path: root/arch/arm/mach-at91/board-pcontrol-g20.c
2011-07-28at91: factorize at91 interrupts init to socJean-Christophe PLAGNIOL-VILLARD
they are the same except the default priority Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: introduce commom AT91_BASE_SYSJean-Christophe PLAGNIOL-VILLARD
On all at91 except rm9200 and x40 have the System Controller starts at address 0xffffc000 and has a size of 16KiB. On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting at 0xfffff000 This patch removes the individual definitions of AT91_BASE_SYS and replaces them with a common version at base 0xfffffc000 and size 16KiB and map the same memory space Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: drop boot_params and PLAT_PHYS_OFFSETJean-Christophe PLAGNIOL-VILLARD
select ARM_PATCH_PHYS_VIRT as with ARM_PATCH_PHYS_VIRT you can patch boot_params at runtime or any recent bootloader will provide a valid atags pointer in r2 as point out by Russell on AT91 we never use XIP so se do not need PLAT_PHYS_OFFSET Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-25at91: fix map_io init usageJean-Christophe PLAGNIOL-VILLARD
switch early init to init_early and introduce soc map_io with this Patch we will not do any more early device setup during the map io tks to Russell to point the new call back Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-12-17at91: Refactor Stamp9G20 and PControl G20 board fileChristian Glindkamp
As PControl G20 is a carrier board for the Stamp9G20 SoM, some code can be shared. Therefore board-stamp9g20.c is refactored to allow reusing the SoM initialization and board-pcontrol-g20.c is modified to use it. Signed-off-by: Christian Glindkamp <christian.glindkamp@taskit.de> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-26AT91: add board support for Pcontrol_G20Peter Gsellmann
Board is a carrier board for Stamp9G20, with additional peripherals for a building automation system Signed-off-by: Peter Gsellmann <pgsellmann@portner-elektronik.at> [nicolas.ferre@atmel.com: remove machine_desc.io_pg_offst and .phys_io] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
