path: root/arch/arm/kernel/armksyms.c
2006-01-14[ARM] 3104/1: ARM EABI: new helper function namesNicolas Pitre
Patch from Nicolas Pitre The ARM EABI defines new names for GCC helper functions. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-18[ARM] Fix get_user when passed a const pointerRussell King
Unfortunately, later gcc versions error out when our get_user is passed a const pointer, since we write to a temporary variable declared as typeof(*(p)) which propagates the const-ness. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-08[ARM] 3134/1: add missing EXPORT_SYMBOL for the ARM version of sha_transformNicolas Pitre
Patch from Nicolas Pitre Noticed by Woody Suwalski <woodys@xandros.com>. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-12[ARM] 2977/1: armksyms.c - make items in export table staticBen Dooks
Patch from Ben Dooks The items in the export table do not need to be exported elsehwere, so quash the sparse warning by making the symbol for the table entry static. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-06[PATCH] ARM: 2791/1: Add CRCs for aliased ARM symbolsTodd Poynor
Patch from Todd Poynor Fix module versioning for 3 ARM symbols that do not have CRCs added, avoid "disagrees about version of symbol struct_module" errors at module load time. From David Singleton. Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: 2723/2: remove __udivdi3 and __umoddi3 from the kernelNicolas Pitre
Patch from Nicolas Pitre Those are big, slow and generally not recommended for kernel code. They are even not present on i386. So it should be concluded that one could as well get away with do_div() alone. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
