Add busfreq support for i.MX6Q/DL, 3 setpoints supported:
HIGH: MMDC = 528MHz on i.MX6Q, = 396MHz on i.MX6DL; AHB = AXI = 24MHz;
AUDIO: MMDC = 50MHz, AXI = 50MHz, AHB = 25MHz;
LOW: MMDC = AXI = AHB = 24MHz.
Signed-off-by: Anson Huang <b20788@freescale.com>
Add SMP support for i.MX7D, including CPU hotplug support.
During 4.14 rebase:
* added arm,cpu-registers-not-fw-configured to timer
* added back fsl,imx51-src to src (removed by upstream)
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Freescale LS1021A SoCs deploy two cortex-A7 processors,
this adds bring-up support for the secondary core.
Signed-off-by: Jingchang Lu <b35083@freescale.com>
With commit c716483c3db1 ("ARM: 8122/1: smp_scu: enable SCU standby
support"), the STANDBY bit of SCU is handled by core function
scu_enable(). So imx_scu_standby_enable() can be removed now.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
We have a handy macro to replace open coded __cpuc_flush_dcache_area(()
and outer_clean_range() sequences. Let's use it. No functional change.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
This removes all the ARM uses of the __cpuinit macros from C code,
and all __CPUINIT from assembly code. It also had two ".previous"
section statements that were paired off against __CPUINIT
(aka .section ".cpuinit.text") that also get removed here.
[1] https://lkml.org/lkml/2013/5/20/589
The diagnostic register holds the errata bits. Mostly bootloader
does not bring up secondary cores, so that when errata bits are set
in bootloader, they are set only for boot cpu. But on a SMP
configuration, it should be equally done on every single core.
Set up the diagnostic register for secondary cores by replicating
the register from boot cpu.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
into next/soc2
From Shawn Guo:
The imx soc changes for 3.10:
* Enable anatop, well bisa and RBC for suspend to optimize the power
consumption a little bit
* Clock changes for TVE, LDB, PATA, SRTC support
* Add System Reset Controller (SRC) support for imx5 and imx6
* Add initial imx6dl support based on imx6q code
* Kconfig for cpufreq-cpu0, defconfig updates and few other changes
* tag 'imx-soc-3.10' of git://git.linaro.org/people/shawnguo/linux-2.6: (275 commits)
ARM i.MX53: set CLK_SET_RATE_PARENT flag on the tve_ext_sel clock
ARM i.MX53: tve_di clock is not part of the CCM, but of TVE
ARM i.MX53: make tve_ext_sel propagate rate change to PLL
ARM i.MX53: Remove unused tve_gate clkdev entry
ARM i.MX5: Remove tve_sel clock from i.MX53 clock tree
ARM: i.MX5: Add PATA and SRTC clocks
ARM: imx: do not bring up unavailable cores
ARM: imx: add initial imx6dl support
ARM: imx1: mm: add call to mxc_device_init
ARM: imx_v4_v5_defconfig: Add CONFIG_GPIO_SYSFS
ARM: imx_v6_v7_defconfig: Select CONFIG_PERF_EVENTS
ARM: i.MX53 Add the cko1, cko2 clock outputs.
staging: drm/imx: Use SRC to reset IPU
ARM i.MX6q: Add GPU, VPU, IPU, and OpenVG resets to System Reset Controller (SRC)
ARM: imx: do not use regmap_read for ANADIG_DIGPROG
ARM i.MX6q: set the LDB serial clock parent to the video PLL
ARM i.MX6q: Add audio/video PLL post dividers for i.MX6q rev 1.1
ARM i.MX6q: fix ldb di divider and selector clocks
ARM i.MX53: fix ldb di divider and selector clocks
ARM i.MX: Add imx_clk_divider_flags and imx_clk_mux_flags
Trivial change/change conflict in arch/arm/mach-imx/mach-imx6q.c resolved.
The i.MX6 Quad can be fused as i.MX6 Dual chip, and similarly i.MX6
DualLite can be fused as i.MX6 Solo. The actual number of available
cores can be found out from SCU.
Since we do not reflect the fusing thing in device tree, the function
arm_dt_init_cpu_maps() will always call set_cpu_possible(true) for 4
cores on i.MX6 Quad/Dual and 2 cores for i.MX6 DualLite/Solo. This
causes failures when kernel tries to bring those unavailable cores
online. For example, the following failure message will be seen when
booting an i.MX6 Solo chip.
CPU1: failed to come online
Though kernel will still boot fine, the message is somehow annoying.
Let's get rid of it by calling set_cpu_possible(false) on those
unavailable cores.
While at it, the set_cpu_possible(true) for available cores is removed,
since it's already been done in arm_dt_init_cpu_maps().
All the calls to gic_secondary_init() pass 0 as the first argument.
Since this function is called on each CPU when starting, it can be done
in a platform-independent way via a CPU notifier registered by the GIC
code.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Tested-by: Dinh Nguyen <dinguyen@altera.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Barry Song <baohua.song@csr.com>
Linux 3.8-rc6
git://git.linaro.org/people/shawnguo/linux-2.6 into next/soc
From Shawn Guo:
imx6q cpuidle support for 3.9
- It's based on imx-cleanup-3.9 to avoid conflicts.
* tag 'imx6q-cpudile-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: imx6q: support WAIT mode using cpuidle
ARM: imx: move imx6q_cpuidle_driver into a separate file
ARM: imx: mask gpc interrupts initially
ARM: imx: return zero in case next event gets a large increment
ARM: imx: Remove mx508 support
ARM: imx: Remove mach-mx51_3ds board
ARM: imx: use debug_ll_io_init() for imx6q
ARM: imx: remove unused imx6q_clock_map_io()
ARM: mach-imx: Kconfig: Do not select Babbage for MACH_IMX51_DT
Still, two delete/change conflicts caused by imx/cleanup:
arch/arm/mach-imx/mach-mx50_rdp.c
arch/arm/mach-imx/mach-mx51_3ds.c
Add WAIT mode (ARM core clock gating) support to imx6q cpuidle driver.
As WAIT mode is broken on imx6q TO 1.0 and 1.1, it only enables the
support for revision 1.2 with chicken bit set.
It's buggy to disable the cpu that is being hot-unplugged in .cpu_die
hook which runs on the cpu itself. Instead, it should be done in
.cpu_kill which runs on the thread (another cpu) that asks for shutting
down the cpu. Move imx_enable_cpu(cpu, false) call into .cpu_kill
hook, and leave the cpu to be hot-unplugged in WFI within .cpu_die,
so that we can get a more stable cpu hot-plug operation.
Now that we have GIC moved to drivers/irqchip and all GIC DT init for
platforms using irqchip_init, move gic.h and update the remaining
includes.
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
In preparation of moving gic code to drivers/irqchip, remove the direct
platform dependencies on gic_raise_softirq. Move the setup of
smp_cross_call into the gic code and use arch_send_wakeup_ipi_mask
function to trigger wake-up IPIs.
Acked-by: Olof Johansson <olof@lixom.net>
It moves a bunch of header files included in hardware.h and itself
from mach-imx/include/mach to mach-imx, and updates users to include
hardware.h rather than mach/hardware.h. The files in mach-imx/devices
will need to include "../hardware.h".
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Rename mach-imx/include/mach/common.h to mach-imx/common.h and update
all users to include common.h rather than mach/common.h.
It also removes an unneeded inclusion to common.h in
mach-imx/devices/devices.c.
Convert the imx6q platform to use struct smp_operations to provide
its SMP and CPU hotplug operations.
Cc: Shawn Guo <shawn.guo@linaro.org>
It adds smp and cpu hotplug support for imx6q.
