path: root/arch/arm/mach-iop13xx/io.c
2013-05-23ARM: 7728/1: mm: Use phys_addr_t properly for ioremap functionsLaura Abbott
Several of the ioremap functions use unsigned long in places resulting in truncation if physical addresses greater than 4G are passed in. Change the types of the functions and the callers accordingly. Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-09-22Merge branch 'cleanup/__iomem' into next/cleanupOlof Johansson
__iomem annotation cleanup branch from Arnd. * cleanup/__iomem: (21 commits) net: seeq: use __iomem pointers for MMIO video: da8xx-fb: use __iomem pointers for MMIO scsi: eesox: use __iomem pointers for MMIO serial: ks8695: use __iomem pointers for MMIO input: rpcmouse: use __iomem pointers for MMIO ARM: samsung: use __iomem pointers for MMIO ARM: spear13xx: use __iomem pointers for MMIO ARM: sa1100: use __iomem pointers for MMIO ARM: prima2: use __iomem pointers for MMIO ARM: nomadik: use __iomem pointers for MMIO ARM: msm: use __iomem pointers for MMIO ARM: lpc32xx: use __iomem pointers for MMIO ARM: ks8695: use __iomem pointers for MMIO ARM: ixp4xx: use __iomem pointers for MMIO ARM: iop32x: use __iomem pointers for MMIO ARM: iop13xx: use __iomem pointers for MMIO ARM: integrator: use __iomem pointers for MMIO ARM: imx: use __iomem pointers for MMIO ARM: ebsa110: use __iomem pointers for MMIO ARM: at91: use __iomem pointers for MMIO ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-19ARM: iop13xx: use __iomem pointers for MMIOArnd Bergmann
ARM is moving to stricter checks on readl/write functions, so we need to use the correct types everywhere. Cc: Rob Herring <rob.herring@calxeda.com> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-26iop13xx: use more regular PCI I/O space handlingArnd Bergmann
iop13xx confuses I/O port numbers with physical addresses, which breaks legacy ISA I/O access behind PCI bridges and makes it unnecessarily hard to unify the inb/outb accessors with other platforms. This removes the special-casing and just puts all I/O ports into a single 128KB virtually mapped I/O port range starting at port zero. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-06ARM: iop13xx: move io.h externs to pci.hRob Herring
These variables are just needed in pci.c and io.c, so move them out of io.h in preparation to remove io.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk>
2012-03-06ARM: iop13xx: use runtime ioremap hookRob Herring
Convert iop13xx platforms to use run-time ioremap hook instead of the compile time hook. The custom ioremap is still needed for 64-bit address handling. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk>
2010-02-15ARM: Add caller information to ioremapRussell King
This allows the procfs vmallocinfo file to show who created the ioremap regions. Note: __builtin_return_address(0) doesn't do what's expected if its used in an inline function, so we leave __arm_ioremap callers in such places alone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05[ARM] mm 10: allow memory type to be specified with ioremapRussell King
__ioremap() took a set of page table flags (specifically the cacheable and bufferable bits) to control the mapping type. However, with the advent of ARMv6, this is far too limited. Replace the page table flags with a memory type index, so that the desired attributes can be selected from the mem_type table. Finally, to prevent silent miscompilation due to the differing arguments, rename the __ioremap() and __ioremap_pfn() functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4077/1: iop13xx: fix __io() macroDan Williams
Since iop13xx defines the PCI I/O spaces with physical resource addresses the __io macro needs to perform the physical to virtual conversion. I incorrectly assumed that this would be handled by ioremap, but drivers (like e1000) directly dereference the address returned from __io. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3995/1: iop13xx: add iop13xx supportDan Williams
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz PCI-X interface, a x8 PCI-Express interface, and other peripherals to form a system-on-a-chip RAID subsystem engine. The iop342 processor replaces the SAS controller with a second Xscale core for dual core embedded applications. The iop341 processor is the single core version of iop342. This patch supports the two Intel customer reference platforms iq81340mc for external storage and iq81340sc for direct attach (HBA) development. The developer's manual is available here: ftp://download.intel.com/design/iio/docs/31503701.pdf Changelog: * removed virtual addresses from resource definitions * cleaned up some unnecessary #include's Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
