26-bit ARM support was removed a long time ago, and this symbol has
been defined to be 'y' ever since. As it's never disabled anymore,
we can kill it without any side effects.
The recently merged AT91SAM9 watchdog driver uses the
AT91SAM9X_WATCHDOG config variable, whereas the original version of
the driver (and the platform support code) used AT91SAM9_WATCHDOG.
This causes the watchdog platform_device to never be registered, and
therefore the driver not to be initialized.
This patch:
- updates the platform support code to use AT91SAM9X_WATCHDOG.
- includes <linux/io.h> to fix compile error (same fix as was applied
to at91rm9200_wdt.c)
- fixes comment regarding watchdog clock-rates in at91rm9200.
Signed-off-by: Andrew Victor <linux@maxim.org.za>
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Structs called at91_nand_data where renamed to atmel_nand_data
and configs called *MTD_NAND_AT91* where renamed to
*MTD_NAND_ATMEL*. This was unfortunately not done consistently,
causing NAND chips not being initialised on several ARM boards.
I am aware that the author of the original change did not rename
MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example.
All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order
to keep naming consistency.
This patch was only tested on a MACH_SAM9_L9260, as this is the
only ARM board I have to my disposal.
Before this patch:
$ git-ls-files |xargs grep atmel_nand |wc -l
105
$ git-ls-files |xargs grep at91_nand |wc -l
4
$ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l
8
$ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l
47
After this patch:
109
0
55
0
Signed-off-by: Pieter du Preez <pdupreez@gmail.com>
Default config files for the three AT91-based boards available from
Calao Systems: USB_A9260, USB_A9263 and QIL_A9260.
Signed-off-by: Grégory Hermant <gregory.hermant@calao-systems.com>
