
Currently we have one device created to handle all (maximum 2) eDMAs in the
system.
With this change all eDMA instance will have it's own device/driver.
This change is needed for further cleanups in the eDMA driver stack since
the one device/driver to handle all eDMAs in the system was not flexible
enough and prevents the upcoming work.
Acked-by: Sekhar Nori <nsekhar@ti.com>
We no longer have users for these functions so they can be removed.
Remove also unused enums from the header file.
In case when the interrupt happened for the second eDMA the channel
number was incorrectly passed to the client driver.
CC: <stable@vger.kernel.org>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Pull ARM development updates from Russell King:
"Included in this update:
- moving PSCI code from ARM64/ARM to drivers/
- removal of some architecture internals from global kernel view
- addition of software based "privileged no access" support using the
old domains register to turn off the ability for kernel
loads/stores to access userspace. Only the proper accessors will
be usable.
- addition of early fixup support for early console
- re-addition (and reimplementation) of OMAP special interconnect
barrier
- removal of finish_arch_switch()
- only expose cpuX/online in sysfs if hotpluggable
- a number of code cleanups"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (41 commits)
ARM: software-based priviledged-no-access support
ARM: entry: provide uaccess assembly macro hooks
ARM: entry: get rid of multiple macro definitions
ARM: 8421/1: smp: Collapse arch_cpu_idle_dead() into cpu_die()
ARM: uaccess: provide uaccess_save_and_enable() and uaccess_restore()
ARM: mm: improve do_ldrd_abort macro
ARM: entry: ensure that IRQs are enabled when calling syscall_trace_exit()
ARM: entry: efficiency cleanups
ARM: entry: get rid of asm_trace_hardirqs_on_cond
ARM: uaccess: simplify user access assembly
ARM: domains: remove DOMAIN_TABLE
ARM: domains: keep vectors in separate domain
ARM: domains: get rid of manager mode for user domain
ARM: domains: move initial domain setting value to asm/domains.h
ARM: domains: provide domain_mask()
ARM: domains: switch to keeping domain value in register
ARM: 8419/1: dma-mapping: harmonize definition of DMA_ERROR_CODE
ARM: 8417/1: refactor bitops functions with BIT_MASK() and BIT_WORD()
ARM: 8416/1: Feroceon: use of_iomap() to map register base
ARM: 8415/1: early fixmap support for earlycon
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next/cleanup
Merge "ARM: Interrupt cleanups and API change preparation" from Thomas
Gleixner:
The following patch series contains the following changes:
- Consolidation of chained interrupt handler setup/removal
- Switch to functions which avoid a redundant interrupt
descriptor lookup
- Preparation of interrupt flow handlers for the 'irq' argument
removal
* 'queue/irq/arm' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ARM/orion/gpio: Prepare gpio_irq_handler for irq argument removal
ARM/pxa: Prepare balloon3_irq_handler for irq argument removal
ARM/pxa: Prepare *_irq_handler for irq argument removal
ARM/dove: Prepare pmu_irq_handler for irq argument removal
ARM/sa1111: Prepare sa1111_irq_handler for irq argument removal
ARM/locomo: Prepare locomo_handler for irq argument removal
ARM, irq: Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc
ARM/LPC32xx: Use irq_set_handler_locked()
ARM/irq: Use access helper irq_data_get_affinity_mask()
ARM/locomo: Consolidate chained IRQ handler install/remove
ARM/orion: Consolidate chained IRQ handler install/remove
Writes to /sys/.../cpuX/online fail if we determine the platform
doesn't support hotplug for that CPU. Furthermore, if the cpu_die
op isn't specified the system hangs when we try to offline a CPU
and it comes right back online unexpectedly. Let's figure this
stuff out before we make the sysfs nodes so that the online file
doesn't even exist if it isn't (at least sometimes) possible to
hotplug the CPU.
Add a new 'cpu_can_disable' op and repoint all 'cpu_disable'
implementations at it because all implementers use the op to
indicate if a CPU can be hotplugged or not in a static fashion.
With PSCI we may need to add a 'cpu_disable' op so that the
secure OS can be migrated off the CPU we're trying to hotplug.
In this case, the 'cpu_can_disable' op will indicate that all
CPUs are hotpluggable by returning true, but the 'cpu_disable' op
will make a PSCI migration call and occasionally fail, denying
the hotplug of a CPU. This shouldn't be any worse than x86 where
we may indicate that all CPUs are hotpluggable but occasionally
we can't offline a CPU due to check_irq_vectors_for_cpu_disable()
failing to find a CPU to move vectors to.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Dave Martin <Dave.Martin@arm.com>
Acked-by: Simon Horman <horms@verge.net.au> [shmobile portion]
Tested-by: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: <linux-sh@vger.kernel.org>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Tested-by: Kevin Hilman <khilman@linaro.org>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Cc: Russell King <linux+kernel@arm.linux.org.uk>
Julia Lawall.
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we
already have a pointer to corresponding irq_desc.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here's the tty and serial driver patches for 4.2-rc1.
A number of individual driver updates, some code cleanups, and other
minor things, full details in the shortlog.
All have been in linux-next for a while with no reported issues"
* tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits)
Doc: serial-rs485.txt: update RS485 driver interface
Doc: tty.txt: remove mention of the BKL
MAINTAINERS: tty: add serial docs directory
serial: sprd: check for NULL after calling devm_clk_get
serial: 8250_pci: Correct uartclk for xr17v35x expansion chips
serial: 8250_pci: Add support for 12 port Exar boards
serial: 8250_uniphier: add bindings document for UniPhier UART
serial: core: cleanup in uart_get_baud_rate()
serial: stm32-usart: Add STM32 USART Driver
tty/serial: kill off set_irq_flags usage
tty: move linux/gsmmux.h to uapi
doc: dt: add documentation for nxp,lpc1850-uart
serial: 8250: add LPC18xx/43xx UART driver
serial: 8250_uniphier: add UniPhier serial driver
serial: 8250_dw: support ACPI platforms with integrated DMA engine
serial: of_serial: check the return value of clk_prepare_enable()
serial: of_serial: use devm_clk_get() instead of clk_get()
serial: earlycon: Add support for big-endian MMIO accesses
serial: sirf: use hrtimer for data rx
serial: sirf: correct the fifo empty_bit
Pull ARM updates from Russell King:
"Bigger items included in this update are:
- A series of updates from Arnd for ARM randconfig build failures
- Updates from Dmitry for StrongARM SA-1100 to move IRQ handling to
drivers/irqchip/
- Move ARMs SP804 timer to drivers/clocksource/
- Perf updates from Mark Rutland in preparation to move the ARM perf
code into drivers/ so it can be shared with ARM64.
- MCPM updates from Nicolas
- Add support for taking platform serial number from DT
- Re-implement Keystone2 physical address space switch to conform to
architecture requirements
- Clean up ARMv7 LPAE code, which goes in hand with the Keystone2
changes.
- L2C cleanups to avoid unlocking caches if we're prevented by the
secure support to unlock.
- Avoid cleaning a potentially dirty cache containing stale data on
CPU initialisation
- Add ARM-only entry point for secondary startup (for machines that
can only call into a Thumb kernel in ARM mode). Same thing is also
done for the resume entry point.
- Provide arch_irqs_disabled via asm-generic
- Enlarge ARMv7M vector table
- Always use BFD linker for VDSO, as gold doesn't accept some of the
options we need.
- Fix an incorrect BSYM (for Thumb symbols) usage, and convert all
BSYM compiler macros to a "badr" (for branch address).
- Shut up compiler warnings provoked by our cmpxchg() implementation.
- Ensure bad xchg sizes fail to link"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (75 commits)
ARM: Fix build if CLKDEV_LOOKUP is not configured
ARM: fix new BSYM() usage introduced via for-arm-soc branch
ARM: 8383/1: nommu: avoid deprecated source register on mov
ARM: 8391/1: l2c: add options to overwrite prefetching behavior
ARM: 8390/1: irqflags: Get arch_irqs_disabled from asm-generic
ARM: 8387/1: arm/mm/dma-mapping.c: Add arm_coherent_dma_mmap
ARM: 8388/1: tcm: Don't crash when TCM banks are protected by TrustZone
ARM: 8384/1: VDSO: force use of BFD linker
ARM: 8385/1: VDSO: group link options
ARM: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
ARM: remove __bad_xchg definition
ARM: 8369/1: ARMv7M: define size of vector table for Vybrid
ARM: 8382/1: clocksource: make ARM_TIMER_SP804 depend on GENERIC_SCHED_CLOCK
ARM: 8366/1: move Dual-Timer SP804 driver to drivers/clocksource
ARM: 8365/1: introduce sp804_timer_disable and remove arm_timer.h inclusion
ARM: 8364/1: fix BE32 module loading
ARM: 8360/1: add secondary_startup_arm prototype in header file
ARM: 8359/1: correct secondary_startup_arm mode
ARM: proc-v7: sanitise and document registers around errata
ARM: proc-v7: clean up MIDR access
Convert SA11x0 (Neponset, SA1111, and UCB1x00 code) to use the new
irq_set_chained_handler_and_data() helper.
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Thierry Reding <thierry.reding@gmail.com>
Link: http://lkml.kernel.org/r/E1Z4yzx-0002S6-7p@rmk-PC.arm.linux.org.uk
arch/arm/kernel/perf_event_cpu.c
arch/arm/kernel/head.S
The ARM Dual-Timer SP804 module is peripheral found not only on ARM32
platforms but also on ARM64 platforms.
This patch moves the driver out of arch/arm to driver/clocksource
so that it can be used on ARM64 platforms also.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Rob Herring <robh@kernel.org>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
The header asm/hardware/arm_timer.h is included in various machine
specific files to access TIMER_CTRL and initialise to a known state.
This patch introduces a new function sp804_timer_disable to disable
the SP804 timers and uses the same for initialising the timers to
known(off) state, thereby removing the dependency on the header
This change is in prepartion to move sp804 timer support out of arch/arm
so that it can be used on ARM64 platforms.
BSYM() was invented to allow us to work around a problem with the
assembler, where local symbols resolved by the assembler for the 'adr'
instruction did not take account of their ISA.
Since we don't want BSYM() used elsewhere, replace BSYM() with a new
macro 'badr', which is like the 'adr' pseudo-op, but with the BSYM()
mechanics integrated into it. This ensures that the BSYM()-ification
is only used in conjunction with 'adr'.
Acked-by: Dave Martin <Dave.Martin@arm.com>
When stopping a DMA transfer with interrupts disabled it is possible
that the DMA transfer completes before the events are cleared. In
this case the completion interrupt will be pending, causing a
completion callback after the transfer was stopped.
By clearing the completion interrupt for the stopping channel it is
ensured that no completion event will be generated after the stop.
Signed-off-by: John Ogness <john.ogness@linutronix.de>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
This is currently unused.
If a suspend must be limited to CPU level only by preventing the last man
from triggering a cluster level suspend then this should be determined
according to many other criteria the MCPM layer is currently not aware of.
It is unlikely that mcpm_cpu_suspend() would be the proper conduit for
that information anyway.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
This concerns the following helpers:
__mcpm_cpu_going_down()
__mcpm_cpu_down()
__mcpm_outbound_enter_critical()
__mcpm_outbound_leave_critical()
__mcpm_cluster_state()
They are and should only be used by the core code now. Therefore their
declarations are removed from mcpm.h and their definitions are made
static, hence the need to move them before their users which accounts
for the bulk of this patch.
This left the mcpm_sync_struct definition at an odd location, therefore
it is moved as well with some comment clarifications.
Now that no one uses the old callbacks anymore, let's remove them
and associated support code.
Pull ARM SoC platform updates from Olof Johansson:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. In this case, that includes:
- support for the new Annapurna Labs "Alpine" platform
- a rework greatly simplifying adding new platform support to the
MCPM subsystem (Multi-cluster power management)
- cpuidle and PM improvements for Exynos3250
- misc updates for Renesas, OMAP, Meson, i.MX. Some of these could
have gone in other branches but ended up here for various reasons"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
ARM: alpine: add support for generic pci
ARM: Exynos: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: DCSCB: tighten CPU validity assertion
ARM: vexpress: migrate TC2 to the new MCPM backend abstraction
ARM: MCPM: move the algorithmic complexity to the core code
ARM: EXYNOS: allow cpuidle driver usage on Exynos3250 SoC
ARM: EXYNOS: add AFTR mode support for Exynos3250
ARM: EXYNOS: add code for setting/clearing boot flag
ARM: EXYNOS: fix CPU1 hotplug on Exynos3250
ARM: S3C64XX: Use fixed IRQ bases to avoid conflicts on Cragganmore
ARM: cygnus: fix const declaration bcm_cygnus_dt_compat
ARM: DRA7: hwmod: Fix the hwmod class for GPTimer4
ARM: DRA7: hwmod: Add data for GPTimers 13 through 16
ARM: EXYNOS: Remove left over 'extra_save'
ARM: EXYNOS: Constify exynos_pm_data array
ARM: EXYNOS: use static in suspend.c
ARM: EXYNOS: Use platform device name as power domain name
ARM: EXYNOS: add support for async-bridge clocks for pm_domains
ARM: omap-device: add missed callback for suspend-to-disk
All backends are reimplementing a variation of the same CPU reference
count handling. They are also responsible for driving the MCPM special
low-level locking. This is needless duplication, involving algorithmic
requirements that are not necessarily obvious to the uninitiated.
And from past code review experience, those were all initially
implemented badly.
After 3 years, it is time to refactor as much common code to the core
MCPM facility to make the backends as simple as possible. To avoid a
flag day, the new scheme is introduced in parallel to the existing
backend interface. When all backends are converted over, the
compatibility interface could be removed.
The new MCPM backend interface implements simpler methods addressing
very platform specific tasks performed under lock protection while
keeping the algorithmic complexity and race avoidance local to the
core code.
Tested-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Use the new tick_suspend/resume_local() and get rid of the
homebrewn implementation of these in the ARM bL switcher. The
check for the cpumask is completely pointless. There is no harm
to suspend a per cpu tick device unconditionally. If that's a
real issue then we fix it proper at the core level and not with
some completely undocumented hacks in some random core code.
Move the tick internals to the core code, now that this nuisance
is gone.
[ rjw: Rebase, changelog ]
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Link: http://lkml.kernel.org/r/1655112.Ws17YsMfN7@vostro.rjw.lan
'enum clock_event_mode' is used for two purposes today:
- to pass mode to the driver of clockevent device::set_mode().
- for managing state of the device for clockevents core.
For supporting new modes/states we have moved away from the
legacy set_mode() callback to new per-mode/state callbacks. New
modes/states shouldn't be exposed to the legacy (now OBSOLOTE)
callbacks and so we shouldn't add new states to 'enum
clock_event_mode'.
Lets have separate enums for the two use cases mentioned above.
Keep using the earlier enum for legacy set_mode() callback and
mark it OBSOLETE. And add another enum to clearly specify the
possible states of a clockevent device.
This also renames the newly added per-mode callbacks to reflect
state changes.
We haven't got rid of 'mode' member of 'struct
clock_event_device' as it is used by some of the clockevent
drivers and it would automatically die down once we migrate
those drivers to the new interface. It ('mode') is only updated
now for the drivers using the legacy interface.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Suggested-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Cc: linaro-kernel@lists.linaro.org
Cc: linaro-networking@linaro.org
Link: http://lkml.kernel.org/r/b6b0143a8a57bd58352ad35e08c25424c879c0cb.1425037853.git.viresh.kumar@linaro.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
"The major updates included in this update are:
- Clang compatible stack pointer accesses by Behan Webster.
- SA11x0 updates from Dmitry Eremin-Solenikov.
- kgdb handling of breakpoints with read-only text/modules
- Support for Privileged-no-execute feature on ARMv7 to prevent
userspace code execution by the kernel.
- AMBA primecell bus handling of irq-safe runtime PM
- Unwinding support for memset/memzero/memmove/memcpy functions
- VFP fixes for Krait CPUs and improvements in detecting the VFP
architecture
- A number of code cleanups (using pr_*, removing or reducing the
severity of a couple of kernel messages, splitting ftrace asm code
out to a separate file, etc.)
- Add machine name to stack dump output"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (62 commits)
ARM: 8247/2: pcmcia: sa1100: make use of device clock
ARM: 8246/2: pcmcia: sa1111: provide device clock
ARM: 8245/1: pcmcia: soc-common: enable/disable socket clocks
ARM: 8244/1: fbdev: sa1100fb: make use of device clock
ARM: 8243/1: sa1100: add a clock alias for sa1111 pcmcia device
ARM: 8242/1: sa1100: add cpu clock
ARM: 8221/1: PJ4: allow building in Thumb-2 mode
ARM: 8234/1: sa1100: reorder IRQ handling code
ARM: 8233/1: sa1100: switch to hwirq usage
ARM: 8232/1: sa1100: merge GPIO multiplexer IRQ to "normal" irq domain
ARM: 8231/1: sa1100: introduce irqdomains support
ARM: 8230/1: sa1100: shift IRQs by one
ARM: 8229/1: sa1100: replace irq numbers with names in irq driver
ARM: 8228/1: sa1100: drop entry-macro.S
ARM: 8227/1: sa1100: switch to MULTI_IRQ_HANDLER
ARM: 8241/1: Update processor_modes for hyp and monitor mode
ARM: 8240/1: MCPM: document mcpm_sync_init()
ARM: 8239/1: Introduce {set,clear}_pte_bit
ARM: 8238/1: mm: Refine set_memory_* functions
ARM: 8237/1: fix flush_pfn_alias
Pull ARM SoC driver updates from Arnd Bergmann:
"These are changes for drivers that are intimately tied to some SoC and
for some reason could not get merged through the respective subsystem
maintainer tree.
The largest single change here this time around is the Tegra
iommu/memory controller driver, which gets updated to the new iommu DT
binding. More drivers like this are likely to follow for the
following merge window, but we should be able to do those through the
iommu maintainer.
Other notable changes are:
- reset controller drivers from the reset maintainer (socfpga, sti,
berlin)
- fixes for the keystone navigator driver merged last time
- at91 rtc driver changes related to the at91 cleanups
- ARM perf driver changes from Will Deacon
- updates for the brcmstb_gisb driver"
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
clocksource: arch_timer: Allow the device tree to specify uninitialized timer registers
clocksource: arch_timer: Fix code to use physical timers when requested
memory: Add NVIDIA Tegra memory controller support
bus: brcmstb_gisb: Add register offset tables for older chips
bus: brcmstb_gisb: Look up register offsets in a table
bus: brcmstb_gisb: Introduce wrapper functions for MMIO accesses
bus: brcmstb_gisb: Make the driver buildable on MIPS
of: Add NVIDIA Tegra memory controller binding
ARM: tegra: Move AHB Kconfig to drivers/amba
amba: Add Kconfig file
clk: tegra: Implement memory-controller clock
serial: samsung: Fix serial config dependencies for exynos7
bus: brcmstb_gisb: resolve section mismatch
ARM: common: edma: edma_pm_resume may be unused
ARM: common: edma: add suspend resume hook
powerpc/iommu: Rename iommu_[un]map_sg functions
rtc: at91sam9: add DT bindings documentation
rtc: at91sam9: use clk API instead of relying on AT91_SLOW_CLOCK
ARM: at91: add clk_lookup entry for RTT devices
rtc: at91sam9: rework the Kconfig description
Convert many (but not all) printk(KERN_* to pr_* to simplify the code.
We take the opportunity to join some printk lines together so we don't
split the message across several lines, and we also add a few levels
to some messages which were previously missing them.
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Felipe Balbi <balbi@ti.com>
The recently introduced resume hook in the edma driver
is not referenced when CONFIG_PM_SLEEP is not set, which
results in a compile warning in keystone builds.
This adds an appropriate #ifdef.
Cc: Nishanth Menon <nm@ti.com>
Cc: Daniel Mack <zonque@gmail.com>
Cc: Joel Fernandes <joelf@ti.com>
Fixes: a2b1175131: ("ARM: common: edma: add suspend resume hook")
This patch makes the edma driver resume correctly after suspend. Tested
on an AM33xx platform with cyclic audio streams and omap_hsmmc.
All information can be reconstructed by already known runtime
information.
As we now use some functions that were previously only used from __init
context, annotations had to be dropped.
[nm@ti.com: added error handling for runtime + suspend_late/early_resume]
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Daniel Mack <zonque@gmail.com>
Tested-by: Joel Fernandes <joelf@ti.com>
Acked-by: Joel Fernandes <joelf@ti.com>
[nsekhar@ti.com: remove unneeded pm_runtime_get_sync() from resume]
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
The horrible split between the low-level part of the edma support
and the dmaengine front-end driver causes problems on multiplatform
kernels. This is an attempt to improve the situation slightly
by only registering the dmaengine devices that are actually
present.
[olof: add missing include of linux/dma-mapping.h]
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
this remove all reference to gpio_remove retval in all driver
except pinctrl and gpio. the same thing is done for gpio and
pinctrl in two different patches.
Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Michael Büsch <m@bues.ch>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The edma_setup_from_hw() should know about the CC number when parsing the
CCCFG register - when it reads the register to be precise. The base
addresses for CCs stored in an array and we need to provide the correct id
to edma_read() in order to read the correct register.
Cc: <stable@vger.kernel.org> # 3.16
