path: root/arch/arm/configs/realview_defconfig
2011-05-20ARM: 6903/1: Realview: Use physmap driver instead of integrator-flashMarc Zyngier
Tested on a PB11-MPCore. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-08ARM: 6365/1: Update RealView defconfigLinus Walleij
This patches the condensed RealView defconfig activating some stuff that has been missing from this config for some time and some stuff that was merged in the 2.6.36 merge window: - The new character LCD driver is enabled - The Versatile I2C is enabled - The PL022 SPI driver is enabled - gpiolib is enabled (and makes MMC detection work properly) - The new LEDs code is enabled with a heartbeat trigger - The RTC class is enabled, and the PL031 RTC (onchip) and the offchip DS1307 on I2C is enabled Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-04-02arm: update realview defconfigs to use smsc911xSteve Glendinning
Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com>
2008-12-01RealView: Update the realview_defconfig file to a newer kernelCatalin Marinas
The original file was based on 2.6.14-rc2. Apart from the new symbols, the explicitly enabled features are AACI, MMC, AEABI, MACH_REALVIEW_PB1176 and MACH_REALVIEW_PB11MP. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-05-12[ARM] dyntick: Remove obsolete and unused ARM dyntick supportRussell King
dyntick is superseded by the clocksource/clockevent infrastructure, using the NO_HZ configuration option. No one implements dyntick on ARM anymore, so it's pointless keeping it around. Remove dyntick support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove DEBUG_WAITQRussell King
DEBUG_WAITQ appears to have been removed by others, but no one removed the configuration option from ARM. Remote it from both Kconfig.debug and all default configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-09[ARM] Remove CONFIG_ARCH_CAMELOT from defconfigsRussell King
EPXA10DB has gone, no need to keep the symbol in the defconfigs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-03[ARM] Add Realview default configuration fileRussell King
