path: root/arch/arm/configs/pxa910_defconfig
2017-06-10ARM: defconfig: Cleanup from old Kconfig optionsKrzysztof Kozlowski
Remove old, dead Kconfig options (in order appearing in this commit): - EXPERIMENTAL is gone since v3.9; - INET_LRO: commit 7bbf3cae65b6 ("ipv4: Remove inet_lro library"); - MTD_CONCAT: commit f53fdebcc3e1 ("mtd: drop MTD_CONCAT from Kconfig entirely"); - MTD_PARTITIONS: commit 6a8a98b22b10 ("mtd: kill CONFIG_MTD_PARTITIONS"); - MTD_CHAR: commit 660685d9d1b4 ("mtd: merge mtdchar module with mtdcore"); - NETDEV_1000 and NETDEV_10000: commit f860b0522f65 ("drivers/net: Kconfig and Makefile cleanup"); NET_ETHERNET should be replaced with just ETHERNET but that is separate change; - INOTIFY: commit 2dfc1cae4c42 ("inotify: remove inotify in kernel interface"); - MISC_DEVICES: commit 7c5763b8453a ("drivers: misc: Remove MISC_DEVICES config option"); - HID_SUPPORT: commit 1f41a6a99476 ("HID: Fix the generic Kconfig options"); - BT_L2CAP and BT_SCO: commit f1e91e1640d8 ("Bluetooth: Always compile SCO and L2CAP in Bluetooth Core"); - DEBUG_ERRORS: commit b025a3f836d1 ("ARM: 6876/1: Kconfig.debug: Remove unused CONFIG_DEBUG_ERRORS"); - USB_DEVICE_CLASS: commit 007bab91324e ("USB: remove CONFIG_USB_DEVICE_CLASS"); - RCU_CPU_STALL_DETECTOR: commit a00e0d714fbd ("rcu: Remove conditional compilation for RCU CPU stall warnings"); - SYSCTL_SYSCALL_CHECK: commit 7c60c48f58a7 ("sysctl: Improve the sysctl sanity checks"); - IP_NF_QUEUE: commit 3dd6664fac7e ("netfilter: remove unused "config IP_NF_QUEUE""); - IP_NF_TARGET_ULOG: commit d4da843e6fad ("netfilter: kill remnants of ulog targets"); - IP6_NF_QUEUE: commit d16cf20e2f2f ("netfilter: remove ip_queue support"); - IP6_NF_TARGET_LOG: commit 6939c33a757b ("netfilter: merge ipt_LOG and ip6_LOG into xt_LOG"); - USB_LED: commit a335aaf3125c ("usb: misc: remove outdated USB LED driver"); - MMC_UNSAFE_RESUME: commit 2501c9179dff ("mmc: core: Use MMC_UNSAFE_RESUME as default behavior"); - AUTOFS_FS: commit 561c5cf9236a ("staging: Remove autofs3"); - DISPLAY_SUPPORT: commit 5a6b5e02d673 ("fbdev: remove display subsystem"); - CFG80211_REG_DEBUG: commit c799ba6eab7a ("cfg80211: remove CFG80211_REG_DEBUG"); - VIDEO_OUTPUT_CONTROL: commit f167a64e9d67 ("video / output: Drop display output class support"); - USB_LIBUSUAL: commit f61870ee6f8c ("usb: remove libusual"); - CRYPTO_ZLIB: commit 110492183c4b ("crypto: compress - remove unused pcomp interface"); - BLK_DEV_UB: commit 68a5059ecf82 ("block: remove the deprecated ub driver"); Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> [for vexpress] Acked-by: Liviu Dudau <liviu.dudau@arm.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-02-21ARM: mmp: add display and fb support in pxa910 defconfigZhou Zhu
Add display and fb support in pxa910 defconfig. Add tpohvga panel, spi support. Add logo support. Signed-off-by: Zhou Zhu <zzhu3@marvell.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Lisa Du <cldu@marvell.com> Cc: Guoqing Li <ligq@marvell.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-16ARM: mmp: enable debug uart port in defconfigHaojian Zhuang
Enable DEBUG_LL & debug uart port in pxa910 & mmp2 defconfig. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-23[ARM] pxa: add defconfig for pxa910-based platformsEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com>
