path: root/arch/arm/mach-ixp4xx/gtwx5715-setup.c
2011-07-18ARM: mach-ixp4xx: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_sizeNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-05IXP4xx: move Gemtek GTWX5715 platform macros to the platform code.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-06[ARM] 3747/1: Fix compilation error in mach-ixp4xx/gtwx5715-setup.cMartin Michlmayr
Patch from Martin Michlmayr Fix the following compilation error in arm/mach-ixp4xx/gtwx5715-setup: CC arch/arm/mach-ixp4xx/gtwx5715-setup.o arch/arm/mach-ixp4xx/gtwx5715-setup.c:110: error: expected identifier or '(' before ‘=’ token arch/arm/mach-ixp4xx/gtwx5715-setup.c:121: error: 'gtwx5715_flash_resource' undeclared here (not in a function) arch/arm/mach-ixp4xx/gtwx5715-setup.c: In function 'gtwx5715_init': arch/arm/mach-ixp4xx/gtwx5715-setup.c:133: error: 'flash_resource' undeclared (first use in this function) arch/arm/mach-ixp4xx/gtwx5715-setup.c:133: error: (Each undeclared identifier is reported only once arch/arm/mach-ixp4xx/gtwx5715-setup.c:133: error: for each function it appears in.) make[1]: *** [arch/arm/mach-ixp4xx/gtwx5715-setup.o] Error 1 Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3226/1: IXP4xx runtime expansion bus window size configurationDeepak Saxena
Patch from Deepak Saxena The expansion bus on the IXP46x NPU can be configured for either 32MiB or 16MiB windows and changing the configuration causes the base address for each chip select for each region to change. Because of this, we cannot hardcode the physical base as we currently do. This patch checks the expansion bus configuration registers at runtime to determine the appropriate window size. Note that this requires that the bootloader already configured the device sizes appropriately, but I feel that is valid assumption to make as the bootloader must configure and access the flash window, the output display (LCD, LEDs, etc) window, and other expansion bus devices. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-29[ARM] 2834/1: Remove IXP4xx board-specific map_io routinesDeepak Saxena
Patch from Deepak Saxena None of the board-specific map_io routines do anything, so kill them. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-26[PATCH] arm: fix IXP4xx flash resource rangeDeepak Saxena
We are currently reserving one byte more than actually needed by the flash device and overlapping into the next I/O expansion bus window. This a) causes us to allocate an extra page of VM due to ARM ioremap() alignment code and b) could cause problems if another driver tries to request the next expansion bus window. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-03[PATCH] ARM: 2835/1: Add UPF_SKIP_TEST to IXP4xx serial portsDeepak Saxena
Patch from Deepak Saxena This allows the serial driver autconf to work properly on all the IXP serial ports. W/o it we basically put the serial port in an unrecoverable state and lose console. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
