Enable VLAN networking functionality.
While at it also enable some more kernel modules for Apalis T30 PCIe
based devices like the Intel E1000E NICs, Intel IWLAGN Wi-Fi cards,
PCIe serial cards and XHCI based USB 3.0 controllers.
Use HDA HDMI audio now on Colibri T30 as well allowing for up to 7.1
multi-channel playback. Split board sound initialisation between Apalis
and Colibri T30 in order to distinguish better between default SPDIF
being supported out-of-the-box on Apalis vs. this being an optional
feature for the Colibri. Therefore remove SPDIF for the Colibri T30.
While at it add csus clock required for vi_sensor camera master clock
on Apalis T30 and clk_out_2/extern2 for Colibri T30, fix debug UART1
initialisation, get rid of spurious CONFIG_SND_USB enable and further
clean-up both board platform data files.
Enable CONFIG_FHANDLE required for systemd >= 209 according to
lists.freedesktop.org/archives/systemd-devel/2014-February/017362.html
While at it put them all 3 on par concerning ARM Errata configuration.
Enable IEEE 1588 precision time protocol (PTP) support.
drivers/media/video/tegra_v4l2_camera.c
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
Activate Fusion touchscreen driver. Use GPIO 5/6 as pen down/reset
GPIO and provide a helper function to free the GPIO before the
driver requests them.
Fusion touchscreen driver now uses platform data to do GPIO
initialization by itself. Make use of this by providing GPIO numbers
instead of doing initialization in the board initialization.
Disable hardware statistics monitor for AVP due to it completely
hanging upon boot on certain Colibri T20 V1.2a modules.
Make use of the new STMPE ADC driver to expose the four free ADC
channels on the STMPE811 to userspace.
This reverts commit dd9a841da571a41d43f1eeaac1785b2adb1d80f3.
The config changes (for V4L2) can be done manually as per need
basis for V4L2, followed by compiling the kernel.
Change-Id: I9174bce0f3da2974ab703b238dfb8fb3bbf607c5
Signed-off-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-on: http://git-master/r/327607
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
- Disables TEGRA_CAMERA
- Enables SOC_CAMERA and OV5640 sensor support
Bug 1369083
Change-Id: I073c226e9f04a6f4f4699051f624a755dceb36cb
Reviewed-on: http://git-master/r/309491
If the boot console is RS232 and RX is left floating this leads
to arbitrary sys requests including reboots...
(RX is left floating on the evaluation boards if USB to serial is
jumpered but USB is not connected)
The firmware is not being in use currently.
So, turn the loading code off.
Bug 1236060
Bug 991551
Change-Id: Id41cf762b59502d0ece470e315ac75d93e3b6b39
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/218613
(cherry picked from commit f15976bdfb32d6c5e20057f6d4d57646c15a5591)
Reviewed-on: http://git-master/r/258354
GVS: Gerrit_Virtual_Submit
Enable the modular camera configuration for ACM which allows switching
not only decoders but also their inputs at run-time.
This is the only correct order to load the modules:
modprobe videobuf2-memops
modprobe videobuf2-dma-nvmap
modprobe max9526
# or modprobe adv7180
modprobe tegra_v4l2_camera
To change the decoder on the fly:
rmmod tegra_v4l2_camera
rmmod max9526
# or rmmod adv7180
modprobe adv7180
# or modprobe max9526
To get a pre-view window through gstreamer:
gst-launch v4l2src ! deinterlace tff=1 method=4 ! nv_omx_videomixer !
nv_gl_eglimagesink
To switch inputs (0-5 resp. 0-4 for ADV7180 and 0-2 for MAX9526 where 2
means auto selection):
v4l2-ctl -i 0
v4l2-ctl -i 1
v4l2-ctl -i 2
v4l2-ctl -i 3
v4l2-ctl -i 4
v4l2-ctl -i 5
To check what input is active:
v4l2-ctl -I
While at it enable NVIDIA confirmed ARM errata 716044 and 720789 as
well.
Enable PCI quirk support resp. don't explicitly disable it in order for
the following fix to take effect.
The Apalis evaluation board needs to set the link speed to 2.5 GT/s
(GEN1). The default link speed setting is 5 GT/s (GEN2). 0x98 is the
Link Control 2 PCIe Capability Register of the PEX8605 PCIe switch. The
switch supports link speed auto negotiation, but falsely sets the link
speed to 5 GT/s.
Integrate ADV7180 and MAX9526 video decoder support and prepare for
drivers as modules.
The following gstreamer pipeline shows a preview window:
nv_gl_eglimagesink
Add initial Android kernel configuration adopted from
tegra_android_defconfig.
Integrate support for the Realtek ALC898 as found on the Apalis
Evaluation Board V1.0a.
Please note that the following HDA rewiring needs to be done:
remove jumpers X6-5 and 7 to 9
rewire as follows:
X5 X7
5 9
7 8
8 5
9 7
Please further note that currently only noise is heard during playback.
Disabled CONFIG_INPUT_MOUSEDEV to avoid kernel registering PS/2 mouse
devices, which are mostly not in use now.
Bug 1162832
Change-Id: I0b44af668fa94ffc589e646a842259afa837731e
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
Reviewed-on: http://git-master/r/187807
Bug 1162832
Change-Id: If47e654063934d3b60d033a0d2523b8caf97825b
Reviewed-on: http://git-master/r/187808
tegra3_android_defconfig.
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Enable building b43 driver as a module to demo Broadcom AirForce
BCM4311 based mini-PCIe Wi-Fi 802.11a/b/g module.
enable /dev mount with ACL
Bug 1225372
Bug 1219372
Change-Id: I3b80012e97c3a5ec8358285f81c5111a30ed19f8
Reviewed-on: http://git-master/r/196206
Tested on early prototype Apalis T30 V1.0a module.
Known issues:
- ADC not integrated yet.
- HDA not integrated yet.
- CEC not integrated yet.
- IrDA not integrated yet.
- Keys not integrated yet therefore no way to wake from suspend.
- 8-bit MMC1 slot card detection interrupt not working despite
detection GPIO successfully being tested with GPIOConfig.
Note: even 8-bit cards work fine if already plugged-in during boot.
- PCIe limited to internal Gigabit Ethernet chip for now due to our
proprietary way of resetting other ports which requires further
integration into NVIDIA's driver.
Get rid of obsolete NAND aka Colibri T30 v1.0a prototype handling.
Clean-up kernel configuration and bring it more in line with Colibri T20.
Do not use P2P, as it does not fit well with
network manager.
Bug 1199933
Change-Id: I355515574baabeace7c48932c52007c1fe0c3d5f
Reviewed-on: http://git-master/r/171551
Tested-by: Matthew Pedro <mapedro@nvidia.com>
- select RT5640 ASoC support in Cardhu machine Kconfig
- enable RT5640 ASoC driver in tegra3_defconfig
- select RT5639 ASoC codec when selecting RT5640, othwise kernel
linking will fail
Bug 1190823
Change-Id: I1046c30667d4ca8276080f1b3174eccd0b25328c
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/168884
There are some classes of devices that are controlled entirely from
user space. Userspace consumer driver provides ability to control power
supplies for such devices. Enable this configuration option to be more
in line with the T30.
If the console is locked while the system is rebooted, the messages in
the temporary log buffer would not have propagated to all the console
drivers. This option forces the console lock to be released if it
failed to be acquired, which will cause all the pending messages to be
flushed. Enable this configuration option to be more in line with the
T30.
Get rid of the 2G/2G user/kernel memory split configuration in order to
use the default 3G/1G user/kernel memory split. This is more in line
with the T30 and avoids issues trying to run Android.
- enable couple of HID devices
- modify couple of BT options
Bug 1178960
Change-Id: Id9377edff2189d8a63f624d5d4e388e54658482f
Reviewed-on: http://git-master/r/167541
required for bluetooth
Bug 1033671
Change-Id: Ibc45eaf344ef7a5eea88e7df5747f8dcdcbf202d
Reviewed-on: http://git-master/r/166347
Enable CONFIG_SATA_AHCI_TEGRA
Bug 1171138
Change-Id: Id0cf3679a0fb0b85e20cd83c94135bf2aab2dd71
Original-author: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/143985
(cherry picked from commit 6830e27f86e0f3a2f1e3bad51ee2bf6855dc99b7)
Reviewed-on: http://git-master/r/166838
Hack to force WIRELESS_EXT required to build Redpine Signals LiteFi driver.
Enable kernel configuration for USB audio.
As Colibris are usually self powered default drawn VBUS to 2 mA rather
than demanding 500 mA. This should fix it running from not self powered
USB hubs as well.
Activate Android rather than mass storage gadget driver to support
multiple USB functions. The functions can be configured via a board
file and may be enabled and disabled dynamically. E.g. the following
enables regular Ethernet aka RNDIS functionality once booted:
echo rndis > /sys/class/android_usb/android0/functions
echo 1 > /sys/class/android_usb/android0/enable
Activate Colibri rather than Tegra USB OTG driver as used on
Colibri T20 as well.
Add default kernel configuration in order to run oe-core on any of the
Colibri PXA series modules. So far no further platform data additions
have been committed meaning only older PXA270 v1.x, PXA300/310 v1.x or
PXA320 v1.x modules as anyway supported in mainline will work.
USB hubs as well.
Activate Android rather than Ethernet gadget driver to support multiple
USB functions. The functions can be configured via a board file and may
be enabled and disabled dynamically. E.g. the following enables regular
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Backlight PWM now runs at 1 kHZ rather than 500kHz.
Make PWM B, C, D accessible from userspace. e.g as /sys/class/leds/pwm_b.
Make PWM A or C a led PWM depending on MECS_TELLURIUM.
To avoid the following systemd failure and as recommended we activate
IPv6 kernel configuration straight from NVIDIA's tegra_defconfig.
[ 21.532106] systemd[1]: could not find module by name='ipv6'
[ 21.555061] systemd[1]: Failed to insert 'ipv6'
