path: root/arch/arm/mach-integrator/impd1.c
2011-02-19ARM: integrator: switch Integrator platforms to use consolidated CLCDRussell King
This switches integrator platforms to use the consolidated CLCD panel support, including the display capabilities. These capabilities prevent the unsupported BGR565 mode being selected, while still allowing RGB5551, BGR5551 and RGB565 modes. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-02ARM: Indirect round/set_rate operations through clk structureRussell King
2010-05-02ARM: Make Integrator/Versatile/Reaview VCO code similarRussell King
2010-05-02ARM: ICST: kill duplicate icst codeRussell King
The only difference between ICST307 and ICST525 are the two arrays for calculating the S parameter; the code is now identical. Merge the two files and kill the duplicated code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: ICST: indirect s2div and idx2s arrays via icst_paramsRussell King
2010-05-02ARM: ICST: move minimum VCO frequency to icst_paramsRussell King
2010-05-02ARM: ICST: use Hz instead of kHzRussell King
This makes the ICST support fit more nicely with the clk API, eliminating the need to *1000 and /1000 in places. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: ICST: provide definitions for max/min VCO frequenciesRussell King
2010-05-02ARM: ICST: merge common ICST VCO structuresRussell King
The structures for the ICST307 and ICST525 VCO devices are identical, so merge them together. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-11-27[ARM] integrator: convert to clkdev and lookup clocks by device nameRussell King
People often point to the Integrator/Versatile/Realview implementations to justify using the consumer name as the sole selector for clocks. Eliminate this excuse by changing the Integrator implementation, so it provides a better example of how it should be done. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-18[ARM] fix impd1.c build warningRussell King
CC arch/arm/mach-integrator/impd1.o arch/arm/mach-integrator/impd1.c: In function `impd1_probe': arch/arm/mach-integrator/impd1.c:408: warning: too few arguments for format Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-21arm: bus_id -> dev_name() and dev_set_name() conversionsKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21driver core: fix a lot of printk usages of bus_idGreg Kroah-Hartman
We have the dev_printk() variants for this kind of thing, use them instead of directly trying to access the bus_id field of struct device. This is done in order to remove bus_id entirely. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-23[ARM] integrator: fix build warnings and errorsRussell King
Fix resource_size_t warning in impd1.c, and printascii() build errors in pci_v3.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Convert kmalloc+memset to kzallocRussell King
Convert all uses of kmalloc followed by memset to use kzalloc instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-07[ARM] Move AMBA include files to include/linux/amba/Russell King
Since the ARM AMBA bus is used on MIPS as well as ARM, we need to make the bus available for other architectures to use. Move the AMBA include files from include/asm-arm/hardware/ to include/linux/amba/ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[PATCH] kfree cleanup: archJesper Juhl
This is the arch/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in arch/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-21[ARM] Fix Integrator IM/PD-1 supportRussell King
