Convert the integrator PCI driver to use the generic config access
functions.
This changes accesses from __raw_readX/__raw_writeX to readX/writeX
variants. The spinlock is removed because it is unnecessary. The config
read and write functions are already protected with a spinlock and no
access can occur during the .pre_init function.
[arnd: remove unused "flags"]
Signed-off-by: Rob Herring <robh@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Russell King <linux@arm.linux.org.uk>
CC: linux-arm-kernel@lists.infradead.org
The ranges property for a host bridge controller in DT describes the
mapping between the PCI bus address and the CPU physical address. The
resources framework however expects that the IO resources start at a pseudo
"port" address 0 (zero) and have a maximum size of IO_SPACE_LIMIT. The
conversion from PCI ranges to resources failed to take that into account,
returning a CPU physical address instead of a port number.
Also fix all the drivers that depend on the old behaviour by fetching the
CPU physical address based on the port number where it is being needed.
Signed-off-by: Liviu Dudau <Liviu.Dudau@arm.com>
CC: Grant Likely <grant.likely@linaro.org>
CC: Rob Herring <robh+dt@kernel.org>
CC: Arnd Bergmann <arnd@arndb.de>
CC: Thierry Reding <thierry.reding@gmail.com>
CC: Simon Horman <horms@verge.net.au>
CC: Catalin Marinas <catalin.marinas@arm.com>
As we move toward multiplatform support for the Integrator family
we need to localize all <mach/*> headers. This moves the hardware.h
header down to the machine folder. There are no users outside the
machine in the kernel.
Cc: Jonathan Austin <jonathan.austin@arm.com>
There is no need to have the two separate headers <mach/platform.h>
and <mach/hardware.h>, especially since we are now going to make them
local files. There is not one single driver outside the mach-integrator
folder referencing any of the files.
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
"DeviceTree updates for 3.13. This is a bit larger pull request than
usual for this cycle with lots of clean-up.
- Cross arch clean-up and consolidation of early DT scanning code.
- Clean-up and removal of arch prom.h headers. Makes arch specific
prom.h optional on all but Sparc.
- Addition of interrupts-extended property for devices connected to
multiple interrupt controllers.
- Refactoring of DT interrupt parsing code in preparation for
deferred probe of interrupts.
- ARM cpu and cpu topology bindings documentation.
- Various DT vendor binding documentation updates"
* tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits)
powerpc: add missing explicit OF includes for ppc
dt/irq: add empty of_irq_count for !OF_IRQ
dt: disable self-tests for !OF_IRQ
of: irq: Fix interrupt-map entry matching
MIPS: Netlogic: replace early_init_devtree() call
of: Add Panasonic Corporation vendor prefix
of: Add Chunghwa Picture Tubes Ltd. vendor prefix
of: Add AU Optronics Corporation vendor prefix
of/irq: Fix potential buffer overflow
of/irq: Fix bug in interrupt parsing refactor.
of: set dma_mask to point to coherent_dma_mask
of: add vendor prefix for PHYTEC Messtechnik GmbH
DT: sort vendor-prefixes.txt
of: Add vendor prefix for Cadence
of: Add empty for_each_available_child_of_node() macro definition
arm/versatile: Fix versatile irq specifications.
of/irq: create interrupts-extended property
microblaze/pci: Drop PowerPC-ism from irq parsing
of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.
of/irq: Use irq_of_parse_and_map()
Several architectures open code effectively the same code block for
finding and mapping PCI irqs. This patch consolidates it down to a
single function.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Michal Simek <monstr@monstr.eu>
All the callers of irq_create_of_mapping() pass the contents of a struct
of_phandle_args structure to the function. Since all the callers already
have an of_phandle_args pointer, why not pass it directly to
irq_create_of_mapping()?
struct of_irq and struct of_phandle_args are exactly the same structure.
This patch makes the kernel use of_phandle_args everywhere. This in
itself isn't a big deal, but it makes some follow-on patches simpler.
The OF irq handling code has been overloading the term 'map' to refer to
both parsing the data in the device tree and mapping it to the internal
linux irq system. This is probably because the device tree does have the
concept of an 'interrupt-map' function for translating interrupt
references from one node to another, but 'map' is still confusing when
the primary purpose of some of the functions are to parse the DT data.
This patch renames all the of_irq_map_* functions to of_irq_parse_*
which makes it clear that there is a difference between the parsing
phase and the mapping phase. Kernel code can make use of just the
parsing or just the mapping support as needed by the subsystem.
The patch was generated mechanically with a handful of sed commands.
In the PCIv3 driver, use devm_ioremap() instead of just ioremap()
when remapping the system controller in the PCIv3 driver, so
the mapping will be automatically released on probe failure.
Reported-by: Mark Rutland <mark.rutland@arm.com>
This header is no longer needed when we boot from the device tree.
The Device Tree boot path now supports everything the ATAG
boot can provide, and the two are equivalent. This deletes
the ATAG boot path from the Integrator/AP and
Integrator/CP platforms to move them on to the future.
The static HW irqs have no meaning in the interrupt handler
and does not correlate to the /proc/interrupts IRQ numbers
anymore, print the Linux IRQ number instead.
Instead of relying on the hard-coded mem/premem bases for
the PCI side, read in these from the device tree in the
DT probe path. Hard-code the old values on the non-DT probe
path. Introduce some static locals to hold these addresses
instead of the earlier static #defines.
This registers the memory ranges for I/O, non-prefetched and
prefetched memory and configuration space for the PCIv3 bridge
and let us fetch these basic memory resources from the device
tree in the device tree boot path. Remove the stepping stone
platform device. This is an either/or approach - the platform
data path is mutually exclusive to the plain platform data
path and provided addresses from the device tree have to be
correct.
This adds the interrupt-map property to the PCIv3 DTS file
and makes the bridge obtain mappings from the device tree.
Try to make this driver self-contained by moving the ioremapping
into the driver.
The global vga_base is used for things like getting an early
console on a PCI-based VGA adapter. Move this assignment into
the probe function for the PCI bridge.
Remove the static mapping for the PCIv3 PCI bridge controller
and do this dynamically when probing instead.
This moves the PCIv3 register definitions into the driver itself.
There is no other driver or board code including this file, nor
will there be. If some other platform needs this driver it should
be generalized to support several platforms.
This moves the point where the PCIv3 driver grabs the SC base
address to the probe function.
This moves the request of the PCI error interrupt to the probe()
function for the device, uses the devm* managed call and switch
to a dev_err() error print.
This converts the PCIv3 driver to a platform device driver, and
registers the device only on the Integrator/AP instead of bailing
out in the initcall if the platform is not correct.
The Integrator/AP PCI bridget, "v3" is contained in two files,
where pci.c is a socket container to plug in the v3 device.
However to transition the v3 to enable device tree probing, it
need to be converted to a platform device (so that it can have
a device node in the device tree) and then we want the PCI
driver in a single file, as any other device driver, so we can
handle variants using compatible strings and device name,
and get the base address etc from resources connected to the
device node.
To move toward this goal we consolidate all code in the
pci_v3.c file.
The Integrator/AP syscon remapping was done in the .setup()
function rather than .preinit() which is wrong - .preinit()
is called before .setup() and the former also use the syscon
base and cause a crash since it was not yet remapped.
Just use BUG_ON() instead of constructions such as:
if (...)
BUG()
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression e;
- if (e) BUG();
+ BUG_ON(e);
// </smpl>
This pushes the dependencies on the Integrator/AP system
controller (SC) down into the PCI V3 driver and the
AP-specific board file.
First, the platform data for the PL010 UART is moved into
the integrator_ap.c board file, and the Integrator/CP is
assigned with NULL pdata. This way the callback functions
can reference the dynamically remapped AP syscon address
in both the ATAG and DT boot path, and this remapping
is localized to the board file.
Second the PCIv3 driver is making its own dynamic remapping
of the SC for the few registers it is using. When we
convert the PCIv3 driver over to using device tree having a
dynamically assigned base address will be useful, but we
will have to use the definition from <mach/platform.h> for
now, the only improvement is that it's done dynamically.
__iomem annotation cleanup branch from Arnd.
* cleanup/__iomem: (21 commits)
net: seeq: use __iomem pointers for MMIO
video: da8xx-fb: use __iomem pointers for MMIO
scsi: eesox: use __iomem pointers for MMIO
serial: ks8695: use __iomem pointers for MMIO
input: rpcmouse: use __iomem pointers for MMIO
ARM: samsung: use __iomem pointers for MMIO
ARM: spear13xx: use __iomem pointers for MMIO
ARM: sa1100: use __iomem pointers for MMIO
ARM: prima2: use __iomem pointers for MMIO
ARM: nomadik: use __iomem pointers for MMIO
ARM: msm: use __iomem pointers for MMIO
ARM: lpc32xx: use __iomem pointers for MMIO
ARM: ks8695: use __iomem pointers for MMIO
ARM: ixp4xx: use __iomem pointers for MMIO
ARM: iop32x: use __iomem pointers for MMIO
ARM: iop13xx: use __iomem pointers for MMIO
ARM: integrator: use __iomem pointers for MMIO
ARM: imx: use __iomem pointers for MMIO
ARM: ebsa110: use __iomem pointers for MMIO
ARM: at91: use __iomem pointers for MMIO
ARM is moving to stricter checks on readl/write functions,
so we need to use the correct types everywhere.
This patch has a few small conflicts with stuff in linux-next, which
we have to sort out in arm-soc.
Cc: Linus Walleij <linus.walleij@linaro.org>
No functional changes.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Move integrator PCI to fixed i/o mapping and remove io.h.
Most PCI implementations perform simple root bus scanning. Rather than
having each group of platforms provide a duplicated bus scan function,
provide the PCI configuration ops structure via the hw_pci structure,
and call the root bus scanning function from core ARM PCI code.
Acked-by: Krzysztof Hałasa <khc@pm.waw.pl>
Pull more ARM updates from Russell King.
This got a fair number of conflicts with the <asm/system.h> split, but
also with some other sparse-irq and header file include cleanups. They
all looked pretty trivial, though.
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits)
ARM: fix Kconfig warning for HAVE_BPF_JIT
ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds
ARM: 7349/1: integrator: convert to sparse irqs
ARM: 7259/3: net: JIT compiler for packet filters
ARM: 7334/1: add jump label support
ARM: 7333/2: jump label: detect %c support for ARM
ARM: 7338/1: add support for early console output via semihosting
ARM: use set_current_blocked() and block_sigmask()
ARM: exec: remove redundant set_fs(USER_DS)
ARM: 7332/1: extract out code patch function from kprobes
ARM: 7331/1: extract out insn generation code from ftrace
ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format
ARM: 7351/1: ftrace: remove useless memory checks
ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path
ARM: Versatile Express: add NO_IOPORT
ARM: get rid of asm/irq.h in asm/prom.h
ARM: 7319/1: Print debug info for SIGBUS in user faults
ARM: 7318/1: gic: refactor irq_start assignment
ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop
ARM: 7315/1: perf: add support for the Cortex-A7 PMU
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
This converts the Integrator AP/CP to use sparse IRQs.
Tested on both machines.
Acked-by: Rob Herring <rob.herring@calxeda.com>
Tell the PCI core about host bridge address translation so it can take
care of bus-to-resource conversion for us.
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus
resource fixups. This fixes the problem of "early" and "header" quirks
seeing incorrect root bus resources.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits)
rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock()
lockdep: Comment all warnings
lib: atomic64: Change the type of local lock to raw_spinlock_t
locking, lib/atomic64: Annotate atomic64_lock::lock as raw
locking, x86, iommu: Annotate qi->q_lock as raw
locking, x86, iommu: Annotate irq_2_ir_lock as raw
locking, x86, iommu: Annotate iommu->register_lock as raw
locking, dma, ipu: Annotate bank_lock as raw
locking, ARM: Annotate low level hw locks as raw
locking, drivers/dca: Annotate dca_lock as raw
locking, powerpc: Annotate uic->lock as raw
locking, x86: mce: Annotate cmci_discover_lock as raw
locking, ACPI: Annotate c3_lock as raw
locking, oprofile: Annotate oprofilefs lock as raw
locking, video: Annotate vga console lock as raw
locking, latencytop: Annotate latency_lock as raw
locking, timer_stats: Annotate table_lock as raw
locking, rwsem: Annotate inner lock as raw
locking, semaphores: Annotate inner lock as raw
locking, sched: Annotate thread_group_cputimer as raw
Fix up conflicts in kernel/posix-cpu-timers.c manually: making
cputimer->cputime a raw lock conflicted with the ABBA fix in commit
bcd5cff7216f ("cputimer: Cure lock inversion").
The changes introduced in commit
cc22b4c18540e5e8bf55c7d124044f9317527d3c
"ARM: set vga memory base at run-time"
Makes the Integrator/AP freeze completely. I appears that
this is due to the VGA base address being assigned at PCI
init time, while this base is needed earlier than that.
Moving the initialization of the base address to the
.map_io function solves this problem.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Annotate the low level hardware locks which must not be preempted.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Convert the incorrectly named PCIMEM_BASE to a variable called vga_base.
This removes the dependency on mach/hardware.h.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow
multi-platform builds. This also removes the requirement for a platform to
have a mach/hardware.h.
The default values for i/o and mem are 0x1000 and 0x01000000, respectively.
Per Arnd Bergmann, other values are likely to be incorrect, but this commit
does not try to address that issue.
Add one more parameter to hook_fault_code() to be able to set 'code'
field of struct fsr_info.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
arch/arm/Kconfig
arch/arm/include/asm/system.h
arch/arm/mm/Kconfig
Rather than using converted base address plus offset, use the register
address itself now that IO_ADDRESS() can cope with these.
Realview doesn't include mach/platform.h in mach/hardware.h, so
make versatile behave in the same way. Also, move the definition
of __io_address() into mach/hardware.h, just like Realview.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
WARNING: vmlinux.o(.text+0xc9d4): Section mismatch in reference from the function pci_v3_scan_bus() to the function .devinit.text:pci_scan_bus_parented()
The function pci_v3_scan_bus() references
the function __devinit pci_scan_bus_parented().
This is often because pci_v3_scan_bus lacks a __devinit
annotation or the annotation of pci_scan_bus_parented is wrong.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
