path: root/arch/arm/mach-at91/Kconfig
2011-05-25at91: drop at572d940hf supportJean-Christophe PLAGNIOL-VILLARD
no-one use it and it's nearly impossible get a board to work on it and the Mainline implementation was never finished Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Andrew Victor <linux@maxim.org.za>
2011-05-25at91: remove MTD_NAND_ATMEL_BUSWIDTH_16 optionJean-Christophe PLAGNIOL-VILLARD
no board configure it as 'n' and it's an issue to merge all defconfigs in one On AT91SAM926x boards both types of NAND flash can be present (8 and 16 bit data bus width). so will pass it via system_rev Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-04-23ARM: at91: AT91CAP9 has a macb deviceUwe Kleine-König
commit ee621dd (net: atmel_macb Kconfig: remove long dependency line) replaced a list of several explicit machines in the dependencies of MACB by a single symbol that is selected by the respective machines. ee621dd missed to let ARCH_AT91CAP9 select HAVE_NET_MACB though which is fixed here. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2011-01-14AT91: Support for gsia18s boardIgor Plyatov
The GS_IA18_S (GMS) is a carrier board from GeoSIG Ltd used with the Stamp9G20 SoM from Taskit company. It operate as an internet accelerometer. Signed-off-by: Igor Plyatov <plyatov@gmail.com> [nicolas.ferre@atmel.com: rm Kconfig, whitespace fixes, change machine name] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-01-14AT91: Acme Systems FOX Board G20 board filesSergio Tanzilli
Signed-off-by: Sergio Tanzilli <tanzilli@acmesystems.it> [nicolas.ferre@atmel.com: whitespace fixes, change machine name] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-26AT91: add board support for Pcontrol_G20Peter Gsellmann
Board is a carrier board for Stamp9G20, with additional peripherals for a building automation system Signed-off-by: Peter Gsellmann <pgsellmann@portner-elektronik.at> [nicolas.ferre@atmel.com: remove machine_desc.io_pg_offst and .phys_io] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-19Merge branch 'devel-stable' into develRussell King
2010-10-18Update broken web addresses in arch directory.Justin P. Mattock
The patch below updates broken web addresses in the arch directory. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-07net: atmel_macb Kconfig: remove long dependency lineJean-Christophe PLAGNIOL-VILLARD
Many Atmel SOC are embedding a MACB controller. This patch removes the long dependency line for this Atmel MACB ethernet driver configuration entry. The HAVE_NET_MACB configuration option is located in the net Kconfig file as it may be setup by ARM/AT91 and AVR32 chips. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: David Miller <davem@davemloft.net> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-10-07AT91: at91sam9g20ek: merge 2mmc version in one boardJean-Christophe PLAGNIOL-VILLARD
The board-sam9g20ek-2slot-mmc.c was a revision of the at91sam9g20ek since board revision C. It contains 2 sd/mmc slots. This merge keep the support of the old machine ID MACH_AT91SAM9G20EK_2MMC for backward compatibility. Now we use the ATAG to pass the hardware functionality to kernel with this board revision encoding bit 0: 0 => 1 sd/mmc slot 1 => 2 sd/mmc slots connectors (board from revision C) system_rev tested on Barebox commit d8f3ee103a9f4bd Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-07AT91: at91sam9m10g45ek: use the right machine idJean-Christophe PLAGNIOL-VILLARD
Today the board use 2 machines id AT91SAM9G45EKES and AT91SAM9M10G45EK now will use only AT91SAM9M10G45EK. The other boards revision will be specified via system_rev. for 9g45ekes, m10g45ekes and m10g45ek boards and revisions Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-04ARM: 6393/1: AT91: Add flexibity board supportMaxim Osipov
This patch adds support for Flexibity Connect platform from http://www.flexibity.com/ (AT91SAM9260 based). Signed-off-by: Maxim Osipov <maxim.osipov@gmail.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-09ARM: 6209/2: at91: Add support for Bluewater Systems Snapper 9260/9G20 modulesRyan Mallon
Add support for Bluewater Systems Snapper 9260/9G20 modules Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-18ARM: remove 'select GENERIC_TIME'Russell King
GENERIC_TIME is now enabled by default, so 'select GENERIC_TIME' is redundant. Remove them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-17Merge branches 'at91', 'bcmring', 'ep93xx', 'iop', 'misc', 'nomadik', ↵Russell King
'omap', 'pxa', 'spear' and 'versatile' into devel Conflicts: arch/arm/Makefile arch/arm/common/Makefile arch/arm/mm/Kconfig
2010-04-14ARM: 6054/1: AT91: taskit PortuxG20 and Stamp9G20 board supportChristian Glindkamp
Both boards share the same board file, as the PortuxG20 is basically an SBC based on the Stamp9G20. Signed-off-by: Christian Glindkamp <christian.glindkamp@taskit.de> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-24ARM: convert arm to arch_gettimeoffset()John Stultz
Convert arm to use GENERIC_TIME via the arch_getoffset() infrastructure, reducing the amount of arch specific code we need to maintain. The arm architecture is the last arch that need to be converted. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2010-01-20ARM: 5851/1: [AT91] AT572D940HF-EK board supportAndrew Victor
Add support for the Atmel AT572D940HF-EK board (development board for the AT572D940HF processor). Signed-off-by: Antonio R. Costa <costa.antonior@gmail.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-20ARM: 5850/1: [AT91] AT572D940HF processor supportAndrew Victor
Add support for the Atmel AT572D940HF processor (DIOPSIS range). This processor integrates an ARM926 core, a DSP and the SoC peripherals usually found on an AT91 processor (USART, SSC, SPI, TWI, CAN, etc) Signed-off-by: Antonio R. Costa <costa.antonior@gmail.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-05Merge branch 'devel-stable' into develRussell King
2009-12-05Merge branches 'at91', 'ep93xx', 'etm', 'ks8695', 'nuc', 'u300' and 'u8500' ↵Russell King
into devel
2009-11-16at91: at91sam9g20ek modify dual slot evaluation kitNicolas Ferre
at91sam9g20ek rev. C and onwards embed two SD/MMC slots. This patch modify the previous dual slot board definition to match the official rev. C board. It also allows the use of at91_mci SD/MMC driver in addition to the atmel-mci one. Some pins have been re-affected from leds or Ethernet phy IRQ to the SD/MMC slot A. This lead to a modification of those definitions. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2009-11-16atmel_lcdfb Kconfig: remove long dependency lineNicolas Ferre
Many Atmel SOC are embedding a LCD controller. This patch removes the long dependency line for this Atmel LCD framebuffer driver configuration entry. The HAVE_FB_ATMEL configuration option is located in the video Kconfig file as it may be setup by ARM/AT91 and AVR32 chips. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2009-11-16at91: Kconfig simplificationJean-Christophe PLAGNIOL-VILLARD
Instead of adding "depends on" at config level, introduce HAVE_* config variables. Add them at machine or soc level to specify the ability of a particular support. It will ease new board introduction and readability. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2009-11-16at91: remove not needed depends onJean-Christophe PLAGNIOL-VILLARD
Those "depends on" are a double check as all machine entries are surrounded by "if <ARCH_xxx>" conditions. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2009-11-10ARM: 5782/1: at91: support for eco920Uwe Kleine-König
CONFIG_MACH_ECO920 is enabled in at91rm9200dk_defconfig. The name is wrong, but this is better than adding another defconfig or don't get compile coverage at all. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-23AT91: atmel-mci: Platform configuration to the the atmel-mci driverRob Emanuele
Created a modified version of the at91sam9g20 evaluation kit platform (board-sam9g20ek-2slot-mmc.c) and device support to make use of the updated atmel-mci driver. As the use of two slots modify GPIO pin allocation, we create another board file. This requires getting the most updated arch/arm/tools/mach-types from http://www.arm.linux.org.uk/developer/machines/download.php to have the machine type for the at91sam9g20ek-2slot-mmc board. [nicolas.ferre@atmel.com: printk, slot_count modification in at91sam9260_devices.c file] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Rob Emanuele <rob@emanuele.us> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-30ARM: 5630/1: Add support for Eukrea's CPUAT91Eric Bénard
CPUAT91 is based on Atmel's AT91RM9200 with up to 16MB Strataflash, up to 128MB SDRAM and an ethernet PHY in RMII mode. Signed-off-by: Eric Benard <ebenard@eukrea.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-30ARM: 5629/1: Add support for Eukrea's CPU9260 & CPU9G20Eric Bénard
CPU9260 and CPU9G20 share the same PCB populated with either Atmel's AT91SAM9260B or AT91SAM9G20B with up to 64MB Strataflash, up to 128MB SDRAM, up to 2GB NAND and an ethernet PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-02[ARM] 5570/1: at91: Support for at91sam9g10: core chip & board supportNicolas Ferre
From: Hong Xu <hong.xu@atmel.com> Here are the modification to at91sam9261 files dedicated to the support of at91sam9g10. This direction has been adopted to minimize code duplication. All at91sam9261 drivers are enabled in _devices and board- files. Modificaton to peripherals that support at91sam9g10 will be added in future patches. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-27[ARM] 5572/1: at91: Support for at91sam9g45 series: core chip & board supportNicolas Ferre
Here are the at91 specific files dedicated to the at91sam9g45 series. They mimic the traditional at91 way of managing chips & boards. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. In the future, the main board for this 9g45 series will be the AT91SAM9M10G45-EK (I choose this last name for the board file). Simple drivers are enabled in _devices and board- files. Newer peripheral support will be added in future patches. Incuded peripherals support (for now): - USART - SPI - Ethernet - NAND flash - LCD - gpio/joystick/buttons - leds and pwm Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-01[ARM] 5290/1: [AT91] Add support for the Adeneo NeoCore 926 boardAndrew Victor
Add support for the Adeneo NeoCore 926 board. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-27[ARM] Arrange for platforms to select appropriate CPU supportRussell King
Rather than: config CPU_BLAH bool depends on ARCH_FOO || MACH_BAR default y if ARCH_FOO || MACH_BAR arrange for ARCH_FOO and MACH_BAR to select CPU_BLAH directly. Acked-by: Nicolas Pitre <nico@marvell.com> Acked-by: Andrew Victor <linux@maxim.org.za> Acked-by: Brian Swetland <swetland@google.com> Acked-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Bellido <ml@acolin.be> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-21[ARM] 5264/2: [AT91] Suspend-to-RAM disables main oscillatorAndrew Victor
This patch adds support for a low(er)-power suspend-to-RAM. In addition to the SDRAM being put into self-refresh mode, the Master Clock is set to the Slow-clock rate (32Khz) and PLLA & PLLB are disabled. Certain peripherals are therefore also disabled, and thus cannot be used as wakeup sources. This patch has been included in the AT91 patches in various forms since 2.6.19 and a number of people have worked or commented on it, most notably: Savin Zlobec (for the original AT91RM9200 support) Anti Sullin (for the SAM9260 version) David Brownell, etc. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-18[ARM] 5210/2: AFEB9260: board supportSergey Lapin
This patch adds support for AT91SAM9260-based board AFEB9260 which is a product from both Open Source design which runs Open Source software. Some commertial projects are made with this design. A board is basically AT91SAM9260-EK with some modifications and different peripherals and different parts used. Main purpose of this project is to gain experience in hardware design. More info: http://groups.google.com/group/arm9fpga-evolution-board (In Russian only, sorry). Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb By this patch only basic functionality is provided. Signed-off-by: Sergey Lapin <slapin@ossfans.org> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-01Fix rename of at91_nand -> atmel_nandPieter du Preez
Structs called at91_nand_data where renamed to atmel_nand_data and configs called *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL*. This was unfortunately not done consistently, causing NAND chips not being initialised on several ARM boards. I am aware that the author of the original change did not rename MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example. All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order to keep naming consistency. This patch was only tested on a MACH_SAM9_L9260, as this is the only ARM board I have to my disposal. Before this patch: $ git-ls-files |xargs grep atmel_nand |wc -l 105 $ git-ls-files |xargs grep at91_nand |wc -l 4 $ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l 8 $ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l 47 After this patch: $ git-ls-files |xargs grep atmel_nand |wc -l 109 $ git-ls-files |xargs grep at91_nand |wc -l 0 $ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l 55 $ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l 0 Signed-off-by: Pieter du Preez <pdupreez@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10[ARM] 5130/4: Support for the at91sam9g20sedji gaouaou
Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC. AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. We created a new board for this device but based the chip support directly on 9260 files with little updates. Here is the chip page on Atmel wabsite: http://atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Justin Waters <justin.waters@timesys.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5057/1: [AT91] Calao Systems - board filesAndrew Victor
Add support for three AT91-based boards available from Calao Systems: USB_A9260, USB_A9263 and QIL_A9260. Signed-off-by: Grégory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5056/1: [AT91] Cleanup YL9200 board fileAndrew Victor
Cleanup the YL9200 board-support file. Other things fixed are: - Use new-style UART initialization - Register all LEDs as gpio_leds. - NOR Flash error noted in comments fixed by increasing YL9200_FLASH_SIZE - The only I2C device is the AT24C eeprom. - Setup of NWAIT pin and programming of SMC controller for the LCD/VGA. - Configure touchscreen interrupt pin. Also adding the board to the KConfig and Makefile. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4989/1: [AT91] SAM9 ClockSource / ClockEventsAndrew Victor
Update AT91SAM9/CAP9 PIT driver to use generic time and clockevent infrastructure: - Clocksource gives sub-microsecond timestamp precision, assuming memory is clocked at over 16 MHz. It's less than a 32 bit counter, unless it's is also generating IRQs. - Clockevent device supports periodic mode only; no oneshot support from this hardware. No IRQs generated unless it's the active clocksource. Later, another timer (probably from a TC module) can provide a oneshot clockevent device to get NO_HZ and High-Res-Timer behavior. This also updates the timekeeping to use the actual master clock rate on the system, instead of compile-time <asm/arch/timex.h> constants matching what Atmel's EK boards use. (Product boards may well differ!) Plus cleanup: rename "*_timer*" symbols to "*_pit*" (there are other timers, but only one PIT); shorter lines; remove needless CPP stuff; make several symbols static; etc. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4980/1: [AT91] emQbit ECB_AT91 board supportAndrew Victor
Support for the emQbit ECB_AT91 board. <http://wiki.emqbit.com/free-ecb-at91> Original patch from Nelson Castillo. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4979/1: [AT91] Olimex SAM9-L9260 board supportAndrew Victor
Support for the Olimex SAM9-L9260 board. <http://www.olimex.com/dev/sam9-L9260.html> Original patch from Ivan Vasilev. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4978/1: [AT91] KB9260 (CAM60) board supportAndrew Victor
Support for the Kwikbyte KB9260 (CAM60) board. <http://www.kwikbyte.com/KB9260.html> Original patch from Kwikbyte. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4660/3: at91: allow selecting UART for early kernel messagesGuennadi Liakhovetski
Currently early kernel messages, i.e., those from uncompression, go to the debugging UART. And if it is enabled in the platform configuration, but not initialized by the bootloader, the machine hangs, waiting for UART status change. Besides, having those messages on another UART - typically the console UART - may be preferrable. This patch allows selecting the UART in kernel configuration. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4765/1: [AT91] AT91CAP9A-DK board supportAndrew Victor
Add support for the Atmel AT91CAP9A-DK Evaluation Kit board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4764/1: [AT91] AT91CAP9 core supportAndrew Victor
Add support for Atmel's AT91CAP9 Customizable Microcontroller family. <http://www.atmel.com/products/AT91CAP/Default.asp> Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4646/1: AT91: configurable HZ, default to 128David Brownell
This makes HZ configurable on AT91, following the model used on OMAP. It defaults to a power of two on AT91rm9200 chips, avoiding rounding errors which come from dividing a 32 KiHz clock to generate scheduler irqs; and uses 100 on AT91sam926x chips, using MCK/16 (multi-MHZ). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Remy Bhmer <linux@bohmer.net> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4539/1: clocksource and clockevents for at91rm9200David Brownell
GENERIC_TIME and GENERIC_CLOCKEVENTS support for the at91rm9200. - Oneshot mode (used for NO_HZ and high res timers) uses the alarm to emulate a real oneshot timer; the trickiest bit is how to avoid some lowlevel races. Thanks to Remy Bohmer for various fixes to this code. - Tighten up periodic mode support using the PIT. - Streamline reads of the 32KHz counter. Thanks to Marc Pignat for some testing results: the CRTR register has *very* odd behavior. The reread appears to work around stranger glitches than just getting an old clock value (which would quickly self-correct). - Remove the rounding-up of tick_usec to 10.009 msec (32KiHz/100), since that no longer acts correct (time increases too fast). Note that the at91sam9 and at91x40 chips need other solutions, since they don't have the same system timer module. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Bill Gatliff <bgat@billgatliff.com> Acked-by:Remy Bohmer <linux@bohmer.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
