The changes introduced in commit
cc22b4c18540e5e8bf55c7d124044f9317527d3c
"ARM: set vga memory base at run-time"
Makes the Integrator/AP freeze completely. I appears that
this is due to the VGA base address being assigned at PCI
init time, while this base is needed earlier than that.
Moving the initialization of the base address to the
.map_io function solves this problem.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Convert the incorrectly named PCIMEM_BASE to a variable called vga_base.
This removes the dependency on mach/hardware.h.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow
multi-platform builds. This also removes the requirement for a platform to
have a mach/hardware.h.
The default values for i/o and mem are 0x1000 and 0x01000000, respectively.
Per Arnd Bergmann, other values are likely to be incorrect, but this commit
does not try to address that issue.
Add one more parameter to hook_fault_code() to be able to set 'code'
field of struct fsr_info.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
arch/arm/Kconfig
arch/arm/include/asm/system.h
arch/arm/mm/Kconfig
Rather than using converted base address plus offset, use the register
address itself now that IO_ADDRESS() can cope with these.
Realview doesn't include mach/platform.h in mach/hardware.h, so
make versatile behave in the same way. Also, move the definition
of __io_address() into mach/hardware.h, just like Realview.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
WARNING: vmlinux.o(.text+0xc9d4): Section mismatch in reference from the function pci_v3_scan_bus() to the function .devinit.text:pci_scan_bus_parented()
The function pci_v3_scan_bus() references
the function __devinit pci_scan_bus_parented().
This is often because pci_v3_scan_bus lacks a __devinit
annotation or the annotation of pci_scan_bus_parented is wrong.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Fix resource_size_t warning in impd1.c, and printascii() build
errors in pci_v3.c
mach-integrator/pci_v3.c: no need to reference 'irq' arg, its constant
mach-omap1/pm.c: remove extra whitespace
arch/arm/mach-sa1100/ssp.c: remove braces around single C stmt
arch/arm/plat-omap/mcbsp.c:
- remove pointless casts from void*
- make longer lines more readable
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
If DEBUG_LL is enabled, we want to use get_irq_regs(), but this
causes a build error due to the inline function missing. Add
the necessary header file.
Lots of places in arch/arm were needlessly including linux/ptrace.h,
resumably because we used to pass a struct pt_regs to interrupt
handlers. Now that we don't, all these ptrace.h includes are
redundant.
Untested, but this should fix up the bulk of the totally mechanical
issues, and should make the actual detail fixing easier.
Add the necessary call to register_isa_ports() so that glibc knows
where these are found on Integrator platforms.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
infrastructure for it.
Let it rip!
