path: root/arch/arm/mach-ixp4xx
2009-05-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits) bonding: fix panic if initialization fails IXP4xx: complete Ethernet netdev setup before calling register_netdev(). IXP4xx: use "ENODEV" instead of "ENOSYS" in module initialization. ipvs: Fix IPv4 FWMARK virtual services ipv4: Make INET_LRO a bool instead of tristate. net: remove stale reference to fastroute from Kconfig help text net: update skb_recycle_check() for hardware timestamping changes bnx2: Fix panic in bnx2_poll_work(). net-sched: fix bfifo default limit igb: resolve panic on shutdown when SR-IOV is enabled wimax: oops: wimax_dev_add() is the only one that can initialize the state wimax: fix oops if netlink fails to add attribute Bluetooth: Move dev_set_name() to a context that can sleep netfilter: ctnetlink: fix wrong message type in user updates netfilter: xt_cluster: fix use of cluster match with 32 nodes netfilter: ip6t_ipv6header: fix match on packets ending with NEXTHDR_NONE netfilter: add missing linux/types.h include to xt_LED.h mac80211: pid, fix memory corruption mac80211: minstrel, fix memory corruption cfg80211: fix comment on regulatory hint processing ...
2009-05-09IXP4xx: use "ENODEV" instead of "ENOSYS" in module initialization.Krzysztof Hałasa
ENOSYS makes modutils complain about missing kernel module support. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-17IXP4xx: PCI ixp4xx_scan_bus() is __devinit.Krzysztof Hałasa
2009-03-17IXP4xx: cpu_is_ixp4*() now recognizes all IXP4xx processors.Krzysztof Hałasa
2009-03-17IXP4xx: add Ethernet and NPE support for IXP43x CPU.Krzysztof Hałasa
2009-03-17IXP4xx: workaround for PCI prefetch problems near 64 MB boundary.Krzysztof Hałasa
Map unused registers at the end of DMA region at 64 MB to allow PCI masters to cross the boundary when prefetching data from SDRAM. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-22IXP4xx: move common debugging from network drivers to QMGR module.Krzysztof Hałasa
2008-12-22IXP4xx: clear IRQ stat in qmgr_disable_irq().Krzysztof Hałasa
2008-12-22IXP4xx: check for queue being empty in qmgr_release_queue().Krzysztof Hałasa
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-11-30[ARM] Add a common typesafe __io implementationRussell King
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b, add a typesafe __io implementation for platforms to use. Convert platforms to use this new simple typesafe implementation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] move MAX_DMA_ADDRESS to mach/memory.hRussell King
Move the definition of MAX_DMA_ADDRESS from mach/dma.h to mach/memory.h, thereby placing it along side its relative, ISA_DMA_THRESHOLD. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] ixp4xx: clean up includesRussell King
mach/io.h doesn't need linux/mm.h. mach/dma.h doesn't need linux/device.h, asm/page.h or mach/hardware.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-31Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/p54/p54common.c
2008-10-30[ARM] gpio_free might sleep, arm architectureUwe Kleine-König
According to the documentation gpio_free should only be called from task context only. To make this more explicit add a might sleep to all implementations. This patch changes the gpio_free implementations for the arm architecture. DaVinci is skipped on purpose to simplify the merge process for patches switching it over to use gpiolib as per request by David Brownell. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Cc: David Brownell <david-b@pacbell.net> Cc: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-17[ARM] dmabounce requires ZONE_DMARussell King
Rather than having everything that needs DMABOUNCE also select ZONE_DMA, arrange for DMABOUNCE to select it instead. This is far more sensible. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/delay.h to linux/delay.hRussell King
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-09-01[ARM] cputype: separate definitions, use themRussell King
Add asm/cputype.h, moving functions and definitions from asm/system.h there. Convert all users of 'processor_id' to the more efficient read_cpuid_id() function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-19[ARM] 5208/1: fsg-setup.c fixesTomasz Chmielewski
This patch against 2.6.27-rc3 does the following changes to FSG-3 setup code: 1) Enable RTC on FSG-3 (proper name is needed). This change is needed due to a recent change in i2c. 2) i variable is only used when compiling for big endian. So move its declaration to ARMEB ifdef to silence the warning when compiling for LE. Mailing list link: http://lists.arm.linux.org.uk/lurker/message/20080813.091556.cae2917e.en.html Signed-off-by: Tomasz Chmielewski <mangoo@wpkg.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-14[ARM] Merge most of the PXA work for initial mergeRussell King
This includes PXA work up to the SPI changes for the initial merge, since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI tree being merged. Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-10Merge branches 'at91', 'dyntick', 'ep93xx', 'iop', 'ixp', 'misc', 'orion', ↵Russell King
'omap-reviewed', 'rpc', 'rtc' and 's3c' into devel
2008-07-09[ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC ↵Philipp Zabel
drivers The pxa2xx_udc.c driver is renamed to pxa25x_udc.c (the platform driver name changes from pxa2xx-udc to pxa25x-udc) and the platform driver name of pxa27x_udc.c is fixed to pxa27x-udc. pxa_device_udc in devices.c is split into pxa25x and pxa27x flavors and the pxa27x_device_udc is enabled in pxa27x.c. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Including from Ian Molton: Fixes for mistakes left over from the PXA2{5,7}X UDC split. Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) tcp: Overflow bug in Vegas [IPv4] UFO: prevent generation of chained skb destined to UFO device iwlwifi: move the selects to the tristate drivers ipv4: annotate a few functions __init in ipconfig.c atm: ambassador: vcc_sf semaphore to mutex MAINTAINERS: The socketcan-core list is subscribers-only. netfilter: nf_conntrack: padding breaks conntrack hash on ARM ipv4: Update MTU to all related cache entries in ip_rt_frag_needed() sch_sfq: use del_timer_sync() in sfq_destroy() net: Add compat support for getsockopt (MCAST_MSFILTER) net: Several cleanups for the setsockopt compat support. ipvs: fix oops in backup for fwmark conn templates bridge: kernel panic when unloading bridge module bridge: fix error handling in br_add_if() netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval tcp: Limit cwnd growth when deferring for GSO tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled [netdrvr] gianfar: Determine TBIPA value dynamically ...
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-29Driver for IXP4xx built-in Ethernet portsKrzysztof Halasa
Adds a driver for built-in IXP4xx Ethernet ports. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-04[ARM] 4874/2: ixp4xx: Add support for the Freecom FSG-3 boardRod Whitby
The Freecom-FSG3 is a small network-attached-storage device with the following feature set: * Intel IXP422 * 4MB Flash (ixp4xx flash driver) * 64MB RAM * 4 USB 2.0 host ports (ehci and ohci drivers) * 1 WAN (eth1) and 3 LAN (eth0) ethernet ports * Supported by the open source ixp4xx ethernet driver * Via VT6421 disk controller (libata and sata-via drivers) * Internal hard disk (PATA supported, SATA not yet supported) * External SATA port (not yet supported) * ISL1208 RTC chip * Winbond 83782 temp sensor and fan controller * MiniPCI slot The ixp4xx_defconfig is also updated to support this device (the leds-fsg driver is to be submitted separately via the leds tree after this initial support is merged, as it depends on header gpio defines). Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-07leds: Standardise LED naming schemeRichard Purdie
As discussed on LKML some notion of 'function' is needed in LED naming. This patch adds this to the documentation and standardises existing LED drivers. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-04[ARM] 4809/2: ixp4xx: Merge dsmg600-power.c into dsmg600-setup.cRod Whitby
There is no reason to have power control in a separate file from the board setup code. Merge it back into the board setup file and remove superfluous header includes. -- Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4808/2: ixp4xx: Merge nas100d-power.c into nas100d-setup.cRod Whitby
2008-02-04[ARM] 4807/2: ixp4xx: Merge nslu2-power.c into nslu2-setup.cRod Whitby
There is no reason to have power control in a separate file from the board setup code. Merge it back into the board setup file, removing superfluous header includes and removing superfluous constants from the machine header file. -- Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4806/1: ixp4xx: Ethernet support for the nslu2 and nas100d boardsRod Whitby
Enables the new ixp4xx qmgr and npe drivers in ixp4xx_defconfig. Sets up the corresponding platform data for the nslu2 and nas100d boards, and reads the ethernet MAC address from the internal flash. Tested on both little-endian and big-endian kernels. Tested-by: Tom King <tom@websb.net> Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Michael Westerhof <mwester@dls.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4805/1: ixp4xx: Use leds-gpio driver instead of IXP4XX-GPIO-LED driverRod Whitby
These are the only three boards to use the IXP4XX-GPIO-LED driver, and they can all use the new leds-gpio driver instead with no change in functionality. -- Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4715/2: Ethernet support for IXDP425 boardsRod Whitby
Adds IXDP425 platform support for two built-in 10/100 Ethernet ports. This patch will do nothing until the actual Ethernet driver is also included. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4713/3: Adds drivers for IXP4xx QMgr and NPE featuresKrzysztof Halasa
This patch adds drivers for IXP4xx hardware Queue Manager and for Network Processor Engines. Requires patch #4712 (reading/writing CPU feature (aka fuse) bits). Posted to linux-arm-kernel on 2 Dec 2007 and revised. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4774/2: ixp4xx: Register dsmg600 rtc i2c_board_infoRod Whitby
Register the i2c board info related to the RTC chip on the dsmg600 board to allow it to be found automatically on boot. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4773/2: ixp4xx: Register nas100d rtc i2c_board_infoRod Whitby
Register the i2c board info related to the RTC chip on the nas100d board to allow it to be found automatically on boot. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4772/2: ixp4xx: Register nslu2 rtc i2c_board_infoRod Whitby
Register the i2c board info related to the RTC chip on the nslu2 board to allow it to be found automatically on boot. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4769/2: ixp4xx: Button updates for the dsmg600 boardRod Whitby
* Remove the superfluous declaration of ctrl_alt_del(). * Convert GPIO and IRQ handling to use the <asm/gpio.h> api. * Perform the reset on the release of the power button, so that NAS devices which have been set to auto-power-on (by solder bridging the power button) do not continuously power cycle. * Remove all superflous constants from dsmg600.h Signed-off-by: Rod Whitby <rod@whitby.id.au> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
