path: root/arch/arm/mach-davinci/board-dm355-evm.c
2011-07-18ARM: mach-davinci: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_sizeNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-05-13Davinci: aintc/cpintc - use ioremap()Cyril Chemparathy
This patch implements the following: - interrupt initialization uses ioremap() instead of passing a virtual address via davinci_soc_info. - machine definitions directly point to cp_intc_init() or davinci_irq_init() - davinci_intc_type and davinci_intc_base now get initialized in controller specific init functions instead of davinci_common_init() - minor fix in davinci_irq_init() to use intc_irq_num instead of DAVINCI_N_AINTC_IRQ Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-05-06DaVinci: move AEMIF #define's to the proper headersSergei Shtylyov
Currently each DaVinci board file #define's its own version of the EMIFA base addresses (all named DAVINCI_ASYNC_EMIF_*_BASE), which leads to duplication. Move these #define's to the SoC specific headers, changing their prefixes from 'DAVINCI' to the 'DM355', 'DM644X', and 'DM646X' since all these base addresses are SoC specific... And while at it, rename DM646X_ASYNC_EMIF_DATA_CE0_BASE to DM646X_ASYNC_EMIF_CS2_SPACE_BASE in order to match the DM646x datasheet. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-02-04Add SDA and SCL pin numbers to i2c platform dataPhilby John
Patch adds SDA and SCL pin numbers to the i2c platform data structure for Davinci DM355 and DM6446. This at present is used for i2c bus recovery. TODO: Add SDA and SCL pin number information to include all Davinci platforms such as dm355-leopard, dm365, dm646x, da8xx etc. Signed-off-by: Philby John <pjohn@in.mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-01-06Davinci VPFE Capture: Take i2c adapter id through platform dataVaibhav Hiremath
The I2C adapter ID is actually depends on Board and may vary, Davinci uses id=1, but in case of AM3517 id=3. So modified respective davinci board files. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25DaVinci: rename setup_usb() to davinci_setup_usb()Sergei Shtylyov
Rename setup_usb() into davinci_setup_usb(). While at it: - move its declaration from <mach/common.h> to more fitting <mach/usb.h>; - teach it to handle values of the 'mA' parameter greater than 510 and thus pass 1000 instead of 500 for the power switches capable of sourcing over 1 A; - teach it to handle odd values of the 'potpgt_ms' parameter... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25DaVinci: remove unneeded #include'sSergei Shtylyov
There have accumulated quite a lot of them after the code reorganizations... In several cases I had to replace #include <linux/dma-mapping.h> which wasn't needed directly but happened to #include <linux/err.h> which was needed. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25davinci: DM355: Update NAND driver platform dataSneha Narnakaje
This patch updates the NAND driver platform data to use 4-bit ECC and the ECC_HW/ECC_HW_OOB_FIRST modes. Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-09-16davinci: DM355 - platform changes for vpfe captureMuralidharan Karicheri
DM355 platform and board setup This has platform and board setup changes to support vpfe capture driver for DM355 EVMs. Tested video capture on DM355 using tvp514x Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Laurent Pinchart <laurent.pinchart@skynet.be> Reviewed-by: David Brownell <david-b@pacbell.net> Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com> Signed-off-by: Denys Dmytriyenko <denis@denix.org> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-08-26davinci: audio: move tlv320aic33 i2c setup into board filesChaithrika U S
Tested on DM6446, DM355, DM6447, DA850 EVMs. Signed-off-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-08-26davinci: audio clocks: use struct device instead of clock namesKevin Hilman
There is no need to pass clock name strings in platform_data. Instead, setup clkdev nodes to have correct ASoC device names. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-08-26davinci: ASoC: Add the platform devices for ASPChaithrika U S
1) Registers the platform devices for ASP on dm355, dm644x and dm646x so that the machine driver can probe to get ASP related platform data. 2) Move towards definition of the asp clocks using physical name(for dm355 and dm644x) 3) Add platform data to board specific files. Signed-off-by: Naresh Medisetty <naresh@ti.com> Signed-off-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-07-25ARM: includecheck fix: board-dm355-evm.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: arch/arm/mach-davinci/board-dm355-evm.c: mach/common.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-26davinci: Encapsulate SoC-specific data in a structureMark A. Greer
Create a structure to encapsulate SoC-specific information. This will assist in generalizing code so it can be used by different SoCs that have similar hardware but with minor differences such as having a different base address. The idea is that the code for each SoC fills out a structure with the correct information. The board-specific code then calls the SoC init routine which in turn will call a common init routine that makes a copy of the structure, maps in I/O regions, etc. After initialization, code can get a pointer to the structure by calling davinci_get_soc_info(). Eventually, the common init routine will make a copy of all of the data pointed to by the structure so the original data can be made __init_data. That way the data for SoC's that aren't being used won't consume memory for the entire life of the kernel. The structure will be extended in subsequent patches but initially, it holds the map_desc structure for any I/O regions the SoC/board wants statically mapped. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26davinci: MMC platform supportKevin Hilman
Add SoC and platform-specific data and init for MMC driver. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26davinci: DM355: add base SoC and board supportKevin Hilman
In addition, add board support for the DM355 Evaluation Module (EVM) and the DM355 Leopard board. Original DM355 EVM support done by Sandeep Paulraj, with significant updates and improvements by David Brownell. DM355 Leopord support done by Koen Kooi. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Koen Kooi <koen@beagleboard.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
