path: root/arch/arm/configs/neponset_defconfig
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-21[ARM] 5408/1: SA1100: update defconfigs after h3800 removalDmitry Artamonow
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2007-07-19i2c: Delete the i2c-isa pseudo bus driverJean Delvare
There are no users of i2c-isa left, so we can finally get rid of it. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-11-30[ARM] Remove DEBUG_WAITQRussell King
DEBUG_WAITQ appears to have been removed by others, but no one removed the configuration option from ARM. Remote it from both Kconfig.debug and all default configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-26[ARM] Add PM_LEGACY defaultsRussell King
Eliminate two warnings: kernel/power/pm.c:205: warning: 'pm_register' is deprecated (declared at kernel/power/pm.c:64) kernel/power/pm.c:206: warning: 'pm_send_all' is deprecated (declared at kernel/power/pm.c:180) by updating defconfig files to contain a sensible PM_LEGACY default. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-09[ARM] Remove CONFIG_ARCH_CAMELOT from defconfigsRussell King
EPXA10DB has gone, no need to keep the symbol in the defconfigs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
