path: root/arch/arm/include/asm/cpu.h
2010-01-10ARM: 5872/1: ARM: include needed linux/cpu.h in asm/cpu.hSantosh Shilimkar
The file arch/arm/include/asm/cpu.h needs to include 'linux/cpu.h' to meet its dependency. Otherwise when using "struct cpuinfo_arm" and including just 'asm/cpu.h' throws below error - arch/arm/include/asm/cpu.h:16: error: field 'cpu' has incomplete type To fix this otherway, one can also include both linux/cpu.h and asm/cpu.h but it shoudn't be that way. So this patch fixes this by including the linux/cpu.h in asm/cpu.h, so that including alone asm/cpu.h is enough. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-02[ARM] move include/asm-arm to arch/arm/include/asmRussell King
Move platform independent header files to arch/arm/include/asm, leaving those in asm/arch* and asm/plat* alone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
