Let the kernel print some debug messages when a user program
crashes due to an exception.
Add user crypto to defconfigs.
Integrate Atmel MXT multitouch controller driver which is interfaced
over I2C bus. The driver supports the 7" multitouch variant available
from Logic Technologies.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Prepare for snapd integration.
Rather than the TPS65910 driver the TPS6591X one is in use and to avoid
any confusion we drop the former completely.
As ext4 is known to cause issues on that ancient NVIDIA L4T kernel just
disable it in favour of ext3 which is known to be working fine.
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Integrate Epson S2D13P04 video decoder support.
Modularise our Wi-Fi configuration meaning build support for our
former Ralink RT3070 based Ambicom WL250N as module as well plus
while at it enable support for newer Ralink RT5370 based common
Wi-Fi USB sticks as well.
Compile USB device classes such as WDM and CDC ACM as modules.
Enable USB driver for GSM and CDMA modems (Option and others).
Also enable USB serial console option which allows to use a USB
serial device as a serial console at boot time.
Enable RTL8192CU driver to support LM006 USB WiFi adapter.
Integrate OV5640 CSI camera sensor support.
Bring the kernel module configuration more in line with what we
currently really deploy. As a second step we can then change the way
kernel modules are actually deployed by just deploying them all.
CONFIG_SATA_AHCI=m
This allows using PCIe cards with a SATA interface.
drivers/mtd/ubi/ubi.h
drivers/mtd/ubi/wl.c
Enable module versioning support (CONFIG_MODVERSIONS and
CONFIG_MODULE_SRCVERSION_ALL) which allows using kernel modules across
different kernel builds/versions.
While at it also update the Android configurations.
Change-Id: I40a8481618b1a5995a713ff343c7532badd20b65
Change-Id: I399302118c9d8d8246a4a304ff7a1ea80889dbc6
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45568
Reviewed-by: Ban Feng <Ban_Feng@asus.com>
Tested-by: Ban Feng <Ban_Feng@asus.com>
Reviewed-by: Sam hblee <Sam_hblee@asus.com>
(cherry picked from commit 121c0c6dffe16c683f4dbf00ed841fb4de1f70a0)
drivers/mmc/core/mmc.c
This patch adds optional UHS support for the 8-bit MMC controller.
Please note that this requires V1.1A or later module hardware plus the
pull-up resistors on the data as well as the command signal lines of
your carrier board need to be removed (e.g. R46 to R54 on our Apalis
Evaluation Board V1.1A). If those pre-requisites are met support can be
enabled using the following kernel command line parameter:
mmc_uhs=1
Enable VLAN networking functionality.
While at it also enable some more kernel modules for Apalis T30 PCIe
based devices like the Intel E1000E NICs, Intel IWLAGN Wi-Fi cards,
PCIe serial cards and XHCI based USB 3.0 controllers.
Use HDA HDMI audio now on Colibri T30 as well allowing for up to 7.1
multi-channel playback. Split board sound initialisation between Apalis
and Colibri T30 in order to distinguish better between default SPDIF
being supported out-of-the-box on Apalis vs. this being an optional
feature for the Colibri. Therefore remove SPDIF for the Colibri T30.
While at it add csus clock required for vi_sensor camera master clock
on Apalis T30 and clk_out_2/extern2 for Colibri T30, fix debug UART1
initialisation, get rid of spurious CONFIG_SND_USB enable and further
clean-up both board platform data files.
Enable CONFIG_FHANDLE required for systemd >= 209 according to
lists.freedesktop.org/archives/systemd-devel/2014-February/017362.html
While at it put them all 3 on par concerning ARM Errata configuration.
Enable IEEE 1588 precision time protocol (PTP) support.
drivers/media/video/tegra_v4l2_camera.c
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
Activate Fusion touchscreen driver. Use GPIO 5/6 as pen down/reset
GPIO and provide a helper function to free the GPIO before the
driver requests them.
Fusion touchscreen driver now uses platform data to do GPIO
initialization by itself. Make use of this by providing GPIO numbers
instead of doing initialization in the board initialization.
Disable hardware statistics monitor for AVP due to it completely
hanging upon boot on certain Colibri T20 V1.2a modules.
Make use of the new STMPE ADC driver to expose the four free ADC
channels on the STMPE811 to userspace.
This reverts commit dd9a841da571a41d43f1eeaac1785b2adb1d80f3.
The config changes (for V4L2) can be done manually as per need
basis for V4L2, followed by compiling the kernel.
Change-Id: I9174bce0f3da2974ab703b238dfb8fb3bbf607c5
Signed-off-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-on: http://git-master/r/327607
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
- Disables TEGRA_CAMERA
- Enables SOC_CAMERA and OV5640 sensor support
Bug 1369083
Change-Id: I073c226e9f04a6f4f4699051f624a755dceb36cb
Reviewed-on: http://git-master/r/309491
If the boot console is RS232 and RX is left floating this leads
to arbitrary sys requests including reboots...
(RX is left floating on the evaluation boards if USB to serial is
jumpered but USB is not connected)
The firmware is not being in use currently.
So, turn the loading code off.
Bug 1236060
Bug 991551
Change-Id: Id41cf762b59502d0ece470e315ac75d93e3b6b39
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/218613
(cherry picked from commit f15976bdfb32d6c5e20057f6d4d57646c15a5591)
Reviewed-on: http://git-master/r/258354
GVS: Gerrit_Virtual_Submit
Enable the modular camera configuration for ACM which allows switching
not only decoders but also their inputs at run-time.
This is the only correct order to load the modules:
modprobe videobuf2-memops
modprobe videobuf2-dma-nvmap
modprobe max9526
# or modprobe adv7180
modprobe tegra_v4l2_camera
To change the decoder on the fly:
rmmod tegra_v4l2_camera
rmmod max9526
# or rmmod adv7180
modprobe adv7180
# or modprobe max9526
To get a pre-view window through gstreamer:
gst-launch v4l2src ! deinterlace tff=1 method=4 ! nv_omx_videomixer !
nv_gl_eglimagesink
To switch inputs (0-5 resp. 0-4 for ADV7180 and 0-2 for MAX9526 where 2
means auto selection):
v4l2-ctl -i 0
v4l2-ctl -i 1
v4l2-ctl -i 2
v4l2-ctl -i 3
v4l2-ctl -i 4
v4l2-ctl -i 5
To check what input is active:
v4l2-ctl -I
While at it enable NVIDIA confirmed ARM errata 716044 and 720789 as
well.
Enable PCI quirk support resp. don't explicitly disable it in order for
the following fix to take effect.
The Apalis evaluation board needs to set the link speed to 2.5 GT/s
(GEN1). The default link speed setting is 5 GT/s (GEN2). 0x98 is the
Link Control 2 PCIe Capability Register of the PEX8605 PCIe switch. The
switch supports link speed auto negotiation, but falsely sets the link
speed to 5 GT/s.
Integrate ADV7180 and MAX9526 video decoder support and prepare for
drivers as modules.
The following gstreamer pipeline shows a preview window:
nv_gl_eglimagesink
Add initial Android kernel configuration adopted from
tegra_android_defconfig.
Integrate support for the Realtek ALC898 as found on the Apalis
Evaluation Board V1.0a.
Please note that the following HDA rewiring needs to be done:
remove jumpers X6-5 and 7 to 9
rewire as follows:
X5 X7
5 9
7 8
8 5
9 7
Please further note that currently only noise is heard during playback.
Disabled CONFIG_INPUT_MOUSEDEV to avoid kernel registering PS/2 mouse
devices, which are mostly not in use now.
Bug 1162832
Change-Id: I0b44af668fa94ffc589e646a842259afa837731e
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
Reviewed-on: http://git-master/r/187807
Bug 1162832
Change-Id: If47e654063934d3b60d033a0d2523b8caf97825b
Reviewed-on: http://git-master/r/187808
tegra3_android_defconfig.
