The DMA API requires that 32-bit DMA masks are always supported, but on
arm LPAE configs they do not currently work when memory is present
above 4GB. Wire up the swiotlb code like for all other architectures
to provide the bounce buffering in that case.
Fixes: 21e07dba9fb11 ("scsi: reduce use of block bounce buffers").
Reported-by: Roger Quadros <rogerq@ti.com>
Tested-by: Vignesh Raghavendra <vigneshr@ti.com>
Pull ARM SoC platform updates from Olof Johansson:
"SoC platform changes. Main theme this merge window:
- The Netx platform (Netx 100/500) platform is removed by Linus
Walleij-- the SoC doesn't have active maintainers with hardware,
and in discussions with the vendor the agreement was that it's OK
to remove.
- Russell King has a series of patches that cleans up and refactors
SA1101 and RiscPC support"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (47 commits)
ARM: stm32: use "depends on" instead of "if" after prompt
ARM: sa1100: convert to common clock framework
ARM: exynos: Cleanup cppcheck shifting warning
ARM: pxa/lubbock: remove lubbock_set_misc_wr() from global view
ARM: exynos: Only build MCPM support if used
arm: add missing include platform-data/atmel.h
ARM: davinci: Use GPIO lookup table for DA850 LEDs
ARM: OMAP2: drop explicit assembler architecture
ARM: use arch_extension directive instead of arch argument
ARM: imx: Switch imx7d to imx-cpufreq-dt for speed-grading
ARM: bcm: Enable PINCTRL for ARCH_BRCMSTB
ARM: bcm: Enable ARCH_HAS_RESET_CONTROLLER for ARCH_BRCMSTB
ARM: riscpc: enable chained scatterlist support
ARM: riscpc: reduce IRQ handling code
ARM: riscpc: move RiscPC assembly files from arch/arm/lib to mach-rpc
ARM: riscpc: parse video information from tagged list
ARM: riscpc: add ecard quirk for Atomwide 3port serial card
MAINTAINERS: mvebu: Add git entry
soc: ti: pm33xx: Add a print while entering RTC only mode with DDR in self-refresh
ARM: OMAP2+: Make some variables static
Merge more updates from Andrew Morton:
"VM:
- z3fold fixes and enhancements by Henry Burns and Vitaly Wool
- more accurate reclaimed slab caches calculations by Yafang Shao
- fix MAP_UNINITIALIZED UAPI symbol to not depend on config, by
Christoph Hellwig
- !CONFIG_MMU fixes by Christoph Hellwig
- new novmcoredd parameter to omit device dumps from vmcore, by
Kairui Song
- new test_meminit module for testing heap and pagealloc
initialization, by Alexander Potapenko
- ioremap improvements for huge mappings, by Anshuman Khandual
- generalize kprobe page fault handling, by Anshuman Khandual
- device-dax hotplug fixes and improvements, by Pavel Tatashin
- enable synchronous DAX fault on powerpc, by Aneesh Kumar K.V
- add pte_devmap() support for arm64, by Robin Murphy
- unify locked_vm accounting with a helper, by Daniel Jordan
- several misc fixes
core/lib:
- new typeof_member() macro including some users, by Alexey Dobriyan
- make BIT() and GENMASK() available in asm, by Masahiro Yamada
- changed LIST_POISON2 on x86_64 to 0xdead000000000122 for better
code generation, by Alexey Dobriyan
- rbtree code size optimizations, by Michel Lespinasse
- convert struct pid count to refcount_t, by Joel Fernandes
get_maintainer.pl:
- add --no-moderated switch to skip moderated ML's, by Joe Perches
misc:
- ptrace PTRACE_GET_SYSCALL_INFO interface
- coda updates
- gdb scripts, various"
[ Using merge message suggestion from Vlastimil Babka, with some editing - Linus ]
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (100 commits)
fs/select.c: use struct_size() in kmalloc()
mm: add account_locked_vm utility function
arm64: mm: implement pte_devmap support
mm: introduce ARCH_HAS_PTE_DEVMAP
mm: clean up is_device_*_page() definitions
mm/mmap: move common defines to mman-common.h
mm: move MAP_SYNC to asm-generic/mman-common.h
device-dax: "Hotremove" persistent memory that is used like normal RAM
mm/hotplug: make remove_memory() interface usable
device-dax: fix memory and resource leak if hotplug fails
include/linux/lz4.h: fix spelling and copy-paste errors in documentation
ipc/mqueue.c: only perform resource calculation if user valid
include/asm-generic/bug.h: fix "cut here" for WARN_ON for __WARN_TAINT architectures
scripts/gdb: add helpers to find and list devices
scripts/gdb: add lx-genpd-summary command
drivers/pps/pps.c: clear offset flags in PPS_SETPARAMS ioctl
kernel/pid.c: convert struct pid count to refcount_t
drivers/rapidio/devices/rio_mport_cdev.c: NUL terminate some strings
select: shift restore_saved_sigmask_unless() into poll_select_copy_remaining()
select: change do_poll() to return -ERESTARTNOHAND rather than -EINTR
isa_page_to_bus() is deprecated and is no longer used anywhere. Remove
it entirely.
Link: http://lkml.kernel.org/r/20190613161155.16946-1-steve@sk2.org
Signed-off-by: Stephen Kitt <steve@sk2.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull rst conversion of docs from Mauro Carvalho Chehab:
"As agreed with Jon, I'm sending this big series directly to you, c/c
him, as this series required a special care, in order to avoid
conflicts with other trees"
* tag 'docs/v5.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (77 commits)
docs: kbuild: fix build with pdf and fix some minor issues
docs: block: fix pdf output
docs: arm: fix a breakage with pdf output
docs: don't use nested tables
docs: gpio: add sysfs interface to the admin-guide
docs: locking: add it to the main index
docs: add some directories to the main documentation index
docs: add SPDX tags to new index files
docs: add a memory-devices subdir to driver-api
docs: phy: place documentation under driver-api
docs: serial: move it to the driver-api
docs: driver-api: add remaining converted dirs to it
docs: driver-api: add xilinx driver API documentation
docs: driver-api: add a series of orphaned documents
docs: admin-guide: add a series of orphaned documents
docs: cgroup-v1: add it to the admin-guide book
docs: aoe: add it to the driver-api book
docs: add some documentation dirs to the driver-api book
docs: driver-model: move it to the driver-api book
docs: lp855x-driver.rst: add it to the driver-api book
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"New stuff from the I2C world:
- in the core, getting irqs from ACPI is now similar to OF
- new driver for MediaTek MT7621/7628/7688 SoCs
- bcm2835, i801, and tegra drivers got some more attention
- GPIO API cleanups
- cleanups in the core headers
- lots of usual driver updates"
* 'i2c/for-5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (74 commits)
i2c: mt7621: Fix platform_no_drv_owner.cocci warnings
i2c: cpm: remove casting dma_alloc
dt-bindings: i2c: sun6i-p2wi: Fix the binding example
dt-bindings: i2c: mv64xxx: Fix the example compatible
i2c: i801: Documentation update
i2c: i801: Add support for Intel Tiger Lake
i2c: i801: Fix PCI ID sorting
dt-bindings: i2c-stm32: document optional dmas
i2c: i2c-stm32f7: Add I2C_SMBUS_I2C_BLOCK_DATA support
i2c: core: Tidy up handling of init_irq
i2c: core: Move ACPI gpio IRQ handling into i2c_acpi_get_irq
i2c: core: Move ACPI IRQ handling to probe time
i2c: acpi: Factor out getting the IRQ from ACPI
i2c: acpi: Use available IRQ helper functions
i2c: core: Allow whole core to use i2c_dev_irq_from_resources
eeprom: at24: modify a comment referring to platform data
dt-bindings: i2c: omap: Add new compatible for J721E SoCs
dt-bindings: i2c: mv64xxx: Add YAML schemas
dt-bindings: i2c: sun6i-p2wi: Add YAML schemas
i2c: mt7621: Add MediaTek MT7621/7628/7688 I2C driver
Converts ARM the text files to ReST, preparing them to be an
architecture book.
The conversion is actually:
- add blank lines and identation in order to identify paragraphs;
- fix tables markups;
- add some lists markups;
- mark literal blocks;
- adjust title markups.
At its new index.rst, let's add a :orphan: while this is not linked to
the main index.rst file, in order to avoid build warnings.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Reviewed-by Corentin Labbe <clabbe.montjoie@gmail.com> # For sun4i-ss
Pull KVM updates from Paolo Bonzini:
"ARM:
- support for chained PMU counters in guests
- improved SError handling
- handle Neoverse N1 erratum #1349291
- allow side-channel mitigation status to be migrated
- standardise most AArch64 system register accesses to msr_s/mrs_s
- fix host MPIDR corruption on 32bit
- selftests ckleanups
x86:
- PMU event {white,black}listing
- ability for the guest to disable host-side interrupt polling
- fixes for enlightened VMCS (Hyper-V pv nested virtualization),
- new hypercall to yield to IPI target
- support for passing cstate MSRs through to the guest
- lots of cleanups and optimizations
Generic:
- Some txt->rST conversions for the documentation"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (128 commits)
Documentation: virtual: Add toctree hooks
Documentation: kvm: Convert cpuid.txt to .rst
Documentation: virtual: Convert paravirt_ops.txt to .rst
KVM: x86: Unconditionally enable irqs in guest context
KVM: x86: PMU Event Filter
kvm: x86: Fix -Wmissing-prototypes warnings
KVM: Properly check if "page" is valid in kvm_vcpu_unmap
KVM: arm/arm64: Initialise host's MPIDRs by reading the actual register
KVM: LAPIC: Retry tune per-vCPU timer_advance_ns if adaptive tuning goes insane
kvm: LAPIC: write down valid APIC registers
KVM: arm64: Migrate _elx sysreg accessors to msr_s/mrs_s
KVM: doc: Add API documentation on the KVM_REG_ARM_WORKAROUNDS register
KVM: arm/arm64: Add save/restore support for firmware workaround state
arm64: KVM: Propagate full Spectre v2 workaround state to KVM guests
KVM: arm/arm64: Support chained PMU counters
KVM: arm/arm64: Remove pmc->bitmask
KVM: arm/arm64: Re-create event when setting counter value
KVM: arm/arm64: Extract duplicated code to own function
KVM: arm/arm64: Rename kvm_pmu_{enable/disable}_counter functions
KVM: LAPIC: ARBPRI is a reserved register for x2APIC
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core and debugfs updates from Greg KH:
"Here is the "big" driver core and debugfs changes for 5.3-rc1
It's a lot of different patches, all across the tree due to some api
changes and lots of debugfs cleanups.
Other than the debugfs cleanups, in this set of changes we have:
- bus iteration function cleanups
- scripts/get_abi.pl tool to display and parse Documentation/ABI
entries in a simple way
- cleanups to Documenatation/ABI/ entries to make them parse easier
due to typos and other minor things
- default_attrs use for some ktype users
- driver model documentation file conversions to .rst
- compressed firmware file loading
- deferred probe fixes
All of these have been in linux-next for a while, with a bunch of
merge issues that Stephen has been patient with me for"
* tag 'driver-core-5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (102 commits)
debugfs: make error message a bit more verbose
orangefs: fix build warning from debugfs cleanup patch
ubifs: fix build warning after debugfs cleanup patch
driver: core: Allow subsystems to continue deferring probe
drivers: base: cacheinfo: Ensure cpu hotplug work is done before Intel RDT
arch_topology: Remove error messages on out-of-memory conditions
lib: notifier-error-inject: no need to check return value of debugfs_create functions
swiotlb: no need to check return value of debugfs_create functions
ceph: no need to check return value of debugfs_create functions
sunrpc: no need to check return value of debugfs_create functions
ubifs: no need to check return value of debugfs_create functions
orangefs: no need to check return value of debugfs_create functions
nfsd: no need to check return value of debugfs_create functions
lib: 842: no need to check return value of debugfs_create functions
debugfs: provide pr_fmt() macro
debugfs: log errors when something goes wrong
drivers: s390/cio: Fix compilation warning about const qualifiers
drivers: Add generic helper to match by of_node
driver_find_device: Unify the match function with class_find_device()
bus_find_device: Unify the match callback with class_find_device
Merge updates from Andrew Morton:
"Am experimenting with splitting MM up into identifiable subsystems
perhaps with a view to gitifying it in complex ways. Also with more
verbose "incoming" emails.
Most of MM is here and a few other trees.
Subsystems affected by this patch series:
- hotfixes
- iommu
- scripts
- arch/sh
- ocfs2
- mm:slab-generic
- mm:slub
- mm:kmemleak
- mm:kasan
- mm:cleanups
- mm:debug
- mm:pagecache
- mm:swap
- mm:memcg
- mm:gup
- mm:pagemap
- mm:infrastructure
- mm:vmalloc
- mm:initialization
- mm:pagealloc
- mm:vmscan
- mm:tools
- mm:proc
- mm:ras
- mm:oom-kill
hotfixes:
mm: vmscan: scan anonymous pages on file refaults
mm/nvdimm: add is_ioremap_addr and use that to check ioremap address
mm/memcontrol: fix wrong statistics in memory.stat
mm/z3fold.c: lock z3fold page before __SetPageMovable()
nilfs2: do not use unexported cpu_to_le32()/le32_to_cpu() in uapi header
MAINTAINERS: nilfs2: update email address
iommu:
include/linux/dmar.h: replace single-char identifiers in macros
scripts:
scripts/decode_stacktrace: match basepath using shell prefix operator, not regex
scripts/decode_stacktrace: look for modules with .ko.debug extension
scripts/spelling.txt: drop "sepc" from the misspelling list
scripts/spelling.txt: add spelling fix for prohibited
scripts/decode_stacktrace: Accept dash/underscore in modules
scripts/spelling.txt: add more spellings to spelling.txt
arch/sh:
arch/sh/configs/sdk7786_defconfig: remove CONFIG_LOGFS
sh: config: remove left-over BACKLIGHT_LCD_SUPPORT
sh: prevent warnings when using iounmap
ocfs2:
fs: ocfs: fix spelling mistake "hearbeating" -> "heartbeat"
ocfs2/dlm: use struct_size() helper
ocfs2: add last unlock times in locking_state
ocfs2: add locking filter debugfs file
ocfs2: add first lock wait time in locking_state
ocfs: no need to check return value of debugfs_create functions
fs/ocfs2/dlmglue.c: unneeded variable: "status"
ocfs2: use kmemdup rather than duplicating its implementation
mm:slab-generic:
Patch series "mm/slab: Improved sanity checking":
mm/slab: validate cache membership under freelist hardening
mm/slab: sanity-check page type when looking up cache
lkdtm/heap: add tests for freelist hardening
mm:slub:
mm/slub.c: avoid double string traverse in kmem_cache_flags()
slub: don't panic for memcg kmem cache creation failure
mm:kmemleak:
mm/kmemleak.c: fix check for softirq context
mm/kmemleak.c: change error at _write when kmemleak is disabled
docs: kmemleak: add more documentation details
mm:kasan:
mm/kasan: print frame description for stack bugs
Patch series "Bitops instrumentation for KASAN", v5:
lib/test_kasan: add bitops tests
x86: use static_cpu_has in uaccess region to avoid instrumentation
asm-generic, x86: add bitops instrumentation for KASAN
Patch series "mm/kasan: Add object validation in ksize()", v3:
mm/kasan: introduce __kasan_check_{read,write}
mm/kasan: change kasan_check_{read,write} to return boolean
lib/test_kasan: Add test for double-kzfree detection
mm/slab: refactor common ksize KASAN logic into slab_common.c
mm/kasan: add object validation in ksize()
mm:cleanups:
include/linux/pfn_t.h: remove pfn_t_to_virt()
Patch series "remove ARCH_SELECT_MEMORY_MODEL where it has no effect":
arm: remove ARCH_SELECT_MEMORY_MODEL
s390: remove ARCH_SELECT_MEMORY_MODEL
sparc: remove ARCH_SELECT_MEMORY_MODEL
mm/gup.c: make follow_page_mask() static
mm/memory.c: trivial clean up in insert_page()
mm: make !CONFIG_HUGE_PAGE wrappers into static inlines
include/linux/mm_types.h: ifdef struct vm_area_struct::swap_readahead_info
mm: remove the account_page_dirtied export
mm/page_isolation.c: change the prototype of undo_isolate_page_range()
include/linux/vmpressure.h: use spinlock_t instead of struct spinlock
mm: remove the exporting of totalram_pages
include/linux/pagemap.h: document trylock_page() return value
mm:debug:
mm/failslab.c: by default, do not fail allocations with direct reclaim only
Patch series "debug_pagealloc improvements":
mm, debug_pagelloc: use static keys to enable debugging
mm, page_alloc: more extensive free page checking with debug_pagealloc
mm, debug_pagealloc: use a page type instead of page_ext flag
mm:pagecache:
Patch series "fix filler_t callback type mismatches", v2:
mm/filemap.c: fix an overly long line in read_cache_page
mm/filemap: don't cast ->readpage to filler_t for do_read_cache_page
jffs2: pass the correct prototype to read_cache_page
9p: pass the correct prototype to read_cache_page
mm/filemap.c: correct the comment about VM_FAULT_RETRY
mm:swap:
mm, swap: fix race between swapoff and some swap operations
mm/swap_state.c: simplify total_swapcache_pages() with get_swap_device()
mm, swap: use rbtree for swap_extent
mm/mincore.c: fix race between swapoff and mincore
mm:memcg:
memcg, oom: no oom-kill for __GFP_RETRY_MAYFAIL
memcg, fsnotify: no oom-kill for remote memcg charging
mm, memcg: introduce memory.events.local
mm: memcontrol: dump memory.stat during cgroup OOM
Patch series "mm: reparent slab memory on cgroup removal", v7:
mm: memcg/slab: postpone kmem_cache memcg pointer initialization to memcg_link_cache()
mm: memcg/slab: rename slab delayed deactivation functions and fields
mm: memcg/slab: generalize postponed non-root kmem_cache deactivation
mm: memcg/slab: introduce __memcg_kmem_uncharge_memcg()
mm: memcg/slab: unify SLAB and SLUB page accounting
mm: memcg/slab: don't check the dying flag on kmem_cache creation
mm: memcg/slab: synchronize access to kmem_cache dying flag using a spinlock
mm: memcg/slab: rework non-root kmem_cache lifecycle management
mm: memcg/slab: stop setting page->mem_cgroup pointer for slab pages
mm: memcg/slab: reparent memcg kmem_caches on cgroup removal
mm, memcg: add a memcg_slabinfo debugfs file
mm:gup:
Patch series "switch the remaining architectures to use generic GUP", v4:
mm: use untagged_addr() for get_user_pages_fast addresses
mm: simplify gup_fast_permitted
mm: lift the x86_32 PAE version of gup_get_pte to common code
MIPS: use the generic get_user_pages_fast code
sh: add the missing pud_page definition
sh: use the generic get_user_pages_fast code
sparc64: add the missing pgd_page definition
sparc64: define untagged_addr()
sparc64: use the generic get_user_pages_fast code
mm: rename CONFIG_HAVE_GENERIC_GUP to CONFIG_HAVE_FAST_GUP
mm: reorder code blocks in gup.c
mm: consolidate the get_user_pages* implementations
mm: validate get_user_pages_fast flags
mm: move the powerpc hugepd code to mm/gup.c
mm: switch gup_hugepte to use try_get_compound_head
mm: mark the page referenced in gup_hugepte
mm/gup: speed up check_and_migrate_cma_pages() on huge page
mm/gup.c: remove some BUG_ONs from get_gate_page()
mm/gup.c: mark undo_dev_pagemap as __maybe_unused
mm:pagemap:
asm-generic, x86: introduce generic pte_{alloc,free}_one[_kernel]
alpha: switch to generic version of pte allocation
arm: switch to generic version of pte allocation
arm64: switch to generic version of pte allocation
csky: switch to generic version of pte allocation
m68k: sun3: switch to generic version of pte allocation
mips: switch to generic version of pte allocation
nds32: switch to generic version of pte allocation
nios2: switch to generic version of pte allocation
parisc: switch to generic version of pte allocation
riscv: switch to generic version of pte allocation
um: switch to generic version of pte allocation
unicore32: switch to generic version of pte allocation
mm/pgtable: drop pgtable_t variable from pte_fn_t functions
mm/memory.c: fail when offset == num in first check of __vm_map_pages()
mm:infrastructure:
mm/mmu_notifier: use hlist_add_head_rcu()
mm:vmalloc:
Patch series "Some cleanups for the KVA/vmalloc", v5:
mm/vmalloc.c: remove "node" argument
mm/vmalloc.c: preload a CPU with one object for split purpose
mm/vmalloc.c: get rid of one single unlink_va() when merge
mm/vmalloc.c: switch to WARN_ON() and move it under unlink_va()
mm/vmalloc.c: spelling> s/informaion/information/
mm:initialization:
mm/large system hash: use vmalloc for size > MAX_ORDER when !hashdist
mm/large system hash: clear hashdist when only one node with memory is booted
mm:pagealloc:
arm64: move jump_label_init() before parse_early_param()
Patch series "add init_on_alloc/init_on_free boot options", v10:
mm: security: introduce init_on_alloc=1 and init_on_free=1 boot options
mm: init: report memory auto-initialization features at boot time
mm:vmscan:
mm: vmscan: remove double slab pressure by inc'ing sc->nr_scanned
mm: vmscan: correct some vmscan counters for THP swapout
mm:tools:
tools/vm/slabinfo: order command line options
tools/vm/slabinfo: add partial slab listing to -X
tools/vm/slabinfo: add option to sort by partial slabs
tools/vm/slabinfo: add sorting info to help menu
mm:proc:
proc: use down_read_killable mmap_sem for /proc/pid/maps
proc: use down_read_killable mmap_sem for /proc/pid/smaps_rollup
proc: use down_read_killable mmap_sem for /proc/pid/pagemap
proc: use down_read_killable mmap_sem for /proc/pid/clear_refs
proc: use down_read_killable mmap_sem for /proc/pid/map_files
mm: use down_read_killable for locking mmap_sem in access_remote_vm
mm: smaps: split PSS into components
mm: vmalloc: show number of vmalloc pages in /proc/meminfo
mm:ras:
mm/memory-failure.c: clarify error message
mm:oom-kill:
mm: memcontrol: use CSS_TASK_ITER_PROCS at mem_cgroup_scan_tasks()
mm, oom: refactor dump_tasks for memcg OOMs
mm, oom: remove redundant task_in_mem_cgroup() check
oom: decouple mems_allowed from oom_unkillable_task
mm/oom_kill.c: remove redundant OOM score normalization in select_bad_process()"
* akpm: (147 commits)
Replace __get_free_page() and alloc_pages() calls with the generic
__pte_alloc_one_kernel() and __pte_alloc_one().
There is no functional change for the kernel PTE allocation.
The difference for the user PTEs, is that the clear_pte_table() is now
called after pgtable_page_ctor() and the addition of __GFP_ACCOUNT to the
GFP flags.
The conversion to the generic version of pte_free_kernel() removes the NULL
check for pte.
The pte_free() version on arm is identical to the generic one and can be
simply dropped.
Link: http://lkml.kernel.org/r/1557296232-15361-4-git-send-email-rppt@linux.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: Albert Ou <aou@eecs.berkeley.edu>
Cc: Anshuman Khandual <anshuman.khandual@arm.com>
Cc: Anton Ivanov <anton.ivanov@cambridgegreys.com>
Cc: Greentime Hu <green.hu@gmail.com>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: Guo Ren <guoren@kernel.org>
Cc: Guo Ren <ren_guo@c-sky.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Sam Creasey <sammy@sammy.net>
Cc: Vincent Chen <deanbo422@gmail.com>
Pull MMC updates from Ulf Hansson:
"MMC core:
- Let the dma map ops deal with bouncing and drop dma_max_pfn() from
the dma-mapping interface for ARM
- Convert the generic MMC DT doc to YAML schemas
- Drop questionable support for powered-on re-init of SDIO cards at
runtime resume and for SDIO HW reset
- Prevent questionable re-init of powered-on removable SDIO cards at
system resume
- Cleanup and clarify some SDIO core code
MMC host:
- tmio: Make runtime PM enablement more flexible for variants
- tmio/renesas_sdhi: Rename DT doc tmio_mmc.txt to renesas,sdhi.txt
to clarify
- sdhci-pci: Add support for Intel EHL
- sdhci-pci-o2micro: Enable support for 8-bit bus
- sdhci-msm: Prevent acquiring a mutex while holding a spin_lock
- sdhci-of-esdhc: Improve clock management and tuning
- sdhci_am654: Enable support for 4 and 8-bit bus on J721E
- sdhci-sprd: Use pinctrl for a proper signal voltage switch
- sdhci-sprd: Add support for HS400 enhanced strobe mode
- sdhci-sprd: Enable PHY DLL and allow delay config to stabilize the
clock
- sdhci-sprd: Add support for optional gate clock
- sunxi-mmc: Convert DT doc to YAML schemas
- meson-gx: Add support for broken DRAM access for DMA
MEMSTICK core:
- Fixup error path of memstick_init()"
* tag 'mmc-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: (52 commits)
mmc: sdhci_am654: Add dependency on MMC_SDHCI_AM654
mmc: alcor: remove a redundant greater or equal to zero comparison
mmc: sdhci-msm: fix mutex while in spinlock
mmc: sdhci_am654: Make some symbols static
dma-mapping: remove dma_max_pfn
mmc: core: let the dma map ops handle bouncing
dt-binding: mmc: rename tmio_mmc.txt to renesas,sdhi.txt
mmc: sdhci-sprd: Add pin control support for voltage switch
dt-bindings: mmc: sprd: Add pinctrl support
mmc: sdhci-sprd: Add start_signal_voltage_switch ops
mmc: sdhci-pci: Add support for Intel EHL
mmc: tmio: Use dma_max_mapping_size() instead of a workaround
mmc: sdio: Drop unused in-parameter from mmc_sdio_init_card()
mmc: sdio: Drop unused in-parameter to mmc_sdio_reinit_card()
mmc: sdio: Don't re-initialize powered-on removable SDIO cards at resume
mmc: sdio: Drop powered-on re-init at runtime resume and HW reset
mmc: sdio: Move comment about re-initialization to mmc_sdio_reinit_card()
mmc: sdio: Drop mmc_claim|release_host() in mmc_sdio_power_restore()
mmc: sdio: Turn sdio_run_irqs() into static
mmc: sdhci: Fix indenting on SDHCI_CTRL_8BITBUS
git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux
Pull clone3 system call from Christian Brauner:
"This adds the clone3 syscall which is an extensible successor to clone
after we snagged the last flag with CLONE_PIDFD during the 5.2 merge
window for clone(). It cleanly supports all of the flags from clone()
and thus all legacy workloads.
There are few user visible differences between clone3 and clone.
First, CLONE_DETACHED will cause EINVAL with clone3 so we can reuse
this flag. Second, the CSIGNAL flag is deprecated and will cause
EINVAL to be reported. It is superseeded by a dedicated "exit_signal"
argument in struct clone_args thus freeing up even more flags. And
third, clone3 gives CLONE_PIDFD a dedicated return argument in struct
clone_args instead of abusing CLONE_PARENT_SETTID's parent_tidptr
argument.
The clone3 uapi is designed to be easy to handle on 32- and 64 bit:
/* uapi */
struct clone_args {
__aligned_u64 flags;
__aligned_u64 pidfd;
__aligned_u64 child_tid;
__aligned_u64 parent_tid;
__aligned_u64 exit_signal;
__aligned_u64 stack;
__aligned_u64 stack_size;
__aligned_u64 tls;
and a separate kernel struct is used that uses proper kernel typing:
/* kernel internal */
struct kernel_clone_args {
u64 flags;
int __user *pidfd;
int __user *child_tid;
int __user *parent_tid;
int exit_signal;
unsigned long stack;
unsigned long stack_size;
unsigned long tls;
The system call comes with a size argument which enables the kernel to
detect what version of clone_args userspace is passing in. clone3
validates that any additional bytes a given kernel does not know about
are set to zero and that the size never exceeds a page.
A nice feature is that this patchset allowed us to cleanup and
simplify various core kernel codepaths in kernel/fork.c by making the
internal _do_fork() function take struct kernel_clone_args even for
legacy clone().
This patch also unblocks the time namespace patchset which wants to
introduce a new CLONE_TIMENS flag.
Note, that clone3 has only been wired up for x86{_32,64}, arm{64}, and
xtensa. These were the architectures that did not require special
massaging.
Other architectures treat fork-like system calls individually and
after some back and forth neither Arnd nor I felt confident that we
dared to add clone3 unconditionally to all architectures. We agreed to
leave this up to individual architecture maintainers. This is why
there's an additional patch that introduces __ARCH_WANT_SYS_CLONE3
which any architecture can set once it has implemented support for
clone3. The patch also adds a cond_syscall(clone3) for architectures
such as nios2 or h8300 that generate their syscall table by simply
including asm-generic/unistd.h. The hope is to get rid of
__ARCH_WANT_SYS_CLONE3 and cond_syscall() rather soon"
* tag 'clone3-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux:
arch: handle arches who do not yet define clone3
arch: wire-up clone3() syscall
fork: add clone3
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68nommu updates from Greg Ungerer:
"A series of cleanups for the FLAT format binary loader, binfmt_flat,
from Christoph.
The end goal is to support no-MMU on RISC-V, and the last patch
enables that"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
riscv: add binfmt_flat support
binfmt_flat: don't offset the data start
binfmt_flat: move the MAX_SHARED_LIBS definition to binfmt_flat.c
binfmt_flat: remove the persistent argument from flat_get_addr_from_rp
binfmt_flat: provide an asm-generic/flat.h
binfmt_flat: make support for old format binaries optional
binfmt_flat: add a ARCH_HAS_BINFMT_FLAT option
binfmt_flat: add endianess annotations
binfmt_flat: use fixed size type for the on-disk format
binfmt_flat: consolidate two version of flat_v2_reloc_t
binfmt_flat: remove the unused OLD_FLAT_FLAG_RAM definition
binfmt_flat: remove the uapi <linux/flat.h> header
binfmt_flat: replace flat_argvp_envp_on_stack with a Kconfig variable
binfmt_flat: remove flat_old_ram_flag
binfmt_flat: provide a default version of flat_get_relocate_addr
binfmt_flat: remove flat_set_persistent
binfmt_flat: remove flat_reloc_valid
These days, the DMA mapping code must bounce buffers for any unsupported
address. If the driver needs to optimize for natively supported ranges,
then it should use dma_get_required_mask.
Acked-by: Marc Gonzalez <marc.w.gonzalez@free.fr>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull force_sig() argument change from Eric Biederman:
"A source of error over the years has been that force_sig has taken a
task parameter when it is only safe to use force_sig with the current
task.
The force_sig function is built for delivering synchronous signals
such as SIGSEGV where the userspace application caused a synchronous
fault (such as a page fault) and the kernel responded with a signal.
Because the name force_sig does not make this clear, and because the
force_sig takes a task parameter the function force_sig has been
abused for sending other kinds of signals over the years. Slowly those
have been fixed when the oopses have been tracked down.
This set of changes fixes the remaining abusers of force_sig and
carefully rips out the task parameter from force_sig and friends
making this kind of error almost impossible in the future"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (27 commits)
signal/x86: Move tsk inside of CONFIG_MEMORY_FAILURE in do_sigbus
signal: Remove the signal number and task parameters from force_sig_info
signal: Factor force_sig_info_to_task out of force_sig_info
signal: Generate the siginfo in force_sig
signal: Move the computation of force into send_signal and correct it.
signal: Properly set TRACE_SIGNAL_LOSE_INFO in __send_signal
signal: Remove the task parameter from force_sig_fault
signal: Use force_sig_fault_to_task for the two calls that don't deliver to current
signal: Explicitly call force_sig_fault on current
signal/unicore32: Remove tsk parameter from __do_user_fault
signal/arm: Remove tsk parameter from __do_user_fault
signal/arm: Remove tsk parameter from ptrace_break
signal/nds32: Remove tsk parameter from send_sigtrap
signal/riscv: Remove tsk parameter from do_trap
signal/sh: Remove tsk parameter from force_sig_info_fault
signal/um: Remove task parameter from send_sigtrap
signal/x86: Remove task parameter from send_sigtrap
signal: Remove task parameter from force_sig_mceerr
signal: Remove task parameter from force_sigsegv
Pull ARM updates from Russell King:
- Add a "cut here" to make it clearer where oops dumps should be cut
from - we already have a marker for the end of the dumps.
- Add logging severity to show_pte()
- Drop unnecessary common-page-size linker flag
- Errata workarounds for Cortex A12 857271, Cortex A17 857272 and
Cortex A7 814220.
- Remove some unused variables that had started to provoke a compiler
warning.
* tag 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8863/1: stm32: select ARM errata 814220
ARM: 8862/1: errata: 814220-B-Cache maintenance by set/way operations can execute out of order
ARM: 8865/1: mm: remove unused variables
ARM: 8864/1: Add workaround for I-Cache line size mismatch between CPU cores
ARM: 8861/1: errata: Workaround errata A12 857271 / A17 857272
ARM: 8860/1: VDSO: Drop implicit common-page-size linker flag
ARM: arrange show_pte() to issue severity-based messages
ARM: add "8<--- cut here ---" to kernel dumps
Pull locking updates from Ingo Molnar:
"The main changes in this cycle are:
- rwsem scalability improvements, phase #2, by Waiman Long, which are
rather impressive:
"On a 2-socket 40-core 80-thread Skylake system with 40 reader
and writer locking threads, the min/mean/max locking operations
done in a 5-second testing window before the patchset were:
40 readers, Iterations Min/Mean/Max = 1,807/1,808/1,810
40 writers, Iterations Min/Mean/Max = 1,807/50,344/151,255
After the patchset, they became:
40 readers, Iterations Min/Mean/Max = 30,057/31,359/32,741
40 writers, Iterations Min/Mean/Max = 94,466/95,845/97,098"
There's a lot of changes to the locking implementation that makes
it similar to qrwlock, including owner handoff for more fair
locking.
Another microbenchmark shows how across the spectrum the
improvements are:
"With a locking microbenchmark running on 5.1 based kernel, the
total locking rates (in kops/s) on a 2-socket Skylake system
with equal numbers of readers and writers (mixed) before and
after this patchset were:
# of Threads Before Patch After Patch
2 2,618 4,193
4 1,202 3,726
8 802 3,622
16 729 3,359
32 319 2,826
64 102 2,744"
The changes are extensive and the patch-set has been through
several iterations addressing various locking workloads. There
might be more regressions, but unless they are pathological I
believe we want to use this new implementation as the baseline
going forward.
- jump-label optimizations by Daniel Bristot de Oliveira: the primary
motivation was to remove IPI disturbance of isolated RT-workload
CPUs, which resulted in the implementation of batched jump-label
updates. Beyond the improvement of the real-time characteristics
kernel, in one test this patchset improved static key update
overhead from 57 msecs to just 1.4 msecs - which is a nice speedup
as well.
- atomic64_t cross-arch type cleanups by Mark Rutland: over the last
~10 years of atomic64_t existence the various types used by the
APIs only had to be self-consistent within each architecture -
which means they became wildly inconsistent across architectures.
Mark puts and end to this by reworking all the atomic64
implementations to use 's64' as the base type for atomic64_t, and
to ensure that this type is consistently used for parameters and
return values in the API, avoiding further problems in this area.
- A large set of small improvements to lockdep by Yuyang Du: type
cleanups, output cleanups, function return type and othr cleanups
all around the place.
- A set of percpu ops cleanups and fixes by Peter Zijlstra.
- Misc other changes - please see the Git log for more details"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (82 commits)
locking/lockdep: increase size of counters for lockdep statistics
locking/atomics: Use sed(1) instead of non-standard head(1) option
locking/lockdep: Move mark_lock() inside CONFIG_TRACE_IRQFLAGS && CONFIG_PROVE_LOCKING
x86/jump_label: Make tp_vec_nr static
x86/percpu: Optimize raw_cpu_xchg()
x86/percpu, sched/fair: Avoid local_clock()
x86/percpu, x86/irq: Relax {set,get}_irq_regs()
x86/percpu: Relax smp_processor_id()
x86/percpu: Differentiate this_cpu_{}() and __this_cpu_{}()
locking/rwsem: Guard against making count negative
locking/rwsem: Adaptive disabling of reader optimistic spinning
locking/rwsem: Enable time-based spinning on reader-owned rwsem
locking/rwsem: Make rwsem->owner an atomic_long_t
locking/rwsem: Enable readers spinning on writer
locking/rwsem: Clarify usage of owner's nonspinaable bit
locking/rwsem: Wake up almost all readers in wait queue
locking/rwsem: More optimal RT task handling of null owner
locking/rwsem: Always release wait_lock before waking up tasks
locking/rwsem: Implement lock handoff to prevent lock starvation
locking/rwsem: Make rwsem_spin_on_owner() return owner state
As part of setting up the host context, we populate its
MPIDR by using cpu_logical_map(). It turns out that contrary
to arm64, cpu_logical_map() on 32bit ARM doesn't return the
*full* MPIDR, but a truncated version.
This leaves the host MPIDR slightly corrupted after the first
run of a VM, since we won't correctly restore the MPIDR on
exit. Oops.
Since we cannot trust cpu_logical_map(), let's adopt a different
strategy. We move the initialization of the host CPU context as
part of the per-CPU initialization (which, in retrospect, makes
a lot of sense), and directly read the MPIDR from the HW. This
is guaranteed to work on both arm and arm64.
Reported-by: Andre Przywara <Andre.Przywara@arm.com>
Tested-by: Andre Przywara <Andre.Przywara@arm.com>
Fixes: 32f139551954 ("arm/arm64: KVM: Statically configure the host's view of MPIDR")
Currently, the {read,write}_sysreg_el*() accessors for accessing
particular ELs' sysregs in the presence of VHE rely on some local
hacks and define their system register encodings in a way that is
inconsistent with the core definitions in <asm/sysreg.h>.
As a result, it is necessary to add duplicate definitions for any
system register that already needs a definition in sysreg.h for
other reasons.
This is a bit of a maintenance headache, and the reasons for the
_el*() accessors working the way they do is a bit historical.
This patch gets rid of the shadow sysreg definitions in
<asm/kvm_hyp.h>, converts the _el*() accessors to use the core
__msr_s/__mrs_s interface, and converts all call sites to use the
standard sysreg #define names (i.e., upper case, with SYS_ prefix).
This patch will conflict heavily anyway, so the opportunity
to clean up some bad whitespace in the context of the changes is
taken.
The change exposes a few system registers that have no sysreg.h
definition, due to msr_s/mrs_s being used in place of msr/mrs:
additions are made in order to fill in the gaps.
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Cc: Christoffer Dall <christoffer.dall@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Link: https://www.spinics.net/lists/kvm-arm/msg31717.html
[Rebased to v4.21-rc1]
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
[Rebased to v5.2-rc5, changelog updates]
KVM implements the firmware interface for mitigating cache speculation
vulnerabilities. Guests may use this interface to ensure mitigation is
active.
If we want to migrate such a guest to a host with a different support
level for those workarounds, migration might need to fail, to ensure that
critical guests don't loose their protection.
Introduce a way for userland to save and restore the workarounds state.
On restoring we do checks that make sure we don't downgrade our
mitigation level.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Reviewed-by: Steven Price <steven.price@arm.com>
Recent commits added the explicit notion of "workaround not required" to
the state of the Spectre v2 (aka. BP_HARDENING) workaround, where we
just had "needed" and "unknown" before.
Export this knowledge to the rest of the kernel and enhance the existing
kvm_arm_harden_branch_predictor() to report this new state as well.
Export this new state to guests when they use KVM's firmware interface
emulation.
so the hyper-v clocksource update can be applied.
Different mechanisms are used to test and set elf_hwcaps between ARM
and ARM64, this results in the use of ifdeferry in this file when
setting/testing for the EVTSTRM hwcap.
Let's improve readability by extracting this to an arch helper.
Signed-off-by: Andrew Murray <andrew.murray@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
This file implements the flat get/put reloc helpers for architectures
that do not need to overload the relocs by simply using get_user/put_user.
Note that many nommu architectures currently use {get,put}_unaligned, which
looks a little bogus and should probably later be switched over to this
version as well.
Reviewed-by: Vladimir Murzin <vladimir.murzin@arm.com>
Signed-off-by: Greg Ungerer <gerg@linux-m68k.org>
This will eventually allow us to kill the need for an <asm/flat.h> for
many cases.
Tested-by: Vladimir Murzin <vladimir.murzin@arm.com>
Instead add a Kconfig variable that only h8300 selects.
This way only the two architectures that do masking need to provide
the helper.
This helper is a no-op on all architectures, remove it.
This helper is the same for all architectures, open code it in the only
caller.
This cleanly handles arches who do not yet define clone3.
clone3() was initially placed under __ARCH_WANT_SYS_CLONE under the
assumption that this would cleanly handle all architectures. It does
not.
Architectures such as nios2 or h8300 simply take the asm-generic syscall
definitions and generate their syscall table from it. Since they don't
define __ARCH_WANT_SYS_CLONE the build would fail complaining about
sys_clone3 missing. The reason this doesn't happen for legacy clone is
that nios2 and h8300 provide assembly stubs for sys_clone. This seems to
be done for architectural reasons.
The build failures for nios2 and h8300 were caught int -next luckily.
The solution is to define __ARCH_WANT_SYS_CLONE3 that architectures can
add. Additionally, we need a cond_syscall(clone3) for architectures such
as nios2 or h8300 that generate their syscall table in the way I
explained above.
Fixes: 8f3220a80654 ("arch: wire-up clone3() syscall")
Signed-off-by: Christian Brauner <christian@brauner.io>
Cc: Adrian Reber <adrian@lisas.de>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: linux-api@vger.kernel.org
Cc: x86@kernel.org
Some big.LITTLE systems have I-Cache line size mismatch between
LITTLE and big cores. This patch adds a workaround for proper I-Cache
support on such systems. Without it, some class of the userspace code
(typically self-modifying) might suffer from random SIGILL failures.
Similar workaround already exists for ARM64 architecture. I has been
added by commit 116c81f427ff ("arm64: Work around systems with mismatched
cache line sizes").
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
show_pte() is used to print information after various other kernel
messages, which themselves are printed at different severities.
Include the severity in the show_pte() information so that associated
messages are printed with the same severity.
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
Based on 1 normalized pattern(s):
published by the free software foundation this program is
distributed in the hope that it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not see http www gnu org
licenses
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 503 file(s).
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Link: https://lkml.kernel.org/r/20190602204653.811534538@linutronix.de
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into arm/soc
This deletes the NetX 100/500 machine support.
After discussing with the subarch maintainers and Hilscher,
we concluded that the netx subarchitecture (Netx 100/500)
is no longer maintained or tested, and noone will miss it
if we delete it. So delete it.
There is a newer Netx 4000 architecture which we may see
included at some point, but this will be supported using
the standard multiplatform and devicetree mechanisms and is
easier to develop from scratch.
* tag 'armsoc-drop-netx-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator:
ARM: delete netx machine
The IOP3xx has some elaborate code to directly slam the
GPIO lines multiplexed with I2C down low before enablement,
apparently a workaround for a hardware bug found in the
early chips.
After consulting the developer documentation for IOP80321
and IOP80331 I can clearly see that this may be useful for
IOP80321 family (mach-iop32x) but it is highly dubious for
any 80331 series or later chip: in these chips the lines
are not multiplexed for UARTs.
We convert the code to pass optional GPIO descriptors
and register these only on the 80321-based boards where
it makes sense, optionally obtain them in the driver and
use the gpiod_set_raw_value() to ascertain the line gets
driven low when needed.
The GPIO driver does not give the GPIO chip a reasonable
label so the patch also adds that so that these machine
descriptor tables can be used.
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
this file is released under the gplv2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 68 file(s).
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Link: https://lkml.kernel.org/r/20190531190114.292346262@linutronix.de
it under the terms and conditions of the gnu general public license
version 2 as published by the free software foundation this program
is distributed in the hope it will be useful but without any
public license along with this program if not write to the free
software foundation inc 51 franklin st fifth floor boston ma 02110
1301 usa
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 111 file(s).
Link: https://lkml.kernel.org/r/20190530000436.567572064@linutronix.de
software foundation inc 59 temple place suite 330 boston ma 02111
1307 usa
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 136 file(s).
Link: https://lkml.kernel.org/r/20190530000436.384967451@linutronix.de
it under the terms of the gnu general public license version 2 and
only version 2 as published by the free software foundation this
program is distributed in the hope that it will be useful but
without any warranty without even the implied warranty of
merchantability or fitness for a particular purpose see the gnu
general public license for more details
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 294 file(s).
Link: https://lkml.kernel.org/r/20190529141900.825281744@linutronix.de
this software is licensed under the terms of the gnu general public
license version 2 as published by the free software foundation and
may be copied distributed and modified under those terms this
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 285 file(s).
Link: https://lkml.kernel.org/r/20190529141900.642774971@linutronix.de
software foundation 51 franklin street fifth floor boston ma 02110
1301 usa
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 67 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Link: https://lkml.kernel.org/r/20190529141333.953658117@linutronix.de
When calling debugfs functions, there is no need to ever check the
return value. The function can work or not, but the code logic should
never do something different based on this.
Cc: Jinbum Park <jinb.park7@gmail.com>
Acked-by: Laura Abbott <labbott@redhat.com>
As a step towards making the atomic64 API use consistent types treewide,
let's have the arm atomic64 implementation use s64 as the underlying
type for atomic64_t, rather than long long, matching the generated
headers.
Otherwise, there should be no functional change as a result of this
patch.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: aou@eecs.berkeley.edu
Cc: arnd@arndb.de
Cc: bp@alien8.de
Cc: catalin.marinas@arm.com
Cc: davem@davemloft.net
Cc: fenghua.yu@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: ink@jurassic.park.msu.ru
Cc: jhogan@kernel.org
Cc: mattst88@gmail.com
Cc: mpe@ellerman.id.au
Cc: palmer@sifive.com
Cc: paul.burton@mips.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: rth@twiddle.net
Cc: tony.luck@intel.com
Cc: vgupta@synopsys.com
Link: https://lkml.kernel.org/r/20190522132250.26499-7-mark.rutland@arm.com
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0
Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com>
licenses
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 228 file(s).
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Link: https://lkml.kernel.org/r/20190528171438.107155473@linutronix.de
license terms gnu general public license gpl version 2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 161 file(s).
Link: https://lkml.kernel.org/r/20190528170027.447718015@linutronix.de
for more details
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 655 file(s).
Link: https://lkml.kernel.org/r/20190527070034.575739538@linutronix.de
