Enabling ISO9660 file system (and its JOLIET extension) support in
kernel.
Bug 1018276.
Change-Id: I1acaf5dc3a571b75a81860485d3c668ea82d822c
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/117372
Tested-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
(cherry picked from commit c35638147c3fa9d56f124b4d6c0435aadad53d97)
CONFIG_TEGRA_CBUS_CLOCK_DIVIDER=1
* Disabled CONFIG_TEGRA_SE_ON_CBUS
So that se clock can be derived from clocks
other than which are driving cbus.
* Changed CONFIG_TEGRA_CBUS_CLOCK_DIVIDER=1
So that pllc can run at same frequency as
cbus is running at.
Bug 978870
Change-Id: I66898e3f16adad3625efb1a484b438c168419a68
Signed-off-by: Mohit Kataria <mkataria@nvidia.com>
Reviewed-on: http://git-master/r/117995
(cherry picked from commit b5d42b0432119ddebcc38f6f40761e3dea3d9f6d)
Reviewed-on: http://git-master/r/117312
GVS: Gerrit_Virtual_Submit
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Enabling CONFIG_NON_ALIASED_COHERENT_MEM in p1852 defconfig
to avoid coherent memmory aliasing.
also enabling ARM_ERRATA_742230
bug 965047
Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-on: http://git-master/r/111174
(cherry picked from commit 086cfc1330df0a158e865d39af48d71d15fd5730)
Change-Id: I410bc14e0c062d14bbfc4b7cfa722a20465010de
Reviewed-on: http://git-master/r/113268
Tested-by: Manoj Chourasia <mchourasia@nvidia.com>
PL310_ERRATA_727915 holds for PL310 revision r2p0 which
is there in T20. T30 has PL310 r3p1.
bug 820324
Reviewed-on: http://git-master/r/111169
(cherry picked from commit 1e29090d6d700f6afb39828e93605d5742847271)
Change-Id: I01516eedbb6bfaec3e3b619d47e30ff54dfb2824
Reviewed-on: http://git-master/r/113267
bug 820324
Change-Id: Ia4dec298b3c0cda8cb4e8572b46067b7d06b3758
Reviewed-on: http://git-master/r/107592
Reviewed-by: Simone Willett <swillett@nvidia.com>
Enable WXGA display and touch input for p1852 touch panel.
board-p1852-panel.c:
added WXGA timing for atmel touch panel.
board-p1852.c:
initialize touch panel if touch input is defined.
board-p1852.h:
added p1852 touch panel GPIO and bus.
tegra_p1852_gnu_linux_defconfig:
added touch panel flags, not defined by default.
bug 936232
Change-Id: Ia50b991f6aa5ed0ece458ad3871a68684a9234a6
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/101348
Added code to select i2s vs tdm mode.
Added tdm-pcm-audio device defination.
Changed the pcm driver to use tdm-pcm-audio device.
Added fields to pass the pcm driver name to ASoC.
Added P1852_TDM config to KConfig and Linux defconfig
Bug 948478
Change-Id: I82fa03ab947cc615089e0a3107fb53901a1c00cd
Signed-off-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-on: http://git-master/r/105383
Enable background ops on p852 and p1852.
Bug 847037.
Change-Id: Ib72d361aba5cf08c171976e6f5bf0ffa555e1471
Reviewed-on: http://git-master/r/99121
1. Disable PM_SLEEP
2. Disable Early ACK for MC
3. Enabled TEGRA SDHCI support
4. Disabled DEBUG_LL.
bug 931053
Change-Id: I387d528bef3e6fa85b986c70e805693f7f5ce701
Reviewed-on: http://git-master/r/91478
Reviewed-by: Mohit Kataria <mkataria@nvidia.com>
Reviewed-by: Shankar Subramanian <ssubramanian@nvidia.com>
Removing config variable CONFIG_REGULATOR_GPIO_SWITCH as the
same functionality can be achieve with fixed regulator.
Change-Id: I803105f2a247da70721f29562881448bb00d3a44
Reviewed-on: http://git-master/r/94197
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Instantiated audio drivers for I2S and AHUB.
Instantiated the machine driver for P1852 boards.
Added clocks that were not initialized by QB which are needed to be on.
Bug 948478
Change-Id: I6e696f97ed114ae684a74d9b9869066606dfaa22
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/90252
Reviewed-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
Tested-by: Bob Johnston <bjohnston@nvidia.com>
bug 871603
Reviewed-on: http://git-master/r/72258
Change-Id: I2ff63550fde536ee0e0f1b69b3a58e4f164e62e5
Reviewed-on: http://git-master/r/78027
