path: root/arch/arm/mach-integrator/impd1.c
2008-05-23[ARM] integrator: fix build warnings and errorsRussell King
Fix resource_size_t warning in impd1.c, and printascii() build errors in pci_v3.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Convert kmalloc+memset to kzallocRussell King
Convert all uses of kmalloc followed by memset to use kzalloc instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-07[ARM] Move AMBA include files to include/linux/amba/Russell King
Since the ARM AMBA bus is used on MIPS as well as ARM, we need to make the bus available for other architectures to use. Move the AMBA include files from include/asm-arm/hardware/ to include/linux/amba/ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[PATCH] kfree cleanup: archJesper Juhl
This is the arch/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in arch/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-21[ARM] Fix Integrator IM/PD-1 supportRussell King
