Use gpio_is_valid also for overcurrent pins (which are currently
negative in many board files).
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The i2c core driver will turn the platform device ID to busnum
When using platfrom device ID as -1, it means dynamically assigned
the busnum. When writing code, we need to make sure the busnum,
and call i2c_register_board_info(int busnum, ...) to register device
if using -1, we do not know the value of busnum
In order to solve this issue, set the platform device ID as a fix number
Here using 0 to match the busnum used in i2c_regsiter_board_info()
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: stable <stable@vger.kernel.org> [very long time]
Pull i2c-embedded changes from Wolfram Sang:
"The changes for i2c-embedded include:
- massive rework of the omap driver
- massive rework of the at91 driver. In fact, the old driver gets
removed; I am okay with this approach since the old driver was
depending on BROKEN and its limitations made it practically
unusable, so people used bitbanging instead. But even if there are
users, there is no platform_data or module parameter which would
need to be converted. It is just another driver doing I2C
transfers, just way better. Modifications of arch/arm/at91 related
files have proper acks from the maintainer.
- new driver for R-Car I2C
- devicetree and generic_clock conversions and fixes
- usual driver fixes and changes.
The rework patches have come a long way and lots of people have been
involved in creating/testing them. Most patches have been in
linux-next at least since 3.6-rc5. A few have been added in the last
week, I have to admit.
An unexpected (but welcome :)) peak in private life is the cause for
that. The "late" patches shouldn't cause any merge conflicts and I
will have a special eye on them during the stabilization phase. This
is an exception and I want to have the patches in place properly in
time again for the next kernels."
* 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (44 commits)
MXS: Implement DMA support into mxs-i2c
i2c: add Renesas R-Car I2C driver
i2c: s3c2410: use clk_prepare_enable and clk_disable_unprepare
ARM: OMAP: convert I2C driver to PM QoS for MPU latency constraints
i2c: nomadik: Add Device Tree support to the Nomadik I2C driver
i2c: algo: pca: Fix chip reset function for PCA9665
i2c: mpc: Wait for STOP to hit the bus
i2c: davinci: preparation for switch to common clock framework
omap-i2c: fix incorrect log message when using a device tree
i2c: omap: sanitize exit path
i2c: omap: switch over to autosuspend API
i2c: omap: remove unnecessary pm_runtime_suspended check
i2c: omap: switch to threaded IRQ support
i2c: omap: remove redundant status read
i2c: omap: get rid of the "complete" label
i2c: omap: resize fifos before each message
i2c: omap: simplify IRQ exit path
i2c: omap: always return IRQ_HANDLED
i2c: omap: simplify errata check
i2c: omap: bus: add a receiver flag
Pull ARM soc driver specific changes from Olof Johansson:
- A long-coming conversion of various platforms to a common LED
infrastructure
- AT91 is moved over to use the newer MCI driver for MMC
- Pincontrol conversions for samsung platforms
- DT bindings for gscaler on samsung
- i2c driver fixes for tegra, acked by i2c maintainer
Fix up conflicts as per Olof.
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
drivers: bus: omap_l3: use resources instead of hardcoded irqs
pinctrl: exynos: Fix wakeup IRQ domain registration check
pinctrl: samsung: Uninline samsung_pinctrl_get_soc_data
pinctrl: exynos: Correct the detection of wakeup-eint node
pinctrl: exynos: Mark exynos_irq_demux_eint as inline
pinctrl: exynos: Handle only unmasked wakeup interrupts
pinctrl: exynos: Fix typos in gpio/wkup _irq_mask
pinctrl: exynos: Set pin function to EINT in irq_set_type of GPIO EINTa
drivers: bus: Move the OMAP interconnect driver to drivers/bus/
i2c: tegra: dynamically control fast clk
i2c: tegra: I2_M_NOSTART functionality not supported in Tegra20
ARM: tegra: clock: remove unused clock entry for i2c
ARM: tegra: clock: add connection name in i2c clock entry
i2c: tegra: pass proper name for getting clock
ARM: tegra: clock: add i2c fast clock entry in clock table
ARM: EXYNOS: Adds G-Scaler device from Device Tree
ARM: EXYNOS: Add clock support for G-Scaler
ARM: EXYNOS: Enable pinctrl driver support for EXYNOS4 device tree enabled platform
ARM: dts: Add pinctrl node entries for SAMSUNG EXYNOS4210 SoC
ARM: EXYNOS: skip wakeup interrupt setup if pinctrl driver is used
As indicated in the datasheet, TWD and TWCK must not be programmed as
open-drain.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Nikolaus Voss <n.voss@weinmann.de>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
This driver has the following properties compared to the old driver:
1. Support for multiple interfaces.
2. Interrupt driven I/O as opposed to polling/busy waiting.
3. Support for _one_ repeated start (Sr) condition, which is enough
for most real-world applications including all SMBus transfer types.
(The hardware does not support issuing arbitrary Sr conditions on the
bus.)
testing: SoC: at91sam9g45
- BQ20Z80 battery SMBus client.
- on a 2.6.38 kernel with several i2c clients (temp-sensor,
audio-codec, touchscreen-controller, w1-bridge, io-expanders)
Signed-off-by: Nikolaus Voss <n.voss@weinmann.de>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Tested-by: Hubert Feurstein <h.feurstein@gmail.com>
Tested-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Reviewed-by: Nicolas Ferre <nicolas.ferre@atmel.com>
[wsa: squashed with the following patches from Ludovic to have some flaws
fixed:
i2c: at91: use managed resources
i2c: at91: add warning about transmission issues for some devices
i2c: at91: use an id table for SoC dependent parameters
AT91_ID_SYS as virq is incorrect because of spare irq support which
introduces NR_IRQS_LEGACY offset. It modifies rtc-at91sam9 driver in
order to get irq from resources.
at91/mci
AT91 SoC related code modifications: a cleanup in defconfigs and
a one liner in a board file.
The most important is the move to atmel-mci driver in AT91 SoC & boards.
The old at91_mci (marked as deprecated) will be removed in 3.7. So all
platform data for this old driver are erased and replace by information
needed by atmel-mci driver.
* tag 'at91-for-next-soc' of git://github.com/at91linux/linux-at91:
ARM: at91: add atmel-mci support for chips and boards which can use it
ARM: at91/defconfig: change the MCI driver to use in defconfigs
ARM: at91: set i2c_board_info.type to "ds1339" directly
ARM: at91/defconfig: Remove unaffected config option
Since atmel-mci driver supports all atmel mci versions,
use it instead of the deprecated at91_mci driver.
Platform data and all related configuration are removed.
[nicolas.ferre@atmel.com: remove at91_mci platform data]
Enable sparse irq support for multisoc image. It involves to add the
NR_IRQS_LEGACY offset to static SoC irq number definitions since NR_IRQS_LEGACY
irq descs are allocated before AIC requests irq descs allocation.
Move NR_AIC_IRQS macro to a more appropiate place with the purpose to
remove mach/irqs.h later.
at91_set_serial_console is used to define the default console of linux.
This is already manage by the cmdline. And if the boot loader can not be
modified you can still set it by enabling the CONFIG_CMDLINE_EXTEND option.
And then the command-line arguments provided by the boot loader will be
appended to the default kernel command string.
SPI chip select pins have to be checked by gpio_is_valid().
The USB host overcurrent_pin checking was missing.
These two branches are a dependency for the at91 device tree changes,
so we pull them in here. at91/base2+cleanup will get merged through
the arm-soc cleanup2 branch, while the irqdomain tree will be sent
by Grant before this one gets integrated.
drivers/rtc/rtc-at91sam9.c
This variable spread on every SoC that is using the atmel_serial.c
driver can be included directly into the latter.
This will allow to compile multiple soc in the same kernel.
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: kernel@avr32linux.org
The GPBR registers are used for storing RTC values. The GPBR registers
to use are now provided using standard resource entry. The array is
filled in SoC specific code.
rtc-at91sam9 RTT as RTC driver is modified to retrieve this information.
[nicolas.ferre@atmel.com: rework resources assignment]
Reviewed-by: Ryan Mallon <rmallon@gmail.com>
For the RTT as RTC driver rtc-at91sam9, the platform_device structure
is filled during SoC initialization. This will allow to convert this
RTC driver as a standard platform driver.
Cc: linux-usb@vger.kernel.org
Registration of at91_udc as a module will enable SoC
related code.
Fix following an idea from Karel Znamenacek.
Acked-by: Karel Znamenacek <karel@ryston.cz>
Since 193ab2a6070039e7ee2b9b9bebea754a7c52fd1b, various AT91 boards don't
register at91_udc anymore due to depending on a now non-existing symbol.
Fix the symbol name.
Signed-off-by: Anders Darander <anders@chargestorm.se>
we will select now the DBGU used by the soc at Kconfig level
For the DEBUG_LL and early_printk this will allow to select which DBGU to use
this will also allow to select them when multiple SOC are enabled
switch the watchdog drivers to resource and pass it via platform_device
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
In commit fb149f9e28354 we introduce ioremap support for static map_io, we do
not need this register entry anymore.
arch/arm/mach-mxs/include/mach/gpio.h
arch/arm/plat-mxc/include/mach/gpio.h
As a new overcurrent_pin[] array has been added to the at91_usbh_data
structure, those pins must be muxed to work properly. This commit
implements this muxing for all AT91 SoCs that support the AT91 OHCI.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
[nicolas.ferre@atmel.com: added i variable declaration for the loop]
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
we do not change the clock naming convention so does not need to switch
the AVR32 yet
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
specify the port num via platform_data this will allow to match the clock
with the plaform_dev staticaly
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
The recently merged AT91SAM9 watchdog driver uses the
AT91SAM9X_WATCHDOG config variable, whereas the original version of
the driver (and the platform support code) used AT91SAM9_WATCHDOG.
This causes the watchdog platform_device to never be registered, and
therefore the driver not to be initialized.
This patch:
- updates the platform support code to use AT91SAM9X_WATCHDOG.
- includes <linux/io.h> to fix compile error (same fix as was applied
to at91rm9200_wdt.c)
- fixes comment regarding watchdog clock-rates in at91rm9200.
Signed-off-by: Andrew Victor <linux@maxim.org.za>
In at91_add_device_nand(), do not configure the Static Memory
controller with specific timing values.
The *_devices.c files are board independent, and the SMC timing values
are specific to the NAND devices that are installed on the board.
The board-specific files are now responsible for configuring the
Static Memory controller (if the don't want to leave it up to a
bootloader).
This just leaves include/asm-arm/plat-* to deal with.
Structs called at91_nand_data where renamed to atmel_nand_data
and configs called *MTD_NAND_AT91* where renamed to
*MTD_NAND_ATMEL*. This was unfortunately not done consistently,
causing NAND chips not being initialised on several ARM boards.
I am aware that the author of the original change did not rename
MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example.
All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order
to keep naming consistency.
This patch was only tested on a MACH_SAM9_L9260, as this is the
only ARM board I have to my disposal.
Before this patch:
$ git-ls-files |xargs grep atmel_nand |wc -l
105
$ git-ls-files |xargs grep at91_nand |wc -l
4
$ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l
8
$ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l
47
After this patch:
109
0
55
0
Signed-off-by: Pieter du Preez <pdupreez@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
New timings are based on application note
"NAND Flash Support on AT91SAM9 Microcontrollers" available at
http://atmel.com/dyn/resources/prod_documents/doc6255.pdf).
Signed-off-by: Patrice Vilchez <patrice.vilchez@atmel.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
This is basically s/at91_nand/atmel_nand/g with some manual inspection.
Signed-off-by: Håvard Skinnemoen <haavard.skinnemoen@atmel.com>
Fix initialization of framebuffer not calling ioremap_writecombine() function
and not using internal SRAM for at91sam9rl.
This is a little rework of the "Don't initialize a pre-allocated framebuffer"
patch that corrects the call to ioremap_writecombine() function.
It also cuts the use of internal SRAM for at91sam9rl : it is a bit small
for a framebuffer.
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
If the user specified a fixed framebuffer address on the command line, it may
have been initialized already with a splash image or something, so we
shouldn't clear it.
Therefore, we should only initialize the framebuffer if we allocated it
ourselves. This patch also updates the AVR32 setup code to clear the
framebuffer if it allocated it itself, i.e. the user didn't provide a fixed
address or the reservation failed.
I've updated the at91 platform code as well so that it initializes the
framebuffer if it is located in SRAM, but I haven't tested that it actually
works.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Nicolas FERRE <nicolas.ferre@rfo.atmel.com>
Cc: Andrew Victor <andrew@sanpeople.com>
All the SAM9 boards supported by mainline and the AT91 patches have
been converted to the new-style UART initialization. Therefore drop
support for the old at91_init_serial() interface for SAM9.
at91_uarts[] array can also be marked as __initdata.
The warning that no serial-console is defined moved from
at91_set_serial_console() to at91_add_device_serial() since the whole
point is the board-specific file is not calling
at91_set_serial_console().
Register platform_devices for the Timer/Counter Block peripherals
found on the AT91RM9200, SAM9 & CAP9 processors.
Original patch from David Brownell.
The RTT-as-RTC driver will search for the user-specified RTT
peripheral via ID number (0 .. 1).
Therefore if the processor only contains a single RTT peripheral, we
need to set its platform_device.id to "0" instead of "-1".
Also add the missing platform_device resource for the CAP9 processor.
Bug reported by Sedji Gaouaou.
The AT91CAP9 processor includes the same Static Memory Controller
(SMC) peripheral as the SAM9 processors, but replaces the SDRAM
Controller with a DDR/SDR Controller (DDRSDRC).
This patch splits the existing
include/asm-arm/arch-at91/at91sam926x_mc.h into at91sam9_sdramc.h and
at91sam9_smc.h.
It also adds an at91cap9_ddrsdr.h for the DDRSDRC controller.
Currently the udc pullup is enabled by default on boot. If the device
is connected to a host at this time, the host starts the negotiation
before the udc/gadget driver is ready to handle it.
Signed-off-by: Christian Glindkamp <christian.glindkamp@taskit.de>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Move the LED initialization code out of the various *_devices.c files,
and into leds.c.
Also add support for NEW_LEDs.
Patch from David Brownell.
