These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Keystone PM bus makes use of generic PM clock core backend. Since
generic PM clock core uses platform bus notifiers to track events like
ADD_DEVICE/DEL_DEVICE and to fill clock lists per each device, we need
to initialise Keystone PM domains before the platform devices have been
created.
Hence, fix it by moving keystone_pm_runtime_init() before platform
devices have been populated.
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Because of inline asm usage in platsmp.c, smc instruction
creates build failure for ARM V6+V7 build where as using instruction
encoding for smc breaks the thumb2 build.
So move the code snippet to separate asm file and mark
it with 'armv7-a$(plus_sec)' to avoid any build issues.
Add basic SMP support for Keystone machines. This does not
include support for CPU hotplug for now.
Cc: arm@kernel.org
Acked-by: Olof Johansson <olof@lixom.net>
