Let USB Storage be built by default.
Also select NLS_ISO8859 so that the USB device can be mounted.
The two SoCs have different PHYS_OFFSETs so it's not (yet) possible to
compile a single (working) kernel for these.
LAKML-Reference: 1302464943-20721-4-git-send-email-u.kleine-koenig@pengutronix.de
This patch is to fix the warning below.
arch/arm/configs/mx51_defconfig:113:warning: symbol value 'm' invalid for LEDS_CLASS
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
Add functionality for the power button on MX51 Babbage board.
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
Further remove FIXED_PHY as it breaks the ethernet.
VGA_CONSOLE isn't selectable anymore since fb78b51cb11e.
EXT3_DEFAULTS_TO_ORDERED defaults to y since aa32a796389b.
INOTIFY is gone since 2dfc1cae4c42.
CONFIG_DETECT_SOFTLOCKUP is gone since e16bb1d7fe07.
Enable TMPFS for udev.
KEYS is selected by NFS_USE_KERNEL_DNS
Update mx51_defconfig to include USB EHCI by default.
This patch applies to 2.6.34-rc6.
This config is used to test the base support for i.MX51 processors on the
Babbage board
Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com>
