path: root/arch/arm/configs/colibri_t30_defconfig
2014-07-26apalis/colibri t20/t30: enable vlan functionalityMarcel Ziswiler
Enable VLAN networking functionality. While at it also enable some more kernel modules for Apalis T30 PCIe based devices like the Intel E1000E NICs, Intel IWLAGN Wi-Fi cards, PCIe serial cards and XHCI based USB 3.0 controllers.
2014-07-25apalis/colibri t30: use hda hdmi audio and split sound initMarcel Ziswiler
Use HDA HDMI audio now on Colibri T30 as well allowing for up to 7.1 multi-channel playback. Split board sound initialisation between Apalis and Colibri T30 in order to distinguish better between default SPDIF being supported out-of-the-box on Apalis vs. this being an optional feature for the Colibri. Therefore remove SPDIF for the Colibri T30. While at it add csus clock required for vi_sensor camera master clock on Apalis T30 and clk_out_2/extern2 for Colibri T30, fix debug UART1 initialisation, get rid of spurious CONFIG_SND_USB enable and further clean-up both board platform data files.
2014-07-25apalis/colibri t20/t30: enable fhandle for systemdMarcel Ziswiler
Enable CONFIG_FHANDLE required for systemd >= 209 according to lists.freedesktop.org/archives/systemd-devel/2014-February/017362.html While at it put them all 3 on par concerning ARM Errata configuration.
2014-01-29colibri_t20/colibri_t30: use new platform data for fusion touchscreenStefan Agner
Fusion touchscreen driver now uses platform data to do GPIO initialization by itself. Make use of this by providing GPIO numbers instead of doing initialization in the board initialization.
2013-12-09colibri_t30/apalis_t30: enable STMPE ADC driverStefan Agner
Make use of the new STMPE ADC driver to expose the four free ADC channels on the STMPE811 to userspace.
2013-10-21toradex defconfigs: don't set CONFIG_MAGIC_SYSRQMax Krummenacher
If the boot console is RS232 and RX is left floating this leads to arbitrary sys requests including reboots... (RX is left floating on the evaluation boards if USB to serial is jumpered but USB is not connected)
2013-01-08colibri_t30: get rid of obsolete NAND handlingMarcel Ziswiler
Get rid of obsolete NAND aka Colibri T30 v1.0a prototype handling.
2012-12-21colibri_t30: clean-up configMarcel Ziswiler
Clean-up kernel configuration and bring it more in line with Colibri T20.
2012-11-27colibri_t30: WIRELESS_EXT hackMarcel Ziswiler
Hack to force WIRELESS_EXT required to build Redpine Signals LiteFi driver.
2012-11-27colibri_t30: enable USB audioMarcel Ziswiler
Enable kernel configuration for USB audio.
2012-11-27colibri_t30: USB: 2 mA VBUS drawMarcel Ziswiler
As Colibris are usually self powered default drawn VBUS to 2 mA rather than demanding 500 mA. This should fix it running from not self powered USB hubs as well.
2012-11-27colibri_t30: activate Android gadgetMarcel Ziswiler
Activate Android rather than mass storage gadget driver to support multiple USB functions. The functions can be configured via a board file and may be enabled and disabled dynamically. E.g. the following enables regular Ethernet aka RNDIS functionality once booted: echo rndis > /sys/class/android_usb/android0/functions echo 1 > /sys/class/android_usb/android0/enable
2012-11-27colibri_t30: usb: activate colibri otg driverMarcel Ziswiler
Activate Colibri rather than Tegra USB OTG driver as used on Colibri T20 as well.
2012-10-03asoc: colibri_t30: initial sgtl5000 codec integrationMarcel Ziswiler
Integrate ALSA SoC SGTL5000 codec on Toradex Colibri T30.
2012-10-03tegra: colibri_t30: initial Toradex Colibri T30 L4T R16 supportMarcel Ziswiler
Tested on early prototype Colibri T30 V1.0a eMMC module. Known issues: - spurious boot hang after following kernel message [ 5.595219] Timed out waiting for lock bit on pll pll_a - no audio (SGTL5000) support integrated yet - NAND detection/support disabled for now due to boot hang - USB OTG support disabled for now due to boot hang - trying to spawn L4T R16 X driver seems to hang Note: requires uImage with adjusted entry point/load address as follows mkimage -A arm -C none -O linux -T kernel -a 0x82008000 -e 0x82008000 -n 'Linux-3.1.10-colibri_t30' -d zImage uImage
