path: root/arch/arm/mach-integrator/pci_v3.c
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-28ARM: Fix section mismatch warning in Integrator pci_v3Russell King
WARNING: vmlinux.o(.text+0xc9d4): Section mismatch in reference from the function pci_v3_scan_bus() to the function .devinit.text:pci_scan_bus_parented() The function pci_v3_scan_bus() references the function __devinit pci_scan_bus_parented(). This is often because pci_v3_scan_bus lacks a __devinit annotation or the annotation of pci_scan_bus_parented is wrong. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23[ARM] integrator: fix build warnings and errorsRussell King
Fix resource_size_t warning in impd1.c, and printascii() build errors in pci_v3.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] Misc minor interrupt handler cleanupsJeff Garzik
mach-integrator/pci_v3.c: no need to reference 'irq' arg, its constant mach-omap1/pm.c: remove extra whitespace arch/arm/mach-sa1100/ssp.c: remove braces around single C stmt arch/arm/plat-omap/mcbsp.c: - remove pointless casts from void* - make longer lines more readable Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-17[ARM] integrator: fix pci_v3 compile error with DEBUG_LLRussell King
If DEBUG_LL is enabled, we want to use get_irq_regs(), but this causes a build error due to the inline function missing. Add the necessary header file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] Remove needless linux/ptrace.h includesRussell King
Lots of places in arch/arm were needlessly including linux/ptrace.h, resumably because we used to pass a struct pt_regs to interrupt handlers. Now that we don't, all these ptrace.h includes are redundant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-28[ARM] Add Integrator support for glibc outb() and friendsRussell King
Add the necessary call to register_isa_ports() so that glibc knows where these are found on Integrator platforms. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
