path: root/arch/arm/mach-ixp4xx
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12dma-mapping: arm: use generic pci_set_dma_mask and pci_set_consistent_dma_maskFUJITA Tomonori
This converts arm to the generic pci_set_dma_mask and pci_set_consistent_dma_mask (removes HAVE_ARCH_PCI_SET_DMA_MASK for dmabounce). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Looked-over-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-25Merge branch 'tmpreg' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ux500/include/mach/debug-macro.S
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-27ARM: 5869/1: ixp4xx: implement sched_clock()Mikael Pettersson
Add a better sched_clock() to the ixp4xx platform, implemented via its clocksource support. This is based on the sched_clock() I implemented for the IOP platform. Tested on a ds101 ixp420 machine. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-05IXP4xx: GTWX5715 platform only has two PCI IRQ lines, not four.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: Introduce IXP4XX_GPIO_IRQ(n) macro and convert IXP4xx platform files.Krzysztof Hałasa
2009-12-05IXP4xx: move Gemtek GTWX5715 platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: Remove unused Motorola PrPMC1100 platform macros.Krzysztof Hałasa
PrPMC1100 is handled by IXDP425 platform code, there is no need for duplicate set of macros. Remove them. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: move FSG platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: move DSM G600 platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: move NAS100D platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: move NSLU2 platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: move Coyote platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: move AVILA platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: move IXDP425 platform macros to the platform code.Krzysztof Hałasa
2009-12-05IXP4xx: Extend PCI MMIO indirect address space to 1 GB.Krzysztof Hałasa
IXP4xx CPUs can indirectly access the whole 4 GB PCI MMIO address space (using the non-prefetch registers). Previously the available space depended on the CPU variant, since one of the IXP43x platforms needed more than the usual 128 MB. 1 GB should be enough for everyone, and if not, we can trivially increase it. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: Fix compilation failure with CONFIG_IXP4XX_INDIRECT_PCI.Krzysztof Hałasa
Instead of including the heavy linux/mm.h for VMALLOC_START, test the addresses against PCI MIN and MAX addresses. Indirect PCI uses 1:1 mapping for MMIO space making this change possible. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: Drop "__ixp4xx_" prefix from in/out/ioread/iowrite functions for ↵Krzysztof Hałasa
clarity. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: Rename indirect MMIO primitives from __ixp4xx_* to __indirect_*.Krzysztof Hałasa
2009-12-05IXP4xx: Ensure index is positive in irq_to_gpio() and npe_request().Roel Kluin
The indexes were signed, so negatives were possible. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05ARM: fix insl() and outsl() endianness on IXP4xx architecture.Krzysztof Hałasa
The repetitive in/out functions must preserve order, not value. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: change the timer base frequency to 66.666000 MHz.Krzysztof Hałasa
Clock generators used by IXP4xx processors are usually 33.333 MHz, sometimes 33.33 MHz and few platforms use 33 MHz. The timers tick twice as fast, that means 66.666, 66.66 or 66 MHz. Current 66.666666 MHz means 10 ppm offset from the usual 66.666 MHz. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-09-21ixp4xx: arch_idle() documentation fixupMikael Pettersson
The body of the mach-ixp4xx arch_idle() is mysteriously disabled by an #if 0 .. #endif. Normally one would expect to find a call to cpu_do_idle() there, but that call is disabled, even though cpu_do_idle() is implemented for XScale cores (and ixp4xx is one). The explanation can be found in the ixp42x developer's manual which states that the XScale core clock and power management registers aren't implemented on ixp42x [3.5.2.2]. Also, the disabled code has suffered from bit rot: - it checks hlt_counter which is obsolete, as that variable and all related code now is private to kernel/process.c - it passes too many parameters to cpu_do_idle() So this patch: - adds a comment before the #if 0 to explain why cpu_do_idle() mustn't be called on ixp4xx - removes the obsolete test of hlt_counter and the obsolete parameter to cpu_do_idle() This is purely a documentation fixup and changes no generated code. Even so, it has been tested on an ixp420 machine (ds101). Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-09-21ixp4xx: timer and clocks cleanupsMikael Pettersson
This patch does a few simple cleanups of the ixp4xx timer and clocksource/clockevent code in mach-ixp4xx/common.c: - ixp4xx_clocksource_init() is static and always returns 0, which is ignored by its only caller: make it return void - ixp4xx_clockevent_init(): ditto - ixp4xx_get_cycles() is only referenced locally: make it static - use the ixp4xx_timer_irq.dev_id field to pass &clockevent_ixp4xx to ixp4xx_timer_interrupt() via its dev_id parameter, allowing the code in ixp4xx_timer_interrupt() to be smaller and faster Tested on an ixp420 machine (ds101). Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-07IXP42x HSS support for setting internal clock rateKrzysztof Halasa
HSS usually uses external clocks, so it's not a big deal. Internal clock is used for direct DTE-DTE connections and when the DCE doesn't provide it's own clock. This also depends on the oscillator frequency. Intel seems to have calculated the clock register settings for 33.33 MHz (66.66 MHz timer base). Their settings seem quite suboptimal both in terms of average frequency (60 ppm is unacceptable for G.703 applications, their primary intended usage(?)) and jitter. Many (most?) platforms use a 33.333 MHz oscillator, a 10 ppm difference from Intel's base. Instead of creating static tables, I've created a procedure to program the HSS clock register. The register consists of 3 parts (A, B, C). The average frequency (= bit rate) is: 66.66x MHz / (A + (B + 1) / (C + 1)) The procedure aims at the closest average frequency, possibly at the cost of increased jitter. Nobody would be able to directly drive an unbufferred transmitter with a HSS anyway, and the frequency error is what it really counts. I've verified the above with an oscilloscope on IXP425. It seems IXP46x and possibly IXP43x use a bit different clock generation algorithm - it looks like the avg frequency is: (on IXP465) 66.66x MHz / (A + B / (C + 1)). Also they use much greater precomputed A and B - on IXP425 it would simply result in more jitter, but I don't know how does it work on IXP46x (perhaps 3 least significant bits aren't used?). Anyway it looks that they were aiming for exactly +60 ppm or -60 ppm, while <1 ppm is typically possible (with a synchronized clock, of course). The attached patch makes it possible to set almost any bit rate (my IXP425 533 MHz quits at > 22 Mb/s if a single port is used, and the minimum is ca. 65 Kb/s). This is independent of MVIP (multi-E1/T1 on one HSS) mode. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-11IXP4xx: Fix IO_SPACE_LIMIT for 2.6.31-rc core PCI changesMikael Pettersson
2.6.31-rc kernels don't boot on my ixp4xx box (ds101), because the libata driver doesn't find the PCI IDE controller any more. 2.6.30 was fine. I traced this to a PCI update (1f82de10d6b1d845155363c895c552e61b36b51a) in 2.6.30-git19. Diffing the kernel boot logs from 2.6.30-git18 and 2.6.30-git19 illustrates the breakage: > --- dmesg-2.6.30-git18 2009-08-04 01:45:22.000000000 +0200 > +++ dmesg-2.6.30-git19 2009-08-04 01:45:46.000000000 +0200 > @@ -26,6 +26,13 @@ > pci 0000:00:02.2: PME# supported from D0 D1 D2 D3hot > pci 0000:00:02.2: PME# disabled > PCI: bus0: Fast back to back transfers disabled > +pci 0000:00:01.0: BAR 0: can't allocate I/O resource [0x10000-0xffff] > +pci 0000:00:01.0: BAR 1: can't allocate I/O resource [0x10000-0xffff] > +pci 0000:00:01.0: BAR 2: can't allocate I/O resource [0x10000-0xffff] > +pci 0000:00:01.0: BAR 3: can't allocate I/O resource [0x10000-0xffff] > +pci 0000:00:01.0: BAR 4: can't allocate I/O resource [0x10000-0xffff] > +pci 0000:00:02.0: BAR 4: can't allocate I/O resource [0x10000-0xffff] > +pci 0000:00:02.1: BAR 4: can't allocate I/O resource [0x10000-0xffff] > bio: create slab <bio-0> at 0 > SCSI subsystem initialized > NET: Registered protocol family 2 > @@ -44,11 +51,7 @@ > console [ttyS0] enabled > serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale > Driver 'sd' needs updating - please use bus_type methods > -PCI: enabling device 0000:00:01.0 (0140 -> 0141) > -scsi0 : pata_artop > -scsi1 : pata_artop > -ata1: PATA max UDMA/100 cmd 0x1050 ctl 0x1060 bmdma 0x1040 irq 28 > -ata2: PATA max UDMA/100 cmd 0x1058 ctl 0x1064 bmdma 0x1048 irq 28 > +pata_artop 0000:00:01.0: no available native port > Using configured DiskOnChip probe address 0x50000000 > DiskOnChip found at 0x50000000 > NAND device: Manufacturer ID: 0x98, Chip ID: 0x73 (Toshiba NAND 16MiB 3,3V 8-bit) The specific change in 1f82de10d6b1d845155363c895c552e61b36b51a responsible for this failure turned out to be the following: > --- a/drivers/pci/probe.c > +++ b/drivers/pci/probe.c > @@ -193,7 +193,7 @@ int __pci_read_base(struct pci_dev *dev, enum pci_bar_type type, > res->flags |= pci_calc_resource_flags(l) | IORESOURCE_SIZEALIGN; > if (type == pci_bar_io) { > l &= PCI_BASE_ADDRESS_IO_MASK; > - mask = PCI_BASE_ADDRESS_IO_MASK & 0xffff; > + mask = PCI_BASE_ADDRESS_IO_MASK & IO_SPACE_LIMIT; > } else { > l &= PCI_BASE_ADDRESS_MEM_MASK; > mask = (u32)PCI_BASE_ADDRESS_MEM_MASK; Every arch except arm's ixp4xx defines IO_SPACE_LIMIT as an all-bits-one bitmask, typically -1UL but sometimes only a 16-bit 0x0000ffff. But ixp4xx defines it as 0xffff0000, which is now causing the PCI failures. Russell King noted that ixp4xx has 64KB PCI IO space, so IO_SPACE_LIMIT should be 0x0000ffff. This patch makes that change, which fixes the PCI failures on my ixp4xx box. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-05-25IXP4xx: Change QMgr function names to qmgr_stat_*_watermark and clean the ↵Krzysztof Hałasa
comments. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-05-23IXP4xx: support for Goramo MultiLink router platform.Krzysztof Hałasa
2009-05-23IXP42x: Use __fls() in QMgr interrupt handlers.Krzysztof Hałasa
2009-05-23IXP42x: Add QMgr support for IXP425 rev. A0 processors.Krzysztof Hałasa
2009-05-23IXP42x: add NPE support for IXP425 rev. A0 processors.Krzysztof Hałasa
2009-05-23IXP42x: Identify Intel IXP425 rev. A0 processors.Krzysztof Hałasa
2009-05-20IXP4xx: Add support for the second half of the 64 hardware queues.Krzysztof Hałasa
2009-05-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits) bonding: fix panic if initialization fails IXP4xx: complete Ethernet netdev setup before calling register_netdev(). IXP4xx: use "ENODEV" instead of "ENOSYS" in module initialization. ipvs: Fix IPv4 FWMARK virtual services ipv4: Make INET_LRO a bool instead of tristate. net: remove stale reference to fastroute from Kconfig help text net: update skb_recycle_check() for hardware timestamping changes bnx2: Fix panic in bnx2_poll_work(). net-sched: fix bfifo default limit igb: resolve panic on shutdown when SR-IOV is enabled wimax: oops: wimax_dev_add() is the only one that can initialize the state wimax: fix oops if netlink fails to add attribute Bluetooth: Move dev_set_name() to a context that can sleep netfilter: ctnetlink: fix wrong message type in user updates netfilter: xt_cluster: fix use of cluster match with 32 nodes netfilter: ip6t_ipv6header: fix match on packets ending with NEXTHDR_NONE netfilter: add missing linux/types.h include to xt_LED.h mac80211: pid, fix memory corruption mac80211: minstrel, fix memory corruption cfg80211: fix comment on regulatory hint processing ...
2009-05-09IXP4xx: use "ENODEV" instead of "ENOSYS" in module initialization.Krzysztof Hałasa
ENOSYS makes modutils complain about missing kernel module support. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-17IXP4xx: PCI ixp4xx_scan_bus() is __devinit.Krzysztof Hałasa
2009-03-17IXP4xx: cpu_is_ixp4*() now recognizes all IXP4xx processors.Krzysztof Hałasa
2009-03-17IXP4xx: add Ethernet and NPE support for IXP43x CPU.Krzysztof Hałasa
2009-03-17IXP4xx: workaround for PCI prefetch problems near 64 MB boundary.Krzysztof Hałasa
Map unused registers at the end of DMA region at 64 MB to allow PCI masters to cross the boundary when prefetching data from SDRAM. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-22IXP4xx: move common debugging from network drivers to QMGR module.Krzysztof Hałasa
2008-12-22IXP4xx: clear IRQ stat in qmgr_disable_irq().Krzysztof Hałasa
2008-12-22IXP4xx: check for queue being empty in qmgr_release_queue().Krzysztof Hałasa
