path: root/arch/arm/lib/copy_from_user.S
2010-04-21ARM: fix build error in arch/arm/kernel/process.cRussell King
/tmp/ccJ3ssZW.s: Assembler messages: /tmp/ccJ3ssZW.s:1952: Error: can't resolve `.text' {.text section} - `.LFB1077' This is caused because: .section .data .section .text .section .text .previous does not return us to the .text section, but the .data section; this makes use of .previous dangerous if the ordering of previous sections is not known. Fix up the other users of .previous; .pushsection and .popsection are a safer pairing to use than .section and .previous. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Thumb-2: Implement the unified arch/arm/lib functionsCatalin Marinas
This patch adds the ARM/Thumb-2 unified support for the arch/arm/lib/* files. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] Remove the __arch_* layer from uaccess.hRussell King
Back in the days when we had armo (26-bit) and armv (32-bit) combined, we had an additional layer to the uaccess macros to ensure correct typing. Since we no longer have 26-bit in this tree, we no longer need this layer, so eliminate it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-01[ARM] 2948/1: new preemption safe copy_{to|from}_user implementationNicolas Pitre
Patch from Nicolas Pitre This patch provides a preemption safe implementation of copy_to_user and copy_from_user based on the copy template also used for memcpy. It is enabled unconditionally when CONFIG_PREEMPT=y. Otherwise if the configured architecture is not ARMv3 then it is enabled as well as it gives better performances at least on StrongARM and XScale cores. If ARMv3 is not too affected or if it doesn't matter too much then uaccess.S could be removed altogether. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
