I'm not exactly sure how to properly fix the cpuidle part as the whole file seems to assume all IMX* are enabled
so this is mostly a "bug-report" instead of a proper patch
arch/arm/mach-imx/built-in.o: In function `init_mmdc_lpddr2_settings':
platform-imx-dma.c:(.text+0x9938): undefined reference to `imx6sll_lpddr2_freq_change'
platform-imx-dma.c:(.text+0x993c): undefined reference to `imx6sll_lpddr2_freq_change'
arch/arm/mach-imx/built-in.o: In function `imx6sl_init_late':
platform-imx-dma.c:(.init.text+0xdef0): undefined reference to `imx6sll_cpuidle_init'
Signed-off-by: Alejandro Mery <amery@hanoverdisplays.com>
Add gpt_3m clock source on i.MX6SLL.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit a0c56a60ea0c0acae0bc8eea75c465eeb11826cd)
The double MU count operations should be only done when changing the
MMDC frequency from 400MHz to a low frequency(100MHz or 24MHz).
Otherwise, the MU count may overflow and lead to system hang/panic issue.
This is basically a porting of 4d09bf110b878a6f720ee9d19c8b64ceace95fbe
to imx6dq lppdr2.
Also a member "freq" has been added to the mmdc_settings_info structure
to store the current ddr frequency on iram settings to be able to execute
the double MU count, only on 400MHz mode and bypass the operation
otherwise within the update freq routine.
Signed-off-by: Juan Gutierrez <juan.gutierrez@nxp.com>
Adding the corresponding brackets were missing when introducing
a new phy fixup function. This patch fix it.
Even though is not affecting the behaviour, the brackets are missing
to limit this check for imx6q as was intended in first place
Drop the VDD_SOC and VDD_ARM voltage to 0.9V when system runs at low
power run mode.
(cherry picked from commit 65517808712fcd4c5cb3b81a5d8714929957e49c)
On i.MX6ULL, some part can run at 1GHz or 800MHz setpoint.
we need to use the speed grading fuse to disable the unsupported
setpoint. speed grading fuse define as below:
2'b00: Reserved;
2'b01: 528MHz;
2'b10: 792MHz;
2b'11: 996Mhz;
For i.mx6q systems the mmdc handshake on channel 0 is kept enabled (while
channel 1 is bypassed). This is ok for lpddr2 systems operating on 1ch-mode,
but not true for 2ch-mode. On this case the handshake needs to be set for
both channels, otherwise a kernel panic or Oops error might be observed
after resuming from suspend.
To configure the suspend settings for lpddr2 systems is necessary
to know if mmdc is operating on 1ch-mode or 2ch-mode.
Here, the imx_get_lpddr2_2ch_mode api is introduced to get this info
when needed and decide accordingly.
Using the CLK_GET_RATE_NOCACHE flag on the clock dividers will allow
the recalculation of the rate instead of just caching its value.
For instance, this allows the mmdc clock to be properly updated,
after being modified by the busfreq driver, within an iram routine
by calling the clk_get_rate api. Using this flag allows to call only
to the .recalc_rate functions instead of additionally call the
.set_rate ones.
Signed-off-by: Ranjani Vaidyanathan <ranjani.vaidyanathan@nxp.com>
As periph_pre_clk's parent is not changed when going to high audio frequency,
the clk framework will not update its children's frequency. This cause
the the mmdc_ch0_axi clk_rate does not reflect the right frequency when
reading it from userspace like:
cat /sys/kernel/debug/clk/mmdc_ch0_axi/clk_rate
Since the mmdc_ch0_axi_podf is changed in the asm busfreq routine, then the
mmdc rate needs to be updated to make sure clk tree is right, although it
will not do any change to hardware.
To do this the clk_get_rate api is used to update the mmdc_clk which
needs to be dereferenced from the device tree. Since for other cases like
ddr3, the update of the rate of the mmdc clk is not needed, the absense of
this parameter (on the device tree) don't make throw an error, instead, NULL
checks are used to check if the mmdc clk needs to be updated or not.
After a frequency transition, like 400MHz to 24Mhz, on i.mx6DQ SCM
systems (which use lpddr2), the curr_ddr_rate variable retains its
previous cached value causing the next frequency update transition
to fail by following a wrong flow which results in a complete hang
of the system.
Issuing an L1 cache flush during the freq update routine (as in in
MXSCM-241-1) and moving up the curr_ddr_rate variable before calling
tge freq update alleviates the problem.
Flush and disable L1 before disabling L2, to let data to be coherent.
Flushing L1 pushes everyhting to L2. L2 is sync later, but it can still
have dirty lines.
Fix busfreq support on i.MX6ULL LPDDR2 board.
(cherry picked from commit 4306d7689b330d67ccf6586e365465f217d3df09)
The previous code only support i.MX6UL EVK RevA, RevB, RevC PHY KSZ8081
with fixed silicon revision.
Different silicon revision may have different phy fixup init setting.
i.MX6UL EVK RevC1 apdate new silicon revision PHY. After debug and tune,
the revision still need the same phyfix setting.
So, add Ethernet PHY KSZ8081 new silicon revision fixup setting.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit: 15c759347681b65fa33986f0fc5687a374d9f3a1)
On i.MX6SLL, if all PLLs is bypassed in low power run mode, we can decrease
the VDD_ARM_IN and VDD_SOC_IN voltage to 0.925V to save power. a 25mV margin
is added to cover IR drop and board tolerance.
Add low power run voltage change support for i.MX6SLL.
(cherry picked from commit 3b9da6e8b867ee59c81314d3e08af60053a5855d)
When ENET wake up is enabled by wake-on-lan (WOL), the weak 2P5
ldo needs to keep power up even for LPDDR2 due to the ENET_PLL is
feed by the weak 2p5 ldo during DSM. If the weak 2P5 ldo is power
down the ENET module is power off hence it is not able to sense the
WOL interrupt and trigger the system resume.
change parent clock to pll3_pfd2 and calculate out a desired pixel clock
rate. This patch fixed the following warning.
"imx_epdc_v2_fb 20f4000.epdc: Unable to get an accurate EPDC pix clkdesired = 40000000, actual = 63529412"
Signed-off-by: Robby Cai <robby.cai@nxp.com>
(cherry picked from commit 76a336b931a74605caa94ca82c7b8343d604fee6)
As on i.MX6SLL, there is no ARM LDO, the code for ARM LDO
bypass check is unnecessary, remove these piece of code in
i.MX6SLL low power idle.
(cherry picked from commit be3df9ec9b68574b5a319009fa6f37c105d6b771)
When MMDC runs at a low frequency, it is not recommended to
perform "force measurement", the MMDC measure unit may return
a wrong measurement value when running below 100MHz.
Additionally, the double MU count operations should be only done
when changing the MMDC frequency from 400MHz to a low
frequency(100MHz or 24MHz). Otherwise, the MU count may overflow
and lead to system hang issue.
(cherry picked from commit 4d09bf110b878a6f720ee9d19c8b64ceace95fbe)
Add low power idle support on i.MX6SLL.
(cherry picked from commit 26de2bb5e8ddef4f1562cc5e6001bfc0027106f0)
Add bufreq driver support on i.MX6SLL. For i.MX6SLL,
it only support LPDDR2 and LPDDR3. the DDR clock change
flow is same on these two type of DDR.
(cherry picked from commit 8479afb4e7c52c6de1bedefb00a7cea4320fc14d)
Increase the AXI and AHB clock rate on i.MX6SLL according to
the RM to improve the system bus performance.
(cherry picked from commit 1bbfc89fa5ecf644115cac878bd8fd7ed10b988c)
add extern audio clock in imx6sll clock tree
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
(cherry picked from commit c23203e1247c94ee154e8f04925eb1d659465229)
i.MX6SLL has new hardware function of bus auto clock gating,
whenerve bus is idle, its clock will be auto gated to save
power, enable this function.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
(cherry picked from commit 857b0c9bb240805662bacbdcad963779848621bb)
i.MX6SLL has different DRAM IO offset, and it has no
CAS/RAS/ODT/RESET pin now, correct the DRAM IO offset.
To better support all different i.MX6 SoCs and different
DRAM types, introduce a new column to store the low power
settings for DRAM IO, then suspend asm code no need to check
SoC or DRAM type, just get the DRAM IO's low power
settings from OCRAM pm_info and set to each DRAM IO.
(cherry picked from commit 00f51e3c882b7674d26954fdf421e8e3824c3ed5)
On i.MX6SLL, the 'L2_PGE' bit in GPC CNTR register is set
by default,this bit must be clear, otherwise, system will
failed to resume from DSM mode if L2 cache is enabled.
(cherry picked from commit c463f044d77ca4b3442013f4f5c3b464fb64f029)
i.MX6SLL LPDDR3 script v1.2 is released, update MMDC
restore settings accordingly.
(cherry picked from commit 45ffeee7a34c5ca54d46722850a8917d0cfc8cd3)
For MMDC, LPDDR3 type's value is 2b'11, which is
different from DDRC, so correct it.
(cherry picked from commit 80c543452d9d66f03b84fe31ca3d6e7bbdf28603)
Add cpufreq support for i.MX6SLL, uses i.MX6SL's
opp table for now.
(cherry picked from commit 750c04596f178dff20408ef7c371fb18134f1a43)
Add DSM mode support for i.MX6SLL, Mega/Fast mix
can be off now.
(cherry picked from commit 408d72246b5e28f2a69e0d4559e414921ae7a4e3)
Add i.MX6SLL MSL support, machine code reuses
i.MX6SL.
(cherry picked from commit f834656e5fcc3338c4fb35b2908d98cf3313b0a9)
Add i.MX6SLL GPT timer support.
(cherry picked from commit 44b5e3b1252a5c82f1332a5bf17877558c50cae4)
Add clock driver for i.MX6SLL.
Signed-off-by: Frank Li <Frank.Li@nxp.com>
(cherry picked from commit 06100a0ca8733700c42d66ce6bb91ca941db9222)
Add Micrel phy initialization for imx6sxscm evb platform
Signed-off-by: Alejandro Sierra <alejandro.sierra@nxp.com>
When a device like (USB, CAMM, tty, etc) prevents the megamix
domain to power down during the suspend process (by enabling
a wakeup source) the resume process goes through a path where
the MMDC context should not be restored. However this resume
path does not reset the read fifo MMDCx_MPDGCTRL0[RST_RD_FIFO]
for the platforms with LPDDR2 causing a bad resuming and reset
of the device due to an exception.
This patch adds the reset_read_fifo on the No-restoring-MMDC
path to fix the bad resuming.
Signed-off-by: Alejandro Sierra <b18039@freescale.com>
vring memory address was hardcoded at the top of the 1GB RAM.
For systems with a memory map with less or different than 1GB,
the hardcoded value might be not correct and cause issues.
This patch add the support to pass the vring address from device
tree configuration on the reg platform argument in the following
format:
reg = <vring_address vring_size>
For example, for a 512MB system, with the rpmgs vring placed at
top of the memory the configuration will look like below:
&rpmsg{
reg = <0x9FFF0000 0x8000>;
1.8v of imx7d pcie phy, should be turned on after
the 1p0d(1.0v) of pcie phy is turned on.
And turned off before the 1p0d(1.0v) of pcie phy
is turned off
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
(cherry picked from commit ee97d82dad19d04e30d482a08923c2e11c629b1f)
The timing settings for 100MHz are almost the same as the ones for
400MHz except for the MMDCx_MISC[RALAT] parameter which needs to be
set to 2 cycles.
For the 100MHz case the restoration of the mmdc setting should be performed
in 2 steps: restore the mmdc setting and then overwrite the RALAT setting
for 2 cycles.
A decision code within the "mmdc_clk_lower_equal_100MHz" macro is added
to go to the "equal to 100MHz" or to the "lower to 100MHz" case
Signed-off-by: Alejandro Lozano <alejandro.lozano@nxp.com>
Setting the Read Additional Latency (RALAT) to 2 cycles,
MMDCx_MDMISC[RALAT] = 2, is needed for 24MHz operation point.
Currently this is set within the "set_timings_below_100MHz_operation"
macro, which is use for the 24MHz case.
In order to provide a generic way for setting RALAT=2 the code
is wrapped in this new macro: "set_mmdc_misc_ralat_2_cycles", so
other set points (besides the below 100MHz case) can reuse this code.
As an example, for 100Mhz operation the RALAT should be set to 2 cycles,
however, the rest of the MMDCFG parameter are not the same as in the
"below_100MHz" case. So, this macro can be reused for its RALAT part.
Two macros are renamed:
1) set_timings_above_100MHz_operation as restore_mmdc_settings_info
2) mmdc_clk_lower_100MHz as mmdc_clk_lower_equal_100MHz
For (1) the operation is generic to several cases and not just related
(at least on a semantic way) with the operations "above" 100MHz
Renamed as restore_mmdc_settings_info the macro can be reused for the
other cases like equal to 100MHz and possibly other intermediate
operation points.
For (2), the macro is renamed as mmdc_clk_lower_equal_100MHz to reflect
that this macro handles both the "lower than 100 MHz" case and the
"equal to 100MHz" case.
Fix system clock topology used by lpddr2 for audio mode
Keep pll2_pfd2 as clock root for periph_pre_clk to match
lpddr2_freq_imx6q.S switching mechanism.
(Rework from commit id 427b1b6d628827ca83887b92c8331a261a254151)
Signed-off-by: Adrian Alonso <adrian.alonso@nxp.com>
(Cherry pick from commit 583b09e4d30ec0ce3b3a0494ebd0419d05701ce2)
Fix switch_to_100Mhz miss to store updated podf dividers
for system clocks running at 100Mhz (audio mode)
(Cherry picked from commit f54f8c9e1fbb0c937c3ad2e0867ccc2d4d50e77a)
Simplify system root clock sources, only use pll2_pfd2 and osc
for system clocks, when busfreq request high bus mode or audio bus
mode only update dividers to achieve operating frequencies from
same source (pll2_pfd2).
Bus freq mode (400M) (100M) (24Mhz)
mmdc_ch0_clk_root @396MHz @99MHz @24Mhz
axi_clk_root @198MHz @49.5MHz @24Mhz
ahb_clk_root @132MHz @49.5Mhz @24Mhz
ipg_clk_root @66MHz @24.75Mhz @12Mhz
(Cherry pick from commit c85924790d0e3d4dd2bc86c088f363853ea4af91)
When the external oscillator is used as pcie ref clk.
the below configurations should done.
- set the lvds_clk1 as input
- set the source of the pll6_bypass to be lvds_clk1
- set the pll6 to be bypass mode.
(cherry picked from commit c45c230b7f488dcf18b715129852d27c24c849e6)
When i.MX6QP with speed grading fuse blown to 1.2GHz,
VPU should run at 396MHz, add this support.
On i,MX6SL, no NUM and DENUM register, so this PLL should not
be registered as IMX_PLLV3_GENERIC type PLL, it should be
registered as IMX_PLLV3_SYSV2.
As i.MX6's PLL2 also support a fractional-N
synthesizer, so we need to consider the NUM
and DENOM's value to get a correct rate, as
fraction may be used in some cases.
Remove round_rate and set_rate for PLL2, as
it is NOT allowed to be changed in kernel
dynamically, otherwise, PFDs and DDR may NOT
work normally, it normally should be changed
in u-boot before DDR is enabled.
i.MX6SX LDB will connect to LCDIF2.
And LCDIF2 pixel clock can not re-parent when it's on.
So default setting clock parent to ldb_di0.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
During suspend, as 24MHz will be disabled, but system counter
needs to be running in order to maintain accurate clock source,
so we need to switch system counter's clock from base clock(24MHz)
to alternate clock(32K) before system enter STOP mode, otherwise,
the suspend time will NOT be counted into system time when issue
a "date" command.
(cherry picked from commit 470f930321d7633ea9844a1ebf6784cafd8b7372)
