commit 833b5794e3303cc97a0d2d4ba97f26cc9d9b4b79 upstream.
The cpu booting of exynos5422 has been still broken since we discussed
it in last year[1]. This patch is inspired from Odroid XU3
code (Actually, it was from samsung exynos vendor kernel)[2]. This weird
reset code was founded exynos5420 octa cores series SoCs and only
required for the first boot core is the Little core (Cortex A7).
Some of the exynos5420 boards and all of the exynos5422 boards will require
this code.
There is two ways to check the little core is the first cpu. One is
checking GPG2CON[1] GPIO value and the other is checking the cluster
number of the first cpu. I selected the latter because it's more easier
than the former.
[1] http://lists.infradead.org/pipermail/linux-arm-kernel/2015-June/350632.html
[2] https://patchwork.kernel.org/patch/6782891/
Cc: Kevin Hilman <khilman@kernel.org>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Signed-off-by: Chanho Park <parkch98@gmail.com>
[k.kozlowski: Adding stable for v4.1+, reformat comment]
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The custom suspend callback is removed for this change. The extra call
to exynos_cpu_power_up(() that was present at the end of exynos_suspend()
is now relocated to the cpu_is_up callback.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Use the MCPM layer to handle core suspend/resume on Exynos5420.
Also, restore the entry address setup code post-resume.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
On revisions of Cortex-A15 prior to r3p3, a CLREX instruction at PL1 may
falsely trigger a watchpoint exception, leading to potential data aborts
during exception return and/or livelock.
This patch resolves the issue in the following ways:
- Replacing our uses of CLREX with a dummy STREX sequence instead (as
we did for v6 CPUs).
- Removing the clrex code from v7_exit_coherency_flush and derivatives,
since this only exists as a minor performance improvement when
non-cached exclusives are in use (Linux doesn't use these).
Benchmarking on a variety of ARM cores revealed no measurable
performance difference with this change applied, so the change is
performed unconditionally and no new Kconfig entry is added.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: stable@vger.kernel.org
Pull ARM SoC platform changes from Olof Johansson:
"This is the bulk of new SoC enablement and other platform changes for
3.17:
- Samsung S5PV210 has been converted to DT and multiplatform
- Clock drivers and bindings for some of the lower-end i.MX 1/2
platforms
- Kirkwood, one of the popular Marvell platforms, is folded into the
mvebu platform code, removing mach-kirkwood
- Hwmod data for TI AM43xx and DRA7 platforms
- More additions of Renesas shmobile platform support
- Removal of plat-samsung contents that can be removed with S5PV210
being multiplatform/DT-enabled and the other two old platforms
being removed
New platforms (most with only basic support right now):
- Hisilicon X5HD2 settop box chipset is introduced
- Mediatek MT6589 (mobile chipset) is introduced
- Broadcom BCM7xxx settop box chipset is introduced
+ as usual a lot other pieces all over the platform code"
* tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits)
ARM: hisi: remove smp from machine descriptor
power: reset: move hisilicon reboot code
ARM: dts: Add hix5hd2-dkb dts file.
ARM: debug: Rename Hi3716 to HIX5HD2
ARM: hisi: enable hix5hd2 SoC
ARM: hisi: add ARCH_HISI
MAINTAINERS: add entry for Broadcom ARM STB architecture
ARM: brcmstb: select GISB arbiter and interrupt drivers
ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs
ARM: configs: enable SMP in bcm_defconfig
ARM: add SMP support for Broadcom mobile SoCs
Documentation: arm: misc updates to Marvell EBU SoC status
Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC
ARM: mvebu: fix build without platforms selected
ARM: mvebu: add cpuidle support for Armada 38x
ARM: mvebu: add cpuidle support for Armada 370
cpuidle: mvebu: add Armada 38x support
cpuidle: mvebu: add Armada 370 support
cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7
ARM: mvebu: export the SCU address
Under "arm/mach-exynos" many files are using PMU register offsets.
Since we have added support for accessing PMU base address via DT,
now we can remove PMU mapping from exynosX_iodesc. Let's convert
all these access using iomapped address.
This will help us in removing static mapping of PMU base address
as well as help in reducing dependency over machine header files.
Thus helping for migration of PMU implementation from machine to
driver folder which can be reused for ARM64 based SoC.
Also as we have removed static mappings from "regs-pmu.h" it does
not need map.h anymore. But "platsmp.c" needed this and till now it
got included indirectly. So lets move header inclusion of
"mach/map.h" from "regs-pmu.h" to "platsmp.c".
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Turning off a cluster when all 4 cores of the cluster are powered off
saves power significantly. Powering off the A15 L2 alone gives around
100mW in savings. Add support for powering off the A15/A7 clusters on
exynos5420/5800.
The patch enables specific register bits which ensure that:
- cluster L2 will be turned on before the first man is powered up.
- last man will be turned off before the cluster L2 is turned off.
- core is powered down before powering it up.
Remove the exynos_cluster_power_control function completely as we can
rely on the above mentioned bits rather than polling the cluster power
status register.
In order to support cpuidle through mcpm, suspend and powered-up
callbacks are required in mcpm platform code.
Hence populate the same callbacks.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Signed-off-by: Chander Kashyap <k.chander@samsung.com>
Ensure that platform maintainers check the CPU part number in the right
manner: the CPU part number is meaningless without also checking the
CPU implement(e|o)r (choose your preferred spelling!) Provide an
interface which returns both the implementer and part number together,
and update the definitions to include the implementer.
Mark the old function as being deprecated... indeed, using the old
function with the definitions will now always evaluate as false, so
people must update their un-merged code to the new function. While
this could be avoided by adding new definitions, we'd also have to
create new names for them which would be awkward.
loopback
The Chromebook firmware doesn't enable the CCI for the boot cpu, and
arguably it shouldn't have to either. Let's have the kernel handle the
CCI on its own for the boot CPU the same way it does it for secondary CPUs
by using the MCPM loopback.
This allows to boot all 8 cores on exynos5420-peach-pit,
exynos5800-peach-pi and ARM Chromebook 2.
Tested-by: Tushar Behera <tushar.b@samsung.com>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Doug Anderson <dianders@chromium.org>
On exynos mcpm systems the firmware is hardcoded to jump to an address
in SRAM (0x02073000) when secondary CPUs come up. By default the
firmware puts a bunch of code at that location. That code expects the
kernel to fill in a few slots with addresses that it uses to jump back
to the kernel's entry point for secondary CPUs.
Originally (on prerelease hardware) this firmware code contained a
bunch of workarounds to deal with boot ROM bugs. However on all
shipped hardware we simply use this code to redirect to a kernel
function for bringing up the CPUs.
Let's stop relying on the code provided by the bootloader and just
plumb in our own (simple) code jump to the kernel. This has the nice
benefit of fixing problems due to the fact that older bootloaders
(like the one shipped on the Samsung Chromebook 2) might have put
slightly different code into this location.
Once suspend/resume is implemented for systems using exynos-mcpm we'll
need to make sure we reinstall our fixed up code after resume. ...but
that's not anything new since IRAM (and thus the address of the
mcpm_entry_point) is lost across suspend/resume anyway.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
Since commit 166aaf39 ("ARM: 8029/1: mcpm: Rename the power_down_finish()
functions to be less confusing") changed the name of power_down_finish to
wait_for_cpu_powerdown, so use new member name wait_for_cpu_powerdown.
The exynos5800 is very similar to exynos5420. We can re-use
the existing MCPM support for exynos5800 for secondary boot
-up and switching.
Add machine-dependent MCPM call-backs for Exynos5420. These are used
to power up/down the secondary CPUs during boot, shutdown, s2r and
switching.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Signed-off-by: Inderpal Singh <inderpal.s@samsung.com>
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org>
