path: root/arch/arm/mach-at91/soc.h
2011-07-28at91: move register clocks to soc generic initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: move clock subsystem init to soc generic initJean-Christophe PLAGNIOL-VILLARD
2011-07-28at91: use structure to store the current socJean-Christophe PLAGNIOL-VILLARD
instead of reading the registers everytime the current implementation respect the following constrain: - allow 1 to n soc to be enabled - allow to have a virtual cpu type and subtype - always detect the cpu type and subtype and report it - detect if the soc support is enabled - prepare for sysfs export support - drop soc specific code via compiler when the soc not enabled (via cpu_is_xxx) Today if we read the exid we will have the same value for 9g35 and 9m11 and we will need to check the cidr too with the new implementation we just need to check the soc subtype this will also allow to have specific virtual subtype for rm9200 which the board will have to specify via at91rm9200_set_type(int) as we have no way to detect it. this implementation is inspired by the SH cpu detection support Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: factorize at91 interrupts init to socJean-Christophe PLAGNIOL-VILLARD
they are the same except the default priority Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: introduce commom AT91_BASE_SYSJean-Christophe PLAGNIOL-VILLARD
On all at91 except rm9200 and x40 have the System Controller starts at address 0xffffc000 and has a size of 16KiB. On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting at 0xfffff000 This patch removes the individual definitions of AT91_BASE_SYS and replaces them with a common version at base 0xfffffc000 and size 16KiB and map the same memory space Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
