path: root/arch/arm/configs/collie_defconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-21[ARM] 5408/1: SA1100: update defconfigs after h3800 removalDmitry Artamonow
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-12[ARM] dyntick: Remove obsolete and unused ARM dyntick supportRussell King
dyntick is superseded by the clocksource/clockevent infrastructure, using the NO_HZ configuration option. No one implements dyntick on ARM anymore, so it's pointless keeping it around. Remove dyntick support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] remove reference to non-existent MTD_OBSOLETE_CHIPSRobert P. J. Day
The CONFIG variable MTD_OBSOLETE_CHIPS was deleted in commit ba7cc09c9c9e29a57045dc5bbf843ac1cfad3283. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove DEBUG_WAITQRussell King
DEBUG_WAITQ appears to have been removed by others, but no one removed the configuration option from ARM. Remote it from both Kconfig.debug and all default configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-11[ARM] Remove PM_LEGACY=y from selected ARM defconfigsRussell King
Most ARM defconfigs don't actually need to have PM_LEGACY enabled. Disable it for ATEB9200, Collie, IXP4xx, OMAP H2, S3C2410 and Versatile. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-09[ARM] 3508/1: Update collie defconfigPavel Machek
Patch from Pavel Machek Update collie defconfig to something that can bring closer-to-working system to its user. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-19[ARM] Remove CONFIG_BROKEN=y from defconfigsRussell King
Remove CONFIG_BROKEN=y from the ARM defconfigs, and update with the appropriate changes. This results in only some unselected configuration symbols being removed - hence no material effect on the configuration. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-09[ARM] Remove CONFIG_ARCH_CAMELOT from defconfigsRussell King
EPXA10DB has gone, no need to keep the symbol in the defconfigs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-10[ARM] 2968/1: defconfig for the ARM Collie platformVincent Sanders
Patch from Vincent Sanders Add a defconfig for the ARM Collie platform Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
