path: root/arch/arm/configs/versatile_defconfig
2013-12-20ARM: versatile: enable LEDs by defaultLinus Walleij
This adds the LEDs and triggers used by the Versatile boards to the default configuration. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: versatile: build using EABILinus Walleij
This should work just fine on this purely v5 platform, so let's config it for EABI by default. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: versatile: enable GPIOLIB and PL061 by defaultLinus Walleij
Select the GPIOLIB and PL061 in the Versatile defconfig, as this is present on all boards, and so we get compile and test coverage for this. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: versatile: update defconfigLinus Walleij
This updates the Versatile defconfig to the thing saved by savedefconfig so we don't get confusing diffs when trying to modify other options. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-10-27ARM: versatile: fix versatile_defconfigArnd Bergmann
With the introduction of CONFIG_ARCH_MULTIPLATFORM, versatile is no longer the default platform, so we need to enable CONFIG_ARCH_VERSATILE explicitly in order for that to be selected rather than the multiplatform configuration. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-05-20ARM: 6907/1: Versatile: Use physmap driver instead of integrator-flashMarc Zyngier
Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-05-12[ARM] dyntick: Remove obsolete and unused ARM dyntick supportRussell King
dyntick is superseded by the clocksource/clockevent infrastructure, using the NO_HZ configuration option. No one implements dyntick on ARM anymore, so it's pointless keeping it around. Remove dyntick support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove DEBUG_WAITQRussell King
DEBUG_WAITQ appears to have been removed by others, but no one removed the configuration option from ARM. Remote it from both Kconfig.debug and all default configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-11[ARM] Remove PM_LEGACY=y from selected ARM defconfigsRussell King
Most ARM defconfigs don't actually need to have PM_LEGACY enabled. Disable it for ATEB9200, Collie, IXP4xx, OMAP H2, S3C2410 and Versatile. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-08[ARM] Update versatile_defconfigRussell King
Update versatile default configuration, enabling the AACI sound driver, VFP and Versatile AB support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-09[ARM] Remove CONFIG_ARCH_CAMELOT from defconfigsRussell King
EPXA10DB has gone, no need to keep the symbol in the defconfigs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
