path: root/arch/arm/include/uapi
2015-04-26Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull second batch of KVM changes from Paolo Bonzini: "This mostly includes the PPC changes for 4.1, which this time cover Book3S HV only (debugging aids, minor performance improvements and some cleanups). But there are also bug fixes and small cleanups for ARM, x86 and s390. The task_migration_notifier revert and real fix is still pending review, but I'll send it as soon as possible after -rc1" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (29 commits) KVM: arm/arm64: check IRQ number on userland injection KVM: arm: irqfd: fix value returned by kvm_irq_map_gsi KVM: VMX: Preserve host CR4.MCE value while in guest mode. KVM: PPC: Book3S HV: Use msgsnd for signalling threads on POWER8 KVM: PPC: Book3S HV: Translate kvmhv_commence_exit to C KVM: PPC: Book3S HV: Streamline guest entry and exit KVM: PPC: Book3S HV: Use bitmap of active threads rather than count KVM: PPC: Book3S HV: Use decrementer to wake napping threads KVM: PPC: Book3S HV: Don't wake thread with no vcpu on guest IPI KVM: PPC: Book3S HV: Get rid of vcore nap_count and n_woken KVM: PPC: Book3S HV: Move vcore preemption point up into kvmppc_run_vcpu KVM: PPC: Book3S HV: Minor cleanups KVM: PPC: Book3S HV: Simplify handling of VCPUs that need a VPA update KVM: PPC: Book3S HV: Accumulate timing information for real-mode code KVM: PPC: Book3S HV: Create debugfs file for each guest's HPT KVM: PPC: Book3S HV: Add ICP real mode counters KVM: PPC: Book3S HV: Move virtual mode ICP functions to real-mode KVM: PPC: Book3S HV: Convert ICS mutex lock to spin lock KVM: PPC: Book3S HV: Add guest->host real mode completion counters KVM: PPC: Book3S HV: Add helpers for lock/unlock hpte ...
2015-04-22KVM: arm/arm64: check IRQ number on userland injectionAndre Przywara
When userland injects a SPI via the KVM_IRQ_LINE ioctl we currently only check it against a fixed limit, which historically is set to 127. With the new dynamic IRQ allocation the effective limit may actually be smaller (64). So when now a malicious or buggy userland injects a SPI in that range, we spill over on our VGIC bitmaps and bytemaps memory. I could trigger a host kernel NULL pointer dereference with current mainline by injecting some bogus IRQ number from a hacked kvmtool: ----------------- .... DEBUG: kvm_vgic_inject_irq(kvm, cpu=0, irq=114, level=1) DEBUG: vgic_update_irq_pending(kvm, cpu=0, irq=114, level=1) DEBUG: IRQ #114 still in the game, writing to bytemap now... Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = ffffffc07652e000 [00000000] *pgd=00000000f658b003, *pud=00000000f658b003, *pmd=0000000000000000 Internal error: Oops: 96000006 [#1] PREEMPT SMP Modules linked in: CPU: 1 PID: 1053 Comm: lkvm-msi-irqinj Not tainted 4.0.0-rc7+ #3027 Hardware name: FVP Base (DT) task: ffffffc0774e9680 ti: ffffffc0765a8000 task.ti: ffffffc0765a8000 PC is at kvm_vgic_inject_irq+0x234/0x310 LR is at kvm_vgic_inject_irq+0x30c/0x310 pc : [<ffffffc0000ae0a8>] lr : [<ffffffc0000ae180>] pstate: 80000145 ..... So this patch fixes this by checking the SPI number against the actual limit. Also we remove the former legacy hard limit of 127 in the ioctl code. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> CC: <stable@vger.kernel.org> # 4.0, 3.19, 3.18 [maz: wrap KVM_ARM_IRQ_GIC_MAX with #ifndef __KERNEL__, as suggested by Christopher Covington] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-04-14Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this update are both some long term fixes and some new features. Fixes: - An integer overflow in the calculation of ELF_ET_DYN_BASE. - Avoiding OOMs for high-order IOMMU allocations - SMP requires the data cache to be enabled for synchronisation primitives to work, so prevent the CPU_DCACHE_DISABLE option being visible on SMP builds. - A bug going back 10+ years in the noMMU ARM94* CPU support code, where it corrupts registers. Found by folk getting Linux running on their cameras. - Versatile Express needs an errata workaround enabled for CPU hot-unplug to work. Features: - Clean up module linker by handling out of range relocations separately from relocation cases we don't handle. - Fix a long term bug in the pci_mmap_page_range() code, which we hope won't impact userspace (we hope there's no users of the existing broken interface.) - Don't map DMA coherent allocations when we don't have a MMU. - Drop experimental status for SMP_ON_UP. - Warn when DT doesn't specify ePAPR mandatory cache properties. - Add documentation concerning how we find the start of physical memory for AUTO_ZRELADDR kernels, detailing why we have chosen the mask and the implications of changing it. - Updates from Ard Biesheuvel to address some issues with large kernels (such as allyesconfig) failing to link. - Allow hibernation to work on modern (ARMv7) CPUs - this appears to have never worked in the past on these CPUs. - Enable IRQ_SHOW_LEVEL, which changes the /proc/interrupts output format (hopefully without userspace breaking... let's hope that if it causes someone a problem, they tell us.) - Fix tegra-ahb DT offsets. - Rework ARM errata 643719 code (and ARMv7 flush_cache_louis()/ flush_dcache_all()) code to be more efficient, and enable this errata workaround by default for ARMv7+SMP CPUs. This complements the Versatile Express fix above. - Rework ARMv7 context code for errata 430973, so that only Cortex A8 CPUs are impacted by the branch target buffer flush when this errata is enabled. Also update the help text to indicate that all r1p* A8 CPUs are impacted. - Switch ARM to the generic show_mem() implementation, it conveys all the information which we were already reporting. - Prevent slow timer sources being used for udelay() - timers running at less than 1MHz are not useful for this, and can cause udelay() to return immediately, without any wait. Using such a slow timer is silly. - VDSO support for 32-bit ARM, mainly for gettimeofday() using the ARM architected timer. - Perf support for Scorpion performance monitoring units" vdso semantic conflict fixed up as per linux-next. * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (52 commits) ARM: update errata 430973 documentation to cover Cortex A8 r1p* ARM: ensure delay timer has sufficient accuracy for delays ARM: switch to use the generic show_mem() implementation ARM: proc-v7: avoid errata 430973 workaround for non-Cortex A8 CPUs ARM: enable ARM errata 643719 workaround by default ARM: cache-v7: optimise test for Cortex A9 r0pX devices ARM: cache-v7: optimise branches in v7_flush_cache_louis ARM: cache-v7: consolidate initialisation of cache level index ARM: cache-v7: shift CLIDR to extract appropriate field before masking ARM: cache-v7: use movw/movt instructions ARM: allow 16-bit instructions in ALT_UP() ARM: proc-arm94*.S: fix setup function ARM: vexpress: fix CPU hotplug with CT9x4 tile. ARM: 8276/1: Make CPU_DCACHE_DISABLE depend on !SMP ARM: 8335/1: Documentation: DT bindings: Tegra AHB: document the legacy base address ARM: 8334/1: amba: tegra-ahb: detect and correct bogus base address ARM: 8333/1: amba: tegra-ahb: fix register offsets in the macros ARM: 8339/1: Enable CONFIG_GENERIC_IRQ_SHOW_LEVEL ARM: 8338/1: kexec: Relax SMP validation to improve DT compatibility ARM: 8337/1: mm: Do not invoke OOM for higher order IOMMU DMA allocations ...
2015-03-27ARM: 8329/1: miscellaneous vdso infrastructure, preparationNathan Lynch
Define the layout of the data structure shared between kernel and userspace. Track the vdso address in the mm_context; needed for communicating AT_SYSINFO_EHDR to the ELF loader. Add declarations for arm_install_vdso; implementation is in a following patch. Define AT_SYSINFO_EHDR, and, if CONFIG_VDSO=y, report the vdso shared object address via the ELF auxiliary vector. Note - this adds the AT_SYSINFO_EHDR in a new user-visible header asm/auxvec.h; this is consistent with other architectures. Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-03-12KVM: arm/arm64: add irqfd supportEric Auger
This patch enables irqfd on arm/arm64. Both irqfd and resamplefd are supported. Injection is implemented in vgic.c without routing. This patch enables CONFIG_HAVE_KVM_EVENTFD and CONFIG_HAVE_KVM_IRQFD. KVM_CAP_IRQFD is now advertised. KVM_CAP_IRQFD_RESAMPLE capability automatically is advertised as soon as CONFIG_HAVE_KVM_IRQFD is set. Irqfd injection is restricted to SPI. The rationale behind not supporting PPI irqfd injection is that any device using a PPI would be a private-to-the-CPU device (timer for instance), so its state would have to be context-switched along with the VCPU and would require in-kernel wiring anyhow. It is not a relevant use case for irqfds. Signed-off-by: Eric Auger <eric.auger@linaro.org> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-02-13Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM update from Paolo Bonzini: "Fairly small update, but there are some interesting new features. Common: Optional support for adding a small amount of polling on each HLT instruction executed in the guest (or equivalent for other architectures). This can improve latency up to 50% on some scenarios (e.g. O_DSYNC writes or TCP_RR netperf tests). This also has to be enabled manually for now, but the plan is to auto-tune this in the future. ARM/ARM64: The highlights are support for GICv3 emulation and dirty page tracking s390: Several optimizations and bugfixes. Also a first: a feature exposed by KVM (UUID and long guest name in /proc/sysinfo) before it is available in IBM's hypervisor! :) MIPS: Bugfixes. x86: Support for PML (page modification logging, a new feature in Broadwell Xeons that speeds up dirty page tracking), nested virtualization improvements (nested APICv---a nice optimization), usual round of emulation fixes. There is also a new option to reduce latency of the TSC deadline timer in the guest; this needs to be tuned manually. Some commits are common between this pull and Catalin's; I see you have already included his tree. Powerpc: Nothing yet. The KVM/PPC changes will come in through the PPC maintainers, because I haven't received them yet and I might end up being offline for some part of next week" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits) KVM: ia64: drop kvm.h from installed user headers KVM: x86: fix build with !CONFIG_SMP KVM: x86: emulate: correct page fault error code for NoWrite instructions KVM: Disable compat ioctl for s390 KVM: s390: add cpu model support KVM: s390: use facilities and cpu_id per KVM KVM: s390/CPACF: Choose crypto control block format s390/kernel: Update /proc/sysinfo file with Extended Name and UUID KVM: s390: reenable LPP facility KVM: s390: floating irqs: fix user triggerable endless loop kvm: add halt_poll_ns module parameter kvm: remove KVM_MMIO_SIZE KVM: MIPS: Don't leak FPU/DSP to guest KVM: MIPS: Disable HTW while in guest KVM: nVMX: Enable nested posted interrupt processing KVM: nVMX: Enable nested virtual interrupt delivery KVM: nVMX: Enable nested apic register virtualization KVM: nVMX: Make nested control MSRs per-cpu KVM: nVMX: Enable nested virtualize x2apic mode KVM: nVMX: Prepare for using hardware MSR bitmap ...
2015-01-11KVM: arm/arm64: vgic: add init entry to VGIC KVM deviceEric Auger
Since the advent of VGIC dynamic initialization, this latter is initialized quite late on the first vcpu run or "on-demand", when injecting an IRQ or when the guest sets its registers. This initialization could be initiated explicitly much earlier by the users-space, as soon as it has provided the requested dimensioning parameters. This patch adds a new entry to the VGIC KVM device that allows the user to manually request the VGIC init: - a new KVM_DEV_ARM_VGIC_GRP_CTRL group is introduced. - Its first attribute is KVM_DEV_ARM_VGIC_CTRL_INIT The rationale behind introducing a group is to be able to add other controls later on, if needed. Signed-off-by: Eric Auger <eric.auger@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-01-07ARM: wire up execveat syscallRussell King
2014-10-29ARM: enable bpf syscallRussell King
2014-09-18arm/arm64: KVM: vgic: make number of irqs a configurable attributeMarc Zyngier
In order to make the number of interrupts configurable, use the new fancy device management API to add KVM_DEV_ARM_VGIC_GRP_NR_IRQS as a VGIC configurable attribute. Userspace can now specify the exact size of the GIC (by increments of 32 interrupts). Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-08-27arm/arm64: KVM: Support KVM_CAP_READONLY_MEMChristoffer Dall
When userspace loads code and data in a read-only memory regions, KVM needs to be able to handle this on arm and arm64. Specifically this is used when running code directly from a read-only flash device; the common scenario is a UEFI blob loaded with the -bios option in QEMU. Note that the MMIO exit on writes to a read-only memory is ABI and can be used to emulate block-erase style flash devices. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-08-09ARM: wire up memfd_create syscallRussell King
Add the memfd_create syscall to ARM. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-08-09ARM: wire up getrandom syscallRussell King
Add the new getrandom syscall for ARM. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-08-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this release: - PKCS#7 parser for the key management subsystem from David Howells - appoint Kees Cook as seccomp maintainer - bugfixes and general maintenance across the subsystem" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (94 commits) X.509: Need to export x509_request_asymmetric_key() netlabel: shorter names for the NetLabel catmap funcs/structs netlabel: fix the catmap walking functions netlabel: fix the horribly broken catmap functions netlabel: fix a problem when setting bits below the previously lowest bit PKCS#7: X.509 certificate issuer and subject are mandatory fields in the ASN.1 tpm: simplify code by using %*phN specifier tpm: Provide a generic means to override the chip returned timeouts tpm: missing tpm_chip_put in tpm_get_random() tpm: Properly clean sysfs entries in error path tpm: Add missing tpm_do_selftest to ST33 I2C driver PKCS#7: Use x509_request_asymmetric_key() Revert "selinux: fix the default socket labeling in sock_graft()" X.509: x509_request_asymmetric_keys() doesn't need string length arguments PKCS#7: fix sparse non static symbol warning KEYS: revert encrypted key change ima: add support for measuring and appraising firmware firmware_class: perform new LSM checks security: introduce kernel_fw_from_file hook PKCS#7: Missing inclusion of linux/err.h ...
2014-07-18ARM: add seccomp syscallKees Cook
Wires up the new seccomp syscall. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Oleg Nesterov <oleg@redhat.com>
2014-07-18ARM: 8097/1: unistd.h: relocate comments back to placeBaruch Siach
Commit cb8db5d45 (UAPI: (Scripted) Disintegrate arch/arm/include/asm) moved these syscall comments out of their context into the UAPI headers. Fix this. Fixes: cb8db5d4578a ("UAPI: (Scripted) Disintegrate arch/arm/include/asm") Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm into nextLinus Torvalds
Pull KVM updates from Paolo Bonzini: "At over 200 commits, covering almost all supported architectures, this was a pretty active cycle for KVM. Changes include: - a lot of s390 changes: optimizations, support for migration, GDB support and more - ARM changes are pretty small: support for the PSCI 0.2 hypercall interface on both the guest and the host (the latter acked by Catalin) - initial POWER8 and little-endian host support - support for running u-boot on embedded POWER targets - pretty large changes to MIPS too, completing the userspace interface and improving the handling of virtualized timer hardware - for x86, a larger set of changes is scheduled for 3.17. Still, we have a few emulator bugfixes and support for running nested fully-virtualized Xen guests (para-virtualized Xen guests have always worked). And some optimizations too. The only missing architecture here is ia64. It's not a coincidence that support for KVM on ia64 is scheduled for removal in 3.17" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (203 commits) KVM: add missing cleanup_srcu_struct KVM: PPC: Book3S PR: Rework SLB switching code KVM: PPC: Book3S PR: Use SLB entry 0 KVM: PPC: Book3S HV: Fix machine check delivery to guest KVM: PPC: Book3S HV: Work around POWER8 performance monitor bugs KVM: PPC: Book3S HV: Make sure we don't miss dirty pages KVM: PPC: Book3S HV: Fix dirty map for hugepages KVM: PPC: Book3S HV: Put huge-page HPTEs in rmap chain for base address KVM: PPC: Book3S HV: Fix check for running inside guest in global_invalidates() KVM: PPC: Book3S: Move KVM_REG_PPC_WORT to an unused register number KVM: PPC: Book3S: Add ONE_REG register names that were missed KVM: PPC: Add CAP to indicate hcall fixes KVM: PPC: MPIC: Reset IRQ source private members KVM: PPC: Graciously fail broken LE hypercalls PPC: ePAPR: Fix hypercall on LE guest KVM: PPC: BOOK3S: Remove open coded make_dsisr in alignment handler KVM: PPC: BOOK3S: Always use the saved DAR value PPC: KVM: Make NX bit available with magic page KVM: PPC: Disable NX for old magic page using guests KVM: PPC: BOOK3S: HV: Add mixed page-size support for guest ...
2014-04-30ARM/ARM64: KVM: Add base for PSCI v0.2 emulationAnup Patel
Currently, the in-kernel PSCI emulation provides PSCI v0.1 interface to VCPUs. This patch extends current in-kernel PSCI emulation to provide PSCI v0.2 interface to VCPUs. By default, ARM/ARM64 KVM will always provide PSCI v0.1 interface for keeping the ABI backward-compatible. To select PSCI v0.2 interface for VCPUs, the user space (i.e. QEMU or KVMTOOL) will have to set KVM_ARM_VCPU_PSCI_0_2 feature when doing VCPU init using KVM_ARM_VCPU_INIT ioctl. Signed-off-by: Anup Patel <anup.patel@linaro.org> Signed-off-by: Pranavkumar Sawargaonkar <pranavkumar@linaro.org> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-04-23ARM: add renameat2 syscallMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> [dropped arch/arm/include/asm/unistd.h changes --rmk] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-25ARM: 7982/1: introduce HWCAP2 feature bits for ARMv8 Crypto ExtensionsArd Biesheuvel
This allocates feature bits 0-4 in HWCAP2 for the crypto and CRC extensions introduced in ARMv8. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-25ARM: 7981/1: add support for AT_HWCAP2 ELF auxv entryArd Biesheuvel
This enables AT_HWCAP2 for ARM. The generic support for this new ELF auxv entry was added in commit 2171364d1a9 (powerpc: Add HWCAP2 aux entry) Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-01-22Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "First round of KVM updates for 3.14; PPC parts will come next week. Nothing major here, just bugfixes all over the place. The most interesting part is the ARM guys' virtualized interrupt controller overhaul, which lets userspace get/set the state and thus enables migration of ARM VMs" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits) kvm: make KVM_MMU_AUDIT help text more readable KVM: s390: Fix memory access error detection KVM: nVMX: Update guest activity state field on L2 exits KVM: nVMX: Fix nested_run_pending on activity state HLT KVM: nVMX: Clean up handling of VMX-related MSRs KVM: nVMX: Add tracepoints for nested_vmexit and nested_vmexit_inject KVM: nVMX: Pass vmexit parameters to nested_vmx_vmexit KVM: nVMX: Leave VMX mode on clearing of feature control MSR KVM: VMX: Fix DR6 update on #DB exception KVM: SVM: Fix reading of DR6 KVM: x86: Sync DR7 on KVM_SET_DEBUGREGS add support for Hyper-V reference time counter KVM: remove useless write to vcpu->hv_clock.tsc_timestamp KVM: x86: fix tsc catchup issue with tsc scaling KVM: x86: limit PIT timer frequency KVM: x86: handle invalid root_hpa everywhere kvm: Provide kvm_vcpu_eligible_for_directed_yield() stub kvm: vfio: silence GCC warning KVM: ARM: Remove duplicate include arm/arm64: KVM: relax the requirements of VMA alignment for THP ...
2014-01-13sched: Add new scheduler syscalls to support an extended scheduling ↵Dario Faggioli
parameters ABI Add the syscalls needed for supporting scheduling algorithms with extended scheduling parameters (e.g., SCHED_DEADLINE). In general, it makes possible to specify a periodic/sporadic task, that executes for a given amount of runtime at each instance, and is scheduled according to the urgency of their own timing constraints, i.e.: - a (maximum/typical) instance execution time, - a minimum interval between consecutive instances, - a time constraint by which each instance must be completed. Thus, both the data structure that holds the scheduling parameters of the tasks and the system calls dealing with it must be extended. Unfortunately, modifying the existing struct sched_param would break the ABI and result in potentially serious compatibility issues with legacy binaries. For these reasons, this patch: - defines the new struct sched_attr, containing all the fields that are necessary for specifying a task in the computational model described above; - defines and implements the new scheduling related syscalls that manipulate it, i.e., sched_setattr() and sched_getattr(). Syscalls are introduced for x86 (32 and 64 bits) and ARM only, as a proof of concept and for developing and testing purposes. Making them available on other architectures is straightforward. Since no "user" for these new parameters is introduced in this patch, the implementation of the new system calls is just identical to their already existing counterpart. Future patches that implement scheduling policies able to exploit the new data structure must also take care of modifying the sched_*attr() calls accordingly with their own purposes. Signed-off-by: Dario Faggioli <raistlin@linux.it> [ Rewrote to use sched_attr. ] Signed-off-by: Juri Lelli <juri.lelli@gmail.com> [ Removed sched_setscheduler2() for now. ] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1383831828-15501-3-git-send-email-juri.lelli@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-21KVM: arm-vgic: Add vgic reg access from dev attrChristoffer Dall
Add infrastructure to handle distributor and cpu interface register accesses through the KVM_{GET/SET}_DEVICE_ATTR interface by adding the KVM_DEV_ARM_VGIC_GRP_DIST_REGS and KVM_DEV_ARM_VGIC_GRP_CPU_REGS groups and defining the semantics of the attr field to be the MMIO offset as specified in the GICv2 specs. Missing register accesses or other changes in individual register access functions to support save/restore of the VGIC state is added in subsequent patches. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Set base addr through device APIChristoffer Dall
Support setting the distributor and cpu interface base addresses in the VM physical address space through the KVM_{SET,GET}_DEVICE_ATTR API in addition to the ARM specific API. This has the added benefit of being able to share more code in user space and do things in a uniform manner. Also deprecate the older API at the same time, but backwards compatibility will be maintained. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21ARM/KVM: save and restore generic timer registersAndre Przywara
For migration to work we need to save (and later restore) the state of each core's virtual generic timer. Since this is per VCPU, we can use the [gs]et_one_reg ioctl and export the three needed registers (control, counter, compare value). Though they live in cp15 space, we don't use the existing list, since they need special accessor functions and the arch timer is optional. Acked-by: Marc Zynger <marc.zyngier@arm.com> Signed-off-by: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-11-15Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Paolo Bonzini: "Here are the 3.13 KVM changes. There was a lot of work on the PPC side: the HV and emulation flavors can now coexist in a single kernel is probably the most interesting change from a user point of view. On the x86 side there are nested virtualization improvements and a few bugfixes. ARM got transparent huge page support, improved overcommit, and support for big endian guests. Finally, there is a new interface to connect KVM with VFIO. This helps with devices that use NoSnoop PCI transactions, letting the driver in the guest execute WBINVD instructions. This includes some nVidia cards on Windows, that fail to start without these patches and the corresponding userspace changes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits) kvm, vmx: Fix lazy FPU on nested guest arm/arm64: KVM: PSCI: propagate caller endianness to the incoming vcpu arm/arm64: KVM: MMIO support for BE guest kvm, cpuid: Fix sparse warning kvm: Delete prototype for non-existent function kvm_check_iopl kvm: Delete prototype for non-existent function complete_pio hung_task: add method to reset detector pvclock: detect watchdog reset at pvclock read kvm: optimize out smp_mb after srcu_read_unlock srcu: API for barrier after srcu read unlock KVM: remove vm mmap method KVM: IOMMU: hva align mapping page size KVM: x86: trace cpuid emulation when called from emulator KVM: emulator: cleanup decode_register_operand() a bit KVM: emulator: check rex prefix inside decode_register() KVM: x86: fix emulation of "movzbl %bpl, %eax" kvm_host: typo fix KVM: x86: emulate SAHF instruction MAINTAINERS: add tree for kvm.git Documentation/kvm: add a 00-INDEX file ...
2013-11-14Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this series are: 1. BE8 (modern big endian) changes for ARM from Ben Dooks 2. big.Little support from Nicolas Pitre and Dave Martin 3. support for LPAE systems with all system memory above 4GB 4. Perf updates from Will Deacon 5. Additional prefetching and other performance improvements from Will. 6. Neon-optimised AES implementation fro Ard. 7. A number of smaller fixes scattered around the place. There is a rather horrid merge conflict in tools/perf - I was never notified of the conflict because it originally occurred between Will's tree and other stuff. Consequently I have a resolution which Will forwarded me, which I'll forward on immediately after sending this mail. The other notable thing is I'm expecting some build breakage in the crypto stuff on ARM only with Ard's AES patches. These were merged into a stable git branch which others had already pulled, so there's little I can do about this. The problem is caused because these patches have a dependency on some code in the crypto git tree - I tried requesting a branch I can pull to resolve these, and all I got each time from the crypto people was "we'll revert our patches then" which would only make things worse since I still don't have the dependent patches. I've no idea what's going on there or how to resolve that, and since I can't split these patches from the rest of this pull request, I'm rather stuck with pushing this as-is or reverting Ard's patches. Since it should "come out in the wash" I've left them in - the only build problems they seem to cause at the moment are with randconfigs, and since it's a new feature anyway. However, if by -rc1 the dependencies aren't in, I think it'd be best to revert Ard's patches" I resolved the perf conflict roughly as per the patch sent by Russell, but there may be some differences. Any errors are likely mine. Let's see how the crypto issues work out.. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits) ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h" ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg(). ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h ARM: 7871/1: amba: Extend number of IRQS ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise() ARM: 7872/1: Support arch_irq_work_raise() via self IPIs ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode ARM: 7878/1: nommu: Implement dummy early_paging_init() ARM: 7876/1: clear Thumb-2 IT state on exception handling ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}() ARM: footbridge: fix build warnings for netwinder ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu ARM: fix misplaced arch_virt_to_idmap() ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation ARM: 7869/1: remove unused XSCALE_PMU Kconfig param ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments ARM: 7862/1: pcpu: replace __get_cpu_var_uses ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code ...
2013-10-12KVM: ARM: Add support for Cortex-A7Jonathan Austin
This patch adds support for running Cortex-A7 guests on Cortex-A7 hosts. As Cortex-A7 is architecturally compatible with A15, this patch is largely just generalising existing code. Areas where 'implementation defined' behaviour is identical for A7 and A15 is moved to allow it to be used by both cores. The check to ensure that coprocessor register tables are sorted correctly is also moved in to 'common' code to avoid each new cpu doing its own check (and possibly forgetting to do so!) Signed-off-by: Jonathan Austin <jonathan.austin@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-09-30ARM: perf: add support for perf registers APIWill Deacon
This patch implements the functions required for the perf registers API, allowing the perf tool to interface kernel register dumps with libunwind in order to provide userspace backtracing. Cc: Jean Pihet <jean.pihet@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-09-26ARM: arch_timer: add support to configure and enable event streamSudeep KarkadaNagesha
This patch adds support for configuring the event stream frequency and enabling it. It also adds the hwcaps definitions to the user to detect this event stream feature. Cc: Russell King <linux@arm.linux.org.uk> Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
2013-07-26ARM: 7791/1: a.out: remove partial a.out supportWill Deacon
a.out support on ARM requires that argc, argv and envp are passed in r0-r2 respectively, which requires hacking load_aout_binary to prevent argc being clobbered by the return code. Whilst mainline kernels do set the registers up in start_thread, the aout loader has never carried the hack in mainline. Initialising the registers in this way actually goes against the libc expectations for ELF binaries, where argc, argv and envp are passed on the stack, with r0 being used to hold a pointer to an exit function for cleaning up after the dynamic linker if required. If the pointer is NULL, then it is ignored. When execing an ELF binary, Linux currently zeroes r0, then sets it to argc and then finally clobbers it with the return value of the execve syscall, so we actually end up with: r0 = 0 stack[0] = argc r1 = stack[1] = argv r2 = stack[2] = envp libc treats r1 and r2 as undefined. The clobbering of r0 by sys_execve works for user-spawned threads, but when executing an ELF binary from a kernel thread (via call_usermodehelper), the execve is performed on the ret_from_fork path, which restores r0 from the saved pt_regs, resulting in argc being presented to the C library. This has horrible consequences when the application exits, since we have an exit function registered using argc, resulting in a jump to hyperspace. This patch solves the problem by removing the partial a.out support from arch/arm/ altogether. Cc: <stable@vger.kernel.org> Cc: Ashish Sangwan <ashishsangwan2@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-18Merge branch 'for-rmk/lpae' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into devel-stable Conflicts: arch/arm/kernel/smp.c Please pull these miscellaneous LPAE fixes I've been collecting for a while now for 3.11. They've been tested and reviewed by quite a few people, and most of the patches are pretty trivial. -- Will Deacon.
2013-05-30ARM: elf: add new hwcap for identifying atomic ldrd/strd instructionsWill Deacon
CPUs implementing LPAE have atomic ldrd/strd instructions, meaning that userspace software can avoid having to use the exclusive variants of these instructions if they wish. This patch advertises the atomicity of these instructions via the hwcaps, so userspace can detect this CPU feature. Reported-by: Vladimir Danushevsky <vladimir.danushevsky@oracle.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-05-22Merge branch 'for-next' of git://git.pengutronix.de/git/ukl/linux into ↵Russell King
devel-stable Pull ARM-v7M support from Uwe Kleine-König: "All but the last patch were in next since next-20130418 without issues. The last patch fixes a problem in combination with 8164f7a (ARM: 7680/1: Detect support for SDIV/UDIV from ISAR0 register) which triggers a WARN_ON without an implemented read_cpuid_ext. The branch merges fine into v3.10-rc1 and I'd be happy if you pulled it for 3.11-rc1. The only missing piece to be able to run a Cortex-M3 is the irqchip driver that will go in via Thomas Gleixner and platform specific stuff."
2013-04-25Merge branch 'mcpm' of git://git.linaro.org/people/nico/linux into devel-stableRussell King
2013-04-17ARM: Add base support for ARMv7-MCatalin Marinas
This patch adds the base support for the ARMv7-M architecture. It consists of the corresponding arch/arm/mm/ files and various #ifdef's around the kernel. Exception handling is implemented by a subsequent patch. [ukleinek: squash in some changes originating from commit b5717ba (Cortex-M3: Add support for the Microcontroller Prototyping System) from the v2.6.33-arm1 patch stack, port to post 3.6, drop zImage support, drop reorganisation of pt_regs, assert CONFIG_CPU_V7M doesn't leak into installed headers and a few cosmetic changes] Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Jonathan Austin <jonathan.austin@arm.com> Tested-by: Jonathan Austin <jonathan.austin@arm.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-03-06ARM: KVM: convert GP registers from u32 to unsigned longMarc Zyngier
On 32bit ARM, unsigned long is guaranteed to be a 32bit quantity. On 64bit ARM, it is a 64bit quantity. In order to be able to share code between the two architectures, convert the registers to be unsigned long, so the core code can be oblivious of the change. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-03-03ARM: 7665/1: Wire up kcmp syscallCyrill Gorcunov
Wire up kcmp syscall for ability to proceed checkpoint/restore procedure on ARM platform. Signed-off-by: Alexander Kartashov <alekskartashov@parallels.com> Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-02-11ARM: KVM: VGIC accept vcpu and dist base addresses from user spaceChristoffer Dall
User space defines the model to emulate to a guest and should therefore decide which addresses are used for both the virtual CPU interface directly mapped in the guest physical address space and for the emulated distributor interface, which is mapped in software by the in-kernel VGIC support. Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-02-11KVM: ARM: Introduce KVM_ARM_SET_DEVICE_ADDR ioctlChristoffer Dall
On ARM some bits are specific to the model being emulated for the guest and user space needs a way to tell the kernel about those bits. An example is mmio device base addresses, where KVM must know the base address for a given device to properly emulate mmio accesses within a certain address range or directly map a device with virtualiation extensions into the guest address space. We make this API ARM-specific as we haven't yet reached a consensus for a generic API for all KVM architectures that will allow us to do something like this. Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-01-23KVM: ARM: Power State Coordination Interface implementationMarc Zyngier
Implement the PSCI specification (ARM DEN 0022A) to control virtual CPUs being "powered" on or off. PSCI/KVM is detected using the KVM_CAP_ARM_PSCI capability. A virtual CPU can now be initialized in a "powered off" state, using the KVM_ARM_VCPU_POWER_OFF feature flag. The guest can use either SMC or HVC to execute a PSCI function. Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
2013-01-23KVM: ARM: VFP userspace interfaceRusty Russell
We use space #18 for floating point regs. Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
2013-01-23KVM: ARM: Demux CCSIDR in the userspace APIChristoffer Dall
The Cache Size Selection Register (CSSELR) selects the current Cache Size ID Register (CCSIDR). You write which cache you are interested in to CSSELR, and read the information out of CCSIDR. Which cache numbers are valid is known by reading the Cache Level ID Register (CLIDR). To export this state to userspace, we add a KVM_REG_ARM_DEMUX numberspace (17), which uses 8 bits to represent which register is being demultiplexed (0 for CCSIDR), and the lower 8 bits to represent this demultiplexing (in our case, the CSSELR value, which is 4 bits). Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
2013-01-23KVM: ARM: Inject IRQs and FIQs from userspaceChristoffer Dall
All interrupt injection is now based on the VM ioctl KVM_IRQ_LINE. This works semantically well for the GIC as we in fact raise/lower a line on a machine component (the gic). The IOCTL uses the follwing struct. struct kvm_irq_level { union { __u32 irq; /* GSI */ __s32 status; /* not used for KVM_IRQ_LEVEL */ }; __u32 level; /* 0 or 1 */ }; ARM can signal an interrupt either at the CPU level, or at the in-kernel irqchip (GIC), and for in-kernel irqchip can tell the GIC to use PPIs designated for specific cpus. The irq field is interpreted like this:  bits: | 31 ... 24 | 23 ... 16 | 15 ... 0 | field: | irq_type | vcpu_index | irq_number | The irq_type field has the following values: - irq_type[0]: out-of-kernel GIC: irq_number 0 is IRQ, irq_number 1 is FIQ - irq_type[1]: in-kernel GIC: SPI, irq_number between 32 and 1019 (incl.) (the vcpu_index field is ignored) - irq_type[2]: in-kernel GIC: PPI, irq_number between 16 and 31 (incl.) The irq_number thus corresponds to the irq ID in as in the GICv2 specs. This is documented in Documentation/kvm/api.txt. Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
2013-01-23KVM: ARM: Initial skeleton to compile KVM supportChristoffer Dall
Targets KVM support for Cortex A-15 processors. Contains all the framework components, make files, header files, some tracing functionality, and basic user space API. Only supported core is Cortex-A15 for now. Most functionality is in arch/arm/kvm/* or arch/arm/include/asm/kvm_*.h. Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-19unify SS_ONSTACK/SS_DISABLE definitionsAl Viro
2012-12-14ARM: add finit_module syscall to ARMKees Cook
Add finit_module syscall to the ARM syscall list. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-29ARM: 7566/1: vfp: fix save and restore when running on pre-VFPv3 and ↵Paul Walmsley
CONFIG_VFPv3 set After commit 846a136881b8f73c1f74250bf6acfaa309cab1f2 ("ARM: vfp: fix saving d16-d31 vfp registers on v6+ kernels"), the OMAP 2430SDP board started crashing during boot with omap2plus_defconfig: [ 3.875122] mmcblk0: mmc0:e624 SD04G 3.69 GiB [ 3.915954] mmcblk0: p1 [ 4.086639] Internal error: Oops - undefined instruction: 0 [#1] SMP ARM [ 4.093719] Modules linked in: [ 4.096954] CPU: 0 Not tainted (3.6.0-02232-g759e00b #570) [ 4.103149] PC is at vfp_reload_hw+0x1c/0x44 [ 4.107666] LR is at __und_usr_fault_32+0x0/0x8 It turns out that the context save/restore fix unmasked a latent bug in commit 5aaf254409f8d58229107b59507a8235b715a960 ("ARM: 6203/1: Make VFPv3 usable on ARMv6"). When CONFIG_VFPv3 is set, but the kernel is booted on a pre-VFPv3 core, the code attempts to save and restore the d16-d31 VFP registers. These are only present on non-D16 VFPv3+, so this results in an undefined instruction exception. The code didn't crash before commit 846a136 because the save and restore code was only touching d0-d15, present on all VFP. Fix by implementing a request from Russell King to add a new HWCAP flag that affirmatively indicates the presence of the d16-d31 registers: http://marc.info/?l=linux-arm-kernel&m=135013547905283&w=2 and some feedback from Måns to clarify the name of the HWCAP flag. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Dave Martin <dave.martin@linaro.org> Cc: Måns Rullgård <mans.rullgard@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
