path: root/arch/arm/mach-ep93xx/dma-m2p.c
2010-10-12ARM: 6440/1: ep93xx: DMA: fix channel_disableMika Westerberg
When channel_disable() is called, it disables per channel interrupts and waits until channels state becomes STATE_STALL, and then disables the channel. Now, if the DMA transfer is disabled while the channel is in STATE_NEXT we will not wait anything and disable the channel immediately. This seems to cause weird data corruption for example in audio transfers. Fix is to wait while we are in STATE_NEXT or STATE_ON and only then disable the channel. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-12ARM: 5876/1: ep93xx: use pr_fmt in dma-m2p.cHartley Sweeten
Use pr_fmt to prefix kernel output with the module name. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-09[ARM] 5595/1: ep93xx: missing header in dma-m2p.cHartley Sweeten
<linux/io.h> was getting included by <mach/ts72xx.h>, is should be included by this file. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-03[ARM] 5414/2: ep93xx m2p dma coreRyan Mallon
Add m2p dma support to the ep93xx Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
