commit c13e7f313da33d1488355440f1a10feb1897480a upstream.
The DRM driver most notably, but also out of tree drivers (for now) like
the VPU or GPU drivers, are quite big consumers of large, contiguous memory
buffers. However, the sunxi_defconfig doesn't enable CMA in order to
mitigate that, which makes them almost unusable.
Enable it to make sure it somewhat works.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Enable the new DRM driver in the sunxi default configuration
Acked-by: Chen-Yu Tsai <wens@csie.org>
Allwinner SoCs typically have a Mentor Graphics Inventra MUSB dual role
controller for USB OTG.
Now that the issue with MUSB and USB gadget registration order has been
resolved, we can enable this driver in dual role mode. This requires the
NOP USB transceiver driver, which is also enabled.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
sunxi_defconfig already enables INPUT_AXP20X_PEK, but the device is not
exposed to userspace. Enable INPUT_EVDEV so it is.
The A10 audio codec driver supports the on-chip audio codec found on
Allwinner A10, A10s, A13, A20 SoCs.
A consumer IR receiver is commonly found on Allwinner SoC based
development boards and set top boxes. The driver has been available
for some time. Enable it by default.
Pull ARM SoC defconfig updates from Olof Johansson:
"As usual, a bunch of commits, mostly adding drivers and other options
to defconfigs because it makes sense to have them enabled on various
development or product boards. Too much to enumerate each here.
There's an introduction of a pxa_defconfig, since PXA finally will
allow building a shared kernel for all boards. With this, we can
hopefully remove a bunch of individual defconfigs down the road but it
requires a bit of real life testing and transition period"
* tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (65 commits)
ARM: Add CONFIG_DEPRECATED_PARAM_STRUCT to netwinder_defconfig
ARM: multi_v7_defconfig: Add rockchip audio support
arm: multi_v7_defconfig: Add virtio drivers
ARM: zx_defconfig: remove CONFIG_MMC_DW_IDMAC
ARM: versatile: enable the right LEDs
ARM: pxa: add defconfig covering all the boards
ARM: versatile: select some defaults in defconfig
ARM: multi_v7_defconfig: Enable fan, sensors and audio for Odroid XU3
ARM: bcm2835: enable auxiliary spi driver in defconfig
ARM: bcm2835: enable all bcm2835-relevant in defconfig
ARM: default to multi_v7_defconfig
ARM: multi_v7_defconfig: enable rk808 clkout module
ARM: multi_v7_defconfig: enable rockchip crypto module
ARM: multi_v7_defconfig: enable Rockchip io-domain driver
ARM: multi_v7_defconfig: Enable generic SoC internal OMAP regulators
ARM: multi_v7_defconfig: Enable AM437x PMIC TPS65218
ARM: multi_v7_defconfig: enable TPS65217 regulator
ARM: realview: select apropriate targets
ARM: defconfig: qcom: Enable SSBI drivers
ARM: defconfig: Update qcom_defconfig
Commit 69fb4dcada77 ("power: Add an axp20x-usb-power driver") introduced a new
driver for the USB power supply used on various Allwinner based SBCs. However,
the driver was not added to sunxi_defconfig which breaks USB support for some
boards (e.g. LeMaker BananaPi) as the kernel will now turn off the USB power
supply during boot by default if the driver isn't present. (This was not the
case in linux 4.3 or lower where the USB power was always left on.)
Hence, add the driver to sunxi_defconfig in order to keep USB support working
on those boards that require it.
Signed-off-by: Timo Sigurdsson <public_timo.s@silentcreek.de>
Reported-by: David Tulloh <david@tulloh.id.au>
Tested-by: David Tulloh <david@tulloh.id.au>
Tested-by: Timo Sigurdsson <public_timo.s@silentcreek.de>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Clean up sunxi_defconfig by generating a fresh file via
make sunxi_defconfig
make savedefconfig
While this moves around a few lines and removes unnecessary symbols,
it doesn't introduce any functional changes. The resulting .config is
identical before and after this patch.
Commit be8becb81bdc ("ARM: sunxi_defconfig: Enable LRADC keys
(KEYBOARD_SUN4I_LRADC)") added CONFIG_KEYBOARD_SUN4I_LRADC=y to
sunxi_defconfig. However, it depends on CONFIG_KEYBOARD which is
explicitly disabled in sunxi_defconfig. Hence, the LRADC keys were
never actually enabled. Remove the line disabling CONFIG_KEYBOARD in
order to really enable KEYBOARD_SUN4I_LRADC.
Commit 3d0b16a66c8a ("nvmem: sunxi: Move the SID driver to the nvmem
framework") moved the the sunxi SID driver to a new framework, but left
sunxi_defconfig with the deprecated config symbol EEPROM_SUNXI_SID
instead of the new symbol NVMEM_SUNXI_SID. Hence, re-enable the driver
in sunxi_defconfig.
axp20x support has been split into 2 parts, I2C and RSB interface
variants.
Update the MFD_AXP20X symbol for I2C support, and also enable
MFD_AXP20X_RSB to support RSB variants.
Keep MFD_AXP20X enabled for now, to ease migration for automated boot
farms while the patches are being merged. This should be removed in the
next release.
Loadable module support is enabled so we should allow unloading
modules too. This also allows lsmod to show values other than "-2" in
the "Used by" column.
Signed-off-by: Jonathan Liu <net147@gmail.com>
Defconfig sunxi for Allwinner A10/A20 CAN driver
Signed-off-by: Gerhard Bertelsmann <info@gerhard-bertelsmann.de>
Signed-off-by: Priit Laes <plaes@plaes.org>
Enable sun6i DMA engine, sun6i P2WI, PWM, and crypto engine (Security
System) drivers by default. EXTCON is needed by the updated sun4i USB
PHY driver.
While at it, enable FHANDLE, which is needed by systemd and newer
versions of udev. Also enable CGROUPS for systemd.
And get rid of POWER_RESET, as the sun6i power reset driver has been
removed in favor of proper sun6i watchdog support.
Now that we have simplefb support, we can enable it in our defconfig. Also
enable the framebuffer console, so that we are sure that we actually get
something displayed in any case.
And while we're at it, enable the module support.
Commit b2b3a8b934e6 ("power/reset: Remove sun6i reboot driver") removed
the sun6i reboot driver. But sunxi_defconfig and multi_v7_defconfig
still contain the symbol CONFIG_POWER_RESET_SUN6I that was deprecated
by that commit, so remove it.
The a80 optimus has 8 CPUs. I propose we increase the maximum number of CPUs to 8 to avoid the following warning identified during automated boot testing [1].
WARNING: CPU: 0 PID: 0 at ../arch/arm/kernel/devtree.c:144 arm_dt_init_cpu_maps+0x110/0x1e0()
DT /cpu 5 nodes greater than max cores 4, capping them
CPU: 0 PID: 0 Comm: swapper Not tainted 3.19.0-00528-gbdccc4edeb03 #1
Hardware name: Allwinner sun9i Family
[] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[] (show_stack) from [] (dump_stack+0x74/0x90)
[] (dump_stack) from [] (warn_slowpath_common+0x70/0xac)
[] (warn_slowpath_common) from [] (warn_slowpath_fmt+0x30/0x40)
[] (warn_slowpath_fmt) from [] (arm_dt_init_cpu_maps+0x110/0x1e0)
[] (arm_dt_init_cpu_maps) from [] (setup_arch+0x634/0x8d4)
[] (setup_arch) from [] (start_kernel+0x88/0x3ac)
[] (start_kernel) from [<20008074>] (0x20008074)
---[ end trace cb88537fdc8fa200 ]---
[1] http://storage.kernelci.org/mainline/v3.19-528-gbdccc4edeb03/arm-sunxi_defconfig/lab-tbaker/boot-sun9i-a80-optimus.html
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Kevin Hilman <khilman@kernel.org>
Signed-off-by: Tyler Baker <tyler.baker@linaro.org>
On sun9i we have a new PHY driver for USB.
Signed-off-by: Carlo Caione <carlo@caione.org>
This patch enables TOUCHSCREEN_SUN4I, CPUFREQ_DT, and CPU_THERMAL to
enable cpufreq support with passive cpu cooling (thermal throttling)
by default.
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Having switched over all of the users of CONFIG_PM_RUNTIME to use
CONFIG_PM directly, turn the latter into a user-selectable option
and drop the former entirely from the tree.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
I missed in 9a2ad529ed26 that REGULATOR_FIXED_VOLTAGE had also gotten
deselected, so it needs to be added back as an explicit option.
Commit 97a13e5289ba ('net: phy: mdio-sun4i: don't select REGULATOR') removed
the select of REGULATOR, which means that it now has to be explicitly
enabled in the defconfig or things won't work very well.
In particular, this fixes a problem with SD/MMC not probing on my A31-based
board.
Cc: Beniamino Galvani <b.galvani@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into next/defconfig
Pull "Allwinner defconfig additions for 3.18" from Maxime Ripard
Nothing major, just a few drivers additions and misc options
* tag 'sunxi-defconfig-for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux:
ARM: sunxi_defconfig: add NLS_CODEPAGE_437 and NLS_ISO8859_1
ARM: sunxi: Add A31 RTC driver to multi_v7_defconfig
ARM: sunxi: Add A31 RTC driver to sunxi_defconfig
The virtual consumer is a test device intended to be used while developing
regulator drivers, it should never be used in production. Remove it from
all defconfigs to avoid confusion among users.
Signed-off-by: Mark Brown <broonie@kernel.org>
Acked-by: Matt Porter <mporter@linaro.org>
Otherwise CONFIG_VFAT_FS is useless as mounting vfat fails.
Signed-off-by: Luc Verhaegen <libv@skynet.be>
Now that we have a driver for A31's RTC, enable it
in the default sunxi config.
Update sunxi_defconfig and multi_v7 with all the latest Allwinner
additions.
Linux 3.15-rc6
Now that the A31 reset code is a driver of its own, we need it in the
defconfig.
this patch drops CONFIG_COMMON_CLK_DEBUG option
as this config option is now obsolete.
CC: Maxime Ripard <maxime.ripard@free-electrons.com>
CC: Olof Johansson <olof@lixom.net>
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Since the support of the GMAC has been merged, we're using it as the ethernet
controller on the A20 devices.
However, sunxi_defconfig wasn't selecting it hence breaking the NFS boot.
This enables a few more options on the sunxi defconfigs such that I can
use nfsroot to boot them (there is no local storage support yet). It
also enables PRINTK_TIME and tmpfs since it's a common distro requirement.
So far, the Allwinner SoCs were only supported using the
multi_v7_defconfig. Add a defconfig of our own to have one a bit more
tailor-made.
