Picked from the upstream linux tree:
* ARM: 6396/1: Add SWP/SWPB emulation for ARMv7 processors
(commit 64d2dc384e41e2b7acead6804593ddaaf8aad8e1)
Change-Id: Ia7fca787b68e7fda9b937005f6daaefda89fa56a
Reviewed-on: http://git-master/r/29741
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
arch/arm/kernel/entry-armv.S
arch/arm/kernel/setup.c
arch/arm/mm/init.c
This function is used by vmcore code to read a page from the old
kernel memory.
Signed-off-by: Mika Westerberg <ext-mika.1.westerberg@nokia.com>
This was deprecated in 2001 and announced to live on for 5 years.
For now provide a kernel parameter for those who still need it.
Acked-by: Eric Miao <eric.miao@canonical.com>
This patch implements support for ARMv6 performance counters in the
Linux performance events subsystem. ARMv6 architectures that have the
performance counters should enable HW_PERF_EVENTS to get hardware
performance events support in addition to the software events.
Note: only ARM Ltd ARM cores are supported.
This implementation also provides an ARM PMU abstraction layer to allow
ARMv7 and others to be supported in the future by adding new a
'struct arm_pmu'.
Cc: Jean Pihet <jpihet@mvista.com>
Signed-off-by: Jamie Iles <jamie.iles@picochip.com>
To add support for perf events and to allow the hardware counters to be
shared with oprofile, we need a way to reserve access to the pmu
(performance monitor unit). Platforms with PMU interrupts should
register the interrupts in arch/arm/kernel/pmu.c
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
This patch allows an earlyprintk console if CONFIG_DEBUG_LL is enabled,
using the printch asm function.
The patch is based on the original work by Sascha Hauer.
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Pavel Machek <pavel@ucw.cz>
This driver implements support for on-chip Embedded Tracing Macrocell and
Embedded Trace Buffer. It allows to trigger tracing of kernel execution flow
and exporting trace output to userspace via character device and a sysrq
combo.
Trace output can then be decoded by a fairly simple open source tool [1]
which is already sufficient to get the idea of what the kernel is doing.
[1]: http://github.com/virtuoso/etm2human
Signed-off-by: Alexander Shishkin <virtuoso@slind.org>
MAINTAINERS
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported:
Bash 4 filters out variables which contain a dot in them.
This happends to be the case of CPPFLAGS_vmlinux.lds.
This is rather unfortunate, as it now causes
build failures when using SHELL=/bin/bash to compile,
or when bash happens to be used by make (eg when it's /bin/sh)
Remove the common definition of CPPFLAGS_vmlinux.lds by
pushing relevant stuff to either Makefile.build or the
arch specific kernel/Makefile where we build the linker script.
This is also nice cleanup as we move the information out where
it is used.
Notes for the different architectures touched:
arm - we use an already exported symbol
cris - we use a config symbol aleady available
[Not build tested]
mips - the jiffies complexity has moved to vmlinux.lds.S where we need it.
Added a few variables to CPPFLAGS - they are only used by
the linker script.
[Not build tested]
powerpc - removed assignment that is not needed
[not build tested]
sparc - simplified it using $(BITS)
um - introduced a few new exported variables to deal with this
xtensa - added options to CPP invocation
[not build tested]
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Chris Zankel <chris@zankel.net>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This adds the TCM interface to Linux, when active, it will
detect and report TCM memories and sizes early in boot if
present, introduce generic TCM memory handling, provide a
generic TCM memory pool and select TCM memory for the U300
platform.
See the Documentation/arm/tcm.txt for documentation.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
From: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
As __builtin_return_address(n) doesn't work for ARM with n > 0, the
kernel needs its own implementation.
This fixes many warnings saying:
warning: unsupported argument to '__builtin_return_address'
The new methods and walk_stackframe must not be instrumented because
CALLER_ADDRESSx is used in the various tracers and tracing the tracer is
a bad idea.
What's currently missing is an implementation using unwind tables. This
is not fatal though, it's just that the tracers don't get enough
information to be really useful.
Note that if both ARM_UNWIND and FRAME_POINTER are enabled,
walk_stackframe uses unwind information. So in this case the same
implementation is used as when FRAME_POINTER is disabled.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
This patch also makes the frame pointer default to y only if
!ARM_UNWIND. LOCKDEP no longer selects FRAME_POINTER if ARM_UNWIND is
enabled.
Add support for detecting non-executable stack binaries, and adjust
permissions to prevent execution from data and stack areas. Also,
ensure that READ_IMPLIES_EXEC is enabled for older CPUs where that
is true, and for any executable-stack binary.
This patch adds the ARCH=arm specific a kgdb backend, originally
written by Deepak Saxena <dsaxena@plexity.net> and George Davis
<gdavis@mvista.com>. Geoff Levand <geoffrey.levand@am.sony.com>,
Nicolas Pitre, Manish Lachwani, and Jason Wessel have contributed
various fixups here as well.
The KGDB patch makes one change to the core ARM architecture such that
the traps are initialized early for use with the debugger or other
subsystems.
[ mingo@elte.hu: small cleanups. ]
[ ben-linux@fluff.org: fixed early_trap_init ]
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Deepak Saxena <dsaxena@plexity.net>
Core ftrace support for the ARM architecture, which includes support
for dynamic function tracing.
Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com>
This patch adds the detection and handling of the ThumbEE extension on
ARMv7 CPUs.
Semaphores are no longer performance-critical, so a generic C
implementation is better for maintainability, debuggability and
extensibility. Thanks to Peter Zijlstra for fixing the lockdep
warning. Thanks to Harvey Harrison for pointing out that the
unlikely() was unnecessary.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Currently, the atags used by kexec are fixed to the ones originally used
to boot the kernel. This is less than ideal as changing the commandline,
initrd and other options would be a useful feature.
This patch exports the atags used for the current kernel to userspace
through an "atags" file in procfs. The presence of the file is
controlled by its own Kconfig option and cleans up several ifdef blocks
into a separate file. The tags for the new kernel are assumed to be at
a fixed location before the kernel image itself. The location of the
tags used to boot the original kernel is unimportant and no longer
saved.
Based on a patch from Uli Luckas <u.luckas@road.de>
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Acked-by: Uli Luckas <u.luckas@road.de>
This is a full implementation of Kprobes including Jprobes and
Kretprobes support.
This ARM implementation does not follow the usual kprobes double-
exception model. The traditional model is where the initial kprobes
breakpoint calls kprobe_handler(), which returns from exception to
execute the instruction in its original context, then immediately
re-enters after a second breakpoint (or single-stepping exception)
into post_kprobe_handler(), each time the probe is hit.. The ARM
implementation only executes one kprobes exception per hit, so no
post_kprobe_handler() phase. All side-effects from the kprobe'd
instruction are resolved before returning from the initial exception.
As a result, all instructions are _always_ effectively boosted
regardless of the type of instruction, and even regardless of whether
or not there is a post-handler for the probe.
Signed-off-by: Quentin Barnes <qbarnes@gmail.com>
Signed-off-by: Nicolas Pitre <nico@marvell.com>
This is the code implementing instruction single-stepping for kprobes
on ARM.
To get around the limitation of no Next-PC and no hardware single-
stepping, all kprobe'd instructions are split into three camps:
simulation, emulation, and rejected. "Simulated" instructions are
those instructions which behavior is reproduced by straight C code.
"Emulated" instructions are ones that are copied, slightly altered
and executed directly in the instruction slot to reproduce their
behavior. "Rejected" instructions are ones that could be simulated,
but work hasn't been put into simulating them. These instructions
should be very rare, if not unencountered, in the kernel. If ever
needed, code could be added to simulate them.
One might wonder why this and the ptrace singlestep facility are not
sharing some code. Both approaches are fundamentally different because
the ptrace code regains control after the stepped instruction by installing
a breakpoint after the instruction itself, and possibly at the location
where the instruction might be branching to, instead of simulating or
emulating the target instruction.
The ptrace approach isn't suitable for kprobes because the breakpoints
would have to be moved back, and the icache flushed, everytime the
probe is hit to let normal code execution resume, which would have a
significant performance impact. It is also racy on SMP since another
CPU could, with the right timing, sail through the probe point without
being caught. Because ptrace single-stepping always result in a
different process to be scheduled, the concern for performance is much
less significant.
On the other hand, the kprobes approach isn't (currently) suitable for
ptrace because it has no provision for proper user space memory
protection and translation, and even if that was implemented, the gain
wouldn't be worth the added complexity in the ptrace path compared to
the current approach.
So, until kprobes does support user space, both kprobes and ptrace are
best kept independent and separate.
Add support for stacktrace. Use the new stacktrace code with
oprofile instead of it's version; there's no point having
multiple versions of stacktracing in the kernel.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (117 commits)
[ARM] 4058/2: iop32x: set ->broken_parity_status on n2100 onboard r8169 ports
[ARM] 4140/1: AACI stability add ac97 timeout and retries
[ARM] 4139/1: AACI record support
[ARM] 4138/1: AACI: multiple channel support for IRQ handling
[ARM] 4211/1: Provide a defconfig for ns9xxx
[ARM] 4210/1: base for new machine type "NetSilicon NS9360"
[ARM] 4222/1: S3C2443: Remove reference to missing S3C2443_PM
[ARM] 4221/1: S3C2443: DMA support
[ARM] 4220/1: S3C24XX: DMA system initialised from sysdev
[ARM] 4219/1: S3C2443: DMA source definitions
[ARM] 4218/1: S3C2412: fix CONFIG_CPU_S3C2412_ONLY wrt to S3C2443
[ARM] 4217/1: S3C24XX: remove the dma channel show at startup
[ARM] 4090/2: avoid clash between PXA and SA1111 defines
[ARM] 4216/1: add .gitignore entries for ARM specific files
[ARM] 4214/2: S3C2410: Add Armzone QT2410
[ARM] 4215/1: s3c2410 usb device: per-platform vbus_draw
[ARM] 4213/1: S3C2410 - Update definition of ADCTSC_XY_PST
[ARM] 4098/1: ARM: rtc_lock only used with rtc_cmos
[ARM] 4137/1: Add kexec support
[ARM] 4201/1: SMP barriers pair needed for the secondary boot process
Fix up conflict due to typedef removal in sound/arm/aaci.h
Add kexec support to ARM.
Improvements like commandline handling could be made but this patch gives
basic functional support. It uses the next available syscall number, 347.
Once the syscall number is known, userspace support will be
finalised/submitted to kexec-tools, various patches already exist.
Originally based on a patch by Maxim Syrchin but updated and forward
ported by various people.
XScale cores either have a DSP coprocessor (which contains a single
40 bit accumulator register), or an iWMMXt coprocessor (which contains
eight 64 bit registers.)
Because of the small amount of state in the DSP coprocessor, access to
the DSP coprocessor (CP0) is always enabled, and DSP context switching
is done unconditionally on every task switch. Access to the iWMMXt
coprocessor (CP0/CP1) is enabled only when an iWMMXt instruction is
first issued, and iWMMXt context switching is done lazily.
CONFIG_IWMMXT is supposed to mean 'the cpu we will be running on will
have iWMMXt support', but boards are supposed to select this config
symbol by hand, and at least one pxa27x board doesn't get this right,
so on that board, proc-xscale.S will incorrectly assume that we have a
DSP coprocessor, enable CP0 on boot, and we will then only save the
first iWMMXt register (wR0) on context switches, which is Bad.
This patch redefines CONFIG_IWMMXT as 'the cpu we will be running on
might have iWMMXt support, and we will enable iWMMXt context switching
if it does.' This means that with this patch, running a CONFIG_IWMMXT=n
kernel on an iWMMXt-capable CPU will no longer potentially corrupt iWMMXt
state over context switches, and running a CONFIG_IWMMXT=y kernel on a
non-iWMMXt capable CPU will still do DSP context save/restore.
These changes should make iWMMXt work on PXA3xx, and as a side effect,
enable proper acc0 save/restore on non-iWMMXt capable xsc3 cores such
as IOP13xx and IXP23xx (which will not have CONFIG_CPU_XSCALE defined),
as well as setting and using HWCAP_IWMMXT properly.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Add the necessary call to register_isa_ports() so that glibc knows
where these are found on Integrator platforms.
Patch from Lennert Buytenhek
This patch makes the iWMMXt context switch hook use the generic
thread notifier infrastructure that was recently merged in commit
d6551e884cf66de072b81f8b6d23259462c40baf.
Add the necessary kernel bits for crunch task switching.
This patch fix compilation problem of start-up codes.
(head-nommu.S, arch/arm/kernel/Makefile)
Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com>
Patch from Nicolas Pitre
The difference between EABI and the legacy ABI may affect either
structure member alignment and/or argument register selection.
The patch has the details.
Included are wrappers for the following syscalls:
sys_stat64
sys_lstat64
sys_fstat64
sys_fcntl64
sys_epoll_ctl
sys_epoll_wait
sys_ipc
sys_semop
sys_semtimedop
sys_pread64
sys_pwrite64
sys_truncate64
sys_ftruncate64
sys_readahead
Signed-off-by: Nicolas Pitre <nico@cam.org>
ISA_DMA_API tells the rest of the kernel if the ISA DMA API is
available. Select this symbol only on machine types which make
use of the ISA DMA API.
Make building of arch/arm/kernel/dma.c depend on this symbol -
if a machine does not support the ISA DMA API, it's pointless
building this file.
We are coding the kernel link address into the makefiles, which is
invisibly dependent on PAGE_OFFSET. If PAGE_OFFSET is changed, the
makefiles also need to be changed.
Make adjustments such that the makefiles encode just the offset from
PAGE_OFFSET for the kernel link address, and use PAGE_OFFSET in the
linker scripts directly.
Since vmlinux.lds.S is preprocessed, we can use the defines already
present in asm/memory.h (allowed by patch #3060) for the XIP kernel link
address instead of relying on a duplicated Makefile hardcoded value, and
also get rid of its dependency on awk to handle it at the same time.
While at it let's clean XIP stuff even further and make things clearer
in head.S with a nice code reduction.
This is not used anymore - RiscPC now contains the necessary
supporting code.
Move common includes to entry-header, and file specific includes
to the relevant file.
Signed-off-by: Russell King <rmk@arm.linux.org.uk>
infrastructure for it.
Let it rip!
