enable CONFIG_NFC and CONFIG_PN544_NFC to support pn544.
Bug 932798
Change-Id: I411edc7dbf97afd050cfe4f68991a2f132886773
Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-on: http://git-master/r/78689
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Bug 926128
Reviewed-on: http://git-master/r/75252
Change-Id: I7f9928ab1efdb82ab73eea595c2a8590057b8c72
Signed-off-by: Om Prakash Singh <omp@nvidia.com>
Reviewed-on: http://git-master/r/78436
Enable Snaptics SPI touch driver which is used for DirectTouch
purposes.
bug 912775
Reviewed-on: http://git-master/r/76379
Change-Id: I2a2bc4dd68c09039dd36b6c8786b8d16ecb35c80
Signed-off-by: Peter Zu <pzu@nvidia.com>
Reviewed-on: http://git-master/r/77776
bug 871603
Reviewed-on: http://git-master/r/72258
Change-Id: I2ff63550fde536ee0e0f1b69b3a58e4f164e62e5
Reviewed-on: http://git-master/r/78027
Reviewed-on: http://git-master/r/77216
Change-Id: I1a9183102bcb1c70956f773101b2cf78c4dc2fc9
Reviewed-on: http://git-master/r/77758
Enable Raydium touch touch driver which is used for
DirectTouchpurposes.
bug 832605
Reviewed-on: http://git-master/r/76385
Change-Id: I633291cf5e11d66709f224292d02e211cca051fd
Reviewed-on: http://git-master/r/77728
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Reviewed-on: http://git-master/r/74496
Change-Id: Icc6316ddddd1e6a7e9634a6539ae48cbbcd87607
Signed-off-by: Johnny Qiu <joqiu@nvidia.com>
Reviewed-on: http://git-master/r/77297
Not used in tegra. With it, the driver continously
spews on console.
Bug: 930042
Change-Id: I6394c1ee1de19bc114006f064d12b987b499d8a6
Reviewed-on: http://git-master/r/#change,61354,patchset=2
(cherry picked from commit 838d4ba231e5bd550114f89cf92c75391416df3b)
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/76969
Modify kernel config flags in tegra3_defconfig and
tegra_defconfig to build the camera drivers as modules.
Bug: 928498
Change-Id: I516618c25e5790dc270a97579a9852c442821eaf
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/76787
Enable CONFIG_SENSORS_NCT1008
Change-Id: I855e68dc30f73ea0e2c7f1c0b1cfbb11a1f8b0e9
Signed-off-by: Wei Ni <wni@nvidia.com>
Reviewed-on: http://git-master/r/75903
Enable CONFIG_NCT1008
Change-Id: I700557b8900401b8f9ab36faab5903ba0afde542
Reviewed-on: http://git-master/r/74564
Reviewed-by: Allen Martin <amartin@nvidia.com>
Reviewed-on: http://git-master/r/76458
Bug 926128
Change-Id: I326e3806a429e031bea78a3e051c22518e705f86
Reviewed-on: http://git-master/r/74973
Reviewed-on: http://git-master/r/75889
bug 924363
Change-Id: Ic5e88e0887d912234e01a759674945524a3350a1
Reviewed-on: http://git-master/r/74258
Signed-off-by: Artiste Hsu <chhsu@nvidia.com>
Reviewed-on: http://git-master/r/75887
Change-Id: I47b9030ebc408ebe546041c8af17136a236433f3
Reviewed-on: http://git-master/r/74946
Signed-off-by: Danny Huang <dahuang@nvidia.com>
Reviewed-on: http://git-master/r/75539
Modify kernel config flag in tegra3_defconfig and tegra_defconfig
to enable usb mass storage gadget driver. This is to enable usb
mass storage gadget driver on L4T for Cardhu/Ventana/Harmony.
Bug: 922561
Change-Id: I2b6e058df60bd2d8ca6fb294765bb8f530b9d944
Reviewed-on: http://git-master/r/74993
CONFIG_BCMDHD was made a part of kernel with configure option(=y)
Its one of the dependency of wifi driver bcm43219 (which is
configured as a module CONDIF_BCM4329(=m)) and gets loaded with the
same module.Making it a part of kernel exposes symbol twice.
Disabling CONFIG_BCMDHD for both AP20 and T30 l4t configs
Bug: 921478
Change-Id: I0c90d2fdee9da7ef97d5ef9197a6d228906bb3bf
Signed-off-by: Shashank Sharma(shashanks@nvidia.com)
Reviewed-on: http://git-master/r/73467
Tested-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-by: Mursalin Akon <makon@nvidia.com>
Bug 921207
Change-Id: Id58bb2c144645a3105a3111ef7ed4eb3da528644
Reviewed-on: http://git-master/r/73719
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/73967
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Bug 920989
Change-Id: Ic1239ee799ac4e80e356ca7b9664f7875af91dce
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/73145
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
(cherry picked from commit 7160189436da41570ad3a69155f0a7f633bd9ca9)
Reviewed-on: http://git-master/r/73961
Build SND_HDA_INTEL as a module. SND_HDA_INTEL is required for
audio on HDMI. Building it with "y" makes it default ALSA device,
which then blocks all multimedia audio use cases.
Bug 921550 922497 922520
Change-Id: I7cf437d10b21d8e99c9e6a783f63399d3b883e75
Signed-Off-By: Rahool Paliwal <rpaliwal@nvidia.com>
Reviewed-on: http://git-master/r/73724
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Enable Cardhu dock Ethernet
Change-Id: Icc2f6329938f74816b304ff32dd7b554f645b088
Reviewed-on: http://git-master/r/70634
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Enabled mtd and yaffs support for harmony
Bug: 921742
Change-Id: I9ccadf8bd568f8c1421351378e94f17a92a6d322
Reviewed-on: http://git-master/r/72870
Added support for SMSC LAN95XX based USB 2.0
Change-Id: Ifa29b83fe5aba5a3d9adf66f5de9d59618384a72
Reviewed-on: http://git-master/r/72750
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
IDT ICS932S401 is not used by Tegra3 reference board.
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Change-Id: I019bad552880aed79d4aaddecca4ebdf2cbb4696
Reviewed-on: http://git-master/r/72080
Majority of bugs on L4T bugs worked on so far were because
of a feature not enabled in L4T defconfig file.
To fix this recurring problem we need to enable all the valid
kernel config options from Android defconfig in L4T as
well (the not-valid config options are Android specific ones
like : ASHMEM, WAKELOCK, and other Android specific options)
Change-Id: Ia85249ca9faf4f0e23ed27d153e1338887e77c6e
Reviewed-on: http://git-master/r/72404
Regenerate defconfig file to reflect current kconfigs.
Change-Id: I0a3ae9deec33e619728a2c3e1cdad8812d6e0b5f
Reviewed-on: http://git-master/r/72129
Regenerate defconfig file to reflect current Kconfigs
Change-Id: Ibb608f9af156d9833904ef691bb06e3773006871
Reviewed-on: http://git-master/r/72105
Touch screen module is not active. Enabling the directive to enable the
Atmel touch screen module.
Bug: 919257
Change-Id: I160136902f4a7dbae6eb4d541ac5bb1ad0a28eae
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/71826
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Remove CONFIG_HOTPLUG_CPU and set CONFIG_SUSPEND
Change-Id: I09278dd9ac0e9f75a17f7e231f83633a2151a410
Reviewed-on: http://git-master/r/71724
Tested-by: Dinesh Israni <disrani@nvidia.com>
Reviewed-by: Krishna Monian <kmonian@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Change-Id: I8fb744ab8997255f779e7bd58571c8d081497851
Reviewed-on: http://git-master/r/71136
bug 909096
Change-Id: I7d82d1f8cd20e54248896559387f4b102fb9a329
Reviewed-on: http://git-master/r/70575
Need to enable it to make power-key wakeup work.
Change-Id: Ic3aa70b977db141a85b2bcc866a621b40d477d8d
Signed-off-by: Bill Huang <bilhuang@nvidia.com>
Reviewed-on: http://git-master/r/69141
enable CONFIG_I2C_CHARDEV variable.
Change-Id: Ie88be13071ecc393907d64f1a155d47134c8df6b
Signed-off-by: Alok Chauhan <alokc@nvidia.com>
Reviewed-on: http://git-master/r/71164
Enable PCI for tegra3
Change-Id: I23cc720632ddb8d48527cdf4daa368500673adff
Reviewed-on: http://git-master/r/70632
Change-Id: I3094e3f781b9fdc3acdea6db20e65bf289ee4de6
Reviewed-on: http://git-master/r/69922
Enabled EMC_SCALING option.
Signed-off-by: Peer Chen <pchen@nvidia.com>
Change-Id: I1a01be4668637c718544fcc6806b4c42a3ad27ae
Reviewed-on: http://git-master/r/70533
Reviewed-by: Simone Willett <swillett@nvidia.com>
Enabled cpu idle option.
Change-Id: I614fddb65f63b143420c7d18d72a1d19c9ea98d2
Reviewed-on: http://git-master/r/70526
Enabled cpu frequency governor option.
Change-Id: I9df41be4a946723549d5af515e7cd4710ca44708
Reviewed-on: http://git-master/r/70522
This CL is to get rid of continuous debug spew.
Change-Id: I9546ff82dcb41c3cd877b4d866d05097581aca85
Reviewed-on: http://git-master/r/70066
Regenerate defconfigs to reflect current Kconfigs
Change-Id: I224833dc80934e2bfa374eaa85e22a70391d3fd2
Reviewed-on: http://git-master/r/70060
bug 902137
Change-Id: I1d92a579672ad5bd93e033000a366b6e5d6b27d9
Signed-off-by: venu byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/70212
Add missing flags to enable multimedia support for T20 on K39.
Bug 909132
Signed-off-by: Jitendra Kumar<jitendrak@nvidia.com>
Change-Id: I943138eac72662912889c9fa6f04a5b23cf45bb3
Reviewed-on: http://git-master/r/68898
Add flags to enable support for TEGRA NVAVP driver required for NvMMLite/TVMR
on K39. Also disable the support for AVP multimedia offload engine and
Tegra Media Serversupport.
Bug 908933
Signed-off-by Jitendra Kumar<jitendrak@nvidia.com>
Change-Id: I085dea2415927ef537648d8dd1ea77ba57e6064d
Reviewed-on: http://git-master/r/68894
Software SH256 Cryptographic hash algorithm is needed
to support basic software encryption functionality.
Bug 882031
Change-Id: I05c9452ee6283e2cac1cf0049e5446b2556d7dd5
Reviewed-on: http://git-master/r/69745
Bug 886459
Change-Id: I9ffce0e0186cace45c403ae6880f3460ed3ede47
Signed-off-by: Raj Jayaraman <rjayaraman@nvidia.com>
Reviewed-on: http://git-master/r/68307
Bug 886459
Change-Id: Id6efa14da2de776208fba2fe58624c79cca809ed
Reviewed-on: http://git-master/r/68285
Add kernel config flags in "tegra_defconfig" & "tegra3_defconfig" to enable
camera sensor,focuser & torch devices.
This is to enable Camera capture on L4T with T20 Ventana & T30 Cardhu.
Bug 869132 & 880107
Change-Id: Ib81908881c8936e7b3dd7ebdcfd9bba006aa343f
Cherry-picked From : f09adb0d15f0991d0e7116f7a1092339bf92f9e9
Reviewed-on: http://git-master/r/55977
Signed-off-by: Amit Pandya <apandya@nvidia.com>
Reviewed-on: http://git-master/r/68165
enable CONFIG_KEYBOARD_GPIO in tegra_defconfig
enable CONFIG_KEYBOARD_GPIO in tegra3_defconfig
bug 910846
Change-Id: Idcb87128736f8576be738ca45bbae9ea98e40510
Reviewed-on: http://git-master/r/69706
Enable backlight pwm control in tegra_defconfig
bug 910846
Change-Id: Ieb24bbde8553bbac39d0858e2db8cbbd87d81122
Reviewed-on: http://git-master/r/69705
Pcie powermanagement issues are yet to be resolved,
so modifying the defconfig to not to enable the
driver by default
bug: 878874
Change-Id: Ie8787342b1ccf9e22486129633d15d566d50e4e0
Signed-off-by: Krishna Kishore <kthota@nvidia.com>
Reviewed-on: http://git-master/r/64772
Bug 909788
Change-Id: I903c26b1d3864ce91b4c519ff1af17993a79f248
Reviewed-on: http://git-master/r/69139
