Signed-off-by: Russell Robinson Jr <rrobinson@phytec.com>
The buttons are initially defined in arch/arm/mach-mvf/board-pcl052
and each LED is set to trigger by a corresponding button press.
This is supported with a modified leds-gpio and trigger driver
that enables assinging default gpio triggers values in kernel space.
Signed-off-by: Johnathan Feuerstein <jfeuerstein@phytec.com>
Signed-off-by: Chris Conley <cconley@phytec.com>
additional changes: enabled ADC and updated QSPI parts
manually integrate from the CAAM part by Jason
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: Alison Wang <b18965@freescale.com>
Enable the softecc in the config to make the NFC use softecc.
also include the defconfig update for:
ENGR220009:The LCD panel goes blank after a long time
Add default kernel config for Faraday.
Enable local timer by default. If wait mode is on,
local timer will be shutdown automatically on boot.
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
add mx6q_sdabresd board in updater defconfig.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
add wm8958 option in defconfig
Signed-off-by: Gary Zhang <b13634@freescale.com>
- Add E Ink support as a default for MX6 platforms
- Conditionalize registration of EPDC-related modules based on "epdc"
kernel command line option
Signed-off-by: Danny Nold <dannynold@freescale.com>
set GPIO config and disable UART3 DMA.
Signed-off-by: Zhou Jianzheng <B38613@freescale.com>
- Added EPDC and EPD PMIC (Maxim 17135) to MX6Q ARM2 board file
- Added EPDC-related IOMUX and GPIO settings
- Added EPDC clock configuration settings to clock file
- Updated config files with EPDC and Maxim 17135 config entries
add ePxP config option
Signed-off-by: Robby Cai <R63905@freescale.com>
enable max8903 in defconfig.
Add 3-axis accelerometer (mma8451) driver.
Add Digital Magnetometer (mag3110) driver.
Add Ambient Light sensor (isl29023) driver.
- Add cfg80211, Atheros Wifi driver into default kernel config.
Signed-off-by: Ryan QIAN <b32804@freescale.com>
Enable CONFIG_COMPACTION on imx6_defconfig to reduce
the external memory fragementation
Signed-off-by: Jason Liu <r64343@freescale.com>
After upgrade kernel to 3.0.15, the defconfig also need
be updated to sync with the kernel version change
Enable PFUZE regulator.
Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
Add suport for i.MX 6Quad SABRE Smart Device.
Rename to SABRESD.
Signed-off-by: Tony Lin <tony.lin@freescale.com>
We need enable the following ARM errata software workaround:
CONFIG_ARM_ERRATA_764369=y
This errata is TKT078684 in i.MX6Q errata list.
In order to enable this errata, we need cherry-pick the following commit:
ARM: 7091/1: errata: D-cache line maintenance operation by MVA may not succeed:
f64f6df4241093ea928b0a263ec53b93b65efc08
In order to apply the above patch successfully and keep the git history, we also
ARM: pm: add function to set WFI low-power mode for SMP CPUs
292ec42af7c6361435fe9df50cd59ec76f6741c6
These ERRATAs applied to i.MX6Q(cortex-a9:r2p10 smp)
Add ADV7180 build as a module
Signed-off-by: Even Xu <b21019@freescale.com>
This commit mainly build in GPIO keypad.But because config
file have not been update for long time, some item is added
by kconfig automatically.
The step is make imx6_defconfig,
Make menuconfig,
Choose gpio keypad enable
Cp .config to imx6_defconfig
Signed-off-by:Yuxi Sun <b36102@freescale.com>
Add board level code for mlb, including platform data, clock, etc.
Signed-off-by: Terry Lv <r65388@freescale.com>
OV8820 MIPI camera driver will be built as a module default.
Add usb audio gadget support at imx6 defconfig
Signed-off-by: Peter Chen <peter.chen@freescale.com>
1.modify some pins for support pfuze100
2.add mx6q_sabreauto_pmic_pfuze100.c to support regulator of pfuze100
3.modify imx6_defconfig to enable pfuze driver and regulator driver
Signed-off-by: Robin Gong <B38343@freescale.com>
Enable the USB video config as module avoid conflict with CSI camera
Enable the USB audio config as defult built in driver
Signed-off-by: make shi <b15407@freescale.com>
* Add egalax touch screen support for sabreauto platform
* Add egalax client to correct i2c channel
* Fix GPIO assigned to touch screen interrupt
* egalax driver depends of LED_CLASS for gpio interrupt handling
and HIDRAW for X11 event notification and added to mx6q_defconfig
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
- Add CONFIG_HOSTAP as CONFIG_WIRELESS_EXT's dependency
- remove the staging driver from default config of MX6
Fix the bug: can't allocate buffer if setting resolution to 1920*1080p
Bug detailed description:
use 1920,1080 output resolution
mxc_sdc_fb mxc_sdc_fb.0: Unable to allocate framebuffer memory
Signed-off-by: Wayne Zou <b36644@freescale.com>
The root cause is that the sata power is not enabled after reboot
the system when boot from sata.
Built in the sata driver would fix this issue.
In this way, the sata power would be enabled defautly
when there is a sata device is plugged into the slot, otherwise,
the power would be disabled.
NOTE:
Pls don't plug the sata disk after the system is booted up.
System wouldn't recognized it, since there are no any power and
clocks on the sata slot.
Signed-off-by: Richard Zhu <r65037@freescale.com>
Add file board-mx6q_sabreauto.c. The only real difference from
board-mx6q_arm2.c is SD pin configuration is changed.
Signed-off-by: Eric Sun <jian.sun@freescale.com>
add performance monitor device to mx6q arm2 board.
add perfmon clocks to clock tree.
add perfmon to default config as a module
Add basic bluetooth support to mx6q platform:
1) Enable bluetooth driver by default
2) Configure uart2 which is used by bluetooth
Signed-off-by: Lionel Xu <Lionel.Xu@freescale.com>
GC355 needs to map all reserved memory and consume too much vmalloc space.
So it needs a special kernel command line vmalloc=xxxM.
otherwise, kernel can not boot
Signed-off-by: Wu Guoxing <b39297@freescale.com>
Build in thermal driver by default.
Signed-off-by: Anson Huang <b20788@freescale.com>
skip build cryptodev because no one use it now.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
1. Config MIPI CSI2 driver as a default build in driver
2. Change ov5640 mipi sensor as a module
The GPU module will eat up lots of memory.
So disable GPU to save same memory.
Signed-off-by: Huang Shijie <b32955@freescale.com>
