path: root/arch/arm/mach-at91/at91sam9rl_devices.c
2008-05-14atmel_lcdfb: fix initialization of a pre-allocated framebufferNicolas Ferre
Fix initialization of framebuffer not calling ioremap_writecombine() function and not using internal SRAM for at91sam9rl. This is a little rework of the "Don't initialize a pre-allocated framebuffer" patch that corrects the call to ioremap_writecombine() function. It also cuts the use of internal SRAM for at91sam9rl : it is a bit small for a framebuffer. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: don't initialize a pre-allocated framebufferHaavard Skinnemoen
If the user specified a fixed framebuffer address on the command line, it may have been initialized already with a splash image or something, so we shouldn't clear it. Therefore, we should only initialize the framebuffer if we allocated it ourselves. This patch also updates the AVR32 setup code to clear the framebuffer if it allocated it itself, i.e. the user didn't provide a fixed address or the reservation failed. I've updated the at91 platform code as well so that it initializes the framebuffer if it is located in SRAM, but I haven't tested that it actually works. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Nicolas FERRE <nicolas.ferre@rfo.atmel.com> Cc: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17[ARM] 4982/1: [AT91] Drop old-style UART initialization (Part 1)Andrew Victor
All the SAM9 boards supported by mainline and the AT91 patches have been converted to the new-style UART initialization. Therefore drop support for the old at91_init_serial() interface for SAM9. at91_uarts[] array can also be marked as __initdata. The warning that no serial-console is defined moved from at91_set_serial_console() to at91_add_device_serial() since the whole point is the board-specific file is not calling at91_set_serial_console(). Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4909/1: [AT91] Timer/Counter Block platform_devicesAndrew Victor
Register platform_devices for the Timer/Counter Block peripherals found on the AT91RM9200, SAM9 & CAP9 processors. Original patch from David Brownell. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4908/1: [AT91] RTT platform_device fixAndrew Victor
The RTT-as-RTC driver will search for the user-specified RTT peripheral via ID number (0 .. 1). Therefore if the processor only contains a single RTT peripheral, we need to set its platform_device.id to "0" instead of "-1". Also add the missing platform_device resource for the CAP9 processor. Bug reported by Sedji Gaouaou. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4904/1: [AT91] Pass ECC controller to NAND driverAndrew Victor
On AT91 processors that include an ECC controller, pass its base address to the NAND driver via platform_device resources. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4902/1: [AT91] SAM9/CAP9 memory controller headerAndrew Victor
The AT91CAP9 processor includes the same Static Memory Controller (SMC) peripheral as the SAM9 processors, but replaces the SDRAM Controller with a DDR/SDR Controller (DDRSDRC). This patch splits the existing include/asm-arm/arch-at91/at91sam926x_mc.h into at91sam9_sdramc.h and at91sam9_smc.h. It also adds an at91cap9_ddrsdr.h for the DDRSDRC controller. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4758/1: [AT91] LEDsAndrew Victor
Move the LED initialization code out of the various *_devices.c files, and into leds.c. Also add support for NEW_LEDs. Patch from David Brownell. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4757/1: [AT91] UART initializationAndrew Victor
Modify the UART initialization to allow the board-initialization code to specify which pins are connected, and which pins should therefore be initialized. The current at91_init_serial() will continue to work as-is, but is marked as "deprecated" and will be removed once the board-specific files has been updated to use the new interface. As in the AVR32 code, we assume that the TX and RX pins will always be initialized. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4754/1: [AT91] SSC library supportAndrew Victor
Core support of the Atmel SSC library for all Atmel AT91 processors. Based on David Brownell's initial patch for the AT91RM9200. Signed-off-by: Andrew Victor <linux@maxim.org.za> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4753/1: [AT91] Use DMA_BIT_MASKAndrew Victor
Replace hard-coded DMA mask (0xffffffff) with DMA_BIT_MASK(32) as defined in dma-mapping.h. Set "dma_mask" field for the UART platform_devices. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4752/1: [AT91] RTT, RTC and WDT peripherals on SAM9Andrew Victor
Add platform_device and initialization for the RTT (Real Time Timer) and WDT (Watchdog) integrated in the Atmel AT91SAM9 processors. For SAM9263, register both RTT peripherals. [From: David Brownell <dbrownell@users.sourceforge.net>] Provide platform_resources for RTT peripherals [From: David Brownell <dbrownell@users.sourceforge.net>] Add support for RTC peripheral on AT91SAM9RL (same RTC peripherals as AT91RM9200) [From: David Brownell <dbrownell@users.sourceforge.net>] Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-26[ARM] 4650/1: AT91: New-style init of I2C, support for i2c-gpioAndrew Victor
The AT91 I2C driver is currently marked as "broken" due to hardware issues. This patch enables AT91-based platforms to also use the bitbanged GPIO for I2C. This updates platform setup logic (setting up an i2c-gpio device using the same pins as the i2c-at91 device, unless only the BROKEN driver is enabled). Also make use of the new-style initialization of I2C devices using i2c_register_board_info(). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4372/1: Define byte sizes in asm-arm/sizes.hAndrew Victor
Define SZ_512, SZ_256 and SZ_16 in asm-arm/sizes.h. Remove the definitions from the at91*_devices.c files. (Dependent on ARM patch #4370/2) Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4370/3: AT91: Support for Atmel AT91SAM9RL processors.Andrew Victor
Add support for Atmel's new AT91SAM9RL range of processors. Includes similar peripherals as other AT91SAM9 processors, but with a High-speed USB controller and various sizes of internal SRAM. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
