path: root/arch/arm/mach-ixp4xx/fsg-setup.c
2011-07-18ARM: mach-ixp4xx: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_sizeNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2009-12-05IXP4xx: move FSG platform macros to the platform code.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-19[ARM] 5208/1: fsg-setup.c fixesTomasz Chmielewski
This patch against 2.6.27-rc3 does the following changes to FSG-3 setup code: 1) Enable RTC on FSG-3 (proper name is needed). This change is needed due to a recent change in i2c. 2) i variable is only used when compiling for big endian. So move its declaration to ARMEB ifdef to silence the warning when compiling for LE. Mailing list link: http://lists.arm.linux.org.uk/lurker/message/20080813.091556.cae2917e.en.html Signed-off-by: Tomasz Chmielewski <mangoo@wpkg.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4874/2: ixp4xx: Add support for the Freecom FSG-3 boardRod Whitby
The Freecom-FSG3 is a small network-attached-storage device with the following feature set: * Intel IXP422 * 4MB Flash (ixp4xx flash driver) * 64MB RAM * 4 USB 2.0 host ports (ehci and ohci drivers) * 1 WAN (eth1) and 3 LAN (eth0) ethernet ports * Supported by the open source ixp4xx ethernet driver * Via VT6421 disk controller (libata and sata-via drivers) * Internal hard disk (PATA supported, SATA not yet supported) * External SATA port (not yet supported) * ISL1208 RTC chip * Winbond 83782 temp sensor and fan controller * MiniPCI slot The ixp4xx_defconfig is also updated to support this device (the leds-fsg driver is to be submitted separately via the leds tree after this initial support is merged, as it depends on header gpio defines). Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
