commit 015664d15270a112c2371d812f03f7c579b35a73 upstream.
The Rio500 kernel driver has not been used by Rio500 owners since 2001
not long after the rio500 project added support for a user-space USB stack
through the very first versions of usbdevfs and then libusb.
Support for the kernel driver was removed from the upstream utilities
in 2008:
https://gitlab.freedesktop.org/hadess/rio500/commit/943f624ab721eb8281c287650fcc9e2026f6f5db
Cc: Cesar Miquel <miquel@df.uba.ar>
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/6251c17584d220472ce882a3d9c199c401a51a71.camel@hadess.net
Remove old, dead Kconfig options (in order appearing in this commit):
- EXPERIMENTAL is gone since v3.9;
- INET_LRO: commit 7bbf3cae65b6 ("ipv4: Remove inet_lro library");
- MTD_CONCAT: commit f53fdebcc3e1 ("mtd: drop MTD_CONCAT from Kconfig entirely");
- MTD_PARTITIONS: commit 6a8a98b22b10 ("mtd: kill CONFIG_MTD_PARTITIONS");
- MTD_CHAR: commit 660685d9d1b4 ("mtd: merge mtdchar module with mtdcore");
- NETDEV_1000 and NETDEV_10000: commit f860b0522f65 ("drivers/net:
Kconfig and Makefile cleanup"); NET_ETHERNET should be replaced with
just ETHERNET but that is separate change;
- INOTIFY: commit 2dfc1cae4c42 ("inotify: remove inotify in kernel interface");
- MISC_DEVICES: commit 7c5763b8453a ("drivers: misc: Remove
MISC_DEVICES config option");
- HID_SUPPORT: commit 1f41a6a99476 ("HID: Fix the generic Kconfig options");
- BT_L2CAP and BT_SCO: commit f1e91e1640d8 ("Bluetooth: Always compile
SCO and L2CAP in Bluetooth Core");
- DEBUG_ERRORS: commit b025a3f836d1 ("ARM: 6876/1: Kconfig.debug:
Remove unused CONFIG_DEBUG_ERRORS");
- USB_DEVICE_CLASS: commit 007bab91324e ("USB: remove CONFIG_USB_DEVICE_CLASS");
- RCU_CPU_STALL_DETECTOR: commit a00e0d714fbd ("rcu: Remove conditional
compilation for RCU CPU stall warnings");
- SYSCTL_SYSCALL_CHECK: commit 7c60c48f58a7 ("sysctl: Improve the
sysctl sanity checks");
- IP_NF_QUEUE: commit 3dd6664fac7e ("netfilter: remove unused "config IP_NF_QUEUE"");
- IP_NF_TARGET_ULOG: commit d4da843e6fad ("netfilter: kill remnants of ulog targets");
- IP6_NF_QUEUE: commit d16cf20e2f2f ("netfilter: remove ip_queue support");
- IP6_NF_TARGET_LOG: commit 6939c33a757b ("netfilter: merge ipt_LOG and
ip6_LOG into xt_LOG");
- USB_LED: commit a335aaf3125c ("usb: misc: remove outdated USB LED driver");
- MMC_UNSAFE_RESUME: commit 2501c9179dff ("mmc: core: Use
MMC_UNSAFE_RESUME as default behavior");
- AUTOFS_FS: commit 561c5cf9236a ("staging: Remove autofs3");
- DISPLAY_SUPPORT: commit 5a6b5e02d673 ("fbdev: remove display subsystem");
- CFG80211_REG_DEBUG: commit c799ba6eab7a ("cfg80211: remove
CFG80211_REG_DEBUG");
- VIDEO_OUTPUT_CONTROL: commit f167a64e9d67 ("video / output: Drop
display output class support");
- USB_LIBUSUAL: commit f61870ee6f8c ("usb: remove libusual");
- CRYPTO_ZLIB: commit 110492183c4b ("crypto: compress - remove unused
pcomp interface");
- BLK_DEV_UB: commit 68a5059ecf82 ("block: remove the deprecated ub driver");
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[for vexpress]
Acked-by: Liviu Dudau <liviu.dudau@arm.com>
IDE subsystem has been deprecated since 2009 and the majority
(if not all) of Linux distributions have switched to use
libata for ATA support exclusively. However there are still
some users (mostly old or/and embedded non-x86 systems) that
have not converted from using IDE subsystem to libata PATA
drivers. This doesn't seem to be good thing in the long-term
for Linux as while there is less and less PATA systems left
in use:
* testing efforts are divided between two subsystems
* having duplicate drivers for same hardware confuses users
This patch converts spitz_defconfig to use libata PATA
drivers.
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
It no longer occurs in Kconfig.
USB: remove CONFIG_USB_DEVICEFS(fb28d58b) leaked remove defconfig.
Signed-off-by: Naoki MATSUMOTO <nekomatu+linux@gmail.com>
The File-backed Storage Gadget (g_file_storage) is being removed, since
it has been replaced by Mass Storage Gadget (g_mass_storage). This commit
changes defconfigs point to the new gadget.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> (AT91)
Acked-by: Tony Lindgren <tony@atomide.com> (OMAP1)
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> (AVR32)
Signed-off-by: Felipe Balbi <balbi@ti.com>
CONFIG_MTD_NAND_VERIFY_WRITE was killed recently, so remove it from
defconfigs as well.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
26-bit ARM support was removed a long time ago, and this symbol has
been defined to be 'y' ever since. As it's never disabled anymore,
we can kill it without any side effects.
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Recent changes have been made to use the generic SPI-based ads7846
touch screen driver and a generic SPI-based corgi-type LCD/backlight
driver. Update the {corgi,spitz}_defconfig to favor the use of these
drivers instead of the legacy ones.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
dyntick is superseded by the clocksource/clockevent infrastructure,
using the NO_HZ configuration option. No one implements dyntick on
ARM anymore, so it's pointless keeping it around. Remove dyntick
support.
DEBUG_WAITQ appears to have been removed by others, but no one
removed the configuration option from ARM. Remote it from both
Kconfig.debug and all default configurations.
Eliminate two warnings:
kernel/power/pm.c:205: warning: 'pm_register' is deprecated (declared at kernel/power/pm.c:64)
kernel/power/pm.c:206: warning: 'pm_send_all' is deprecated (declared at kernel/power/pm.c:180)
by updating defconfig files to contain a sensible PM_LEGACY default.
EPXA10DB has gone, no need to keep the symbol in the defconfigs.
Patch from Richard Purdie
Akita requires inbuilt kernel i2c support for its GPIOs. Add this
requirement to Kconfig and update the defconfig to match.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
This updates the Zaurus defconfigs. Poodle gets merged into
corgi_defconfig and support for tosa and akita is enabled.
Patch from Vincent Sanders
Add a defconfig for the ARM Spitz Zarus platform
Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk>
