path: root/arch/arm/configs/ams_delta_defconfig
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2010-05-20Merge branch 'omap-boards' into omap-for-linusTony Lindgren
2010-05-20OMAP1: Amstrad Delta: modify defconfig for external keyboardsupportJanusz Krzysztofik
The patch adds a CONFIG directive required for supporting the Amstrad Delta connected external keyboard by default. Created and tested against linux-omap master, commit 104a77440f05430f29f9d3f4ecb88c1536819585 dated 2010-04-27. Works on top of PATCH v4 4/5(7), "input: serio: add support for Amstrad Delta serial keyboard port". Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-05-20omap1: amsdelta: defconfig updatesJanusz Krzysztofik
The patch provides the following ams_delta_defconfig updates: - explicitly select preemptable RCU, - replace outdated CONFIG_LBD and CONFIG_LSF options with CONFIG_LBDAF, - activate support for LCD contrast setting (new in 2.6.34), - turn off verbose bug reporting for smaller kernel. Created and tested against linux-2.6.34-rc3. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-11omap1: Amstrad Delta defconfig fixesJanusz Krzysztofik
The patch provides the following fixes: - keep kernel small enough to boot with standard tools, - ensure compatibility with both new and legacy distros, - turn on support for recently added or fixed hardware features. Created and tested against linux-2.6.32-rc5. Signed-off-by: Janusz Krzysztofik <jkrzysz@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-08-27[ARM] OMAP: Add and update OMAP default configuration filesRussell King
Update omap_h2_1610 and omap_osk_5912 default configurations. Add ams delta, n770, omap 2430sdp, apollon_2420, generic 1510, 1610, 1710, 2420, h4 2420, innovator 1510 and 1610, perseus2 730, palte, palmtt, palmz71 and sx1 default configurations. Pulled out of the omap zoom tree. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
