path: root/arch/arm/mach-ixp2000
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: ixp2000: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2010-10-27ARM: 6460/1: ixp2000: fix type of ixp2000_timer_interruptUwe Kleine-König
This fixes a build warning existing since at least 2.6.30: arch/arm/mach-ixp2000/core.c:217: warning: initialization from incompatible pointer type Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-07-27ARM: 6269/1: Add 'code' parameter for hook_fault_code()Kirill A. Shutemov
Add one more parameter to hook_fault_code() to be able to set 'code' field of struct fsr_info. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-13ARM: fix clps711x, footbridge, integrator, ixp2000, ixp2300 and s3c build bugRussell King
Anders Grafström reports that footbridge fails to build after 1c4a4f4. Fix this by adding the necessary definitions for __pfn_to_bus and __bus_to_pfn. Reported-by: Anders Grafström <anders.grafstrom@netinsight.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-16genirq: fix name space collisions of nr_irqs in arch/*Thomas Gleixner
local shadows of global variables are _bad_ Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09Merge branch 'ptebits' into develRussell King
Conflicts: arch/arm/Kconfig
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] Remove MT_DEVICE_IXP2000 and associated definitionsRussell King
As of the previous commit, MT_DEVICE_IXP2000 encodes to the same PTE bit encoding as MT_DEVICE, so it's now redundant. Convert MT_DEVICE_IXP2000 to use MT_DEVICE instead, and remove its aliases. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] Fix timer damage from d3d74453c34f8fd87674a8cf5b8a327c68f22e99Russell King
Move the xtime write mode seqlock into timer_tick(), so it only surrounds the call to do_timer(). This avoids a deadlock in update_process_times() ... hrtimer_get_softirq_time() which tries to get a read mode seqlock on xtime, thereby preventing booting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-30Kbuild/doc: fix links to Documentation filesDirk Hohndel
Fix links to files in Documentation/* in various Kconfig files Signed-off-by: Dirk Hohndel <hohndel@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-30[ARM] Fix some section mismatch warningsRussell King
The following patch fixes these section mismatch warnings: WARNING: arch/arm/mach-at91/built-in.o(.text+0xdf4): Section mismatch: reference to .init.data:dk_nand_partition (between 'nand_partitions' and 'at91_leds_event') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (between 'nand_partitions' and 'ads7843_pendown_state') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-at91/built-in.o(.text+0xc28): Section mismatch: reference to .init.data:kb9202_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-footbridge/built-in.o(.text+0xaa4): Section mismatch: reference to .init.data:cats_pci (between 'cats_pci_init' and 'ebsa285_leds_event')WARNING: arch/arm/mach-ixp2000/built-in.o(.text+0xb54): Section mismatch: reference to .init.text:ixp2000_init_irq (between 'ixdp2x00_init_irq' and 'ixdp2x00_irq_handler') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x670): Section mismatch: reference to .init.text:ixp23xx_pci_common_init (between 'ixp23xx_pci_slave_init' and 'ixp23xx_pci_scan_bus') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x890): Section mismatch: reference to .init.text:ixp23xx_init_irq (between 'ixdp2351_init_irq' and 'roadrunner_pci_preinit') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x9a8): Section mismatch: reference to .init.text:ixp23xx_pci_preinit (after 'roadrunner_pci_preinit') WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x80): Section mismatch: reference to .init.text:imx_set_mmc_info (between '__ksymtab_imx_set_mmc_info' and '__ksymtab_set_imx_fb_info') WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x88): Section mismatch: reference to .init.text:set_imx_fb_info (after '__ksymtab_set_imx_fb_info') WARNING: arch/arm/mach-sa1100/built-in.o(.text+0x1930): Section mismatch: reference to .init.data:neponset_port_fns (between 'neponset_probe' and 'assabet_leds_event') WARNING: drivers/built-in.o(.text+0x3f100): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x3f1c8): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x4f988): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x4fa50): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-05[ARM] mm 9: add additional device memory typesRussell King
Add cached device type for ioremap_cached(). Group all device memory types together, and ensure that they all have a "MT_DEVICE" prefix. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-01[ARM] 3965/1: ixp2000: fix handling of pci master abortsLennert Buytenhek
The master abort check in ixp2000_pci_read_config() recently started failing due to the compiler optimising out the read access following the clearing of pci_master_aborts. Mark pci_master_aborts volatile to force the compiler to reload it on every use. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-24[ARM] Fix breakage in 7281c248f797723f66244b7ecef204620f664648Russell King
A couple of missing semicolons. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-17[ARM] switch to new pci_get_bus_and_slot APIAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[ARM] 3681/1: ARM: Convert ixp2000 to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-24[ARM] 3644/1: ixp2000: export gpio_line_config()Lennert Buytenhek
Patch from Lennert Buytenhek Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3616/1: fix timer handler wrap logic for a number of platformsLennert Buytenhek
Patch from Lennert Buytenhek A couple of platforms aren't using the right comparison type in their timer interrupt handlers (as we're comparing two wrapping timestamps, we need a bmi/bpl-type comparison, not an unsigned comparison) -- this patch fixes them up. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-25[ARM] 3383/3: ixp2000: ixdp2x01 platform serial conversionLennert Buytenhek
Patch from Lennert Buytenhek Add a PLAT8250_DEV_PLATFORM2, and convert the two ixdp2x01 CPLD serial ports to use platform serial devices with ids PLAT8250_DEV_PLATFORM[12]. (The on-chip xscale UART is PLAT8250_DEV_PLATFORM, id #0.) Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-22[ARM] 3378/1: ixp2000: fix gpio interrupt handlingLennert Buytenhek
Patch from Lennert Buytenhek ixp2000 used to initially mark GPIO interrupts as invalid, and not mark them valid until set_irq_type() was called, but this doesn't work if you want to use request_irq() with the SA_TRIGGER_* flags. So, just mark the GPIO interrupts valid from the beginning. We configure GPIOs as inputs when set_irq_type() is called anyway, so this shouldn't be a problem. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3373/1: move uengine loader to arch/arm/commonLennert Buytenhek
Patch from Lennert Buytenhek Move the uengine loader from arch/arm/mach-ixp2000 to arch/arm/common so that ixp23xx can use it too. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3334/1: Add support for IXDP28x5 platformsDeepak Saxena
Patch from Deepak Saxena This patch adds support for Intel's IXDP28x5 platform. This is just and IXDP2801 with a new CPU rev but the bootloader has been updated to reflect a new machine ID so we just build support for it by default when we build IXDP2801. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3302/1: make pci=firmware the default for ixp2000Lennert Buytenhek
Patch from Lennert Buytenhek Most ixp2000 boards don't actually work if pci=firmware isn't used, so the defconfig isn't really the right place to specify this. Instead of specifying it in the defconfigs, make the relevant board code take care of setting pci=firmware. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3300/1: make ixdp2x01 co-exist with other ixp2000 machine typesLennert Buytenhek
Patch from Lennert Buytenhek The ixdp2x01 pci init call doesn't check whether it's really running on an ixdp2x01, making it impossible to compile one kernel that works on both the ixdp2x01 and another ixp2000 board. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3257/1: ixp2000: map in scratch and sramLennert Buytenhek
Patch from Lennert Buytenhek For the ixp2000 netdev driver, we need to map in a chunk of SRAM (to store the transmit and receive descriptors) and the scratch get/put area (so that we can use the scratchpad rings in the cpu for managing the descriptors.) These are the final two mappings needed for the netdev driver and the last missing piece for the driver in mainline to work. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[ARM] 3121/1: unconditionally use XCB=101 on ixp2000Lennert Buytenhek
Patch from Lennert Buytenhek Since we have to use XCB=101 instead of XCB=000 on the ixp2400 to prevent it from regularly falling over, and since we have to deal with manual write buffer flushing because of that, we might as well use XCB=101 on all ixp2000 platforms since it's faster than XCB=000. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-06[ARM] 3114/1: use ixp2000_reg_wrb in ixp2000 uengine loaderLennert Buytenhek
Patch from Lennert Buytenhek Make the uengine loader use ixp2000_reg_wrb in the right places. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-04[ARM] 3086/1: ixp2xxx error irq handlingDave Jiang
Patch from Dave Jiang This provides support for IXP2xxx error interrupt handling. Previously there was a patch to remove this (although the original stuff was broken). Well, now the error bits are needed again. These are used extensively by the micro-engine drivers according to Deepak and also we will need it for the new EDAC code that Alan Cox is trying to push into the main kernel. Re-submit of 3072/1, generated against git tree pulled today. AFAICT, this git tree pulled in all the ARM changes that's in arm.diff. Please let me know if there are additional changes. Thx! Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
