[ Upstream commit f97f03578b997a8ec2b9bc4928f958a865137268 ]
The DSP device on Davinci platforms does not have an MMU and requires
specific DDR memory to boot. This memory is reserved using the rproc_mem
kernel boot parameter and is assigned to the device on non-DT boots.
The remoteproc core uses the DMA API and so will fall back to assigning
random memory if this memory is not assigned to the device, but the DSP
remote processor boot will not be successful in such cases. So, check
that memory has been reserved and assigned to the device specifically
before even creating the DSP device.
Signed-off-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
[ Upstream commit 7e431af8fa0b9ed9d74378c99514856211cb9db8 ]
Add PM support for DA850 device-tree boot.
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
commit ef37427ac5677331145ab27a17e6f5f1b43f0c11 upstream.
Similarly to the aemif clock - this screws up the linked list of clock
children. Create a separate clock for mdio inheriting the rate from
emac_clk.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
[nsekhar@ti.com: add a comment over mdio_clk to explaing its existence +
commit headline updates]
Pull ARM DT updates from Arnd Bergmann:
"These are as usual a very large number of mostly boring updates to
enable devices in existing machines, or to fix minor bugs. Notably, an
ongoing treewide effort to fix warnings caused by an update to the
device tree compiler. These are enabled with "make W=1" at the moment
but can hopefully become the default once all issues have been
addressed.
No new SoC platform is added this time around (Armada 395 and Orion
mv88f5181 are slight variations of existing ones), but a significant
number of new dts files are added, which I list by platform:
- Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets,
Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite,
Olimex A33-Olinuxino, and Nano Pi Neo single-board computers
- ARM Realview: all supported machines (ported from board files)
- Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and
BCM958622hr reference boards for Northstar platform, Raspberry Pi
Zero single-board computer
- Marvell EBU: Netgear WNR854T router (ported from board file),
Armada 395 SoC platform and GP board Armada 390 DB development
board
- NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x
single-board computer, Technologic Systems TS-4900 and Engicam
IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board
- Qualcomm: LG Nexus 5 Phone
- Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards
- Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288
Reload platform
- ST Microelectronics STi: B2260 (96boards) single-board computer
- TI Davinci: OMAP-L138 LCDK Development kit
- TI OMAP: beagleboard-x15 rev B1 single-board computer"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits)
ARM: dts: sony-nsz-gs7: add missing unit name to /memory node
ARM: dts: chromecast: add missing unit name to /memory node
ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node
ARM: dts: berlin2: Add missing unit name to /soc node
ARM: dts: berlin2cd: Add missing unit name to /soc node
ARM: dts: berlin2q: Add missing unit name to /soc node
ARM: dts: berlin2: Remove skeleton.dtsi inclusion
ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion
ARM: dts: berlin2q: Remove skeleton.dtsi inclusion
arm: dts: berlin2q: enable all wdt nodes unconditionally
arm: dts: berlin2: enable all wdt nodes unconditionally
ARM: dts: omap5-igep0050.dts: Use tabs for indentation
ARM: dts: Fix igepv5 power button GPIO direction
ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node
ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes
ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
The davinci boards don't have their clocks in DT yet and getting a clock
will fail, unless registering them as clk_lookups. This registers the
aemif clock for the ti-aemif memory driver.
The current aemif lookup entry resolving to the same clock:
'CLK(NULL, "aemif", &aemif_clk)'
is currently used by davinci_nand and remains for non-DT and backward
compatibility.
Currently the davinci boards only configure the AEMIF in case of non-DT
boot, via some code in mach-davinci.
This change will allow DT-based davinci platforms to do the same, via
the ti-aemif memory driver code.
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
[nsekhar@ti.com: reworded commit message]
The LCDK is the successor to the late Hawkboard.
Among the differences are the flash (16bits vs 8bits) and some pins
(MMC, LEDs, buttons, some external connectors), however the main
components remain the same (eth. phy, audio codec, video decoder and
DAC) except for the main PMIC, different and hard-wired on the LCDK (the
LDOs and DCDCs are always on).
A DT-only boot with this addition gives functional UART, reboot via
watchdog, RTC, ethernet and MMC (I added the CD GPIO for the MMC
although davinci_mmc doesn't call the OF facilities of mmc core).
Cc: Sekhar Nori <nsekhar@ti.com>
Tested-by: Kevin Hilman <khilman@baylibre.com>
Pull ARM SoC platform updates from Olof Johansson:
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
commit 6bce5efd4424 ("ARM: davinci: remove unused davinci-i2s pdata")
removed all instances of davinci-i2s pdata. However, on DM365 EVM,
the same platform data is passed to the voicecodec present on that
device.
This causes build breakage when voicecodec support is enabled:
arch/arm/mach-davinci/board-dm365-evm.c:764:17: error: 'dm365_evm_snd_data' undeclared (first use in this function)
voicecodec driver does not use the platform data as well, and
it is safe to remove it.
Fixes: 6bce5efd4424 ("ARM: davinci: remove unused davinci-i2s pdata")
- dts: rename 'ide-disk' to 'disk-activity'
- platform: rename 'ide-disk' to 'disk-activity'
- defconfig: rename 'LEDS_TRIGGER_IDE_DISK' to 'LEDS_TRIGGER_DISK'
Signed-off-by: Stephan Linz <linz@li-pro.net>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
The davinci-i2s driver ("davinci-mcbsp") does not use platform
data any longer. Remove the dummy pdata provided by the board
drivers dm355, dm365, dm644x and neuros-osd2.
Signed-off-by: Petr Kulhavy <petr@barix.com>
Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Add clock definitions "davinci-mcbsp.0" and "davinci-mcbsp.1" in order
to make McBSP driver work on the DA850 platform.
The McBSP 0 and 1 interfaces were not defined for the DA850 platform.
Neither were the related clocks. In order to make the use of McBSP via
devicetree the clocks need to be defined.
"These are all the updates to device tree files for 32-bit platforms,
which as usual makes up the bulk of the ARM SoC changes: 462 non-merge
changesets, 450 files changed, 23340 insertions, 5216 deletions.
The three platforms that are added with the "soc" branch are here as
well, and we add some related machine files:
- For Aspeed AST2400/AST2500, we get the evaluation platform and the
Tyan Palmetto POWER8 mainboard that uses the AST2400 BMC
- For Oxnas 810SE, the Western Digital "My Book World Edition" is
added as the only platform at the moment.
- For ARM MPS2, the AN385 (Cortex-M3) and AN399 (Cortex-M7) are
supported
On the ARM Realview development platform, we now support all machines
with device tree, previously only the board files were supported,
which in turn will likely be removed soon.
Qualcomm IPQ4019 is the second generation ARM based "Internet
Processor", following the IPQ806x that is used in many high-end WiFi
routers. This one integrates two ath10k wifi radios that were
previously on separate chips.
Other boards that got added for existing chips are:
Ti OMAP family:
- Amazon Kindle Fire, first generation, tablet and ebook reader
- OnRISC Baltos iR 2110 and 3220 embedded industrial PCs
- TI AM5728 IDK, TI AM3359 ICE-V2, and TI DRA722 Rev C EVM
development systems
Samsung EXYNOS platform:
- Samsung ARTIK5 evaluation board, see
https://www.artik.io/modules/overview/artik-5/
NXP i.MX platforms:
- Ka-Ro electronics TX6S-8034, TX6S-8035, TX6U-8033, TX6U-81xx,
TX6Q-1036, TX6Q-1110/-1130, TXUL-0010 and TXUL-0011 industrial
SoM modules
- Embest MarS Board i.MX6Dual DIY platform
- Boundary Devices i.MX6 Quad Plus Nitrogen6_MAX and SoloX
Nitrogen6sx embedded boards
- Technexion Pico i.MX6UL compute module
- ZII VF610 Development Board
Marvell embedded (mvebu, orion, kirkwood) platforms:
- Linksys Viper (E4200v2 / EA4500) WiFi router
- Buffalo Kurobox Pro NAS
Qualcomm Snapdragon:
- Arrow DragonBoard 600c (96boards) with APQ8064 Snapdragon 600
Rockchips platform:
- mqmaker MiQi single-board computer
Altera SoCFPGA:
- samtec VIN|ING 1000 vehicle communication interface
Allwinner Sunxi platforms:
- Dserve DSRV9703C tablet
- Difrnce DIT4350 tablet
- Colorfly E708 Q1 tablet
- Polaroid MID2809PXE04 tablet
- Olimex A20 OLinuXino LIME2 single board computer
- Xunlong Orange Pi 2, Orange Pi One, and Orange Pi PC single board
computers
Across many platforms, bug fixes went in to address warnings that dtc
now emits with 'make dtbs W=1'. Further changes for device enablement
went into Ti OMAP, bcm283x (Raspberry Pi), bcm47xx (wifi router), Ti
Davinci, Samsung EXYNOS, Marvell mvebu/kirkwood/orion, NXP i.MX/Vybrid
NXP LPC18xx, NXP LPC32xx, Renesas shmobile/r-mobile/r-car, Rockchips
rk3xxx, ST Ux500, ST STi, Atmel AT91/SAMA5, Altera SoCFPGA, Allwinner
Sunxi, Sigma Designs Tango, NVIDIA Tegra, Socionext Uniphier and ARM
Versatile Express"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (458 commits)
ARM: dts: tango4: Import watchdog node
ARM: dts: tango4: Update cpus node for cpufreq
ARM: dts: tango4: Update DT to match clk driver
ARM: dts: tango4: Initial thermal support
arm/dst: Add Aspeed ast2500 device tree
arm/dts: Add Aspeed ast2400 device tree
ARM: sun7i: dt: Add pll3 and pll7 clocks
ARM: dts: sunxi: Add a olinuxino-lime2-emmc
ARM: dts: at91: sama5d4: add trng node
ARM: dts: at91: sama5d3: add trng node
ARM: dts: at91: sama5d2: add trng node
ARM: dts: at91: at91sam9g45 family: reduce the trng register map size
ARM: sun4i: dt: Add pll3 and pll7 clocks
ARM: sun5i: chip: Enable the TV Encoder
ARM: sun5i: r8: Add display blocks to the DTSI
ARM: sun5i: a13: Add display and TCON clocks
ARM: dts: ux500: configure the accelerometers open drain
ARM: mx5: dts: Enable USB OTG on M53EVK
ARM: dts: imx6ul-14x14-evk: Add audio support
ARM: dts: imx6qdl: Remove unneeded unit-addresses
Pull ARM SoC platform updates from Arnd Bergmann:
"We get support for three new 32-bit SoC platforms this time.
The amount of changes in arch/arm for any of them is miniscule, as all
the interesting code is in device driver subsystems (irqchip, clk,
pinctrl, ...) these days. I'm listing them here, as the addition of
the Kconfig statement is the main relevant milestone for a new
platform. In each case, some drivers are are shared with existing
platforms, while other drivers are added for v4.7 as well, or come in
a later release.
- The Aspeed platform is probably the most interesting one, this is
what most whitebox servers use as their baseboard management
controller. We get support for the very common ast2400 and ast2500
SoCs. The OpenBMC project focuses on this chip, and the LWN
article about their ELC 2016 presentation at
https://lwn.net/Articles/683320/
triggered the submission, but the code comes from IBM's OpenPOWER
team rather than the team at Facebook. There are still a lot more
drivers that need to get added over time, and I hope both teams can
work together on that.
- OXNAS is an old platform for Network Attached Storage devices from
Oxford Semiconductor. There are models with ARM10 (!) and
ARM11MPCore cores, but for now, we only support the original ARM9
based versions. The product lineup was subsequently part of PLX,
Avago and now the new Broadcom Ltd.
https://wiki.openwrt.org/doc/hardware/soc/soc.oxnas
has some more information.
- V2M-MPS2 is a prototyping platform from ARM for their Cortex-M
cores and is related to the existing Realview / Versatile Express
lineup, but without MMU.
We now support various NOMMU platforms, so adding a new one is
fairly straightforward.
http://infocenter.arm.com/help/topic/com.arm.doc.100112_0100_03_en/
has detailed information about the platform.
Other noteworthy updates:
- Work on LPC32xx has resumed, and Vladimir Zapolskiy and Sylvain
Lemieux are now maintaining the platform.
This is an older ARM9 based platform from NXP (not Freescale), but
it remains in use in embedded markets.
- Kevin Hilman is now co-maintaining the Amlogic Meson platform for
both 32-bit and 64-bit ARM, and started contributing some patches.
- As is often the case, work on the OMAP platforms makes up the bulk
of the actual SoC code changes in arch/arm, but there isn't a lot
of that either"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits)
MAINTAINERS: ARM/Amlogic: add co-maintainer, misc. updates
MAINTAINERS: add ARM/NXP LPC32XX SoC specific drivers to the section
MAINTAINERS: add new maintainers of NXP LPC32xx SoC
MAINTAINERS: move ARM/NXP LPC32xx record to ARM section
arm: Add Aspeed machine
ARM: lpc32xx: remove duplicate const on lpc32xx_auxdata_lookup
ARM: lpc32xx: remove leftovers of legacy clock source and provider drivers
ARM: lpc32xx: remove reboot header file
ARM: dove: Remove CLK_IS_ROOT
ARM: orion5x: Remove CLK_IS_ROOT
ARM: mv78xx0: Remove CLK_IS_ROOT
ARM: davinci: da850: use clk->set_parent for async3
ARM: davinci: Move clock init after ioremap.
MAINTAINERS: Update ARM Versatile Express platform entry
ARM: vexpress/mps2: introduce MPS2 platform
MAINTAINERS: add maintainer entry for ARM/OXNAS platform
ARM: Add new mach-oxnas
irqchip: versatile-fpga: add new compatible for OX810SE SoC
ARM: uniphier: correct the call order of of_node_put()
MAINTAINERS: fix stale TI DaVinci entries
Pull ARM SoC cleanups and fixes from Arnd Bergmann:
"Traditionally we've had two separate branches for cleanups and
non-critical bug fixes, but both of these got smaller with each
release and the differences are rather unclear now, so it seems more
appropriate to have a combined branch.
The most notable change is for OMAP, which gets a small rework to
simplify handling of the AUXDATA mechanism used on machines that are
not completely DT based yet, along with other work that is used as
preparation for dropping the legacy board files"
* tag 'armsoc-cleanups-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: exynos: Add interrupt line to MAX8997 PMIC on exynos4210-trats
ARM: dts: exynos: Fix regulator name to avoid forbidden character on exynos4210-trats
ARM: dts: exynos: Add MFC memory banks for Peach boards
ARM: OMAP2+: n900 needs MMC slot names for legacy user space
ARM: OMAP2+: Add more functions to pwm pdata for ir-rx51
ARM: debug: remove extraneous DEBUG_HI3716_UART option
ARM: OMAP2+: Simplify auxdata by using the generic match
of/platform: Allow secondary compatible match in of_dev_lookup
ARM: davinci: use IRQCHIP_DECLARE for cp_intc
ARM: davinci: remove unused DA8XX_NUM_UARTS
ARM: davinci: simplify call to of populate
ARM: DaVinci USB: removed deprecated properties from MUSB config
ARM: rockchip: Fix use of plain integer as NULL pointer
ARM: realview: hide unused 'pmu_device' object
soc: versatile: dynamically detect RealView HBI numbers
Pull MMC updates from Ulf Hansson:
"MMC core:
- Add TRACE support to be able to debug request flow
- Extend/improve reset support for (e)MMC
- Convert MMC pwrseq to platform device drivers
- Use IDA for indexes
- Some additional minor improvements
MMC host:
- sdhci: Re-factoring, clean-ups and improvements
- sdhci-acpi|pci: Use MMC_CAP_AGGRESSIVE_PM for Broxton
- omap/omap_hsmmc: Convert to use dma_request_chan()
- usdhi6rol0: Add support for UHS modes
- sh_mmcif: Update runtime PM support
- tmio: Wolfram Sang steps in as maintainer
- tmio: Add UHS-I mode support
- sh_mobile_sdhi: Add UHS-I mode support
- tmio/sdhi: Re-factoring, clean-ups and improvements
- dw_mmc: Re-factoring and clean-ups
- davinci: Convert to use dma_request_chan()"
* tag 'mmc-v4.7' of git://git.linaro.org/people/ulf.hansson/mmc: (99 commits)
mmc: mmc: Fix partition switch timeout for some eMMCs
mmc: sh_mobile_sdhi: enable SDIO IRQs for RCar Gen3
mmc: sdio: fall back to SDIO 1.0 for broken 1.1 cards
mmc: sdhci-st: correct name of sd-uhs-sdr50 property
MAINTAINERS: update entry for TMIO MMC driver
mmc: block: improve logging of handling emmc timeouts
mmc: sdhci: removed unneeded function wrappers
mmc: core: remove the invalid message in mmc_select_timing
mmc: core: fix using wrong io voltage if mmc_select_hs200 fails
mmc: sdhci-of-arasan: fix set_clock when a phy is supported
mmc: omap: Use dma_request_chan() for requesting DMA channel
mmc: mmc: Attempt to flush cache before reset
mmc: sh_mobile_sdhi: check return value when changing clk
mmc: sh_mobile_sdhi: only change the clock on RCar Gen2+
mmc: tmio/sdhi: introduce flag for RCar 2+ specific features
mmc: sh_mobile_sdhi: make clk_update function more compact
mmc: omap_hsmmc: Use dma_request_chan() for requesting DMA channel
mmc: sdhci-of-at91: add presets setup
mmc: usdhi6rol0: add pinctrl to set pin drive strength
mmc: usdhi6rol0: add support for UHS modes
The davinci_mmc driver no longer uses platform resources for getting dma
channels. Instead lookup is now done using dma_slave_map.
Signed-off-by: David Lechner <david@lechnology.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The davinci platform contains code that calls into the nvmem
subsystem, but that might be a loadable module, causing a
link error:
arch/arm/mach-davinci/built-in.o: In function `davinci_get_mac_addr':
:(.text+0x1088): undefined reference to `nvmem_device_read'
arch/arm/mach-davinci/built-in.o: In function `read_factory_config':
:(.text+0x214c): undefined reference to `nvmem_device_read'
Also, when NVMEM is completely disabled, the functions fail with
nonobvious error messages.
This ensures we only call the API functions when the code is actually
reachable from the board file, and otherwise prints a unique log
message.
Fixes: bec3c11bad0e ("misc: at24: replace memory_accessor with nvmem_device_read")
The da850 family of processors has an async3 clock domain that can be
muxed to either pll0_sysclk2 or pll1_sysclk2. Now that the davinci clocks
have a set_parent callback, we can use this to control the async3 mux
instead of a stand-alone function.
This adds a new async3_clk and sets the appropriate child clocks. The
default is use to pll1_sysclk2 since it is not affected by processor
frequency scaling.
[nsekhar@ti.com: drop unnecessary comment]
Some clocks (such as the USB PHY clocks in DA8xx) will need to use iomem.
The davinci_common_init() function must be called before the ioremap, so
the clock init is now split out as separate function.
Add AUXDATA needed to match the device-tree node for spi0 to the
non-device-tree clock.
[nsekhar@ti.com: commit description updates]
Introduce a set_parent callback that will be used for mux clocks, such as
the USB PHY muxes and the async3 clock domain mux.
[nsekhar@ti.com: checkpatch fixes]
We will be adding more da8xx-specific code for phy and clocks, so it will
be better to have this in a separate file. This way we don't have a bunch
of #ifdefs for all of the da8xx stuff.
While at it, fix some checkpatch warnings coming from existing code.
[nsekhar@ti.com: typo and checkpatch fixes]
Remove boilerplate code by using IRQCHIP_DECLARE macro.
DA8X_NUM_UARTS not used in the code anywhere and should be determined
by DT anyway.
Take advantage of of_platoform_default_populate convience function.
The following properties of the musb_hdrc_config structure
are deprecated and no longer required/used by the MUSB driver:
.dyn_fifo
.soft_con
.dma
.dma_channels
.eps_bits
Add OF_DEV_AUXDATA entry for second i2c on the da850 DT board driver
to use i2c clock.
"Newly added support for additional SoCs:
- Axis Artpec-6 SoC family
- Allwinner A83T SoC
- Mediatek MT7623
- NXP i.MX6QP SoC
- ST Microelectronics stm32f469 microcontroller
New features:
- SMP support for Mediatek mt2701
- Big-endian support for NXP i.MX
- DaVinci now uses the new DMA engine dma_slave_map
- OMAP now uses the new DMA engine dma_slave_map
- earlyprintk support for palmchip uart on mach-tango
- delay timer support for orion
Other:
- Exynos PMU driver moved out to drivers/soc/
- Various smaller updates for Renesas, Xilinx, PXA, AT91, OMAP,
uniphier"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: uniphier: rework SMP code to support new System Bus binding
ARM: uniphier: add missing of_node_put()
ARM: at91: avoid defining CONFIG_* symbols in source code
ARM: DRA7: hwmod: Add data for eDMA tpcc, tptc0, tptc1
ARM: imx: Make reset_control_ops const
ARM: imx: Do L2 errata only if the L2 cache isn't enabled
ARM: imx: select ARM_CPU_SUSPEND only for imx6
dmaengine: pxa_dma: fix the maximum requestor line
ARM: alpine: select the Alpine MSI controller driver
ARM: pxa: add the number of DMA requestor lines
dmaengine: mmp-pdma: add number of requestors
dma: mmp_pdma: Add the #dma-requests DT property documentation
ARM: OMAP2+: Add rtc hwmod configuration for ti81xx
ARM: s3c24xx: Avoid warning for inb/outb
ARM: zynq: Move early printk virtual address to vmalloc area
ARM: DRA7: hwmod: Add custom reset handler for PCIeSS
ARM: SAMSUNG: Remove unused register offset definition
ARM: EXYNOS: Cleanup header files inclusion
drivers: soc: samsung: Enable COMPILE_TEST
MAINTAINERS: Add maintainers entry for drivers/soc/samsung
Pull ARM SoC non-urgent fixes from Arnd Bergmann:
"As usual, we queue up a few fixes that don't seem urgent enough to go
in through -rc.
- a number of randconfig warning fixes from Arnd
- various small fixes for OMAP
- one somewhat larger patch to restore the OMAP3 cpuidle tuning that
was lost in a cleanup
- a small regression fix for cns3xxx PCI"
* tag 'armsoc-fixes-nc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (26 commits)
CNS3xxx: Fix PCI cns3xxx_write_config()
MAINTAINERS: unify email addrs for Kevin Hilman
CNS3xxx: remove unused *_VIRT definitions
ARM: OMAP2+: Fix hwmod clock for l4_ls
soc: TI knav_qmss: fix dma_addr_t printing
ARM: prima2: always enable reset controller
ARM: socfpga: hide unused functions
ARM: ux500: fix ureachable iounmap()
ARM: ks8695: fix __initdata annotation
ARM: mvebu: mark mvebu_hwcc_pci_nb as __maybe_unused
ARM: mv78xx0: avoid unused function warning
ARM: orion: only select I2C_BOARDINFO when using I2C
ARM: OMAP2+: Fix out of range register access with syscon_config.max_register
ARM: OMAP3: Add cpuidle parameters table for omap3430
ARM: davinci: make I2C support optional
ARM: davinci: DA8xx+DMx combined kernels need PATCH_PHYS_VIRT
ARM: davinci: avoid unused mityomapl138_pn_info variable
ARM: davinci: limit DT support to DA850
ARM: DRA7: hwmod: Add reset data for PCIe
ARM: DRA7: hwmod: Fix OCP2SCP sysconfig
Pull ARM updates from Russell King:
"Another mixture of changes this time around:
- Split XIP linker file from main linker file to make it more
maintainable, and various XIP fixes, and clean up a resulting
macro.
- Decompressor cleanups from Masahiro Yamada
- Avoid printing an error for a missing L2 cache
- Remove some duplicated symbols in System.map, and move
vectors/stubs back into kernel VMA
- Various low priority fixes from Arnd
- Updates to allow bus match functions to return negative errno
values, touching some drivers and the driver core. Greg has acked
these changes.
- Virtualisation platform udpates form Jean-Philippe Brucker.
- Security enhancements from Kees Cook
- Rework some Kconfig dependencies and move PSCI idle management code
out of arch/arm into drivers/firmware/psci.c
- ARM DMA mapping updates, touching media, acked by Mauro.
- Fix places in ARM code which should be using virt_to_idmap() so
that Keystone2 can work.
- Fix Marvell Tauros2 to work again with non-DT boots.
- Provide a delay timer for ARM Orion platforms"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (45 commits)
ARM: 8546/1: dma-mapping: refactor to fix coherent+cma+gfp=0
ARM: 8547/1: dma-mapping: store buffer information
ARM: 8543/1: decompressor: rename suffix_y to compress-y
ARM: 8542/1: decompressor: merge piggy.*.S and simplify Makefile
ARM: 8541/1: decompressor: drop redundant FORCE in Makefile
ARM: 8540/1: decompressor: use clean-files instead of extra-y to clean files
ARM: 8539/1: decompressor: drop more unneeded assignments to "targets"
ARM: 8538/1: decompressor: drop unneeded assignments to "targets"
ARM: 8532/1: uncompress: mark putc as inline
ARM: 8531/1: turn init_new_context into an inline function
ARM: 8530/1: remove VIRT_TO_BUS
ARM: 8537/1: drop unused DEBUG_RODATA from XIP_KERNEL
ARM: 8536/1: mm: hide __start_rodata_section_aligned for non-debug builds
ARM: 8535/1: mm: DEBUG_RODATA makes no sense with XIP_KERNEL
ARM: 8534/1: virt: fix hyp-stub build for pre-ARMv7 CPUs
ARM: make the physical-relative calculation more obvious
ARM: 8512/1: proc-v7.S: Adjust stack address when XIP_KERNEL
ARM: 8411/1: Add default SPARSEMEM settings
ARM: 8503/1: clk_register_clkdev: remove format string interface
ARM: 8529/1: remove 'i' and 'zi' targets
Now that the AT24 uses the NVMEM framework, replace the
memory_accessor in the setup() callback with nvmem API calls.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Tested-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
When CONFIG_DEBUG_ICEDCC is set, we don't use the platform
specific putc() function, but use icedcc_putc() instead, so
putc is unused and causes a compile time warning:
In file included from ../arch/arm/boot/compressed/misc.c:28:0:
arch/arm/mach-rpc/include/mach/uncompress.h:79:13: warning: 'putc' defined but not used [-Wunused-function]
arch/arm/mach-w90x900/include/mach/uncompress.h:30:13: warning: 'putc' defined but not used [-Wunused-function]
On most platforms, this does not happen, because putc is defined
as 'static inline' so the compiler will automatically drop it
when it's unused.
This changes the remaining seven platforms to behave the same way.
Provide the dma_slave_map to edma which will allow us to move the drivers
to the new, simpler dmaengine API and we can remove the DMA resources also
for the devices.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
[nsekhar@ti.com: fix typos in code]
for the devices.
[nsekhar@ti.com: typo fixes in code]
for the devices.
for the devices.
for the devices.
[nsekhar@ti.com: fix map for edma1]
The davinci platform has tried to get support for the EEPROM right,
but failed to get a clean build so far. At the moment, we get
a warning whenever CONFIG_SYSFS is disabled, as that is needed by
EEPROM_AT24:
warning: (MACH_DAVINCI_EVM && MACH_SFFSDR && MACH_DAVINCI_DM6467_EVM && MACH_DAVINCI_DM365_EVM && MACH_DAVINCI_DA830_EVM && MACH_MITYOMAPL138 && MACH_MINI2440) selects EEPROM_AT24 which has unmet direct dependencies (I2C && SYSFS)
Kevin Hilman initially added the 'select' to ensure that EEPROM_AT24
is always enabled in machines that really want it for normal operation
(i.e. for reading the MAC address). This broke when I2C was disabled,
and Russell King followed up with another patch to select that as
well.
I now see that the SYSFS dependency is still missing, which leaves
us with three options:
a) add 'select SYSFS' in addition to the others
b) change AT24_EEPPROM to work without sysfs (should be possible)
c) remove all those selects again and get the files to build when
I2C is disabled.
I would really hate to do a) because adding select statements that
hardwire user-selectable symbols is generally a bad idea. I first
tried b) but then ended up redoing the patch from scratch to approach
c), so we can also remove the other selects.
I checked that CONFIG_I2C is still enabled with davinci_all_defconfig,
so that does not have to change.
Fixes: 45b146d746ea ("ARM: Davinci: Fix I2C build errors")
Fixes: 22ca466847ad ("davinci: kconfig: select at24 eeprom for selected boards")
We already forbid that combination when AUTO_ZRELADDR is disabled,
for the same reason that the two have their RAM at different
physical addresses as seen from the CPU.
This does the same change for PATCH_PHYS_VIRT: if you disable
either of the options, Kconfig now enforces that you have to
pick one or the other SoC family.
The mityomapl138_pn_info structure belongs into the CPU_FREQ support
that is hidden behind an #ifdef, and causes a harmless warning when
that support is disabled:
mach-davinci/board-mityomapl138.c:59:28: error: 'mityomapl138_pn_info' defined but not used [-Werror=unused-variable]
This moves the variable definition where it belongs.
When da8xx-dt.c is built with onlu DA830 support but not DA850
support enabled, we get a compiler warning about unused symbols:
arch/arm/mach-davinci/da8xx-dt.c:28:20: warning: 'da8xx_init_irq' defined but not used [-Wunused-function]
static void __init da8xx_init_irq(void)
arch/arm/mach-davinci/da8xx-dt.c:33:30: warning: 'da850_auxdata_lookup' defined but not used [-Wunused-variable]
static struct of_dev_auxdata da850_auxdata_lookup[] __initdata = {
Obviously none of the file make sense for DA830, so we should not
even attempt this, so we can avoid the warning by ensuring it is
only built for 850, not 830.
Pull ARM SoC multiplatform code updates from Arnd Bergmann:
"This branch is the culmination of 5 years of effort to bring the ARMv6
and ARMv7 platforms together such that they can all be enabled and
boot the same kernel. It has been a tremendous amount of cleanup and
refactoring by a huge number of people, and creation of several new
(and major) subsystems to better abstract out all the platform details
in an appropriate manner.
The bulk of this branch is a large patchset from Arnd that brings
several of the more minor and older platforms we have closer to
multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0
and realview Much of this is moving around header files from old mach
directories, but there are also some cleanup patches of debug_ll
(lowlevel debug per-platform options) and other parts.
Linus Walleij also has some patchs to clean up the older ARM Realview
platforms by finally introducing DT support, and Rob Herring has some
for ARM Versatile which is now DT-only. Both of these platforms are
now multiplatform.
Finally, a couple of patches from Russell for Dove PMU, and a fix from
Valentin Rothberg for Exynos ADC, which were rebased on top of the
series to avoid conflicts"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: realview: don't select SMP_ON_UP for UP builds
ARM: s3c: simplify s3c_irqwake_{e,}intallow definition
ARM: s3c64xx: fix pm-debug compilation
iio: exynos-adc: fix irqf_oneshot.cocci warnings
ARM: realview: build realview-dt SMP support only when used
ARM: realview: select apropriate targets
ARM: realview: clean up header files
ARM: realview: make all header files local
ARM: no longer make CPU targets visible separately
ARM: integrator: use explicit core module options
ARM: realview: enable multiplatform
ARM: make default platform work for NOMMU
ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location
ARM: defconfig: use correct debug_ll settings
ARM: versatile: convert to multi-platform
ARM: versatile: merge mach code into a single file
ARM: versatile: switch to DT only booting and remove legacy code
ARM: versatile: add DT based PCI detection
ARM: pxa: mark ezx structures as __maybe_unused
ARM: pxa: mark raumfeld init functions as __maybe_unused
Pull non-urgent ARM SoC fixes from Olof Johansson:
in through -rc.
- MAINTAINERS updates to add a list for brcmstb and fix a typo
- A handful of fixes for OMAP 81xx, a recently resurrected platform
so these can't be considered real regressions and thus got queued.
- A couple of other small fixes for scoop, sa1100 and davinci"
ARM: OMAP2+: Fix randconfig build warning for dm814_pllss_data
ARM: sa1100/simpad: Be sure to clamp return value
ARM: scoop: Be sure to clamp return value
ARM: davinci: fix a problematic usage of WARN()
ARM: davinci: only select WT cache if cache is enabled
ARM: OMAP2+: Remove useless check for legacy booting for dm814x
ARM: OMAP2+: Enable GPIO for dm814x
ARM: dts: Fix dm814x pinctrl address and mask
ARM: dts: Fix dm8148 control modules ranges
ARM: OMAP2+: Fix timer entries for dm814x
ARM: dts: Fix some mux and divider clocks to get dm814x-evm booting
ARM: OMAP2+: Add DPPLS clock manager for dm814x
clk: ti: Add few dm814x clock aliases
ARM: dts: Fix dm814x entries for pllss and prcm
MAINTAINERS: gpio-brcmstb: Remove stray '>'
MAINTAINERS: brcmstb: Include Broadcom internal mailing-list
WARN() takes a condition and a format string. The condition was
omitted. So I added it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
The DA830 chip only works if the dcache is in writethrough mode,
but that produces a harmless Kconfig warning if the cache happens
to be disabled:
warning: (ARCH_DAVINCI_DA830) selects CPU_DCACHE_WRITETHROUGH which has unmet direct dependencies ((CPU_ARM740T || CPU_ARM920T || CPU_ARM922T || CPU_ARM925T || CPU_ARM926T || CPU_ARM940T || CPU_ARM946E || CPU_ARM1020 || CPU_FA526) && !CPU_DCACHE_DISABLE)
This makes the select conditional so we don't have to worry
about the warning in randconfig builds any more.
Some header files are never included outside of a mach-davinci
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Currently, include/media is messy, as it contains both the V4L2 core
headers and some driver-specific headers on the same place. That makes
harder to identify what core headers should be documented and what
headers belong to I2C drivers that are included only by bridge/main
drivers that would require the functions provided by them.
Let's move those i2c specific files to its own subdirectory.
The files to move were produced via the following script:
mkdir include/media/i2c
(cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done)
(cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/*/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done)
for i in include/media/*.h; do n=`basename $i`; (for j in $(git grep -l $n); do dirname $j; done)|sort|uniq|grep -ve '^.$' > list; num=$(wc -l list|cut -d' ' -f1); if [ $num == 1 ]; then if [ "`grep i2c list`" != "" ]; then git mv $i include/media/i2c; fi; fi; done
And the references corrected via this script:
MAIN_DIR="media/"
PREV_DIR="media/"
DIRS="i2c/"
echo "Checking affected files" >&2
for i in $DIRS; do
for j in $(find include/$MAIN_DIR/$i -type f -name '*.h'); do
n=`basename $j`
git grep -l $n
done
done|sort|uniq >files && (
echo "Handling files..." >&2;
echo "for i in \$(cat files|grep -v Documentation); do cat \$i | \\";
cd include/$MAIN_DIR;
for j in $DIRS; do
for i in $(ls $j); do
echo "perl -ne 's,(include [\\\"\\<])$PREV_DIR($i)([\\\"\\>]),\1$MAIN_DIR$j\2\3,; print \$_' |\\";
done;
done;
echo "cat > a && mv a \$i; done";
echo "Handling documentation..." >&2;
echo "for i in MAINTAINERS \$(cat files); do cat \$i | \\";
for j in $DIRS; do
echo " perl -ne 's,include/$PREV_DIR($i)\b,include/$MAIN_DIR$j\1,; print \$_' |\\";
done;
done;
) >script && . ./script
Merged Sakari Ailus patch that moves smiapp.h to include/media/i2c.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Pull ARM SoC non-urgent fixes from Olof Johansson:
"A handful of fixes that came in and didn't seem warranted to go in
through the 4.3-rc cycle.
- MAINTAINERS updates for one of the Broadcom platforms and lpc18xx
- A couple of non-critical Davinci bugfixes
- A fix to reset irq affinity for TI platforms (silences a warning at
reboot)"
MAINTAINERS: update lpc18xx entry with more drivers
soc: ti: reset irq affinity before freeing irq
ARM: cns3xxx: pci: avoid potential stack overflow
ARM: davinci: clock: Correct return values for API functions
ARM: davinci: re-use %*ph specifier
MAINTAINERS: add entry for the Broadcom Northstar Plus SoCs
The upcoming change to merge the arch/arm/common/edma.c into
drivers/dma/edma.c will need this change when booting daVinci devices in
no DT mode.
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Convert the eDMA platform device creation to use
struct platform_device_info XXXXXX __initconst and
platform_device_register_full()
This will allow us to cleanly specify the dma_mask for the devices in an
upcoming patch.
