scripts/checkkconfigsymbols.py indicates that omap1_defconfig
references the following obsolete Kconfig symbols:
CONFIG_BT_L2CAP
CONFIG_BT_SCO
CONFIG_DEBUG_ERRORS
CONFIG_EXPERIMENTAL
CONFIG_FB_OMAP_BOOTLOADER_INIT
CONFIG_LEDS_CPU
CONFIG_MACH_OMAP_HTCWIZARD
CONFIG_MTD_CHAR
CONFIG_MTD_DEBUG
CONFIG_MTD_DEBUG_VERBOSE
CONFIG_MTD_PARTITIONS
CONFIG_NET_ETHERNET
CONFIG_RCU_CPU_STALL_DETECTOR
CONFIG_SCSI_MULTI_LUN
CONFIG_USB_DEVICE_CLASS
CONFIG_VIDEO_OUTPUT_CONTROL
Drop them from omap1_defconfig.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: Valentin Rothberg <valentinrothberg@gmail.com>
Cc: Stefan Hengelein <stefan.hengelein@fau.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
Having switched over all of the users of CONFIG_PM_RUNTIME to use
CONFIG_PM directly, turn the latter into a user-selectable option
and drop the former entirely from the tree.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
There are no existing users for OMAP1 mailbox driver
in kernel. Commit ab6f775 "Removing dead OMAP_DSP"
has cleaned up all the dead code related to the only
possible user, including the creation of the mailbox
platform device.
Remove this stale driver so that the OMAP mailbox
driver can be simplified and streamlined better for
converting to mailbox framework.
Signed-off-by: Suman Anna <s-anna@ti.com>
Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Now that CONFIG_USB_DEBUG is gone, remove it from a number of defconfig
files that were enabling it.
It no longer occurs in Kconfig.
USB: remove CONFIG_USB_DEVICEFS(fb28d58b) leaked remove defconfig.
Signed-off-by: Naoki MATSUMOTO <nekomatu+linux@gmail.com>
The mailbox hardware (in OMAP) uses a queued mailbox interrupt
mechanism that provides a communication channel between processors
through a set of registers and their associated interrupt signals
by sending and receiving messages.
The OMAP mailbox framework/driver code is moved to be under
drivers/mailbox, in preparation for adapting to a common mailbox
driver framework. This allows the build for OMAP mailbox to be
enabled (it was disabled during the multi-platform support).
As part of the migration from plat and mach code:
- Kconfig symbols have been renamed to build OMAP1 or OMAP2+ drivers.
- mailbox.h under plat-omap/plat/include has been split into a public
and private header files. The public header has only the API related
functions and types.
- The module name mailbox.ko from plat-omap is changed to
omap-mailbox.ko
- The module name mailbox_mach.ko from mach-omapX is changed as
mailbox_omap1.ko for OMAP1
mailbox_omap2.ko for OMAP2+
[gregkh@linuxfoundation.org: ack for staging part]
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Omar Ramirez Luna <omar.ramirez@copitl.com>
Commit 84ebc10294a3d7be4c66f51070b7aedbaa24de9b (USB: remove
CONFIG_USB_SUSPEND option) failed to remove all of the usages of
USB_SUSPEND throughout the kernel. This patch (as1677) removes the
remaining instances of that symbol.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
The Kconfig entry for USB_OMAP unconditionally selects USB_ISP1301,
which is now only visible when USB_PHY is also enabled.
This adds an appropriate dependency and enables USB_PHY in the omap1
defconfig, avoiding these build warnings:
warning: (USB_OHCI_HCD && USB_OMAP) selects ISP1301_OMAP which has unmet direct dependencies (USB_SUPPORT && USB_PHY && I2C && ARCH_OMAP_OTG)
Also fix a Makefile typo while we're at it.
Cc: Felipe Balbi <balbi@ti.com>
The File-backed Storage Gadget (g_file_storage) is being removed, since
it has been replaced by Mass Storage Gadget (g_mass_storage). This commit
changes defconfigs point to the new gadget.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> (AT91)
Acked-by: Tony Lindgren <tony@atomide.com> (OMAP1)
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> (AVR32)
Signed-off-by: Felipe Balbi <balbi@ti.com>
For still better multi-OMAP1 support, expand omap1_rate_table with flags
for different SoC types and match them while selecting clock rates. The
idea is stolen from current omap24xx clock rate selection algorithm.
Since clkdev platform flag definitions are reused here, those had to be
expanded with one extra entry for OMAP1710 subtype, as this is the only
SoC for which we allow selection of the highest, 216 MHz rate.
Once done, remove no longer needed clock rate configure time options.
Tested on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
[tony@atomide.com: updated comments]
DPLL1 reprogramming to a different rate is actually blocked inside
omap1_select_table_rate(), resulting in the defalut rate of 60 MHz
always used instead of the one selected in .config. OTOH, in
omap1_defconfig we currently rely on Kconfig options for the supported
MHz rates in case of boards which boot with dpll1 not set correctly by
their boot loaders.
This means that before we allow for reprogramming of dpll1 rate, we
should remove all unsafe clock selections from omap1_defconfig,
otherwise it will stop booting on boards with imperfect boot loaders,
as it would always try to change to 216MHz.
Keep only one safe clock rate per each supported xtal frequency, i.e.
60MHZ dpll1 for 12MHz xtal and 182MHz dpll1 for 13MHz xtal.
BTW, this change goes into the direction of removing all OMAP1 clock
rate options, planned for next merge window.
Commit a66cb3454f220f49f900646ebdc76cb943319eb7 (ARM: OMAP: Map SRAM
later on with ioremap_exec()) moved the SRAM init to happen later
to remove a dependency to early SoC detection for map_io.
This broke booting on some boards not using Kconfig option for
OMAP_CLOCKS_SET_BY_BOOTLOADER as the dpll1 reprogramming would
cause the following error:
kernel BUG at arch/arm/plat-omap/sram.c:226!
Internal error: Oops - undefined instruction: 0 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.2.0-rc1-e3 #9)
PC is at omap_sram_reprogram_clock+0x28/0x30
LR is at omap1_select_table_rate+0x88/0xb4
pc : [<c001b0c4>] lr : [<c0019f54>] psr: 600000d3
sp : c035bf10 ip : c035bf20 fp : c035bf1c
r10: c035bfd4 r9 : 54029252 r8 : c03f8120
r7 : c0362b50 r6 : 00b71b00 r5 : c03873cc r4 : c0362b40
r3 : 00000000 r2 : c0362b40 r1 : 0000010a r0 : 00002cb0
Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
Control: 0000317f Table: 10004000 DAC: 00000017
Process swapper (pid: 0, stack limit = 0xc035a270)
Stack: (0xc035bf10 to 0xc035c000)
bf00: c035bf3c c035bf20 c0019f54 c001b0ac
bf20: 00001000 00002cb3 00000004 c035ed4c c035bf74 c035bf40 c033ea24 c0019edc
bf40: c02f526c 00000002 00000015 bc058c9b 93111a16 c035335c 02000000 c035ed4c
bf60: c035ed4c c03f8120 c035bf84 c035bf78 c00194c4 c033e8ec c035bfc4 c035bf88
bf80: c033bc24 c00194a0 c035bf90 c035bf98 00000000 00000000 00000000 00000000
bfa0: 00000001 00000000 c0354678 c035ece4 10004000 103532f4 c035bff4 c035bfc8
bfc0: c0338574 c033b598 00000000 00000000 00000000 c035467c 0000317d c035c03c
bfe0: c0354678 c035ece4 00000000 c035bff8 10008040 c0338508 00000000 00000000
Backtrace:
[<c001b09c>] (omap_sram_reprogram_clock+0x0/0x30) from [<c0019f54>] (omap1_select_table_rate+0x88/0xb4)
[<c0019ecc>] (omap1_select_table_rate+0x0/0xb4) from [<c033ea24>] (omap1_clk_init+0x148/0x334)
r7:c035ed4c r6:00000004 r5:00002cb3 r4:00001000
[<c033e8dc>] (omap1_clk_init+0x0/0x334) from [<c00194c4>] (omap1_init_early+0x34/0x48)
r8:c03f8120 r7:c035ed4c r6:c035ed4c r5:02000000 r4:c035335c
[<c0019490>] (omap1_init_early+0x0/0x48) from [<c033bc24>] (setup_arch+0x69c/0x79c)
[<c033b588>] (setup_arch+0x0/0x79c) from [<c0338574>] (start_kernel+0x7c/0x2f4)
[<c03384f8>] (start_kernel+0x0/0x2f4) from [<10008040>] (0x10008040)
r7:c035ece4 r6:c0354678 r5:c035c03c r4:0000317d
Code: 0a000002 e1a0e00f e12fff13 e89da800 (e7f001f2)
Fix this by adding omap1_clk_late_init() that only reprograms dpll1
if the bootloader rate is less than 60MHz. This also allows removing
of the OMAP_CLOCKS_SET_BY_BOOTLOADER option.
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
The omap1_defconfig this should be eventually usable for booting
all omap1 machines. Generated based on:
$ grep ARCH_OMAP1=y arch/arm/configs/* | cut -d: -f1 | xargs cat | \
sort | uniq >> arch/arm/configs/omap1_defconfig
Then change few things manually, like use Nokia 770 CONFIG_CMDLINE
as it does not allow setting it in the bootloader.
Finally ran make savedefconfig on it.
